Hi there,
I am new to CNC I have only this week finished my build of a custom FLA100 router. I have finally attached gecko 540 etc and I am trying to get my machine to move but having trouble.
I downloaded the correct .xml file from cncrouterparts.com and have watched a bunch of set up tutorials and read heaps of info but still cannot seem to get mach 3 to move my stepper motors. I am sure it is something so minor (i.e.) one little box checked or un-checked. I am having an issue with mach3 saying there is an e-stop issue and will not re-set even if i un check the box in pins/ports or even use emulate function. The emergency switch attached to power supply and gecko appears to be functioning fine as it lights up green and when pressed triggers FAULT response light. Any information would be greatly appreciated to fix this and finally get the machine moving.
cheers amos.
