587,771 active members*
2,948 visitors online*
Results 1 to 5 of 5
    Dec 2014
    2
    Chinese 40 w machine faulty ?
    I have one of thes which ha suddenly dropped in power.
    replacing the tube and realining the mirrors has had no effect.
    i suspect the psu or control circuitry to be faulty.
    are there any known problems with these please ?
    what is my best course of action ?
    Nov 2008
    382
    Re: Chinese 40 w machine faulty ?
    hi there
    like I sayd before to many people you need to tell more what kind you got what motherboard , what software etc, because there so many different machnes out there all called K40 what actually just a group for 40 W laser ( what actually is not 40W just around 30W)
    greetings
    waltfl
    Sep 2012
    212
    Yes, just as herby said, please give us more info about the machine. Also is there any signal light on the psu? That will be helpful to find out the problem.
    G.Weike Laser
    [email protected] [email protected] skype:melody.gweike
    Dec 2014
    2
    Its one of these, late model with the plastic cover on the pcb.
    i have no idea about part nos etc
    50W CO2 LASER ENGRAVING AIR ASSIST U-FLASH DISK ENGRAVER CUTTER MODERATE COST |
    Jan 2008
    940
    in your software when you edit the color if the cut is the min power set low If I set mine at 30% on the minimum power and try to cut at below 5 mm at 85% power it shows that I am only cutting at 30% according to my meter. When I bump the minimum power up to 85% it cuts correctly. I added the meter to keep track of the power. hope this makes sense
  1. Faulty Chinese spindle - or am I being stupid?
    By ukpete in forum Spindles / VFD
    Last Post: 03-19-2016, 10:19 PM
  2. What Chinese machine to buy ?
    By woodslayer in forum Chinese Machines
    Last Post: 08-15-2014, 03:44 AM
  3. help with a new Chinese machine
    By Turner_nz in forum Chinese Machines
    Last Post: 02-23-2014, 07:27 AM
  4. Looking for CNC Chinese machine
    By cup67 in forum Chinese Machines
    Last Post: 05-10-2008, 08:28 PM
  5. Tnc 151 Vdu Faulty?
    By PRIOR666 in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2007, 03:54 PM
