587,302 active members*
3,236 visitors online*
Results 1 to 11 of 11
    Feb 2011
    212
    changing gear lube on IH cnc
    can anyone tell me where the drain plug is Also where the filler is ( I think it is the pipe on the top left on my mill ) also how much fluid to replace after I drain it
    Thanks in advance
    May 2008
    1185
    Re: changing gear lube on IH cnc
    Filler is the vent cap. The drain is a plug on the underside of the head.
    A lighter oil is fine too for less heat.
    youtube videos of the G0704 under the name arizonavideo99
    Feb 2011
    212
    Quote Originally Posted by arizonavideo View Post
    Thanks I will look into it.
    Jun 2013
    41
    As Arizonavideo mentioned, the head is filled through the breather cap and the drain is inside the cavity under the head. The head will take about 3.75 quarts of oil (to center of sight glass). We recommend 30 weight non-detergent oil along with 8 oz. of standard Lucas oil additive. Add the Lucas first to avoid overfilling the head.
    Feb 2011
    212
    Great and the drain bolt is underneath the head it looks like a 1/2-13 bolt ? Or at least on mine that's the only bolt I see
    Jun 2013
    41
    It will definitely be metric. The factory has changed them slightly over the years. Currently they are 12mm x 1 thread with an O-ring and 10mm Allen head.
    Feb 2011
    212
    ok I will look when I get off of work and go from there. Thanks for you help
    Nov 2003
    287
    Take the cover off and dump the gears out along with the oil, Switch to belt drive. You will never regret it.
    Feb 2011
    212
    You have info on a direct replacement ? I would love a quite mill lol with higher rpm
    Quote Originally Posted by vertcnc View Post
    Nov 2003
    287
    well Arizonavideo was making belt drives i think. i have drawings that i used to convert my MD001 which i believe is very similar. You would need a lathe and mill to make the parts. Mine uses a keyway machined in the spindle shaft.
    Its not really a cheap upgrade to get the full potential you would need a 3 phase motor and VFD
    Feb 2011
    212
    Well no have the 3 phase 3 hp motor already on this mill. I will look more into this.
  1. Changing headstock gear ratio?
    By truedblued in forum Mini Lathe
    Last Post: 01-17-2013, 04:28 PM
  2. Replies: 3
    Last Post: 03-04-2012, 10:42 PM
  3. re Spindle Lube and Lube Pump
    By robkuhi in forum Tree
    Last Post: 10-24-2011, 06:49 PM
  4. Changing lube on a ballscrew
    By Guldberg in forum Linear and Rotary Motion
    Last Post: 06-19-2009, 02:55 PM
  5. Info on changing gear needed
    By SteveS in forum Stepper Motors / Drives
    Last Post: 06-12-2009, 04:23 AM
