587,480 active members*
3,467 visitors online*
Results 1 to 14 of 14
    Nov 2014
    6
    Fanuc 0m-a no spindle control
    Hello all, I have a knockoff brand bed mill (Long Chang Machinery RB-1) with a Fanuc 0m-a CNC.
    Up until last week when I finished manually facing off a piece of aluminum, I stopped the spindle like I always do... Then I went to turn it back on (MDI mode -> spindle cw button), and nothing.
    Lights don't change, diagnostics bits pick up the button presses, but they don't do anything.
    Any calls to m3/m4 just hang the program and MDI until you hit reset.
    I'm assuming there's a limit or something that needs to be met, but there aren't any on the spindle (only the typical axis switches).
    I've checked all the relays and wires, but I don't have any schematics for this thing either.
    Anyone have any ideas? I don't need the machine right now, but I'm sure I will soon.
    Edit:
    Oh and its just a basic spindle, not a servo driven unit, so the CNC only controls a reversing contactor.
    Jun 2004
    511
    Re: Fanuc 0m-a no spindle control
    If M03 hangs a condition needed to allow it is not right. Can you get into the ladder?
    Nov 2014
    6
    No, from everything I've read, the ladder is not displayable on this model unless you pull the PROM chips and have the decoding software (I have equipment to read the PROM chips, but no way to decode them).
    I couldn't find any info on the ladders by google search either.
    Jun 2004
    511
    That makes this a hard nut to crack. I would look at the tool clamp switch.
    Nov 2014
    6
    See that's what I don't get... There aren't any other switches than the axis limits and one switch on hi/low gear change (to reverse cw/ccw), but other than that I don't see anything.
    I've been digging through the wires and it also seems that it won't turn on the coolant pump either, of which the relays have power and I can engage them manually... So it seems the CNC output just isn't switching the output.
    Which brings me back to software issues or limits not met.
    Jun 2004
    511
    WIl the people you bought it from have any information?
    Nov 2014
    6
    No unfortunately, they've passed on from what I know... That's why I have the machine (auction).
    Is there a document that explains the inputs/outputs on the controller, along with the diagnostic bits?
    Jun 2004
    511
    inputs/outputs on the controller, along with the diagnostic bits must come from the builder of the machine.
    Jun 2004
    511
    The builder designs all that. The control is a blank slate, untill the bullder loads the software that they have designed for that machine.
    Aug 2007
    793
    what kind of eeproms with ladder on your CNC - 27C64 or 27C256?
    Nov 2014
    6
    64.
    The front panel is labeled "General Numeric GN0".
    Its nearly identical to this one on eBay:
    https://www.google.com/url?sa=t&rct=...80185997,d.eXY
    Aug 2007
    793
    for 27C256 you can use FAPT ladder under DOS for decompiling, but 64 - not
    Nov 2014
    6
    Well, I think I found a solution...
    While fiddling around with M3/M4 in MDI, I found that it only hangs until one of the relays for the spindle pull in, so that got me thinking...
    Then while fiddling with M3/M4 a little more while watching the output bits (#45 & #46 I think) in the diagnostic params, I noticed that there were two different bits that followed M3 and M4.
    So with M3/M4 hanging, I probed the extra output wires and found the two that matched the bits I saw in diagnostics.
    I didn't have enough time today to rewire it today, so it will have to wait until Monday to find out for sure, but here's hoping!
    I get the feeling that M3/M4 will work, but I won't be able to engage the spindle with the CW/CCW buttons.
    The big question is, why did this happen?
    Aug 2007
    793
    at least try to find diagnostics bits that correspond to buttons, maybe there is lack of 24V
  1. Replies: 6
    Last Post: 02-17-2016, 08:12 PM
  2. FANUC 10M Control/ Spindle Trouble
    By Mike T. in forum Fanuc
    Last Post: 11-26-2014, 12:18 AM
  3. Fanuc Powermate D Spindle Control
    By robokd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-25-2014, 02:23 PM
  4. Fanuc OT-C spindle RPM control
    By robertox in forum Fanuc
    Last Post: 04-25-2011, 06:57 PM
  5. Spindle Problems with Fanuc 0T control
    By thardy in forum Fanuc
    Last Post: 01-21-2007, 09:35 PM
