587,832 active members*
3,537 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Hypertherm Plasma > Can you use a T100M machine torch with a Powermax 1250?
Results 1 to 3 of 3
    Aug 2005
    158
    Can you use a T100M machine torch with a Powermax 1250 plug and play without changing any of the connector's pinout? The hand torch wire colours and pins are in a different configuration but don't know if it's suppose to be that way??
    I seen another thread on the zone where the guy had this exact setup http://www.cnczone.com/forums/general-waterjet/70535-hypertherm-1250-t100m-torch-short-consumable-life.html
    Tried to PM the guy who started that thread but no replies so far.
    Dan
    www.decalpro.ca
    Jan 2008
    2247
    Re: Can you use a T100M machine torch with a Powermax 1250?
    Yes, the T100M (machine torch) is essentially the same torch as the T80M. You can use the T100 on Powermax 1650, 1250 and 1000 models. Consumable life and cut quality will be identical as using the T80 torch.
    Jim Colt Hypertherm
    Quote Originally Posted by pimpbike View Post
    Dan
    Aug 2005
    158
    Thanks for confirming that Jim!
    www.decalpro.ca
  1. Hypertherm Powermax 1250 Machine torch questions.
    By pimpbike in forum Hypertherm Plasma
    Last Post: 01-04-2014, 12:43 AM
  2. Powermax 1250 with automatic 100A torch
    By bdrotaru in forum Hypertherm Plasma
    Last Post: 09-05-2011, 01:04 PM
  3. T60 Torch on a Powermax 1250
    By Stout in forum Hypertherm Plasma
    Last Post: 08-04-2011, 10:26 PM
  4. Hypertherm T100M Machine Torch Cable diameter
    By Zaher in forum Waterjet General Topics
    Last Post: 01-18-2010, 02:29 PM
  5. Hypertherm 1250 with a T100M torch??? Short consumable life
    By Brink_ in forum Waterjet General Topics
    Last Post: 01-08-2009, 05:28 PM
