587,499 active members*
4,710 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Oct 2014
    25
    fanuc 6m system
    Can anyone help me with the fanuc 6m??
    I have this errors
    600
    603
    607
    This is appear on the CRT after I unplug the 6 wire connector that located on the power unit
    So before I did that there was not anything appear on the CRT nothing powered up ..I don't know what I should be doing with these errors
    Replace PCB master or pc model-b or mdi and crt or connection unit. ...Please someone help me
    Oct 2014
    28
    Re: fanuc 6m system
    This error is problem between NC&PC. And you can check on check point to ground is normal or not.
    Oct 2014
    25
    Re: fanuc 6m system
    Dear sir, Enkima_ll
    I was checking the ground its ok ... I measured the ground resistance,so its in the allowed limits..
    The switch off lamp is light ..so the machine is power off ..only the crt is power on and show the alarms list ..the mdi also is power off ..also I wss try to power up the machine by jumpers the relays points ..and nothing happen...
    Oct 2014
    28
    Re: fanuc 6m system
    OK, can you take photo unplug point to me via [email protected]? Now you can take A20B-0008-0430 and A20B-0008-0440 out and check CRT and test power ON.
    Oct 2014
    25
    Re: fanuc 6m system
    When I power up the machine by pressing the switch on key on the crt .. I see that
    Rom ready
    Bubble ready
    Alarms message
    Not ready
    Thats mean the rom and bubble carts is work well
    ..so remain the PC-model B and the crt I/o carts
    Oct 2014
    28
    Re: fanuc 6m system
    You can test one card on mainbord.
    Oct 2014
    25
    Re: fanuc 6m system
    Which one that o can test it on the main board
    Oct 2014
    25
    Re: fanuc 6m system
    I was unplugging the PC-model B and test it ... nothing was wrong ... so I think that the PCB master or the crt I /o fault. .
    Oct 2014
    28
    Re: fanuc 6m system
    Do you have new part for conferm?
    Oct 2014
    25
    Re: fanuc 6m system
    No , I don't have .
    Oct 2014
    25
    Re: fanuc 6m system
    It's big problem ...I should be buy new pcb master and crt card .. I don't know what I should be doing with these! !!
    Oct 2014
    25
    Re: fanuc 6m system
    Excuse me , my English so bad .
    Oct 2014
    28
    Re: fanuc 6m system
    Your master board code is A16B-1000-0030 or A20B-0008-0410?
    Oct 2014
    28
    Re: fanuc 6m system
    Me too ,english so badly hahahaha.
    Oct 2014
    25
    Re: fanuc 6m system
    Its A20B-0008-0410
    Oct 2014
    25
    Re: fanuc 6m system
    I'm not sure until now . ...is the next step is buy new part or there is something else??
    Oct 2014
    28
    Re: fanuc 6m system
    Ummmmm...I m Not sure, my work shop have this code.
    Oct 2014
    25
    Re: fanuc 6m system
    Do u have the same machine ?
    Oct 2014
    28
    Re: fanuc 6m system
    No, I dont have any machine. I m engineer. Now you have 2 choice, repeir board or buy new part.
    Oct 2014
    25
    Re: fanuc 6m system
    Thanks alot dear engineer Enikma_ll for ur reply....
Page 1 of 2 12
  1. Fanuc System 10M
    By stevenchan in forum Fanuc
    Last Post: 03-25-2021, 08:15 PM
  2. fanuc system 10t
    By Giang978 in forum Fanuc
    Last Post: 11-11-2012, 02:54 AM
  3. Fanuc 5T System BTR
    By protyper in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-08-2007, 03:06 PM
  4. Fanuc System
    By chinthakahk in forum Fanuc
    Last Post: 10-01-2007, 09:50 AM
  5. Fanuc system 10
    By kayleesdad in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-30-2006, 05:59 PM
