587,587 active members*
4,867 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Beginner question, please help!
Results 1 to 7 of 7
    Jul 2013
    51
    Hi guys
    I'm a Camworks newb and having a lot of trouble adjusting
    Can someone please help me to understand why when I've set my first pass to be 3mm with a 3mm max and to be calculated equal, why it's doing this several passes?
    The slot is only 5mm deep.
    My head says that should make it 2x pass at 2.5mm each.
    Thank you in advance
    Mar 2008
    638
    Re: Beginner question, please help!
    I think you have the % button on so that's 3% not 3mm?
    May 2005
    15
    Does anybody know what "Wedge Machining" is or does?
    Jul 2013
    51
    Quote Originally Posted by extanker59 View Post
    Thankyou, thankyou, thankyou, it worked. I could kiss you!
    Something so simple yet I overlooked it due to being unfamiliar with the program.
    Very appreciative.
    Jul 2013
    51
    Quote Originally Posted by Harvdog42 View Post
    It was pre set by default so I left it. It's one of a million things I need to "look up"
    (decided to look up before entering post)
    2 Axis Rough Pocket Wedge Machining
    Purpose:
    Eliminates unmachined wedge shaped areas that sometimes result when roughing with Pocket In or Pocket Out, where the step over is greater than 50% of the tool diameter.
    Implementation:
    The toolpath is modified automatically when wedges are generated for stepovers greater than 50% of the tool diameter.
    May 2005
    15
    Thanks Demonx,
    That makes perfect sense. I've never paid much attention to that setting and have probably had it activated all along.
    Mar 2008
    638
    Quote Originally Posted by demonx View Post
    Very appreciative.
    LOL, you're welcome but no kissing. My wife might get mad. lol
  1. a beginner's question
    By lseuanes in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-20-2014, 02:20 PM
  2. beginner question
    By negativentropy in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-25-2013, 07:12 PM
  3. Beginner Question
    By Tee_Pee in forum Open Source CNC Machine Designs
    Last Post: 11-19-2012, 01:08 AM
  4. Beginner Question
    By j-radkemachine in forum BobCad-Cam
    Last Post: 05-15-2007, 02:40 PM
  5. Beginner's Question
    By Gorillakilla in forum CNC Machine Related Electronics
    Last Post: 10-11-2005, 10:21 PM
