587,133 active members*
3,353 visitors online*
Results 1 to 2 of 2
    Jan 2006
    105
    TL-1 IPS With LH Tooling
    I have set up gang tooling on our new TL1 but can NOT figure out how to get a LH mounted tool to cut the correct direction using the IPS. I have a parting tool mounted upside down on the far side of the part. I have my tool type set to 'cutoff' and have tried every possible tip direction number. The tool always moves away from the part instead of cutting through it. What am I missing?
    Thanks in advance!!
    2000 Haas VF-2 : Tormach PCNC1100 :OneCnc XR5 Pro
    Nov 2010
    73
    Re: TL-1 IPS With LH Tooling
    Try to enable mirroring for the x axis (G101 x0). This command must be added independently. Don't forget to turn off at the end of the work tool (G100 x).
  1. Replies: 4
    Last Post: 05-07-2012, 12:54 PM
  2. punch tooling,cnc punch press tooling
    By sentool in forum News Announcements
    Last Post: 10-04-2011, 04:26 AM
  3. hsk-100 tooling
    By 1234567 in forum Uncategorised MetalWorking Machines
    Last Post: 05-03-2011, 05:34 PM
  4. Replies: 2
    Last Post: 08-09-2010, 04:17 PM
  5. What is Live tooling versus "non-live tooling"?
    By squale in forum Uncategorised MetalWorking Machines
    Last Post: 11-15-2007, 09:38 PM
