587,475 active members*
3,527 visitors online*
Page 7 of 8 5678
Results 121 to 140 of 153
  1. #121
    Jun 2014
    1780
    Re: I love my Tormach, but...
    Quote Originally Posted by popspipes View Post
    I did have some issues when the pdb release button was pushed with the spindle running, It knocked the pdb nut balance rings out a bit, they are close now but not perfect, need to find one of those "roundtuits"
    I have since made up a relay lockout setup for it, works nice for manual drilling etc. A simple phone cabe will work also on the factory setup.
    The main problem I have now is the computer, windows, and Mach! I would spend some serious bucks for a dedicated controller if and when Tormach comes out with one.
    I spent the day yesterday getting the spindle back in balance, at least as perfect as I can get it, I was getting the vibration pattern in the finish cuts again, I havent machined anything yet but the spindle is smooth at 5140. There is no sheetmetal vibration now, just a bit of a whirring sound from the fenner belt. I have a spindle lockout on the machine now so this spindle nut- PDB problem shouldnt happen again.
    mike sr
  2. #122
    Sep 2012
    1543
    Yeah, I was just going to say, I can't operate the PDB when spindle is running. Unlike my new GT-27... I just ran a bar (50 parts) and... zero parts were produced, lol. Had the collet open, and first op was drilling so it pushed the bar back, and then during bar pull op it couldn't grab it.
  3. #123
    Feb 2007
    1041
    What's up guys ! Brad out of these two, which is the Tormach S2 finish ?
  4. #124
    Jun 2008
    1082
    I'd say the bottom *photo* looks better.
    I'm not Brad though.
  5. #125
    Sep 2012
    1543
    I agree
  6. #126
    Feb 2007
    1041
    Ding ding B as you guys can tell is a very nice finish (Mori), but the little engine that could wasn't that far behind.
  7. #127
    Jun 2008
    1082
    You're right, the top one is also quite nice looking. I should have said that earlier... I was thinking it.
    Were they both cut the same way (within reason)? Like, were they both cut using the same speed and feed, same cut depth and width, and using the same kind of tool? I have to assume they are the same material. Another couple metrics I would be curious about would be tool length (let's say from the spindle nose, including the holder) and TIR.
  8. #128
    Jun 2014
    1780
    Quote Originally Posted by twocik View Post
    I sure like your finishes and parts Chris!
    mike sr
  9. #129
    Sep 2012
    1543
    To bad the other thread got shut down, lol. Hopefully some of those guys watch my videos I posted in the last post.
  10. #130
    Feb 2011
    605
    Yeah, but neither of those are exceptional. Is that a factor?
  11. #131
    Sep 2012
    1543
    Guy who has a Speedio in his garage, lol
  12. #132
    Feb 2011
    605
    I'm just saying the end user doesn't care what tool is being used, their expectations are based on what is possible. This is straight off the machine finish - not my parts, but a good example of great surface finish.
    With small tools it gets easier as the machine and tool holder rigidity get less important.
    PM-45 CNC conversion built/run/sold.
  13. #133
    Sep 2012
    1543
    That is off a Tormach? Give us all the parameters.
  14. #134
    Feb 2006
    7063
    Quote Originally Posted by BAMCNC.COM View Post
    Those did NOT come off a Tormach, or any other low-cost Chinese mill. Those were done on a FAR more expensive commercial VMC, and probably took a loooooooong time to machine.
    Regards,
    Ray L.
  15. #135
    Sep 2012
    1543
    My point. This is a TORMACH thread. If someone was making those parts on a Tormach... Then all common sense is lost in this world.
  16. #136
    Feb 2006
    7063
    Yeah, but he's showing what's possible with a more expensive machine, however unrealistic it is to think an inexpensive hobby machine could ever reach that level of finish.
    Regards,
    Ray L.
  17. #137
    Feb 2011
    605
    My point is, "I love my tormach (hobby machine)", but it will never provide exceptional surface finish. And if you are a person building product to sell then the customer does not care about your equipment limitations. And a photo showing the same quality of surface created on a Tormach and then a Mori is not telling the full story.
  18. #138
    Mar 2009
    1863
    Quote Originally Posted by jid2 View Post
    I don't care what anyone says, those 2 parts do NOT have machine finishes. I have been machining for over 50 years and I have run some pretty sophisticated machines and I have NEVER seen a part come off the machine with an almost polished finish like those. I have seen some fine machine finishes, but never like those.
  19. #139
    Feb 2006
    7063
    Some of it is machine-finished - the top surface is clearly face-milled. The angled surface is clearly 3D machined with a very fine stepover. I am, however, skeptical about the finish on the side faces. Either those were polished, or the angle and lighting simply obscure the machining marks. I believe it's the latter. If you magnify the image about 400%, there are what look like machining marks.
    Regards,
    Ray L.
  20. #140
    Jan 2010
    251
    has it been established that the part in jid2s pics are indeed the 6061 most of you are limited to experience with? an alloy with more zinc will give a nice shiny finish right off the machine, yes even on a tormach. there are a lot more alloys out there used in the industry than 6061.
    walt
Page 7 of 8 5678
  1. Love My Job!!!
    By eneias_eringer in forum Benchtop Machines
    Last Post: 07-14-2013, 09:21 PM
  2. Love my Tormach
    By tbaker2500 in forum Tormach Personal CNC Mill
    Last Post: 08-20-2012, 01:24 AM
  3. I Love Grex
    By borrisl in forum Shopmaster/Shoptask
    Last Post: 07-21-2006, 03:15 AM
  4. Do you love boats? Do you love planes?
    By cncadmin in forum Hobby Discussion
    Last Post: 03-20-2006, 04:01 AM
  5. Hmm.. got to love it
    By Pole in forum MetalWork Discussion
    Last Post: 08-28-2004, 12:58 AM
