587,490 active members*
7,062 visitors online*
Page 1 of 2 12
Results 1 to 20 of 27
    Oct 2012
    72
    How to Change from 6515 to AWC608
    Hi I am interested in changing controllers to the AWC608.
    I want to be able to control the laser pulses hence why I am interested in this upgrade.
    Has anyone done this and is it easy? Is there an online manual or photos I can take a look at in doing this correctly?
    Any help would be appreciated.
    Nov 2008
    382
    I have done quite a few conversion and helped many others to convert there machines to the AW608
    if you send me a email to my PM what is [email protected] then I can direct communicate with you and also send maybe some picture or schematic.
    greetings
    waltfl
    May 2013
    11
    Re: How to Change from 6515 to AWC608
    Hi, herby08, I need your help, I bought lasercut and engraver with AWC608, please help me for setting up the workspace, it always says "Beyond of size". Thank you a lot, and i will send you an email, too
    Nov 2008
    382
    no problem I just finish wolfau's set up
    send email
    greetings
    waltfl
    May 2013
    11
    Ok. Sending pictures now. Please can we talk on videocall?
    Mar 2014
    4
    hey herby08 I'm in the process of switching out my leetro mpc6535 to the awc608 and I ran into a problem will you be able to help me.
    Nov 2008
    382
    sure I can help you just send a PM
    greetings
    waltfl
    Mar 2014
    4
    hey walt your pm box if full. I can't send you anything.
    Nov 2008
    382
    hi
    the inbox is already open a while.
    greetings
    walt
    Oct 2010
    3
    I have similar problem with my AWC608C controller. It can cut at high speeds, but I cannot engrave at all. It display message "Engrave Beyond Size!". I already tried to change "Position relative" and few other things, but no luck. Anyone can help
    Nov 2008
    382
    you need to lower your speed because the laser need some space as he returns. if the design is small move I more to the middle.
    greetings
    waltfl
    Oct 2010
    3
    Can you post your settings file?
    I already tried to engrave at 150, 50, but still the same issue. I had this message for cutting process as well, but once I changed origin position it works fine.
    Nov 2008
    382
    push the reset on the display first maybe even format the machine memory.
    greetings
    waltfl
    Nov 2010
    787
    Quote Originally Posted by wolfau View Post
    What kind of CO2 laser do you have in your machine?
    CNC lasers, constructions, service
    Nov 2008
    382
    hi
    I got the CO2 tube in all two of my machines
    greetings
    waltfl
    Nov 2008
    382
    just post your lasercad file here and let me see whats going on
    greetings
    waltfl
    Nov 2010
    787
    Quote Originally Posted by herby08 View Post
    hi
    I didnt ask you but "wolfau"
    Oct 2010
    3
    Hi. Finally I have get it to work! Quite simple solution. It is only a way of setting two parameters on your controller. Work Space -> Machine Zero, Control Zero and Position Relative (LaserCad v6.99). Before you change anything just go to the middle of your working area and set is as origin. This way laser can move in each direction, up down or left right. Engrave or cut something and see how it looks. For me it was mirror image, so I have to reverse settings for X axle. Good luck!
    Feb 2013
    38
    Hi herby08 ... another waif and stray - this time from New Zealand.
    Are you still able/willing to advise on Leetro->AWC608 migrations?
    I'm nearly there - just a couple of things I'm not sure about.
    Nov 2008
    382
    no problem just send me a PM that I can give you my email address
    greetings
    walt
Page 1 of 2 12
  1. LaserCAD does not communicate proper feedrate and power to AWC608 DSP
    By wontpontificate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-22-2015, 07:04 PM
  2. Convert WK Laser LC1290 leetro to AWC608 - Vic, Aus
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-25-2014, 12:20 AM
  3. mpc 6515 engrave problem
    By lingegnere in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-26-2013, 07:09 PM
  4. MPC 6515 and Lasercut 5.3
    By vlada2 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-17-2010, 08:07 PM
