587,523 active members*
3,471 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Microkinetics NM400E Cable SCSI50M to DB25M Cable Pin-Out
Results 1 to 3 of 3
    Jan 2009
    234
    I need to find the pin outs for the Microkinetics NM400E Cable SCSI50M to DB25M & Cable SCSI50M to DB25M/DB15M Cables... I Cannot see Paying $50.00 - $75.00 for a Cable that costs $7.00 SCSI 50M Cable on eBay + a $2.00 DB25 Connector! Unless I cannot find the pin-out.
    Jan 2009
    234
    Re: Microkinetics NM400E Cable SCSI50M to DB25M Cable Pin-Out
    I found the pin-out for the MN400 I just need to find the pin-out for the DriveRack Model # 3400-304 DB25 Connector.. What would also be nice is to get manual for the Drive Rack. I had no luck with MicroKinetics in getting a manual the phone call was brief and short not very helpful customer service this CNC kit was partially installed never ran! They have the manual online for the Newer Drive Rack with the Integrated MN400 but not the older one! Any help would be grateful!
    Photo of the Drive Rack Back Side.
    Jan 2009
    234
    Ok, got an E-mail from Microkinetics the breakout for the 25 pin is the same as the Optistep. http://www.microkinetics.com/pdfmanu...25wirediag.pdf
  1. Replies: 0
    Last Post: 01-14-2014, 05:50 AM
  2. Looking for a cable
    By groundhog719 in forum Syil Products
    Last Post: 12-03-2011, 01:33 AM
  3. AC power cable in the same cable carrier with motor cables
    By bandtank in forum CNC Machine Related Electronics
    Last Post: 06-02-2010, 12:06 AM
  4. Replies: 0
    Last Post: 01-22-2010, 07:06 PM
