587,613 active members*
3,471 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal jog key skips
Results 1 to 6 of 6
    Aug 2007
    298
    Fadal jog key skips
    Hi
    Having a issue with Jog key. Not sure if it's a board problem or dirty contacts on keypad, hopefully someone has had some previous experience?
    When doing certain functions, like setting tool or fixture offsets, in the middle of picking off the various axis touch offs or more correctly when machine prompts to 'hit jog key' which I press, the machine briefly shows the jog screen then goes to the 'enter next command' or jogs by the tool touch off screen and waits to get next tool.....:devious:
    Mar 2013
    8
    Did you ever figure out what the problem is? I am experiencing the same issue. Thanks!
    Mar 2013
    8
    Bump - Still trying to figure out this issue. Any help/direction very appreciated.
    Jun 2012
    516
    Re: Fadal jog key skips
    i swapped out my 1090-3 card for a 1090-3B which has eprom version 5.5. jog button ****ty-ness gone now. best of luck out there.
    Jan 2015
    417
    It is the keyboard i have a VMC15Xt that does that exact thing. I just learned to deal with it dont feel like changing the keyboard. The way i have gotten around it is to poke the Jog key real quick and it will stay in jog and not want to grab the next tool. If you need a keyboard $200 go to ELE-1784P - Calmotion ask for Glenn and tell them what its doing to make sure its the keyboard only
    Jun 2012
    516
    Quote Originally Posted by rodney247 View Post
    fyi its not the keyboard itself thats broken. its a software problem. i didn't used to have this issue before I went from sys 96 to sys 101 cpu software.
    so u need a new 1090 - or like you say, just live with it.
    I have to also mention that I have had axis' run away when spinning the jog wheel fast. I spun the sh*t outta my jog wheel last night to test it out and this new 1090 didn't run away.
    seems like a nice fix.
  1. G-Code skips
    By rkonnen in forum Mach Software (ArtSoft software)
    Last Post: 10-19-2013, 09:03 PM
  2. Mitsubishi LXP Skips Every Odd or Even Part
    By recips in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-21-2013, 06:22 PM
  3. My Program Skips Lines
    By DroopyPawn in forum G-Code Programing
    Last Post: 11-22-2007, 09:26 AM
  4. Mazak Block Skips
    By ajl6549 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-05-2007, 06:37 PM
  5. torque skips
    By scappini in forum Fanuc
    Last Post: 02-02-2007, 11:07 AM
