587,925 active members*
3,671 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > 6040z Gecko g540 conversion wiring question
Results 1 to 9 of 9
    Sep 2014
    13
    Hi all,
    So this is my first foray into CNC machines. I have done some extensive reading here and bought the 6040z and Gecko g540. I was able to power up the g540 and hook up an E-stop button to get it to cycle between ready and fault mode. Now I am hooking it up to my x-axis motor on the g540. I have 4 wires green, red, yellow-green, and black and was wondering how can I tell which two go to which coil and how to tell which are +/-. Any help is appreciated.
    PS: I'll post pictures soon.
    Thanks!
    Sep 2014
    13
    Re: 6040z Gecko g540 conversion wiring question
    Nov 2012
    108
    Here's a good wiring diagram for G540s: http://www.homanndesigns.com/pdfs/EN010_V8.pdf
    It includes the connections for the steppers and the DB9 connectors.
    You can tell which stepper motor connectors are the two coils with a multimeter -- there should be continuity between A- and A+ and between B- and B+, but not between other pairs.
    Sep 2014
    13
    Great tip thanks, that should have been fairly obvious to me. So what happens then if the polarity on the A coil or B coil or both is backwards?
    Thanks again!
    If the polarity is different the motor will turn in the wrong direction.
    Reverse one coil pair wires and it will turn in the opposite direction.
    Sep 2014
    13
    Thank you I appreciate the response. I was looking at a few sources to see exactly how stepper motors work and I found this: How Stepper Motors Work
    Looking at this is it safe to say that it won't matter which coil I deem coil A and which I deem coil B?
    It does not make a difference which coil you deem A or B.
    If it does not spin the direction you expect, reverse the wires on one of the coils at the connector and it will spin in the opposite direction.
    Sep 2014
    13
    Thank you all I have my spindle control and x,y,z control up and running beautifully. Thanks for all the help!
    In an effort to consolidate all of the 6040 and 6040z threads please post here: http://www.cnczone.com/forums/open-s...ml#post1790768
  1. Another sPID, G540, and Mach wiring question for the wiring challenged..
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-02-2014, 01:29 AM
  2. Planet CNC USB Mk2 Controller + Gecko G540 driver wiring
    By lingo124 in forum Open Source CNC Machine Designs
    Last Post: 06-24-2013, 06:59 AM
  3. Wiring Gecko G540 to PSU
    By rnm85 in forum DIY CNC Router Table Machines
    Last Post: 01-08-2012, 02:48 AM
  4. Minimum wiring connections for Gecko G540
    By CNC Lurker in forum DIY CNC Router Table Machines
    Last Post: 12-09-2011, 10:30 PM
  5. Wiring diagram for Gecko g540 and cnc4pc C8 relay
    By blackrat in forum Gecko Drives
    Last Post: 04-25-2009, 11:22 AM
