587,450 active members*
2,587 visitors online*
Thread: Hoss's G0704
Page 291 of 344 191241281289290291292293301341
Results 5,801 to 5,820 of 6871
  1. #5801
    Re: Hoss's G0704
    Quote Originally Posted by kd5ahl View Post
    Hi Hoss, Love your plans! I had a question about the solenoid valve you used for the PDB. are you using a 5 port and actively pushing and pulling the piston or a 3 port valve and letting the belvilles return the piston to the resting position?
    It uses a 5 port since it's a double acting air cylinder otherwise it wouldn't retract and the cylinder rod would rub on top of the drawbar.
    You could use a 3 port solenoid if you use a single acting cylinder with spring return, that's what I used on the first pdb on the x2.
    The bellevilles have no control over retracting the cam/rod off of the drawbar to create clearance to prevent rubbing.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #5802
    Aug 2014
    45
    Re: Hoss's G0704
    Hi Hoss,
    What is a good source for the misc. cap screws, nuts, washers used in the CNC conversion? I know McMaster-Carr has a great selection but their ordering quantities are often quite large. I will eventually want to build up some hardware stock but not 100 pieces at a time.
    Thanks,
    Joe
  3. #5803
    Re: Hoss's G0704
    As recommended in the plans there is also boltdepot.com, you can order only as many as you want or in bulk.
    The Nutty Company - Leading Supplier of Stainless Steel Nuts and Bolts is another.
    Hoss
  4. #5804
    Aug 2014
    45
    Re: Hoss's G0704
    Thanks Hoss, missed that in your plans. Bolt Depot is exactly what I was looking for. - Joe
  5. #5805
    Re: Hoss's G0704
    I haven't forgotten about the PDB 3, had another sad family matter but the parts are machined now, just some tapping, deburring and powdercoating to do.
    The mill ran great, the parts came out perfect, nice to have the extra pressure with the flood and washdown hose and not one chip or drip on the floor.
    Hoss
  6. #5806
    Jul 2012
    159
    Re: Hoss's G0704
    Any new updates, pictures or videos of the PDB3?
  7. #5807
    Re: Hoss's G0704
    I'm prepped to powdercoat the finished parts tomorrow, yellow.
    Hoss
    Attached Thumbnails Attached Thumbnails 100_5909_800x600.jpg   100_5924_800x600.jpg   100_5927_800x600.jpg
  8. #5808
    Jul 2012
    159
    Re: Hoss's G0704
    looks great!
  9. #5809
    Feb 2010
    3447
    Re: Hoss's G0704
    Never fails to impress! Good job hoss!!
  10. #5810
    Nov 2009
    4415
    Re: Hoss's G0704
    All machined with printed plastic stepper mounts?
    A lazy man does it twice.
  11. #5811
    Re: Hoss's G0704
    Quote Originally Posted by Fastest1 View Post
    No the stepper mounts were machined from ally a while back for the phase 3 update, note the red powder coated parts.
    Hoss
  12. #5812
    Nov 2009
    4415
    Re: Hoss's G0704
    Bad eyes on my part. That PC throws me off.
  13. #5813
    Re: Hoss's G0704
    Powder coating done, the yellow looks more vibrant in person.
    Have some goodies coming in the next couple days so I'll be busy with that but should get this done this weekend.
    Hoss
    Attached Thumbnails Attached Thumbnails 100_5929_800x600.jpg   100_5936_800x600.jpg   100_5942_800x600.jpg
  14. #5814
    Feb 2014
    103
    Re: Hoss's G0704
    Very nice! I just did the deed and ordered a G0704! Expect to see more of me around these parts! I'm sure I'll be contacting you soon Hoss!
  15. #5815
    Re: Hoss's G0704
    Sweet, welcome aboard, always room for another g0704 owner.
    Hoss
  16. #5816
    Feb 2014
    103
    Re: Hoss's G0704
    I am super pumped. Been playing with a bench top router. The x6 1500gt yearning to eat up aluminum and steel. I don't know what took me so long to find all the amazing upgrades you have come up with. I totally overlooked the G0704 until I saw your videos!
  17. #5817
    Nov 2009
    4415
    Re: Hoss's G0704
    Hoss, what is going on with the double nutted screws? I never heard the results of them.
  18. #5818
    Re: Hoss's G0704
    From back in June, http://www.cnczone.com/forums/bencht...ml#post1505846
    Hoss
  19. #5819
    Jul 2012
    159
    Re: Hoss's G0704
    I am using Hoss's probing screenset and have a few questions
    1. what does the auto tool set do on the main screen?
    2. how do you change the size of the probe in the macro? I am using different size probes depending on the hole sizes and need to know how to change it.
    3. What is the largest and smallest holes you can use the ID and OD center probing?
    4. How can you use the probing to set the tool lengths in the tool table?
    Thanks for all your help
    David
    San Jose, CA
  20. #5820
    Nov 2009
    4415
    Re: Hoss's G0704
    I still didnt see anything regarding backlash of the new screws. I remember you receiving them.
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
