587,925 active members*
3,693 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > New Opti BF46 - soon to be CNC'ed
Page 3 of 4 1234
Results 41 to 60 of 77
  1. #41
    Jul 2004
    108
    Re: New Opti BF46 - soon to be CNC'ed
    Hey Digits,
    Pics on the weekend,even though it will only be of a few servos and drives and other thingos
    But progress will be rather quick from hereon in....i have also ordered the Mesa 5I25 and 7I77 kit, just a bit concerned about bandwidth for the std parallel port, hey, i guess for this built, if i have to justify anything, i will :lol:
    Keep you posted.
    Cheers,
    Beano
  2. #42
    Mar 2014
    62
    I'll be watching this thread with much interest. I'm in process of importing a BF46 to the USA, but it is currently hung up in customs. I hope they don't hold it for ransom for too much money, as I hear manual inspections can cost big $$ (the container has been x-rayed so far).
    I'm also going with DMM AC drives like Mr. Bean did, 750 W on all three axes. My initial attempt will be with a 2:1 belt ratio, all controlled with a Dynomotion Kflop. Once (if?) the mill finally arrives, I'll start my own build thread.
    So until then, carry on, and lead the way!
    -Steve
  3. #43
    Jul 2004
    108
    Good luck with yours, I hope it clears customs soon!
    Be prepared to manhandle it to get it in position in its final resting place though, it is a monster! Please keep us posted, there are very few builds of this machine around.
    Cheers,
    Beano
  4. #44
    May 2009
    20
    Quote Originally Posted by MrBean_pm View Post
    Hello Everyone,
    After a very busy spell at work, a new regional role and all the pressure that goes with it, I finally managed to get my Mill uncrated, on its pedestal, (temporarily) DRO'ed, and even cut a few chips with it.
    But, as I don't have much time at my disposal for my hobbys, whatever little time I have, it needs to be used efficiently, so this conversion will proceed - of course, any old excuse to do this would suffice, but time-management is as good as any :lol:
    I finally made the decision to go with AC Servos and drives from DMM-Tech, they are with TNT in Australia and will be delivered on Monday, yeay - sad that I am flying out to Bangkok on tuesday though for the weeke again, but such is life, at least now the components are coming in. Refer to the attachment for the list....
    I have also purchased a wallmount Rittal 500mm (h) x 400mm (w) x 210mm (d) cabinet to house the computer, drives, as well as a 15" panel mount display and industrial keyboard - this will be the control center. I do have a variety of industrial SBC computers to choose from, all Commell-based motherboards, i.e LV-677, LS-373, LS-573, LE-570E, oreven Pico-ITX, but no need for that..... These are all coming with std RS-232 and RS-485 ports, as well as an onboard LVDS interface to connect the correct LCD without a controller directly to the motherboard....to make for a small footprint very powerful setup.
    I will naturally finish the cabinet and controls-side first, before dabbling into the mechanical side - I am an automation guy after all, hehe.
    @ Kiwi 007: If you read this, can you let me know where in NZ you got your ballscrews from, are they 20mm or 25mm?
    I got my ballscrews from the dealer that sold me my mill, do you want me to see if he can source a set for you??
    @ Madwelder: I will go and check your buildlog too, thanx for linking.
    Cheers,
    Beano
    See highlights above
  5. #45
    Jul 2004
    108
    Hey Kiwi,
    Would be obliged if you can do, please Mate, I see you replied in your thread too, thanx!
    Otherwise I can give them a bel and see if they can help me. Can you recall the pricing on yours?
    Cheers,
    Beano
  6. #46
    Jul 2004
    108
    Hey Guys,
    A few pics to show it actualy exsists
    and the DRO I have fitted.....
    and the actual machine itself - it doesn't look like it from the photo, but it stands at ~2.2M tall on its stand - it is a big bench mill, as mentioned earlier...
    Here a few pics of the 2x 750W DMM Tech motors and DYN3-H drives - I went down this path as now I do not need external PSU's for the drives, they are powered directly from 220V AC....
    and
    and drives........
    and
    and them all sitting nice and cosy together...
    I do have a Mesanet 5I25 and 7I77 controller card and breakout board too, I will not be using the original DMM Tech breakout board....I will post pics of that when I take the Camera to the garage - to chilly out there now.
    Cheers,
    Beano
  7. #47
    Aug 2014
    103
    What Oz are you drives rated to mate?
  8. #48
    Jul 2004
    108
    Hey Mate, they are rated at 0,750kW or pretty close to 1HP - at the rated rpm of 1,200 it would be ~ 845 oz-in.....
  9. #49
    Aug 2006
    1602
    Nice set of bits you have there Having 3-HP in the axes sounds a bit insane though - well, done!
  10. #50
    Jul 2004
    108
    Cheers digits, hopefully I can get the mechanical bits sorted with Kiwi007's help
  11. #51
    Aug 2006
    1602
    Have you managed to make any more progress? I've seen a BF46 in the metal myself now, and I'm very interested to know how well they CNC...
  12. #52
    May 2013
    149
    Envy! Steppers for me.
    Wisdom results from foolishness!
  13. #53
    Jul 2004
    108
    Unfortunately not much progress, professional life exceedingly busy, barely at home during the weeks anymore.
    I am most likely going to keep this as a manual mill only, and order a CNC setup from Skyfire (www.skyfirecnc.com) I will use my motors and controllers, but the machine will be CNC ready, with linear ways and other goodies. It was designed as a CNC machine from the ground up, pretty impressive specs, I should have done this back then, pity they were not available then. I will opt for the SMV-2.
    A big worklog here, if you are interested.
    I will anyway keep you posted on what I will do with the BF46, been operating it in manual mode for my small projects.
    Cheers,
    Beano
  14. #54
    Nov 2012
    220
    Cheers,
    Beano
    If I were you, I would wait for Skyfire to deliver a machine first. If you do buy from him go through PayPal.
  15. #55
    Oct 2010
    1189
    PayPal onliy helps to some Extend it didnt for me ...
  16. #56
    Jul 2004
    108
    Thanx for the feedback, guys, appreciated!
    I think the first machine has shipped, will await feedback and go from there It is a significant investment for a hobbyist, I need to make sure this will answer my needs.
    Will keep you all posted.
    Cheers,
    Beano
  17. #57
    Apr 2012
    7
    Cheers,
    Beano
    Just wondering if you have the dimensions for the ball-screws. I have a BF46 I would like to start converting, and thought the best place to start would be the ball-screws.
    Cheers
    Rick
  18. #58
    Oct 2010
    1189
    You Camp büy a kit for that als far as i Know
    Gesendet von iPhone mit Tapatalk
  19. #59
    Jul 2004
    108
    @Thomas: Yes, good advice, I am aware of the kit available for the BF46.
    After observing the issues around SkyFireCNC, which includes long delays from order to delivery, partial deliveries, I decided to continue with the BF46.
    I have it already, it is a nice solid machine, and would lend itself very well to a CNC conversion. I will visit a local shop who is able to get me a standard Optimum Factory CNC conversion kit, ok, not the whole kit, but the ballscrews, as well as motor mounts. In any event, this will no longer be a big deal, I have all the bearing numbers available now, and can actually design my own solution with HiWin screws.....I might even do custom bearing blocks, no biggie - I will do the design and have them machined somewhere, as have no access to machining equipment.
    So, all mechanical bits will have to be outsourced, no hassles - anyone knows someone that can machine the bearing blocks from my CAD files, I will be appreciated.
    Onto the electronics: I will run LinuxCNC, and it is already installed on a pretty decent Lex Twister 963A setup. Latencies are ok, and the MESA PCI 5i25 is setup and recognized in the CNC app....
    I have a 7i77 that will connect to the 5i25, and this will be the interface to the drive controllers. As you might recall from earlier, I sourced 3x DMMTech DYN3 drive controllers, as well as 3x 750W servos. I will not use the controllers anymore, I have instead opted to go with controllers I know pretty well, 3x Argon controllers from Granite Devices. I will also replace the 14-bit encoders on the 750W servos with quadrature encoders, so it can be used with the Argon and 7i77 board.
    I will sell the DMMTech sevos.
    I already have a nice enclosure for it all, as well as a 24V PSU to supply the electronics, and a few isolators etc....thus this part will go rather quick.
    I should make rapid progress with the control-side of things, I know this project was up and down for a long time, but things will start to move along now.
    I will keep you all posted.
    Cheers,
    Beano
  20. #60
    Oct 2010
    1189
    If You live in Europa we can do the Parts for You Thomas
Page 3 of 4 1234
  1. Info on Ballscrews for Optimum BF46
    By MrBean_pm in forum Linear and Rotary Motion
    Last Post: 11-01-2013, 06:57 PM
  2. Heavily CNC converted Opti BF 20 Vario
    By JMI80 in forum Benchtop Machines
    Last Post: 04-15-2012, 02:34 PM
  3. Optimum BF46 Centroid retrofit
    By yolklab in forum Benchtop Machines
    Last Post: 04-01-2012, 04:33 AM
  4. Opti BF 20 CNC kit
    By donalddk in forum Benchtop Machines
    Last Post: 09-17-2007, 05:38 AM
  5. Question about OPTI BF20 Vario
    By BMaynard in forum Benchtop Machines
    Last Post: 08-17-2006, 01:20 PM
