587,372 active members*
3,104 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Help! x-axis is alining in the wrong direction
Results 1 to 3 of 3
    Jul 2014
    1
    Exclamation Help! x-axis is alining in the wrong direction
    Hello,
    We have a Cincinnati sabre 750 with a acramatic 850 control. now for some reason after we moved the machine and powered it back up it comes up fine no alarms, but when we go to align it z homes y homes then x trys to home but heads in the + direction and it should home in the - Direction( if you just hold it it will go + till it hits the hard limit sw. I feel like this might off happened before I don't think anything is wrong with the machine, I believe it might be a g code or a offset of some sort if anyone has any ideas on how I can fix this please let me know im not very familiar with these controls. I work on fanuc most the time
    Thank you for you time
    Oct 2011
    205
    Re: Help! x-axis is alining in the wrong direction
    Sounds like you have an issue with a limit switch. Probably just dirty...
    Dec 2006
    585
    The X-axis align switch is stuck on. Clean or replace the switch in the front of the X-axis under the front sheet metal guard.
    Mike cncmachineservices (dot) com
  1. Need Help! Y-axis wrong direction
    By ponte in forum Redsail Laser
    Last Post: 08-10-2013, 03:07 AM
  2. Z-axis only turns in ONE direction, anyone know what might be wrong?
    By effimos in forum DIY CNC Router Table Machines
    Last Post: 03-15-2012, 01:20 PM
  3. Z axis backlash that drives the wrong direction
    By Kingjamez in forum Benchtop Machines
    Last Post: 10-05-2010, 03:46 AM
  4. Z axis going in wrong direction
    By erkiwi in forum CNC Machine Related Electronics
    Last Post: 01-20-2010, 11:43 AM
  5. integrex 200 II SY b axis wrong direction
    By smile in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-07-2006, 05:09 AM
