587,272 active members*
4,693 visitors online*
Results 1 to 3 of 3
    Aug 2013
    3
    Wiring the SSR SOLID STATE RELAY
    Hi
    How Wiring the SSR SOLID STATE RELAY to the HY-JK02-M5 break out board
    thanks
    Jun 2014
    12
    Re: Wiring the SSR SOLID STATE RELAY
    I only know how to wiring the solid state relay to realize motor control with single chip. For reference only
    220VAC to wire the main contact of solid state relay;
    Live wire L and R to wire the normally open and closed contact separately;
    null line to wire the null line.
    For reference only
    Machine, For save Labors.
    --From Jason(Wisebuy)
    Mar 2007
    2083
    one way is to use the relay on the breakout board to control your solid state relay
    if your not using all 5 axis outputs you can try using either a step or direction output to control the solid state relay
    posts 1018 and 1020 have some info on the breakout board :-
    http://www.cnczone.com/forums/open-s...e-easy-85.html
    John
Name:	bob and ssr.jpg
  1. BOB to Solid State Relay Plasma CNC wiring
    By greenjeens in forum CNC Machine Related Electronics
    Last Post: 12-20-2012, 02:29 AM
  2. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  3. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
  4. solid state relay question
    By aegfurn in forum CNC Machine Related Electronics
    Last Post: 02-24-2007, 04:09 AM
  5. Solid state relay
    By N4NV in forum CNC Machine Related Electronics
    Last Post: 05-07-2006, 06:19 AM
