587,115 active members*
3,225 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Brake needed on Vertical Z axis ??
Results 1 to 3 of 3
    Jul 2014
    20
    Building a 3 axis cnc machine using stepper motors.
    For the Z axis, the rotary cutting tool will be moved vertically. When the Z axis is not being told to move by the software, I am assuming there will be no signal being sent to the Z axis stepper motor. My fear is that unless some sort of brake is applied to this axis, then gravity will cause the cutting tool to 'fall' every time there is no instruction being sent to the Z stepper. Is this the case?? Or will the software automatically send a holding current to this stepper in order to keep it stationary? If a stepper is given a holding current like this, is there a chance that the stepper can get burnt out because it's having current on the same coil for an extended period of time? Any help would be appreciated greatly
    35538
    Re: Brake needed on Vertical Z axis ??
    Steppers are strongest when they are not spinning. If no step signals are sent to the drive, then they will hold steady. That's how they work. And no, they won't be damaged.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2014
    20
    Thanks for another great quick response and a straight forward answer. Many pleasure filled nights be sent your way.
  1. 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging, Extrusion...
    Last Post: 11-01-2015, 10:24 AM
  2. 2 Axis Vertical milling machine safety guards-Pics needed.
    By Lugy in forum Uncategorised MetalWorking Machines
    Last Post: 11-25-2008, 11:31 AM
  3. Help with press brake manual... Experts needed.
    By rjahr in forum Bending, Forging, Extrusion...
    Last Post: 02-10-2008, 11:41 PM
  4. press brake cam needed
    By cnc metalcraft in forum Bending, Forging, Extrusion...
    Last Post: 10-04-2007, 03:39 AM
  5. Vertical mill , part needed
    By stragenmitsuko in forum Vertical Mill, Lathe Project Log
    Last Post: 06-30-2007, 08:40 PM
