587,089 active members*
2,871 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Wholesale Tool 3n1 CNC Conversion (56k warning!)
Results 1 to 20 of 272
    Apr 2014
    52
    Re: Wholesale Tool 3n1 CNC Conversion (56k warning)
    Quote Originally Posted by Bob La Londe View Post
    Depends on how you thread I imagine.
    Rigid tapping is always a hit or miss with Mach 3 in my opinion, but there are folks who do it. Those using a servo spindle should be able to reliably though.
    Thread milling can be done with nearly any CNC mill as exact RPM is not critical.
    Extension compression tapping should be doable with most mills that are reasonably close to RPM numbers and have decent torque at lower RPMs.
    I do most of my tapping as a secondary operation on my drill press with a tapping head.
    There is also the start and stop time for the spindle to consider.
    I was thinking of external or internal threads over a longer distance, using the lathe, the way the auto-feed is already set up with the gears.
    Oct 2008
    2100
    Quote Originally Posted by KevMoto View Post
    Actually Mach3Lathe will accept an index pulse from a lathe spindle for synchronizing lathe type threading.
    Bob La Londe
    http://www.YumaBassMan.com
    Apr 2014
    52
    perfect,then FannBlade's set up will be perfect and it will allow me to move the big electical box on the G9729 like he did. Right now it's not centered and I just don't care for how it looks sitting on the table I built. I'll build my own cabinet like he did, replace the pulleys and motors.
  1. My Wholesale Tools ZX45 CNC conversion
    By DrewSmith007 in forum Benchtop Machines
    Last Post: 11-17-2012, 01:51 AM
  2. Wholesale Tool Lathe to CNC conversion
    By 71BlackGTX in forum Uncategorised MetalWorking Machines
    Last Post: 05-29-2012, 07:18 AM
  3. wholesale tool
    By ged in forum Mini Lathe
    Last Post: 07-20-2008, 08:55 AM
  4. Are there any coupons availible for wttool (Wholesale Tool)
    By jalessi in forum Benchtop Machines
    Last Post: 04-07-2008, 06:11 AM
  5. Softlimit warning after 1 tool change
    By pzzamakr1980 in forum Mach Mill
    Last Post: 03-09-2008, 04:47 AM
