587,453 active members*
7,344 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Working out power supply needed for NEMA 23
Results 1 to 3 of 3
    Dec 2011
    8
    I've been wanting to build a CNC router for a long time, and finally my finances are at a point that I can afford to.
    I' have ordered some NEMA 23 motors (these: Wholesale Product Snapshot Product name is 3 PCS 1.8deg Nema 23 CNC Stepper Motor Bipolar 56mm 2.8A 1.26Nm(178.5oz.in) 4 Leads CNC Router Laser Grind Foam Plasma Cut ) and I found a website that had these calculations to work out the required power supply:
    Quote Originally Posted by http://www.cnc4everyone.com/electronics/power-supplies/
    Voltage = 32 * sqrt( Inductance in mH )
    Supply voltage should be based off your motors inductance:
    Current = Amps needed per drive * Number of drives * 0.7
    Current needed should be 70% of the individual amp requirement of one drive times the number of drives in your setup. Generally it is possible to run your drives from even down to 50% of the total amp requirement, but for good measure stick with 70%
    I have calculated:
    Voltage = 32 x sqrt of 2.5
    Voltage = 32 x 1.58113883008419
    Voltage = 50.59644256269407 (close enough to 50v)
    Current = 2.8 (amps) * 3 (motors) * 0.7 (70%)
    Current = 5.88 A
    So, a 50v 6 A power supply.
    I found a power supply rated 48v 7.3A. My question is, will this do? It's not quite 50v, but the current is greater, so this will compensate right?
    Dec 2011
    8
    Re: Working out power supply needed for NEMA 23
    Well crap.
    I just had a look at the specs of the stepper drivers I've ordered, and they are rated to 36v max (recommended using 24v).
    So, will using a 24v power supply with a higher current output work or do I have to order different stepper drivers?
    Jan 2007
    146
    A 24v rated at 6 amp will work. The 50 volts is for max performance. With 50v the stepper should have higher top rpm than the 24v.
  1. Nema motor Power supply
    By aquaveg in forum Open Source CNC Machine Designs
    Last Post: 01-23-2012, 12:15 PM
  2. G540,620 oz nema 23, what power supply and winding?
    By umustsurf in forum Gecko Drives
    Last Post: 09-16-2011, 06:50 PM
  3. Power supply and Nema 17
    By woodturn in forum Stepper Motors / Drives
    Last Post: 02-13-2007, 05:11 PM
