587,419 active members*
3,155 visitors online*
Results 1 to 5 of 5
    Jun 2013
    16
    Jerky movement - motion easing
    I'm using a k2cnc 2539 machine with Kmotion/KmotionCNC
    I'm finding that when the machine is moving very slowly <15in/min the action seems normal, however when moving at a quicker pace the machine shakes due to very abrupt changes in direction. Is there a way to tell the machine to slow into a point, change direction and slowly pick up speed again?
    I'm new to using CNC machines and this might be normal at those speeds, but it seems hard on the machine. I've seen posts about Constant Velocity in Mach3 but I'm not currently using that softeware.
    I'll also note, that the cuts seem relatively fine but based on the problem amplifying I worry that going any faster will break a motor or shake the machine apart.
    thanks
    nate
    May 2006
    4047
    Re: Jerky movement - motion easing
    Hi natev,
    I'm not familiar with that machine. Is that using servos?
    Could you make a screen shot of the Trajectory planner settings under KMotionCNC | Tool Setup | Trajectory Planner?
    The Break Angle setting should determine when the machine decides to come to a stop at a corner rather than slowing down to "round" the corner.
    You may want to reduce the acceleration.
    For more information see here.
    Regards
    TK
    http://dynomotion.com
    Jun 2013
    16
    Yes, it's using servos. The axis that jerks is the Y which is perpendicular to the gantry. This is probably common in that the gantry only has X axis supports and there is no support on the Y. E.g. a ladder is more likely to tip forward or back rather than side to side. Anyway, here's a link to the machine and a tool setup shot. Desktop HD CNC Router | KG3925HD | K2CNC
    Attachment 234624
    May 2006
    4047
    Hi natev,
    I really liked your ladder analogy. I agree that seems to have significant mass high up with narrow support.
    I don't see anything major wrong with your settings. The break angle of 10 degrees should cause a stop for most angles.
    The 30in/s2 acceleration seems pretty aggressive for such a system. To accelerate to your mentioned speed of 15ipm would only take 8ms which is virtually instant for a system like that.
    Have you tried reducing the acceleration settings? This will not effect your Rapid or Jogging acceleration which uses 3rd order motion specified in the KFLOP Acceleration and Jerk settings. Also with KMotionCNC you shouldn't have the issues with lower acceleration that you might have with other systems - like rounded corners.
    Regards
    TK
    Mar 2013
    48
    I have the same machine, and I found the "factory" acceleration setting of 30 in/s^2 to be way too high, as Tom said. I set it to 5 for most work, and 2 for fine detail work like cutting mother of pearl inlays. This is probably conservative, but it works well for me.
  1. Using Cup brush on aluminum, 'jerky' movement
    By dylanmoz in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2012, 11:56 PM
  2. jerky movement
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 03-08-2012, 01:22 PM
  3. G320 and jerky movement
    By Ed Williams in forum Gecko Drives
    Last Post: 07-28-2011, 02:19 PM
  4. Jerky Movement
    By elogicca in forum Mach Mill
    Last Post: 11-22-2007, 03:19 AM
  5. Jerky Movement on Interact 1 MK2
    By palikalsi in forum Bridgeport / Hardinge Mills
    Last Post: 04-27-2007, 11:41 PM
