I loaded Mach3 on a new Computer win7. Now I can only see 66% of the top of the fonts on all screens? I can't seem to reset the fonts to something smaller?
any Ideas
CH
any Ideas
CH
Make sure your font setting in Windows is set to normal size.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
I had similar problem.
18 pt Arial seems to work well
Installing Arial Narrow on the computer for labels, code and buttons might help (if it is not installed)
General config --> screen control. Turn off hi-res screens
Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
HI
Never mind Got if figured out, I'm new to Win 7 so I'm still learning here. I have to reduce the text size % in the Win7 display settings. I dropped it from 125 to 120% at least I can still see it with these old eyes.Thanks guys.
CH
You didn't do what I said, The issue is your Windows font size setting. It's not a resolution setting. Go to Control Panel in Windows, and click on Display. The fonts need to be set to 100% (Smaller setting).
You can't change the Font size in Mach3, even though it appears that you can. They are locked at 18.
Gerry
I haven't been able to change size from 18, but can change font.
I select Arial Narrow, then immediately goto config, save settings then exit and restart Mach3
Looking at your screen, I think it is a crappy video driver scaling problem, as all vertical dimensions are squashed.
Try different video settings.
Aspect ratio options: full, no border, <<<-----
1366 x 768 or 1024 x 768.
Edit:
Gerry is correct.
Right click windows screen,Screen Resolution,
make text and other items larger or smaller
Select 100%
