Try V1=0, etc without the #.
I just had a look in old Bosch manuals, and it requires all the variables, etc to initialized before executable code, and this I remember from using DNC stuff.
Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
I have to admit that I have not tried to run the macro statements without the # sign. the idea freaks me out because if you were to do for example, a math operation like V1=V2*V3, it should make a comment out of the V3 portion.
I will try this immediately though - in a sense, declaring the variables at the start.
I tried some different things:
V1=0
#V1=0
N40 #V1=0
N40 V1=0
I tried all these kinds of calls with the SETP parameter for line numbers in order set to On, and Off.
the lines without # stop the program and say 'ERROR'
the lines with # but with no line numbers stop the program and say 'ERROR'
the lines with # but with line numbers just get skipped entirely.
I also learned something interesting, when you have the SETP parameter for lines in order set to off / not in order, when you load a program into the CNC memory (not DNC, just a transfer) it adds line numbers, even though there may already be line numbers.
I found that any line, when run from memory, that has two line numbers e.g. N10 N310 #V1=0 (or any other macro statement) gets ignored by the control, but lines with two line numbers e.g. N10 N320 G0 X0, get executed. interesting.
problem still not solved tho
