That's a nice website.
Where did you get the plans for the controller board?
I've been a member for a while, I'm proficient in Solid Works and ok in Solid Edge. I've owned and operated a dyna benchtop CNC mill and am currently working on building a small mill.
I'd like to learn Mastercam.
I am in need of getting a few parts machined for the mill I'm building, but I've found it very difficult to get anything made here in Calgary due to the fact that most machinists are tied up with oil related machining. If anyone knows of a retired machinist in the Calgary Alberta area that might be willing to help me get my mill done, please let me know. There are four pieces and they're all fairly simple. I have all the parts completely drawn up in Solid Works and ready to go.
Great forum,
-Dan Gates
There are 10 types of people in this world, those who understand binary and those who do not.
Helllo All,
Just a quick note to introduce myself.
I found the "Printing, Scanners, Vinyl cutting and Plotters" forum here and thought I'd join in.
I'm looking to purchase an import vinyl cutter to do some sign work, which I've been outsourcing. Banners, window signs, vehicle lettering and such. I'd also like to cut heat transfer materials for t-shirts and do some stencil cutting for rhinestone designs.
But enough about me. I'm here to learn and hopefully avoid some of the pitfalls branching out can get you into.
This looks like just the place to rub elbows with like minded entrepreneurs. I think I'll like it here. :wave:
So long for now and GOD bless,
Richard
R&B Photo & Promo
OEM leader of waterjet cutter manufacturing factory, Nanjing Bitong Technology Co.,Ltd
The model WC5WA3020H
The high pressure pump:
Pump type: dual plunger reciprocal intensifier.
Intensifier driven by: hydraulic pump.
Max pressure: 55,000psi (380Mpa).
Max water flow rate: 0.8Gal/min (3.2L/min).
Attenuator 0.35Gal (1.4 Liters).
Cooling method: forced water. Or oil chiller as an option
Hydraulic fluid tank capacity: 42Gal (170L).
Water filter: 2 stage filtration included inside the pump unit.
Power source: 3 phase, 380VAC, 50Hz (or 220V 60Hz), 37kw
Form size: 60" x 36"x 55"(1600 x900 x1400mm), weight 1100kg.
Protective automatic shut off under the following circumstances:
Over pressure limit.
Over temperature limit.
Electrical circuitry enables soft start of the motor that lowers the instantaneous current requirement for electricity power supply.
CNC cutting table:
The table consists of water tank, X-Y motion system, Z axis motion, cutting head assembly, and abrasive reservoir with adjustable abrasive feed control. Overpass style. Cutting table working area size: 78"x130" (2000x3000mm). Water tank is made of stainless steel.
from china
