587,655 active members*
3,567 visitors online*
Thread: Hoss's G0704
Page 273 of 344 173223263271272273274275283323
Results 5,441 to 5,460 of 6871
  1. #5441
    Here's what was supposed to be a short video of a bit of the console functions but oh well.
    Hoss
    G0704 Mill Console Intro - YouTube
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #5442
    Jan 2010
    151
    That is way cool hoss! Everything there but the kitchen sink.
    am
  3. #5443
    Thanks, the sink is coming.
    Hoss
  4. #5444
    Nov 2009
    4415
    Hoss, I was watching that console video. At 1 point you change the feed rate over ride by manually turning a potentiometer or encoder and you can visually see the DRO for it move.
    I would like to implement a few manual buttons on my lathe in the next rendition of wiring. Manual feed rate over ride is 1 of them. Mostly to mimic the original flexibility of the lathe. Was this done using keygrabber? I dont see the options in hotkeys and really havent ventured into or understood OEM's and VB scripting etc. Was that a pot or encoder that you used? How many inputs did it require if that was the method of communication? 2 or 3?
  5. #5445
    It uses a 0-5k ohm iirc pot connected to the same place as little pot on the logitech controller, see keygrabber setup page 3 here.
    Projects 2
    Hoss
  6. #5446
    I still had the controllers hooked up for things like that pot that use keygrabber but most everything else is hooked up to my Pokeys board, very simple and loads of possibilities.
    Hoss
  7. #5447
    Nov 2009
    4415
    I wondered about that. Pokeys has 51-56 I/O's IIRC and uses a plug in. Do you notice 1 being more responsive than the other? I am running the ESS on this. It gives me 3 potential ports. I thought I would just use a few additional pins of 2 & 3. That would work too wouldn't it?
    A lazy man does it twice.
  8. #5448
    Never noticed any kind of lag using either keygrabber or pokeys, works the instant the button is pushed.
    Have not tried to hook a pot up any other way than keygrabber.
    Hoss
  9. #5449
    Mar 2012
    189
    Hoss,
    Really like the console. Looks like you printed almost everything on the front? Is each control group a modular box or just covers?
    I ordered your belt drive dvd download last night. Quality machine tools indicated a non-specific number of around $200 for the 1100 watt motor and made it sound like he didn't really want to sell one, so I will probably do the treadmill motor.
    -Jon
  10. #5450
    Yes I printed most of the panels on the console, they are open back, more room for the wires.
    Got my 200 psi compressor today, looks like it will do the job nicely and only $138 on ebay.
    Hoss
    200 PSI Air Compressor for my Power Drawbar - YouTube
    Attached Thumbnails Attached Thumbnails 100_5063_cropped_481x600.jpg   100_5064_800x600.jpg   100_5070_cropped_715x600.jpg
  11. #5451
    Nope, after checking the push-to-connects are rated @150 psi and the tubing only 120 psi but put in a quick order to Mcmaster and I'll have both rated to 300 psi tomorrow.
    Hoss
  12. #5452
    Jan 2014
    4
    Hi all -- new to the forum and relatively new to machining. Just unboxed and cleaned the cosmo off of my G0704. Grizzly shipped next day and FedEx had it to me undamaged on the 3rd business day. I was worried about damage and poor factory QC, but I have to say, mine looks pretty good. It's dated 12/2013 and has the 3-bolt head mod already done. I also see an empty threaded hole on the rear bottom right of the head. Not sure if that is for a (not included) tramming block or there for another reason.
    Thanks very much to Hoss and the rest of the community. I've followed many of these threads with great interest. I see a spindle lock, belt drive and CNC conversion in my future. I'm looking forward to more info on the Phase 3 conversion with double ball nuts.
    Sorry for the hi-jack, carry on! Thanks.
  13. #5453
    Nov 2009
    4415
    adam, ditch the spindle lock idea. Use Hoss' original manual tool changing method with the flip up bar and the TTS collet.
  14. #5454
    Nov 2013
    39
    What size Kurt "style" milling vise is appropriate for these machines?
    I don't want to waste space in any direction I don't have to, or put more weight on the table than is advisable.
    Bill
  15. #5455
    Thanks Adam, welcome aboard!
    Bill, a 4 inch is good for the stock mill, I use a 5 inch for mine with extended travels.
    Bunch of links under accessories here.
    g0704.com
    Hoss
  16. #5456
    Nov 2013
    39
    Do people prefer the machined-on-all-sides style?
    In the cheaper style, are Shars and Grizzly about the same quality wise?
    Quote Originally Posted by hoss2006 View Post
    g0704.com
    Hoss
  17. #5457
    Nov 2009
    4415
    I will vouch for Shars (Grizzly's machines seem nice too so I am guessing their QC on vises is decent too). They arent Kurt I am sure, but they are well built, functional, reasonably priced and mine is as flat and square as I can measure. My indicator only goes to .0005 though ;-)
  18. #5458
    Aug 2010
    630
    Quote Originally Posted by wrljet View Post
    I'm glad someone brought this up. I have a Shars 5". I have it mounted using the lugs. It over hangs the back of the table. The lip of the vise that is. Was wondering of someone tried a Tormach 5" CNC style vise on a G0704? I'm wanting to switch to one of those.
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
  19. #5459
    Jul 2010
    60
    My PM25MV came with a 3" but I got a 4" after running out of capacity on the 3" and seems to fit it perfectly and not too big, unfortunately machine shop stuff is hard to guage size from pictures as things just get scaled up or down. I think the 5" would have been a tad bigger than I needed and would have eaten up a bit of my envelope.
  20. #5460
    Nov 2009
    4415
    Quote Originally Posted by Connor View Post
    Turn it sideways?
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
