587,905 active members*
3,199 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How to cut 20 start thread with single point tool on OTA control
Results 1 to 3 of 3
    Feb 2013
    1
    Post How to cut 20 start thread with single point tool on OTA control
    I have to cut 20 start RH threads on OD of 85.5,pitch 3.0, minor dia 82.5, thread length 18 mm, I have never used threading,Pl guide me and if possible make a sample program for above data.Thanks
    Aug 2010
    190
    Whats up, do you use mach 3? Download the free demo version, select mach3turn, hit estop at the bottom left, goto wizards at the top, select threading, and enter your information, press save and post code, then exit. To get the code you can manually type it into a txt or load it into your machine, I think you can edit the text too by clicking 'EDIT'.
    Good luck!
    Feb 2013
    1
    Thanks ! Ishall try it .
    [email protected]
  1. single point thread?
    By elsanch in forum CNC Swiss Screw Machines
    Last Post: 07-06-2012, 05:20 PM
  2. Single point od thread in 1018
    By CJdave in forum MetalWork Discussion
    Last Post: 11-09-2010, 03:59 AM
  3. single point thread milling
    By sensph in forum Rhinocam
    Last Post: 07-06-2009, 09:10 AM
  4. Single Point Diamond Tool Relapping
    By ImanCarrot in forum Toolgrinding / Toolgrinding Machines
    Last Post: 11-14-2005, 05:27 PM
  5. Thread milling single point tool
    By Ikon in forum MetalWork Discussion
    Last Post: 08-22-2005, 11:15 PM
