587,772 active members*
3,410 visitors online*
Results 1 to 9 of 9
    Jun 2013
    8
    two aluminum molds ( for composite parts , simple molds )
    Hello , im looking for someone who can make these two molds i've made in solidworks.
    I dont know what type of file you guys want so , send me a PM and i'll do the conversion asap and just in case the PM box fills this is my email : [email protected]
    the dimensions of the mold are : 680 x 355 x 15 millimeters , and the second one : 718 x 355 x 15 millimeters
    and they need to be shipped to Puerto Rico
    thank you
Name:	mold 1 pic.jpg
Name:	mold 2 pic.jpg
    Apr 2006
    3498
    What material? i mean what grade of Aluminum? and tolerances of machined parts etc
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Jun 2013
    8
    about aluminum , the one with the most corrosion resistant
    and about tolerance , i dont know about that , i think it would be , 0.30mm , this molds are a prototype , depending how the part pulls out , ill be making adjustments , and ill require a new mold
    Apr 2006
    3498
    Okay,
    Is it possible for you to make it on MDF and check?... Just for cost saving..post the 3d model so that values (dimensions) may be extracted..we do not know the draft angle and Z-depth...
    Jun 2013
    8
    i can send you the .igs file if you want
    the thing with mdf is that the mold was created to pull the outer part of the original , MDF cant be used for composites because in the curing process , it will expand , and lets not forget that i have to put some tooling gelcoat to the mdf , so i have to make the mold like .5 - 1mm bigger , for the tooling gelcoat
    sometimes the main part is made out of MDF and we do the mold out of it , but since we got now SW , we just do it digitally
    Jun 2013
    8
    the RFQ is still open
    Jan 2014
    5
    Can you send all information and files to [email protected]
    I would like to quote on this.
    Thanks,
    Mike
    Email sent.
    Thank you for your time.
    Jun 2013
    8
    RFQ is close
  1. Aluminum molds for thermoforming
    By fer_mayrl in forum Vacuum forming, Thermoforming etc
    Last Post: 01-03-2011, 12:09 AM
  2. Aluminum molds for sole
    By dane in forum Moldmaking
    Last Post: 08-03-2008, 01:35 PM
  3. Aluminum molds for Ultem???
    By implmex in forum Moldmaking
    Last Post: 06-27-2008, 03:47 AM
  4. Question on permanent molds for aluminum
    By CPS in forum Casting Metals
    Last Post: 07-29-2006, 12:35 PM
  5. Need info on molds for aluminum
    By carbidecraters in forum Moldmaking
    Last Post: 06-24-2005, 05:39 AM
