587,125 active members*
2,538 visitors online*
Results 1 to 6 of 6
    Nov 2013
    78
    Polygon turning
    Does this mean I can turn a round shape into a hexagon on a Cnc lathe that would be great but I assume the attachments are expensive , any info on this subject.would be greatly appreciated
    Using Tapatalk
    Jun 2004
    355
    It requires live tooling. It can be done either via a sycnronised serveo, or some machines use a mechanical drive from the spindle.
    One key point to remember is it doesn't produce perfect flats. If you search for Horn polygon milling tools, they have a catalogue which lists the possible/recommended shapes possible.
    Dec 2013
    34
    Check out eurotechs if you're doing production.
    Russ
    Nov 2013
    78
    Thanks guys will look in to this
    Using Tapatalk
    Oct 2012
    87
    Also try this company,
    I use there polygon cutters on some Index Multi spindle lathes.
    http://www.mas-tools.de/en_engineering_polyturn.php
    Alan
    Nov 2013
    78
    Thanks alsn
    Using Tapatalk
  1. Mori Lathe Polygon Turning
    By DIFF OVER in forum Mori Seiki lathes
    Last Post: 04-13-2013, 04:06 AM
  2. Formula for Polygon turning of a hex
    By chet470 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-24-2011, 04:48 AM
  3. Here is simple polygon turning program
    By yatin555 in forum G-Code Programing
    Last Post: 09-06-2010, 01:57 PM
  4. POLYGON TURNING
    By Stebedeff in forum G-Code Programing
    Last Post: 09-25-2008, 02:31 PM
  5. True Polygon CNC Turning Offered
    By npkaye in forum News Announcements
    Last Post: 09-30-2007, 09:11 PM
