Originally Posted by
quapman
OK, I tweaked the pots and the howling is almost 100% gone. Finishes seem a little better, but your spindle bearing theory seems sound. Ugh. Can a spindle be rebuilt or do I need a new assembly?
All was well until I got repeated limit switch alarms. I knew the X switch was bad (plunger is GONE!), so I removed it and tied the wires together for now. MORE limit alarms! Ugh. Took the Y switch out, opened it up and YUCK! Full of crusty coolant and rust. Bypassed that one and planning on fabbing up a bracket to use a the newer style switch. Fun, fun, fun.
Is that bracket available to purchase? Should be the one from 3 digit and newer machines.
