I am trying to carve some grape vines with my cnc. Does anyone have some grape cluster in dxf. thanks
Hi I'm new to this website and wondering if anyone has any clock plans in dxf they would like to share
Thank you
Hi Dave, try the following website
Home
I hope this is not inappropriate. If this request is inappropriate, please delete this post. Can someone generate g code for me. I don't know how to do it with the software I have. I have Mach3 running my cnc router and I would like to machine this in aluminium with a .125" ball endmill.
I would like to make the two swoosh a pocket, but the narrow side is at zero and the bigger end would be .15" deep.
Thanks in advance.
Attachment 204298
What type of software do you have? What cnc machine do you have?
wondering if it is possible to change this to a dxf ?
Just wondering what program you guys use for converting pictures to DXF?
Am trying to make a custom bicycle sprocket for a friend.
Attachment 204478
J. Marti
If you are looking for shareware try Inkscape or Win-topo.
Your artwork is terrible, much higher resolution is necessary if you want crisp lines.
Hope this helps,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Since I don't have more information, here it is the g-code for the 2 rail, you will have to edit the speeds, like:
N20G0X0Y0Z1
N40T1M6
N50(0.125 INCH BALL NOSE)
N80G0X0.000Y0.000S???????????????????????????????? ?????????M3 (spindle speed)
N90G0X0.404Y0.918Z0.539
N100G1Z0.000F????????????????????????????????????? ????????? (machining speed)
and any initial set up for your machine
if some one try it please show it here
Edit: it is to be machine in INCHES
Alberto
Anyone know if there is a font similar to Susa, for free download ?
My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
Have you tried using Identifont?
Identifont - Susa
Jeff...
