587,487 active members*
3,662 visitors online*
Results 1 to 20 of 20
    Jul 2013
    13
    Autoleveller software
    Hi guys,
    I have created some software which is compatible with LinuxCNC and which might interest you. It uses the probe to measure the Z height precisely at many points on the surface and modifies a GCode file to calculate a more accurate tool height during the etching process.
    When milling a PCB I would get very uneven results before I wrote the software, with large areas of my PCB completely untouched by my tools. An autolevelling software seemed to be the best idea, but there didnt seem to be too many around, certainly none that were particularly easy to setup or use. Therefore I created my own autoleveller software: AutoLeveller - The height adjusting CNC software.
    This helped me, helped others and will hopefully help many more. Here are some pics from my site which hopefully demonstrate what the software does.
    A circuit milled without autolevelling:
    Attachment 203436
    A circuit milled after autolevelling:
    Attachment 203438
    My site contains a couple of videos,so check them out if you are interested. As the 2nd video demonstrates, you are not limited to PCB's either. If it has a metal surface then you can probe it and you can level it.
    Check out my site to see other benefits, instructions and to download it - its free and open source. Its written in Java so it will run in Linux as well.
    If there are any issues with the software, let me know here or on my own forum. I am happy to help www.autoleveller.co.uk/forum.
    Sine the probe is so fundamental to the autolevelling process, I made a quick guide for setup: www.autoleveller.co.uk/probeGuide.html
    best,
    James.
    Jun 2007
    3735
    Nice idea, and I like it,
    but the java interface, and non standard windows browse for instance, is just awful (IMHO)
    I have used a surround pressure brush system like the big machines use, that push the PCB down against the base to maintain even height.
    Just a few pins to locate PCB and that is it.
    Mechanically, when Z moves below a certain level, air is applied to cylinders pressing the ring brush down.
    There are quick release clips to remove brush to change tool bits.
    Requires no modification of code, and just works. It clips onto the quill of my mill.
    This is where I got the idea.
    Here is what the big machines do, I caught on video. Sorry it's a bit jerky. Phones are meant for voice. (nuts)
    PCB Drill-router.MOV - YouTube
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Jul 2013
    13
    Thanks Neil,
    The surround pressure is a great idea and a new one on me. I have heard a lot of talk about using vacuum tables for this, but not a pressure brush, looks like a good solution though.
    The only thing I would say is that, you do not need to modify the GCode but u did obviously need to modify you machine a bit. With my software solution there is no need to get your hands dirty, and its free.
    Using Java means it runs on any OS, Windows, Linux, Mac but of course the interface can always be improved. Can you give me any ideas where it needs to improve?
    thanks very much for the feedback,
    James.
    Jun 2007
    3735
    Try as I might, I can't seem to create or modify a file.
    It offered a save file menu, but no file was created. What have I done wrong?
    How does it handle the deep routed paths for the outline?
    Here is the code I tried, which was generated by my PCB editor, and works fine in Mach3.
    Code:
    ( ---- \\_XQK\\PCB\\CPAP\\HEAT1206.NC ----)
    (G-Code generation for : HEAT1206.BPC)
    /G52 X0 Y0 Z0 (CANCEL any CRAZY SCALING)
    G0 G80 G90.1 G17 G64
    G59 P12 (Pxx TABLE NUMBER HERE)
    #500=500 (FEED TO Z SAFE)
    #501=150 (FEED TO G81 DRILLING)
    #502=150 (FEED FOR ENGRAVING)
    #505=300 (FAST ENGRAVING IN FILL)
    #503=20 (FEED FOR ROUTING)
    #600=0.00  (CURRENT X LOCATION)
    #700=0.00  (CURRENT Y LOCATION)
    (== 1.40 PCB Material ==)
    #800=12.70 (Z SAFE at RAPID)
    #801=2.45  (G81 Z RETRACT)
    #802=-0.11 (Z ENGRAVE)
    #803=-1.80 (G81 DRILL DEPTH)
    #804=-1.60 (G1 ROUTER DEPTH)
    #805=2.00  (G1 Z RETRACT)
    #806=12.70 (FINAL RETRACT HEIGHT AT FINISH)
    #666=0.35 (ENGRAVING CUTTER DIAMETER)
    (----- END of VARIABLE SETUP -----)
    (--- START OF MACHINE MOVEMENT ---)
    G0 Z#800 (FIRST MOVE ALWAYS UP TO SOMEWHERE SAFE)
    G0 X#600 Y#700
    (0.35mm ENGRAVING CUTTER)
    M6 T1 (INSERTED ENGRAVING CUTTER at Z0)
    (SET ZERO TOP OF PCB, CYCLE START)
    M3 S3600
    M00 (TURN ON MOTOR 3600RPM)
    G0 Z#800 (SAFE RAPID)
    G1 Z#801 F#500 (FEED DOWN TO RETRACT)
    F#502(START OF ENGRAVING)
    G0 X-0.076 Y-2.337
    G1 Z#802  (Z ENGRAVE)
    G1 Y-2.159
    X-1.981
    Y-19.152
    X-0.076
    Y-2.413
    X-1.727 F#505
    Y-18.898
    X-0.330
    Y-2.667
    X-1.473
    Y-18.644
    X-0.584
    Y-2.921
    X-1.219
    Y-18.390
    X-0.838
    Y-3.175
    X-1.016
    Y-18.136
    F#502
    G0 Z#801 (RETRACT UP)
    G0 X-0.381 Y-19.228
    G1 Y-19.050
    X-0.889
    Y-29.108
    X-0.381
    Y-19.304
    X-0.635
    Y-28.854
    X-0.457 Y-29.007
    X-2.134
    Y-39.573
    X-0.457
    Y-29.261 F#505
    X-1.880
    Y-39.319
    X-0.711
    Y-29.515
    X-1.626
    Y-39.065
    X-0.965
    Y-29.769
    X-1.372
    Y-38.811
    X-1.219
    Y-30.023
    X-1.295
    Y-38.557
    F#502
    G0 X-2.286 Y-38.811
    G1 Y-38.633
    X-2.515
    Y-39.548
    X-2.286
    Y-38.887
    X-2.388
    Y-39.294
    G0 X-2.311 Y-38.608
    G1 Y-37.236
    G0 X-2.540 Y-37.160
    G1 Y-38.379
    X-13.462
    X-13.894 Y-38.837
    X-14.529 Y-39.268
    X-15.088 Y-39.497
    X-15.723 Y-39.599
    X-15.748 Y-39.548
    G2 X-18.466 Y-36.830 I-15.748 J-36.830
    G1 X-18.339 Y-36.043
    X-18.034 Y-35.382
    X-17.932 Y-35.230
    Y-25.857
    X-16.510 Y-25.883
    Y-20.447
    X-49.505
    X-61.874 Y-0.203
    G0 X-39.573 Y-0.254
    G1 Y-0.076
    X-62.128
    Y-1.245
    X-39.573
    Y-0.330 F#505
    X-61.874
    Y-0.991
    X-39.827
    Y-0.584
    X-61.620
    Y-0.737
    X-40.081
    Y-0.660
    X-61.366
    F#502
    G0 X-39.954 Y-1.118
    G1 X-39.116 Y-1.956
    G0 X-2.388 Y-0.127
    G1 Y0.051
    X-39.319
    Y-1.727
    X-2.388
    Y-0.203
    X-39.065 F#505
    Y-1.473
    X-2.642
    Y-0.457
    X-38.811
    Y-1.219
    X-2.896
    Y-0.711
    X-38.557
    Y-0.965
    X-3.150
    Y-0.838
    X-38.303
    F#502
    G0 X-3.658 Y-0.965
    G1 X-1.981 Y-2.540
    G0 X-1.930 Y-2.997
    G1 X-3.454 Y-1.397
    G0 X-3.658 Y-1.575
    G1 X-1.930 Y-3.327
    G0 X-1.905 Y-3.683
    G1 X-3.708 Y-1.880
    G0 X-4.191 Y-1.778
    G1 Y-2.159
    G0 X-5.842
    G1 Y-1.981
    X-7.341
    Y-3.480
    X-5.842
    Y-2.235
    X-7.087
    Y-3.226
    X-6.096
    Y-2.489
    X-6.833
    Y-2.972
    X-6.350
    Y-2.718
    X-6.579
    G0 X-5.867 Y-3.454
    G1 Y-4.013
    X-4.877 Y-3.988
    X-6.655 Y-4.039
    G0 X-6.960 Y-3.810
    G1 X-4.902
    X-4.343 Y-4.369
    Y-4.470
    X-5.842
    Y-17.602
    X-4.343
    Y-4.724
    X-5.588 F#505
    Y-17.348
    X-4.597
    Y-4.978
    X-5.334
    Y-17.094
    X-4.851
    Y-5.232
    X-5.080
    Y-16.840
    G0 Z#801 F#502 (RETRACT UP)
    G0 X-4.115 Y-17.805
    G1 X-3.810 Y-18.085
    Y-19.152
    X-4.318
    G0 X-4.115 Y-17.805
    G1 X-8.941
    X-8.839 Y-17.932
    X-40.411
    Y-17.424
    G0 X-40.005 Y-17.526
    G1 Y-17.805
    G0 X-39.726
    G1 X-40.005 Y-17.526
    X-44.145 Y-17.501
    G0 X-44.196 Y-16.891
    G1 X-44.450 Y-16.637
    Y-14.732
    X-44.196 Y-14.605
    G0 Y-13.995
    G1 X-39.954
    Y-10.135
    X-46.076
    X-45.999 Y-10.262
    X-40.157
    Y-13.310
    X-40.284 Y-13.437
    Y-13.945
    G0 X-39.954 Y-13.995
    G1 Y-17.501
    G0 X-39.726 Y-17.805
    G1 X-8.484
    G0 X-10.566 Y-18.212
    G1 Y-18.034
    X-12.294
    Y-24.867
    X-10.566
    Y-18.288
    X-12.040 F#505
    Y-24.613
    X-10.820
    Y-18.542
    X-11.786
    Y-24.359
    X-11.074
    Y-18.796
    X-11.532
    Y-24.105
    X-11.328
    Y-19.050
    X-11.430
    Y-23.851
    G0 X-10.490 Y-23.876
    G1 Y-23.622
    G0 Y-21.717
    G1 X-3.632
    X-3.124
    Y-20.828
    X-2.616
    X-2.413 Y-20.625
    X-2.210
    Y-27.584
    X-3.556
    Y-29.362
    X-3.937
    Y-36.881
    X-13.005
    X-13.106 Y-37.313
    X-3.581
    Y-37.160
    X-3.683 Y-37.084
    X-13.081
    X-13.056 Y-36.906
    Y-36.449
    X-13.157 Y-35.941
    X-13.360 Y-35.433
    X-13.792 Y-34.976
    X-14.122 Y-34.646
    X-14.605 Y-34.392
    X-15.088 Y-34.188
    Y-27.407
    X-10.770
    G0 X-10.897 Y-27.584
    G3 X-6.731 Y-31.750 I-10.897 J-31.750
    G0 X-6.960 Y-31.877
    G1 Y-29.947
    X-7.264
    Y-30.404
    X-7.137 Y-30.937
    G0 X-7.417 Y-30.582
    G1 X-7.290 Y-31.471
    X-7.315 Y-31.902
    X-7.290 Y-31.750
    G2 X-10.897 Y-28.143 I-10.897 J-31.750
    G0 Y-27.864
    G3 X-7.010 Y-31.750 I-10.897 J-31.750
    G0 X-7.417 Y-30.582
    G1 X-7.696 Y-30.124
    Y-26.695
    Y-26.873
    Y-26.365
    X-6.071
    Y-26.645
    G0 X-7.087 Y-27.635
    G1 Y-27.457
    X-7.493
    Y-30.023
    X-7.087
    Y-27.711
    X-7.290
    Y-29.769
    G0 X-3.378 Y-26.772
    G1 Y-26.594
    X-7.595
    Y-27.457
    X-3.378
    Y-26.848
    X-7.341
    Y-27.203
    X-3.632
    Y-27.026
    X-7.087
    G0 X-4.064 Y-27.737
    G1 Y-27.559
    X-4.648
    Y-36.678
    X-4.064
    Y-27.813
    X-4.394
    Y-36.424
    X-4.318
    Y-28.067
    X-4.343
    Y-36.170
    G0 X-3.912 Y-35.789
    G1 X-2.134
    Y-35.281
    X-4.166
    G0 Y-35.535
    G1 X-1.880
    G0 X-1.930 Y-33.909
    G1 X-2.438
    Y-33.147
    X-1.930
    G0 X-3.607
    G1 X-4.115
    G0 X-3.607
    G1 Y-33.909
    X-3.962
    G0 X-3.861 Y-31.394
    G1 Y-31.140
    X-2.083
    G0 Y-31.394
    G1 X-3.861
    G0 X-3.835 Y-29.362
    G1 Y-27.584
    G0 X-2.261 Y-21.107
    G1 Y-20.930
    X-3.099
    Y-27.356
    X-2.261
    Y-21.184 F#505
    X-2.845
    Y-27.102
    X-2.515
    Y-21.438
    X-2.667
    Y-26.848
    G0 X-3.023 Y-26.645
    G1 X-3.048 Y-26.365
    G0 X-2.515 Y-28.778
    G1 Y-29.362
    X-2.108
    Y-37.160
    X-2.540
    G0 X-2.794 Y-38.811
    G1 Y-38.633
    X-13.310
    Y-39.649
    X-2.794
    Y-38.887 F#505
    X-13.056
    Y-39.395
    X-3.048
    Y-39.141
    X-12.802
    G0 X-0.203 Y-39.776
    G1 X-18.745
    G0 Y-40.030
    G1 X-0.203
    Y-39.776
    G0 X-0.178 Y-40.335
    G1 X-18.745
    Y-40.030
    G0 X-19.253 Y-39.599
    G1 X-17.602
    G0 X-17.907 Y-39.853
    G1 X-18.872 Y-38.964
    G0 X-18.720 Y-36.830
    G3 X-15.748 Y-39.802 I-15.748 J-36.830
    G0 Y-40.056
    G2 X-18.974 Y-36.830 I-15.748 J-36.830
    G0 X-19.228
    G3 X-15.748 Y-40.310 I-15.748 J-36.830
    G0 X-15.037 Y-39.675
    G1 X-14.148
    X-14.173 Y-39.319
    G0 X-14.046 Y-39.675
    G1 X-13.970 Y-38.964
    X-14.554 Y-39.497
    X-15.037 Y-39.675
    G0 X-14.046
    G1 X-13.716 Y-39.700
    X-13.691 Y-38.938
    X-13.437 Y-38.608
    X-13.462 Y-39.827
    G0 X-6.934 Y-35.839
    G1 Y-35.662
    X-12.675
    Y-36.576
    X-6.934
    Y-35.916 F#505
    X-12.421
    Y-36.322
    X-7.188
    Y-36.119
    X-12.167
    G0 X-6.883 Y-34.646
    G1 Y-34.468
    X-7.849
    Y-35.585
    X-6.883
    Y-34.722
    X-7.595
    Y-35.331
    X-7.137
    Y-34.976
    X-7.366
    Y-35.077
    G0 X-7.823 Y-35.103
    G1 X-6.883 Y-33.960
    G0 Y-33.477
    G1 X-7.747 Y-34.773
    X-8.763 Y-35.662
    G0 X-8.382 Y-35.560
    G1 X-7.823 Y-35.103
    G0 X-12.878 Y-36.500
    G1 X-13.056 Y-35.255
    G0 X-14.148 Y-34.417
    G1 X-14.808 Y-34.112
    Y-33.426
    X-14.529 Y-34.214
    G0 X-18.085 Y-34.925
    G1 X-18.491 Y-34.849
    Y-35.687
    G0 X-18.567 Y-36.093
    G1 X-18.085 Y-34.925
    G0 X-14.808 Y-30.277
    G1 Y-27.711
    X-11.862
    G0 X-11.379 Y-28.143
    G1 X-10.541
    Y-26.416
    X-12.319
    Y-26.568
    X-15.113
    X-15.367 Y-26.314
    Y-19.609
    X-15.723 Y-19.253
    G0 X-15.469 Y-19.152
    G1 X-40.411
    Y-19.355
    X-41.656
    X-42.926
    X-44.196
    Y-12.014
    X-41.656
    Y-14.300
    G0 X-42.926
    G1 Y-12.014
    G0 X-42.621 Y-10.643
    G1 Y-10.465
    X-43.231
    Y-11.760
    X-42.621
    Y-10.719
    X-42.977
    Y-11.506
    X-42.875
    Y-10.973
    X-42.926
    Y-11.252
    G0 X-43.561 Y-9.017
    G1 Y-8.763
    G0 X-43.231 Y-6.629
    G1 Y-6.452
    X-43.891
    Y-6.833
    X-43.231
    Y-6.629
    X-43.637
    G0 X-43.231 Y-4.724
    G1 Y-4.547
    X-43.891
    Y-4.953
    X-43.231
    Y-4.750
    X-43.637
    G0 X-43.561 Y-2.667
    G1 Y-2.413
    G0 Y-1.524
    G1 Y-1.270
    G0 X-46.355
    G1 Y-1.524
    G0 Y-2.413
    G1 Y-2.667
    G0 X-46.025 Y-4.724
    G1 Y-4.547
    X-46.685
    Y-4.953
    X-46.025
    Y-4.750
    X-46.431
    G0 X-46.025 Y-6.629
    G1 Y-6.452
    X-46.685
    Y-6.858
    X-46.025
    Y-6.655
    X-46.431
    G0 X-46.355 Y-8.763
    G1 Y-9.017
    G0 X-45.644 Y-10.135
    G1 X-48.819
    Y-10.236
    Y-6.223
    X-49.047 Y-5.994
    Y-5.867
    X-51.333
    Y-6.883
    X-46.076 Y-15.646
    Y-16.815
    X-47.777
    Y-15.545
    X-48.717 Y-13.995
    X-49.555
    Y-12.725
    X-50.444 Y-11.176
    X-51.359
    Y-9.703
    X-52.146 Y-8.382
    X-53.086
    Y-6.782
    X-53.696 Y-5.766
    X-54.381
    Y-4.242
    G0 X-40.894 Y-2.997
    G1 Y-2.819
    X-54.686
    Y-4.267
    X-40.894
    Y-3.073
    X-54.432 F#505
    Y-4.013
    X-41.148
    Y-3.327
    X-54.178
    Y-3.759
    X-41.402
    Y-3.531
    X-53.924
    G0 X-41.072 Y-3.581
    G1 Y-4.851
    X-40.132
    X-40.818 Y-4.166
    Y-4.572
    X-40.538
    G0 X-40.005 Y-4.648
    G1 X-41.072 Y-3.581
    G0 X-40.767 Y-2.921
    G1 Y-2.413
    G0 X-37.846 Y-2.210
    G1 Y-2.032
    X-39.319
    Y-3.150
    X-37.846
    Y-2.286
    X-39.065
    Y-2.896
    X-38.100
    Y-2.540
    X-38.811
    Y-2.642
    X-38.354
    Y-2.591
    X-38.583
    G0 X-37.871 Y-3.302
    G1 Y-3.734
    G0 Y-3.531
    G1 X-38.913
    G0 X-38.583 Y-3.861
    G1 X-38.456 Y-3.988
    X-36.932
    X-37.821
    G0 X-38.125 Y-4.470
    G1 X-36.398
    X-36.297 Y-4.572
    X-37.008 Y-3.861
    X-38.583
    G0 X-38.862 Y-4.191
    G1 X-36.322
    G0 X-36.347 Y-4.851
    G1 Y-4.674
    X-37.795
    Y-17.628
    X-36.347
    Y-4.928
    X-37.541 F#505
    Y-17.374
    X-36.601
    Y-5.182
    X-37.287
    Y-17.120
    X-36.855
    Y-5.436
    X-37.059
    Y-16.866
    G0 X-35.941 Y-15.367
    G1 X-38.227
    G0 X-39.624
    G1 X-40.005
    G0 X-41.656 Y-17.094
    G1 Y-19.355
    G0 X-42.926
    G1 Y-17.094
    G0 X-45.339 Y-17.526
    G1 Y-19.050
    X-45.593
    Y-17.526
    X-45.720
    X-45.339
    G0 X-45.847 Y-17.399
    G1 Y-17.221
    X-46.812
    Y-18.796
    X-45.847
    Y-17.475
    X-46.558
    Y-18.542
    X-46.101
    Y-17.729
    X-46.330
    Y-18.288
    G0 X-46.965 Y-18.390
    G1 X-46.939 Y-17.297
    X-47.727
    X-47.041 Y-17.983
    X-47.244 Y-17.348
    G0 X-47.930 Y-17.145
    G1 X-45.898
    Y-10.312
    X-48.997
    G0 X-49.098 Y-9.754
    G1 X-48.514 Y-10.643
    X-46.076
    Y-14.580
    X-48.387 Y-10.795
    G0 X-48.133 Y-10.744
    G1 X-46.177 Y-13.970
    G0 X-45.593
    G1 X-45.339
    Y-12.065
    X-45.593
    Y-13.970
    G0 X-45.923 Y-15.265
    G1 X-51.130 Y-6.807
    Y-6.172
    X-49.098
    Y-9.754
    G0 X-49.301 Y-8.890
    G1 Y-8.712
    X-49.632
    Y-9.322
    X-49.301
    Y-8.966
    X-49.454
    Y-9.068
    G0 X-40.005 Y-7.315
    G1 Y-7.137
    X-50.089
    Y-8.611
    X-40.005
    Y-7.391
    X-49.835 F#505
    Y-8.357
    X-40.259
    Y-7.645
    X-49.581
    Y-8.103
    X-40.513
    Y-7.874
    X-49.327
    G0 X-40.767 Y-8.763
    G1 Y-9.017
    G0 X-40.005 Y-5.105
    G1 Y-4.928
    X-41.072
    Y-6.858
    X-40.005
    Y-5.182
    X-40.818 F#505
    Y-6.604
    X-40.259
    Y-5.436
    X-40.564
    Y-6.350
    X-40.513
    Y-5.690
    X-40.538
    Y-6.096
    G0 X-40.005 Y-6.985
    G1 X-39.624
    G0 X-38.227
    G1 X-35.941
    G0 X-33.655
    G1 X-31.369
    G0 X-31.775 Y-5.080
    G1 Y-4.902
    X-33.249
    Y-17.602
    X-31.775
    Y-5.156
    X-32.995 F#505
    Y-17.348
    X-32.029
    Y-5.410
    X-32.741
    Y-17.094
    X-32.283
    Y-5.664
    X-32.512
    Y-16.840
    G0 X-31.369 Y-15.367
    G1 X-33.655
    G0 Y-12.573
    G1 X-31.369
    G0 X-29.083
    G1 X-26.797
    G0 X-24.511
    G1 X-22.225
    G0 X-19.939
    G1 X-17.653
    G0 X-15.367
    G1 X-13.081
    G0 X-10.795
    G1 X-8.509
    G0 X-6.223
    G1 X-3.937
    G0 X-2.413
    G1 X-1.905
    G0 Y-9.779
    G1 X-2.413
    G0 X-3.937
    G1 X-6.223
    G0 X-8.509
    G1 X-10.795
    G0 X-13.081
    G1 X-15.367
    G0 X-17.653
    G1 X-19.939
    G0 X-22.225
    G1 X-24.511
    G0 X-26.797
    G1 X-29.083
    G0 X-31.369
    G1 X-33.655
    G0 X-35.941
    G1 X-38.227
    G0 Y-12.573
    G1 X-35.941
    G0 X-39.624
    G1 X-40.005
    X-40.132 Y-12.065
    X-40.513
    G0 X-45.339 Y-10.287
    G1 X-45.720
    X-45.644 Y-10.211
    Y-19.050
    X-46.939
    X-49.047 Y-16.942
    Y-16.688
    X-49.301 Y-16.434
    Y-14.681
    X-49.911
    X-51.029 Y-12.929
    Y-11.913
    X-51.689
    X-52.832 Y-10.109
    Y-9.093
    X-53.518
    X-54.610 Y-7.341
    Y-6.299
    X-55.270
    X-55.626 Y-5.715
    Y-3.632
    X-54.762 Y-2.769
    G0 X-54.813 Y-3.099
    G1 X-55.397 Y-3.531
    Y-6.096
    G0 X-54.407 Y-3.658
    G1 Y-3.480
    X-55.169
    Y-6.071
    X-54.407
    Y-3.734
    X-54.915
    Y-5.817
    X-54.661
    Y-3.988
    X-54.788
    Y-5.563
    G0 X-54.483 Y-5.944
    G1 X-54.508 Y-7.341
    X-53.467 Y-8.865
    X-53.492 Y-6.706
    X-54.026 Y-6.020
    X-54.280
    X-54.153 Y-7.518
    X-53.594 Y-8.407
    X-53.696 Y-6.655
    X-54.051 Y-6.096
    X-53.797 Y-8.026
    G0 X-53.975 Y-8.763
    G1 X-51.689
    G0 X-52.095 Y-8.814
    G1 X-52.781 Y-8.992
    X-52.553 Y-10.338
    X-51.689 Y-11.532
    X-51.867 Y-9.449
    X-52.375 Y-8.865
    X-52.476 Y-9.042
    X-52.273 Y-10.490
    X-51.841 Y-10.973
    X-52.045 Y-9.322
    X-52.273 Y-9.119
    X-52.095 Y-10.744
    G0 X-52.197 Y-11.557
    G1 X-50.038
    G0 X-50.444 Y-11.735
    G1 X-51.003
    X-50.775 Y-12.954
    X-49.886 Y-14.300
    X-49.911 Y-12.598
    X-50.775 Y-11.811
    X-50.495 Y-13.386
    X-50.013 Y-13.843
    X-50.165 Y-12.497
    X-50.546 Y-12.065
    X-50.267 Y-13.589
    G0 X-50.419 Y-14.351
    G1 X-48.387
    G0 X-48.539 Y-14.656
    G1 X-47.930 Y-15.596
    Y-17.145
    G0 X-48.235 Y-17.043
    G1 X-48.209 Y-15.215
    G0 X-48.489 Y-14.986
    G1 Y-16.815
    X-46.965 Y-18.390
    G0 X-46.914 Y-18.720
    G1 X-48.793 Y-16.789
    Y-14.757
    G0 X-49.047 Y-14.656
    G1 X-48.539
    G0 X-49.047
    G1 Y-16.942
    G0 X-50.571 Y-16.713
    G1 X-50.775
    Y-16.053
    X-52.095 Y-13.970
    X-52.451 Y-13.945
    Y-13.462
    X-53.924 Y-11.176
    X-54.254
    Y-10.668
    X-55.651 Y-8.407
    X-56.007
    Y-7.950
    X-57.150 Y-6.121
    G0 X-57.404 Y-6.680
    G1 X-49.022 Y-20.218
    X-48.133 Y-20.244
    X-49.936 Y-18.364
    X-48.616 Y-20.244
    G0 X-49.301 Y-20.295
    G1 X-47.625 Y-20.447
    X-50.571 Y-17.501
    Y-16.713
    G0 X-50.902 Y-16.408
    G1 X-54.026 Y-11.481
    X-55.728 Y-8.788
    X-56.921 Y-6.756
    X-57.277 Y-6.731
    X-50.749 Y-17.170
    G0 X-49.708 Y-14.300
    G1 X-49.733 Y-12.700
    X-50.444 Y-11.735
    G0 X-51.435 Y-11.481
    G1 X-51.638 Y-9.525
    X-52.095 Y-8.814
    G0 X-53.188 Y-8.687
    G1 X-53.289 Y-6.731
    X-53.873 Y-5.944
    X-54.483
    G0 X-53.721 Y-5.969
    G1 X-53.340
    G0 X-51.943 Y-4.699
    G1 Y-2.413
    G0 Y-1.524
    G1 Y-1.270
    G0 X-48.819 Y-1.651
    G1 Y-1.473
    X-49.479
    Y-2.616
    X-48.819
    Y-1.727
    X-49.225
    Y-2.362
    X-49.073
    Y-1.981
    X-49.149
    Y-2.108
    G0 Y-4.318
    G1 Y-4.699
    G0 X-49.276 Y-6.553
    G1 Y-6.375
    X-50.851
    Y-7.163
    X-49.276
    Y-6.629
    X-50.597
    Y-6.909
    X-49.530
    Y-6.756
    X-50.343
    G0 X-50.216 Y-7.595
    G1 Y-7.417
    X-50.597
    Y-7.849
    X-50.216
    Y-7.620
    X-50.394
    G0 X-47.066 Y-10.947
    G1 Y-10.770
    X-47.955
    Y-11.735
    X-47.066
    Y-11.024
    X-47.701
    Y-11.481
    X-47.320
    Y-11.252
    X-47.498
    G0 X-46.406 Y-10.973
    G1 Y-10.795
    X-47.244
    Y-13.335
    X-46.406
    Y-11.049
    X-46.990
    Y-13.081
    X-46.660
    Y-11.303
    X-46.812
    Y-12.827
    G1 X-59.512 Y-3.683
    G0 X-59.207 Y-3.581
    G1 X-58.674 Y-4.699
    X-58.750 Y-3.658
    X-59.207 Y-3.861
    G0 X-58.699 Y-1.651
    G1 Y-1.473
    X-59.868
    Y-3.607
    X-58.699
    Y-1.727
    X-59.614
    Y-3.353
    X-58.953
    Y-1.981
    X-59.360
    Y-3.099
    X-59.207
    Y-2.235
    X-59.284
    Y-2.845
    G0 X-59.919 Y-3.023
    G1 X-59.995 Y-1.219
    X-60.706 Y-1.473
    X-59.969 Y-2.489
    X-60.198 Y-1.194
    X-60.630 Y-1.270
    X-60.071 Y-2.032
    G0 X-59.919 Y-3.023
    G1 X-60.985 Y-1.295
    G0 X-57.048 Y-1.549
    G1 X-55.829
    X-56.845 Y-2.565
    Y-1.778
    X-56.363
    X-56.744 Y-2.159
    G0 X-57.048 Y-1.549
    G1 Y-2.972
    X-55.423 Y-1.346
    G0 X-54.737 Y-1.270
    G1 Y-1.524
    G0 X-57.125 Y-1.600
    G1 Y-1.422
    X-58.572
    Y-6.629
    X-57.125
    Y-1.676
    X-58.318 F#505
    Y-6.375
    X-57.379
    Y-1.930
    X-58.064
    Y-6.121
    X-57.633
    Y-2.184
    X-57.836
    Y-5.867
    G0 X-49.428 Y-20.295
    G1 X-49.251 Y-20.930
    X-17.170
    X-17.145 Y-25.171
    G0 X-16.891 Y-25.121
    G1 Y-25.298
    X-32.131
    G0 X-29.820 Y-25.578
    G1 Y-25.400
    X-31.471
    Y-26.264
    X-29.820
    Y-25.654
    X-31.217
    Y-26.010
    X-30.074
    Y-25.832
    X-30.963
    G0 X-30.023 Y-25.527
    G1 X-16.815
    Y-20.676
    X-49.428
    G0 X-38.278 Y-25.121
    G1 X-16.891
    G0 X-16.510 Y-25.756
    G3 X-17.932 Y-27.178 I-16.510 J-27.178
    G0 X-17.958 Y-26.416
    G1 X-17.501 Y-25.832
    G0 X-15.113 Y-27.407
    G1 Y-19.507
    X-15.469 Y-19.152
    G0 X-13.487 Y-4.928
    G1 Y-4.750
    X-14.961
    Y-17.653
    X-13.487
    Y-5.004
    X-14.707 F#505
    Y-17.399
    X-13.741
    Y-5.258
    X-14.453
    Y-17.145
    X-13.995
    Y-5.512
    X-14.224
    Y-16.891
    G0 X-13.233 Y-18.059
    G1 X-12.471
    Y-18.567
    X-12.979 Y-18.059
    G0 X-13.233
    G1 X-12.598 Y-18.694
    Y-19.152
    X-12.344
    G0 X-4.115 Y-18.136
    G1 Y-17.958
    X-10.566
    Y-19.152
    X-4.115
    Y-18.212 F#505
    X-10.312
    Y-18.898
    X-4.369
    Y-18.466
    X-10.058
    Y-18.644
    X-4.623
    Y-18.542
    X-9.804
    G0 X-5.969 Y-21.006
    G1 Y-20.828
    X-7.747
    Y-21.565
    X-5.969
    Y-21.082
    X-7.493
    Y-21.311
    X-6.223
    Y-21.184
    X-7.239
    G0 X-5.969 Y-24.384
    G1 Y-24.206
    X-7.696
    Y-24.867
    X-5.969
    Y-24.460
    X-7.442
    Y-24.613
    X-6.223
    Y-24.536
    X-7.188
    G0 X-10.770 Y-26.873
    G1 Y-26.695
    X-14.910
    Y-27.711
    X-10.770
    Y-26.949
    X-14.656
    Y-27.457
    X-11.024
    Y-27.203
    X-14.402
    G0 X-12.802 Y-27.788
    G1 X-14.732 Y-29.515
    G0 X-13.919 Y-28.651
    G1 Y-28.473
    X-14.707
    Y-29.159
    X-13.919
    Y-28.727
    X-14.453
    Y-28.905
    X-14.173
    Y-28.804
    X-14.300
    G0 X-13.106 Y-28.092
    G1 Y-27.915
    X-14.808
    Y-28.473
    X-13.106
    Y-28.169
    X-14.554
    Y-28.219
    X-13.360
    Y-28.194
    X-14.300
    G0 X-8.915 Y-4.877
    G1 Y-4.699
    X-10.389
    Y-17.678
    X-8.915
    Y-4.953
    X-10.135 F#505
    Y-17.424
    X-9.169
    Y-5.207
    X-9.881
    Y-17.170
    X-9.423
    Y-5.461
    X-9.652
    Y-16.916
    G0 X-8.509 Y-15.367
    G1 X-10.795
    G0 X-13.081
    G1 X-15.367
    G0 X-17.653
    G1 X-19.939
    G0 X-22.225
    G1 X-24.511
    G0 X-26.797
    G1 X-29.083
    G0 X-27.203 Y-4.902
    G1 Y-4.724
    X-28.677
    Y-17.780
    X-27.203
    Y-4.978
    X-28.423 F#505
    Y-17.526
    X-27.457
    Y-5.232
    X-28.169
    Y-17.272
    X-27.711
    Y-5.486
    X-27.940
    Y-17.018
    G0 X-22.631 Y-4.928
    G1 Y-4.750
    X-24.105
    Y-17.602
    X-22.631
    Y-5.004
    X-23.851 F#505
    Y-17.348
    X-22.885
    Y-5.258
    X-23.597
    Y-17.094
    X-23.139
    Y-5.512
    X-23.368
    Y-16.840
    G0 X-18.085 Y-4.928
    G1 Y-4.750
    X-19.507
    Y-17.653
    X-18.085
    Y-5.004
    X-19.253 F#505
    Y-17.399
    X-18.339
    Y-5.258
    X-18.999
    Y-17.145
    X-18.593
    Y-5.512
    X-18.796
    Y-16.891
    G0 X-17.653 Y-6.985
    G1 X-19.939
    G0 X-22.225
    G1 X-24.511
    G0 X-26.797
    G1 X-29.083
    G0 X-29.235 Y-4.547
    G1 X-27.178
    X-27.889 Y-3.835
    X-29.896
    Y-3.658
    X-28.727
    Y-3.378
    G0 X-29.235 Y-4.547
    G1 X-30.175 Y-3.607
    G0 X-28.727 Y-2.159
    G1 Y-1.981
    X-30.201
    Y-3.429
    X-28.727
    Y-2.235
    X-29.947
    Y-3.175
    X-28.981
    Y-2.489
    X-29.693
    Y-2.921
    X-29.235
    Y-2.692
    X-29.464
    G0 X-30.099 Y-4.191
    G1 X-27.051
    G0 X-24.155 Y-2.134
    G1 Y-1.956
    X-25.629
    Y-3.404
    X-24.155
    Y-2.210
    X-25.375
    Y-3.150
    X-24.409
    Y-2.464
    X-25.121
    Y-2.896
    X-24.663
    Y-2.667
    X-24.892
    G0 X-24.155 Y-3.378
    G1 Y-3.632
    X-25.324
    X-25.146 Y-3.835
    X-23.368
    X-22.657 Y-4.547
    X-24.663
    X-25.603 Y-3.607
    Y-3.531
    G0 X-25.400 Y-4.191
    G1 X-22.479
    G0 X-19.583 Y-2.159
    G1 Y-1.981
    X-21.057
    Y-3.454
    X-19.583
    Y-2.235
    X-20.803
    Y-3.200
    X-19.837
    Y-2.489
    X-20.549
    Y-2.946
    X-20.091
    Y-2.718
    X-20.320
    G0 X-19.660 Y-3.404
    G1 Y-3.658
    X-20.650
    Y-3.835
    X-18.796
    X-18.085 Y-4.547
    X-20.066
    X-21.006 Y-3.607
    G0 X-20.828 Y-4.191
    G1 X-17.907
    G0 X-15.240 Y-1.905
    G1 Y-1.727
    X-16.281
    Y-3.581
    X-15.240
    Y-1.981
    X-16.027
    Y-3.327
    X-15.494
    Y-2.235
    X-15.748
    Y-3.073
    G0 X-15.011 Y-3.835
    G1 Y-1.549
    G0 X-16.459
    G1 Y-3.581
    X-15.596 Y-4.445
    X-13.513
    Y-4.953
    G0 Y-4.445
    G1 X-14.122 Y-3.835
    X-15.011
    X-14.884 Y-3.912
    X-16.002
    G0 X-16.256 Y-4.191
    G1 X-13.335
    G0 X-10.465 Y-2.159
    G1 Y-1.981
    X-11.938
    Y-3.429
    X-10.465
    Y-2.235
    X-11.684
    Y-3.175
    X-10.719
    Y-2.489
    X-11.430
    Y-2.921
    X-10.973
    Y-2.692
    X-11.201
    G0 X-10.541 Y-3.607
    G1 X-11.532
    X-11.557 Y-3.810
    X-9.652
    X-9.017 Y-4.445
    X-11.024
    X-11.862 Y-3.607
    G0 X-11.684 Y-4.191
    G1 X-8.763
    G0 X-9.601 Y-4.039
    G1 X-11.278 Y-4.013
    G0 X-13.462 Y-2.159
    G1 Y-1.651
    G0 X-18.034
    G1 Y-2.159
    G0 X-22.606
    G1 Y-1.651
    G0 X-27.178
    G1 Y-2.159
    G0 X-31.750
    G1 Y-1.651
    G0 X-33.299 Y-2.184
    G1 Y-2.007
    X-34.773
    Y-3.429
    X-33.299
    Y-2.261
    X-34.519
    Y-3.175
    X-33.553
    Y-2.515
    X-34.265
    Y-2.921
    X-33.807
    Y-2.718
    X-34.036
    G0 X-33.299 Y-3.505
    G1 Y-3.632
    X-34.646
    X-34.722
    Y-3.404
    G0 Y-3.632
    G1 X-33.807 Y-4.547
    X-32.055
    G0 X-31.801 Y-4.724
    G1 X-32.461 Y-4.064
    Y-3.835
    X-34.519
    G0 X-34.544 Y-4.191
    G1 X-31.750
    G0 X-36.322 Y-2.159
    G1 Y-1.651
    G0 X-38.125 Y-4.470
    G1 X-39.345 Y-3.251
    G0 X-40.005 Y-4.648
    G1 Y-4.851
    G0 X-37.440 Y-25.552
    G1 Y-25.375
    X-38.100
    Y-40.488
    X-37.440
    Y-25.629 F#505
    X-37.846
    Y-40.234
    X-37.694
    Y-25.883
    X-37.770
    Y-39.980
    G0 X-37.363 Y-40.310
    G1 X-34.798
    X-30.785
    G0 X-30.886 Y-40.513
    G1 X-37.109 Y-40.538
    X-37.338 Y-29.159
    Y-29.972
    X-37.109 Y-30.709
    X-36.703 Y-31.318
    X-36.246 Y-31.928
    X-35.839 Y-32.233
    X-35.255 Y-32.588
    Y-34.544
    X-35.535 Y-34.798
    X-35.890 Y-35.204
    X-36.220 Y-35.662
    X-36.373 Y-36.119
    X-36.500 Y-36.855
    Y-36.830
    G3 X-31.064 Y-36.830 I-33.782 J-36.830
    G1 X-31.166 Y-35.966
    X-31.521 Y-35.306
    X-32.004 Y-34.823
    X-32.385 Y-34.519
    Y-32.588
    X-31.674 Y-32.283
    X-31.191 Y-31.826
    X-30.658 Y-31.242
    X-30.328 Y-30.531
    X-30.099 Y-29.845
    X-30.048 Y-29.235
    X-30.124 Y-29.312
    G3 X-37.338 Y-29.312 I-33.731 J-29.312
    G0 X-37.592
    G2 X-29.870 Y-29.312 I-33.731 J-29.312
    G0 X-29.616
    G3 X-37.846 Y-29.312 I-33.731 J-29.312
    G0 X-38.100
    G2 X-29.362 Y-29.312 I-33.731 J-29.312
    G0 X-29.947 Y-30.023
    G1 X-29.972 Y-31.953
    X-31.344 Y-32.588
    X-31.725 Y-32.614
    X-30.810 Y-32.004
    X-30.226 Y-31.267
    X-30.099 Y-30.937
    X-30.429 Y-32.182
    G0 X-30.531 Y-31.496
    G1 X-29.947 Y-30.023
    G1 X-32.055 Y-32.791
    G0 X-32.182 Y-32.639
    G1 X-32.156 Y-34.620
    G0 X-30.048 Y-32.969
    G1 Y-32.791
    X-32.004
    Y-34.595
    X-30.048
    Y-33.045
    X-31.750
    Y-34.341
    X-30.302
    Y-33.299
    X-31.496
    Y-34.087
    X-30.556
    Y-33.553
    X-31.242
    Y-33.833
    X-30.810
    Y-33.680
    X-31.013
    G0 X-30.023 Y-32.182
    G1 Y-32.004
    X-30.963
    Y-32.588
    X-30.023
    Y-32.258
    X-30.709
    Y-32.334
    X-30.277
    Y-32.283
    X-30.480
    G0 X-29.896 Y-34.823
    G1 X-31.852
    G0 X-31.547 Y-34.569
    G1 Y-35.154
    G0 X-31.318 Y-35.306
    G1 Y-34.874
    G0 X-31.064 Y-34.976
    G1 X-31.318 Y-35.433
    G0 X-31.115 Y-35.865
    G1 X-31.064 Y-34.976
    G0 X-30.810 Y-36.830
    G2 X-36.754 Y-36.830 I-33.782 J-36.830
    G1 X-36.398 Y-35.357
    X-35.662 Y-34.493
    X-37.160 Y-34.519
    X-36.957 Y-36.855
    X-36.855 Y-34.646
    X-35.916
    X-36.779 Y-35.890
    X-36.652 Y-34.798
    X-36.017 Y-34.646
    X-36.678 Y-35.357
    G0 X-35.433 Y-32.918
    G1 Y-32.741
    X-37.211
    Y-34.392
    X-35.433
    Y-32.995
    X-36.957
    Y-34.138
    X-35.687
    Y-33.249
    X-36.703
    Y-33.884
    X-35.941
    Y-33.503
    X-36.449
    Y-33.630
    X-36.195
    Y-33.553
    X-36.322
    G0 X-35.484 Y-32.791
    G1 X-37.236 Y-31.013
    X-37.033 Y-32.690
    X-35.992 Y-32.461
    X-37.084 Y-31.394
    X-36.906 Y-32.588
    X-36.347 Y-32.156
    X-36.932 Y-31.674
    X-36.652 Y-32.537
    G0 X-37.008 Y-36.830
    G3 X-30.556 Y-36.830 I-33.782 J-36.830
    G0 X-30.302
    G2 X-37.262 Y-36.830 I-33.782 J-36.830
    G0 X-36.220 Y-38.786
    G1 Y-38.608
    X-37.033
    Y-40.107
    X-36.220
    Y-38.862
    X-36.779
    Y-39.853
    X-36.474
    Y-39.116
    X-36.627
    Y-39.599
    G0 X-35.331 Y-39.929
    G1 Y-39.751
    X-36.297
    Y-40.107
    X-35.331
    Y-39.929
    X-36.043
    G0 X-30.988 Y-39.472
    G1 Y-39.294
    X-32.080
    Y-40.107
    X-30.988
    Y-39.548
    X-31.826
    Y-39.853
    X-31.242
    Y-39.700
    X-31.572
    G0 Z[#801+5] (RETRACT UP)
    G0 X-30.023 Y-26.619
    G1 Y-25.527
    G0 X-36.017 Y-25.679
    G1 Y-25.502
    X-37.338
    Y-26.289
    X-36.017
    Y-25.756
    X-37.084
    Y-26.035
    X-36.271
    Y-25.883
    X-36.830
    G0 X-15.367 Y-6.985
    G1 X-13.081
    G0 X-10.795
    G1 X-8.509
    G0 X-6.223
    G1 X-3.937
    G0 X-2.413
    G1 X-1.905
    G0 X-1.778 Y-4.191
    G1 X-2.413
    G0 X-3.937
    G1 X-7.239
    G0 X-7.214 Y-3.708
    G1 Y-3.327
    G0 Y-3.708
    G1 X-6.375 Y-4.547
    X-5.969
    G0 X-8.890 Y-2.159
    G1 Y-1.651
    G0 X-6.223 Y-15.367
    G1 X-3.937
    G0 X-2.413
    G1 X-1.905
    G0 X-2.032 Y-17.602
    G1 X-2.286 Y-17.856
    Y-19.482
    X-1.041
    Y-28.829
    G0 X-0.483 Y-28.778
    G1 X-2.515
    G0 X-0.178 Y-18.974
    G1 Y-40.335
    G0 Z#800
    M5 M9 (SPINDLE STOP)
    (2.40mm ROUTER BIT <<--======)
    M6 T2 (SET INSERTED BIT at Z0)
    M3 S3600
    G0 F#502(START OF DRILLING)
    X-10.897 Y-31.750
    X-10.897 Y-31.750
    G1 Z#804  (Z DRILL)
    G3 X-10.592 Y-31.750 I-10.744 J-31.750
    G3 X-10.592 Y-31.750 I-10.897 J-31.750
    G3 X-10.897 Y-31.750 I-10.744 J-31.750
    G0 Z[#805+5] (RETRACT UP)
    X-33.731 Y-29.312
    G1 Z#804  (Z DRILL)
    G3 X-33.426 Y-29.312 I-33.579 J-29.312
    G3 X-33.426 Y-29.312 I-33.731 J-29.312
    G3 X-33.731 Y-29.312 I-33.579 J-29.312
    G0 Z#800
    M6 T3 (SET INSERTED BIT at Z0)
    M3 S3600
    G0 Z[#800+5] (SAFE RAPID)
    (2.40mm ENGRAVING CUTTER)
    M6 T4 (INSERTED ENGRAVING CUTTER at Z0)
    M3 S3600
    G0 X-3.277 Y-22.758
    G1 X-13.945
    Y-22.962
    X-3.277
    Y-22.860
    X-12.319
    G0 X-5.664 Y-29.743
    G1 Y-28.550
    X-5.817
    Y-35.560
    X-5.664
    Y-30.175
    X-5.740
    Y-33.934
    G0 X-19.685 Y-37.338
    G1 Y-36.144
    X-29.845
    Y-39.370
    X-19.685
    Y-37.744
    X-28.219
    G0 X-19.177 Y-28.092
    G1 Y-26.899
    X-28.778
    Y-34.011
    X-19.177 F#505
    Y-28.524
    X-27.153
    Y-32.385
    X-20.803
    Y-30.150
    X-25.527
    Y-30.759
    X-22.428
    Y-30.455
    X-23.978
    G0 Z[#801+5] F#502 (RETRACT UP)
    G0 X-38.964 Y-27.356
    G1 Y-26.062
    X-41.546
    Y-39.522
    X-38.964
    Y-27.788
    X-40.305
    Y-37.897
    G0 X-41.199 Y-15.164
    G1 X-43.002
    Y-16.332
    X-41.199
    Y-15.748
    X-42.088
    G0 Z#805 (RETRACT UP)
    F#503
    (==== GROOVE ROUTING ====)
    G0 X-67 Y1.194
    G1 Z#804  (Z ENGRAVE)
    G1 X-7.518
    G2 Y-7.518 X1.194 I-7.518 J-7.518
    G1 Y-40.513
    G2 X0.000 Y-41.707 I0.000 J-40.513
    G1 X-42.049
    G2 X-43.243 Y-40.513 I-42.049 J-40.513
    G1 Y-25.298
    G2 X-42.049 Y-24.105 I-42.049 J-25.298
    G1 X-18.186
    G1 Y-21.996
    G1 X-50.165
    G1 X-64.110 Y1.194
    (  618 ITEMS FOUND   )
    (TRACK:--------------)
    (  532 found         )
    (  532 engrave_found )
    (  532 engraved      )
    (    0 rout_found    )
    (    0 routed        )
    (    0 ,      0 dups.)
    (FILL: --------------)
    (   68 found         )
    (   63 engrave_found )
    (   63 engraved      )
    (    5 rout_found    )
    (    5 routed        )
    (ARC: ---------------)
    (   16 found         )
    (   16 engrave_found )
    (   16 engraved      )
    (    0 rout_found    )
    (    0 routed        )
    (PAD: ---------------)
    (    2 found         )
    (    0 drilled       )
    (    2 routed        )
    (SLOTS: -------------)
    (   12 found         )
    (   12 routed        )
    (    0 ,     0 missed)
    (    4 TOOLS LOADED  )
    G0 Z#806
    M30
    (------- end -------)
    Center click on this image for clearer display, or click then click again on big image.
    Image compliments of NCPlot.com
    Jul 2013
    13
    Hi Neil,
    You are probably not doing anything wrong. I suspect there is nothing happening because of all the variables in that file. My program is not too clever when it comes to variables yet and because most of the GCode generating programs I have seen so far dont use variables at all, I have not added much support for them. That being said, it is important that my software is as compatible as possible with other programs and therefore a fix might be in order.
    The fix could be a challenge because my program uses variables starting from #500 which are used by your editor. What editor are you using? Edit: Oh, ncplot, sorry, didnt see that.
    Rest assured, I will find a fix though.
    Here is some GCode generated by pcb-gcode which does work in the autolevelling software, so that you can at least see what should be happening:
    Code:
    (.../Program Files/EAGLE-6.3.0/ulp/pcb-gcode.ulp)
    (Copyright 2005 - 2009 by John Johnson)
    (See readme.txt for licensing terms.)
    (This file generated from the board:)
    (.../personal/eagle/spindle/spindle.brd)
    (Current profile is .../EAGLE-6.3.0/ulp/profiles/emc.pp  )
    (This file generated 28/06/2013 11:05:39)
    G20
    (Absolute Coordinates)
    G90
    G00 X0.0000 Y0.0000
    M03
    G04 P3.000000
    G00 Z0.0787
    G00 X1.4654 Y0.6586
    G01 Z-0.0039 F5.91
    G01 X1.5322 Y0.6586 F7.87
    G01 X1.5388 Y0.6599
    G01 X1.5451 Y0.6625
    G01 X1.5507 Y0.6662
    G01 X1.5555 Y0.6710
    G01 X1.5592 Y0.6767
    G01 X1.5618 Y0.6829
    G01 X1.5631 Y0.6895
    G01 X1.5631 Y0.6963
    G01 X1.5618 Y0.7029
    G01 X1.5592 Y0.7092
    G01 X1.5555 Y0.7148
    G01 X1.5507 Y0.7196
    G01 X1.5451 Y0.7233
    G01 X1.5388 Y0.7259
    G01 X1.5322 Y0.7272
    G01 X1.4654 Y0.7272
    G01 X1.4588 Y0.7259
    G01 X1.4526 Y0.7233
    G01 X1.4469 Y0.7196
    G01 X1.4422 Y0.7148
    G01 X1.4384 Y0.7092
    G01 X1.4358 Y0.7029
    G01 X1.4345 Y0.6963
    G01 X1.4345 Y0.6895
    G01 X1.4358 Y0.6829
    G01 X1.4384 Y0.6767
    G01 X1.4422 Y0.6710
    G01 X1.4469 Y0.6662
    G01 X1.4526 Y0.6625
    G01 X1.4588 Y0.6599
    G01 X1.4654 Y0.6586
    G00 Z0.0787
    G00 X1.4654 Y0.5586
    G01 Z-0.0039 F5.91
    G01 X1.5322 Y0.5586 F7.87
    G01 X1.5388 Y0.5599
    G01 X1.5451 Y0.5625
    G01 X1.5507 Y0.5662
    G01 X1.5555 Y0.5710
    G01 X1.5592 Y0.5767
    G01 X1.5618 Y0.5829
    G01 X1.5631 Y0.5895
    G01 X1.5631 Y0.5963
    G01 X1.5618 Y0.6029
    G01 X1.5592 Y0.6092
    G01 X1.5555 Y0.6148
    G01 X1.5507 Y0.6196
    G01 X1.5451 Y0.6233
    G01 X1.5388 Y0.6259
    G01 X1.5322 Y0.6272
    G01 X1.4654 Y0.6272
    G01 X1.4588 Y0.6259
    G01 X1.4526 Y0.6233
    G01 X1.4469 Y0.6196
    G01 X1.4422 Y0.6148
    G01 X1.4384 Y0.6092
    G01 X1.4358 Y0.6029
    G01 X1.4345 Y0.5963
    G01 X1.4345 Y0.5895
    G01 X1.4358 Y0.5829
    G01 X1.4384 Y0.5767
    G01 X1.4422 Y0.5710
    G01 X1.4469 Y0.5662
    G01 X1.4526 Y0.5625
    G01 X1.4588 Y0.5599
    G01 X1.4654 Y0.5586
    G00 Z0.0787
    G00 X1.4654 Y0.4586
    G01 Z-0.0039 F5.91
    G01 X1.5322 Y0.4586 F7.87
    G01 X1.5388 Y0.4599
    G01 X1.5451 Y0.4625
    G01 X1.5507 Y0.4662
    G01 X1.5555 Y0.4710
    G01 X1.5592 Y0.4767
    G01 X1.5618 Y0.4829
    G01 X1.5631 Y0.4895
    G01 X1.5631 Y0.4963
    G01 X1.5618 Y0.5029
    G01 X1.5592 Y0.5092
    G01 X1.5555 Y0.5148
    G01 X1.5507 Y0.5196
    G01 X1.5451 Y0.5233
    G01 X1.5388 Y0.5259
    G01 X1.5322 Y0.5272
    G01 X1.4854 Y0.5272
    G01 X1.4821 Y0.5281
    G01 X1.4635 Y0.5281
    G01 X1.2699 Y0.7217
    G01 X1.2661 Y0.7239
    G01 X1.2620 Y0.7250
    G01 X0.9516 Y0.7250
    G01 X0.6774 Y0.9993
    G01 X0.6736 Y1.0014
    G01 X0.6695 Y1.0026
    G01 X0.5210 Y1.0026
    G01 X0.5204 Y1.0039
    G01 X0.5163 Y1.0100
    G01 X0.5111 Y1.0152
    G01 X0.5050 Y1.0193
    G01 X0.4982 Y1.0221
    G01 X0.4910 Y1.0236
    G01 X0.4177 Y1.0236
    G01 X0.4104 Y1.0221
    G01 X0.4036 Y1.0193
    G01 X0.3975 Y1.0152
    G01 X0.3923 Y1.0100
    G01 X0.3882 Y1.0039
    G01 X0.3854 Y0.9971
    G01 X0.3840 Y0.9899
    G01 X0.3840 Y0.9825
    G01 X0.3854 Y0.9753
    G01 X0.3882 Y0.9685
    G01 X0.3923 Y0.9624
    G01 X0.3975 Y0.9572
    G01 X0.4036 Y0.9531
    G01 X0.4104 Y0.9503
    G01 X0.4177 Y0.9489
    G01 X0.4910 Y0.9489
    G01 X0.4982 Y0.9503
    G01 X0.5050 Y0.9531
    G01 X0.5111 Y0.9572
    G01 X0.5163 Y0.9624
    G01 X0.5204 Y0.9685
    G01 X0.5210 Y0.9699
    G01 X0.6606 Y0.9699
    G01 X0.9318 Y0.6986
    G01 X0.9349 Y0.6956
    G01 X0.9386 Y0.6934
    G01 X0.9427 Y0.6923
    G01 X1.2531 Y0.6923
    G01 X1.4378 Y0.5076
    G01 X1.4358 Y0.5029
    G01 X1.4345 Y0.4963
    G01 X1.4345 Y0.4895
    G01 X1.4358 Y0.4829
    G01 X1.4384 Y0.4767
    G01 X1.4422 Y0.4710
    G01 X1.4469 Y0.4662
    G01 X1.4526 Y0.4625
    G01 X1.4588 Y0.4599
    G01 X1.4654 Y0.4586
    G00 Z0.0787
    G00 X3.7883 Y1.0586
    G01 Z-0.0039 F5.91
    G01 X3.8550 Y1.0586 F7.87
    G01 X3.8617 Y1.0599
    G01 X3.8679 Y1.0625
    G01 X3.8735 Y1.0662
    G01 X3.8783 Y1.0710
    G01 X3.8821 Y1.0767
    G01 X3.8847 Y1.0829
    G01 X3.8860 Y1.0895
    G01 X3.8860 Y1.0963
    G01 X3.8847 Y1.1029
    G01 X3.8821 Y1.1092
    G01 X3.8783 Y1.1148
    G01 X3.8735 Y1.1196
    G01 X3.8679 Y1.1233
    G01 X3.8617 Y1.1259
    G01 X3.8550 Y1.1272
    G01 X3.7883 Y1.1272
    G01 X3.7816 Y1.1259
    G01 X3.7754 Y1.1233
    G01 X3.7698 Y1.1196
    G01 X3.7650 Y1.1148
    G01 X3.7612 Y1.1092
    G01 X3.7586 Y1.1029
    G01 X3.7573 Y1.0963
    G01 X3.7573 Y1.0895
    G01 X3.7586 Y1.0829
    G01 X3.7612 Y1.0767
    G01 X3.7650 Y1.0710
    G01 X3.7698 Y1.0662
    G01 X3.7754 Y1.0625
    G01 X3.7816 Y1.0599
    G01 X3.7883 Y1.0586
    G00 Z0.0787
    G00 X3.7883 Y0.9586
    G01 Z-0.0039 F5.91
    G01 X3.8550 Y0.9586 F7.87
    G01 X3.8617 Y0.9599
    G01 X3.8679 Y0.9625
    G01 X3.8735 Y0.9662
    G01 X3.8783 Y0.9710
    G01 X3.8821 Y0.9767
    G01 X3.8847 Y0.9829
    G01 X3.8860 Y0.9895
    G01 X3.8860 Y0.9963
    G01 X3.8847 Y1.0029
    G01 X3.8821 Y1.0092
    G01 X3.8783 Y1.0148
    G01 X3.8735 Y1.0196
    G01 X3.8679 Y1.0233
    G01 X3.8617 Y1.0259
    G01 X3.8550 Y1.0272
    G01 X3.7883 Y1.0272
    G01 X3.7816 Y1.0259
    G01 X3.7754 Y1.0233
    G01 X3.7698 Y1.0196
    G01 X3.7650 Y1.0148
    G01 X3.7612 Y1.0092
    G01 X3.7586 Y1.0029
    G01 X3.7573 Y0.9963
    G01 X3.7573 Y0.9895
    G01 X3.7586 Y0.9829
    G01 X3.7612 Y0.9767
    G01 X3.7650 Y0.9710
    G01 X3.7698 Y0.9662
    G01 X3.7754 Y0.9625
    G01 X3.7816 Y0.9599
    G01 X3.7883 Y0.9586
    G00 Z0.0787
    G00 X3.7883 Y0.8586
    G01 Z-0.0039 F5.91
    G01 X3.8550 Y0.8586 F7.87
    G01 X3.8617 Y0.8599
    G01 X3.8679 Y0.8625
    G01 X3.8735 Y0.8662
    G01 X3.8783 Y0.8710
    G01 X3.8821 Y0.8767
    G01 X3.8847 Y0.8829
    G01 X3.8860 Y0.8895
    G01 X3.8860 Y0.8963
    G01 X3.8847 Y0.9029
    G01 X3.8821 Y0.9092
    G01 X3.8783 Y0.9148
    G01 X3.8735 Y0.9196
    G01 X3.8679 Y0.9233
    G01 X3.8617 Y0.9259
    G01 X3.8550 Y0.9272
    G01 X3.7883 Y0.9272
    G01 X3.7816 Y0.9259
    G01 X3.7754 Y0.9233
    G01 X3.7698 Y0.9196
    G01 X3.7650 Y0.9148
    G01 X3.7612 Y0.9092
    G01 X3.7586 Y0.9029
    G01 X3.7573 Y0.8963
    G01 X3.7573 Y0.8895
    G01 X3.7586 Y0.8829
    G01 X3.7612 Y0.8767
    G01 X3.7650 Y0.8710
    G01 X3.7698 Y0.8662
    G01 X3.7754 Y0.8625
    G01 X3.7816 Y0.8599
    G01 X3.7883 Y0.8586
    G00 Z0.0787
    G00 X3.3307 Y2.4915
    G01 Z-0.0039 F5.91
    G01 X3.3307 Y2.5258 F7.87
    G01 X3.3065 Y2.5500
    G01 X3.2723 Y2.5500
    G01 X3.2480 Y2.5258
    G01 X3.2480 Y2.4915
    G01 X3.2723 Y2.4673
    G01 X3.3065 Y2.4673
    G01 X3.3307 Y2.4915
    G00 Z0.0787
    G00 X3.2307 Y2.4915
    G01 Z-0.0039 F5.91
    G01 X3.2307 Y2.5258 F7.87
    G01 X3.2065 Y2.5500
    G01 X3.1723 Y2.5500
    G01 X3.1480 Y2.5258
    G01 X3.1480 Y2.4915
    G01 X3.1723 Y2.4673
    G01 X3.2065 Y2.4673
    G01 X3.2307 Y2.4915
    G00 Z0.0787
    G00 X3.3307 Y2.5915
    G01 Z-0.0039 F5.91
    G01 X3.3307 Y2.6258 F7.87
    G01 X3.3065 Y2.6500
    G01 X3.2723 Y2.6500
    G01 X3.2480 Y2.6258
    G01 X3.2480 Y2.5915
    G01 X3.2723 Y2.5673
    G01 X3.3065 Y2.5673
    G01 X3.3307 Y2.5915
    G00 Z0.0787
    G00 X3.2307 Y2.5915
    G01 Z-0.0039 F5.91
    G01 X3.2307 Y2.6258 F7.87
    G01 X3.2065 Y2.6500
    G01 X3.1723 Y2.6500
    G01 X3.1480 Y2.6258
    G01 X3.1480 Y2.5915
    G01 X3.1723 Y2.5673
    G01 X3.2065 Y2.5673
    G01 X3.2307 Y2.5915
    G00 Z0.0787
    G00 X3.2307 Y2.6915
    G01 Z-0.0039 F5.91
    G01 X3.2307 Y2.7258 F7.87
    G01 X3.2065 Y2.7500
    G01 X3.1723 Y2.7500
    G01 X3.1480 Y2.7258
    G01 X3.1480 Y2.6915
    G01 X3.1723 Y2.6673
    G01 X3.2065 Y2.6673
    G01 X3.2307 Y2.6915
    G00 Z0.0787
    G00 X3.3307 Y2.7915
    G01 Z-0.0039 F5.91
    G01 X3.3307 Y2.8258 F7.87
    G01 X3.3301 Y2.8263
    G01 X3.3989 Y2.8951
    G01 X3.4010 Y2.8988
    G01 X3.4022 Y2.9030
    G01 X3.4022 Y2.9549
    G01 X3.4010 Y2.9591
    G01 X3.3989 Y2.9628
    G01 X3.3959 Y2.9658
    G01 X3.3171 Y3.0446
    G01 X3.3134 Y3.0467
    G01 X3.3092 Y3.0478
    G01 X2.9900 Y3.0478
    G01 X2.9858 Y3.0467
    G01 X2.9821 Y3.0446
    G01 X2.9791 Y3.0415
    G01 X2.8657 Y2.9281
    G01 X2.2527 Y2.9281
    G01 X2.2507 Y2.9311
    G01 X2.2465 Y2.9354
    G01 X2.2415 Y2.9387
    G01 X2.2360 Y2.9410
    G01 X2.2302 Y2.9421
    G01 X2.1722 Y2.9421
    G01 X2.1663 Y2.9410
    G01 X2.1608 Y2.9387
    G01 X2.1558 Y2.9354
    G01 X2.1516 Y2.9311
    G01 X2.1483 Y2.9262
    G01 X2.1460 Y2.9207
    G01 X2.1449 Y2.9148
    G01 X2.1449 Y2.9088
    G01 X2.1460 Y2.9030
    G01 X2.1483 Y2.8974
    G01 X2.1516 Y2.8925
    G01 X2.1558 Y2.8883
    G01 X2.1608 Y2.8849
    G01 X2.1663 Y2.8826
    G01 X2.1722 Y2.8815
    G01 X2.2302 Y2.8815
    G01 X2.2360 Y2.8826
    G01 X2.2415 Y2.8849
    G01 X2.2465 Y2.8883
    G01 X2.2507 Y2.8925
    G01 X2.2527 Y2.8955
    G01 X2.8746 Y2.8955
    G01 X2.8787 Y2.8966
    G01 X2.8825 Y2.8987
    G01 X2.9989 Y3.0152
    G01 X3.3003 Y3.0152
    G01 X3.3695 Y2.9460
    G01 X3.3695 Y2.9119
    G01 X3.3070 Y2.8494
    G01 X3.3065 Y2.8500
    G01 X3.2723 Y2.8500
    G01 X3.2480 Y2.8258
    G01 X3.2480 Y2.7915
    G01 X3.2723 Y2.7673
    G01 X3.3065 Y2.7673
    G01 X3.3307 Y2.7915
    G00 Z0.0787
    G00 X3.2307 Y2.7915
    G01 Z-0.0039 F5.91
    G01 X3.2307 Y2.8258 F7.87
    G01 X3.2065 Y2.8500
    G01 X3.1723 Y2.8500
    G01 X3.1480 Y2.8258
    G01 X3.1480 Y2.7915
    G01 X3.1723 Y2.7673
    G01 X3.2065 Y2.7673
    G01 X3.2307 Y2.7915
    G00 Z0.0787
    G00 X3.3307 Y2.8915
    G01 Z-0.0039 F5.91
    G01 X3.3307 Y2.9258 F7.87
    G01 X3.3065 Y2.9500
    G01 X3.2723 Y2.9500
    G01 X3.2480 Y2.9258
    G01 X3.2480 Y2.8915
    G01 X3.2723 Y2.8673
    G01 X3.3065 Y2.8673
    G01 X3.3307 Y2.8915
    G00 Z0.0787
    G00 X3.2307 Y2.8915
    G01 Z-0.0039 F5.91
    G01 X3.2307 Y2.9258 F7.87
    G01 X3.2065 Y2.9500
    G01 X3.1723 Y2.9500
    G01 X3.1480 Y2.9258
    G01 X3.1480 Y2.9250
    G01 X3.0640 Y2.9250
    G01 X3.0598 Y2.9239
    G01 X3.0561 Y2.9217
    G01 X2.9427 Y2.8083
    G01 X2.9397 Y2.8053
    G01 X2.9375 Y2.8016
    G01 X2.9364 Y2.7974
    G01 X2.9364 Y2.3439
    G01 X2.9375 Y2.3398
    G01 X2.9397 Y2.3360
    G01 X3.1762 Y2.0996
    G01 X3.1756 Y2.0990
    G01 X3.1756 Y2.0982
    G01 X2.2691 Y2.0982
    G01 X2.2650 Y2.0971
    G01 X2.2612 Y2.0950
    G01 X2.2084 Y2.0421
    G01 X2.1939 Y2.0421
    G01 X2.1142 Y2.1218
    G01 X2.1112 Y2.1249
    G01 X2.1075 Y2.1270
    G01 X2.1033 Y2.1281
    G01 X1.6527 Y2.1281
    G01 X1.6507 Y2.1311
    G01 X1.6465 Y2.1354
    G01 X1.6415 Y2.1387
    G01 X1.6360 Y2.1410
    G01 X1.6302 Y2.1421
    G01 X1.5939 Y2.1421
    G01 X1.5607 Y2.1754
    G01 X1.5577 Y2.1784
    G01 X1.5539 Y2.1806
    G01 X1.5498 Y2.1817
    G01 X1.4635 Y2.1817
    G01 X1.4280 Y2.2172
    G01 X1.4280 Y2.2307
    G01 X1.4102 Y2.2484
    G01 X1.3851 Y2.2484
    G01 X1.3673 Y2.2307
    G01 X1.3673 Y2.2055
    G01 X1.3851 Y2.1878
    G01 X1.4102 Y2.1878
    G01 X1.4107 Y2.1883
    G01 X1.4467 Y2.1523
    G01 X1.4504 Y2.1501
    G01 X1.4545 Y2.1490
    G01 X1.5409 Y2.1490
    G01 X1.5552 Y2.1347
    G01 X1.5516 Y2.1311
    G01 X1.5496 Y2.1281
    G01 X1.0380 Y2.1281
    G01 X1.0339 Y2.1270
    G01 X1.0301 Y2.1249
    G01 X1.0271 Y2.1218
    G01 X0.9098 Y2.0046
    G01 X0.9092 Y2.0051
    G01 X0.9085 Y2.0051
    G01 X0.9085 Y2.2990
    G01 X0.9073 Y2.3032
    G01 X0.9052 Y2.3069
    G01 X0.9022 Y2.3099
    G01 X0.8037 Y2.4083
    G01 X0.8037 Y2.8090
    G01 X0.8626 Y2.8679
    G01 X0.8632 Y2.8673
    G01 X0.8974 Y2.8673
    G01 X0.9216 Y2.8915
    G01 X0.9216 Y2.9258
    G01 X0.8974 Y2.9500
    G01 X0.8632 Y2.9500
    G01 X0.8390 Y2.9258
    G01 X0.8390 Y2.8915
    G01 X0.8395 Y2.8910
    G01 X0.7774 Y2.8288
    G01 X0.7743 Y2.8258
    G01 X0.7722 Y2.8221
    G01 X0.7711 Y2.8179
    G01 X0.7711 Y2.3994
    G01 X0.7722 Y2.3953
    G01 X0.7743 Y2.3915
    G01 X0.8758 Y2.2901
    G01 X0.8758 Y2.0051
    G01 X0.8750 Y2.0051
    G01 X0.8508 Y1.9809
    G01 X0.8508 Y1.9467
    G01 X0.8750 Y1.9224
    G01 X0.9092 Y1.9224
    G01 X0.9335 Y1.9467
    G01 X0.9335 Y1.9809
    G01 X0.9329 Y1.9815
    G01 X1.0469 Y2.0955
    G01 X1.5496 Y2.0955
    G01 X1.5516 Y2.0925
    G01 X1.5558 Y2.0883
    G01 X1.5608 Y2.0849
    G01 X1.5663 Y2.0826
    G01 X1.5722 Y2.0815
    G01 X1.6302 Y2.0815
    G01 X1.6360 Y2.0826
    G01 X1.6415 Y2.0849
    G01 X1.6465 Y2.0883
    G01 X1.6507 Y2.0925
    G01 X1.6527 Y2.0955
    G01 X2.0944 Y2.0955
    G01 X2.1552 Y2.0347
    G01 X2.1516 Y2.0311
    G01 X2.1483 Y2.0262
    G01 X2.1460 Y2.0207
    G01 X2.1449 Y2.0148
    G01 X2.1449 Y2.0088
    G01 X2.1460 Y2.0030
    G01 X2.1483 Y1.9974
    G01 X2.1516 Y1.9925
    G01 X2.1558 Y1.9883
    G01 X2.1608 Y1.9849
    G01 X2.1663 Y1.9826
    G01 X2.1722 Y1.9815
    G01 X2.2302 Y1.9815
    G01 X2.2360 Y1.9826
    G01 X2.2415 Y1.9849
    G01 X2.2465 Y1.9883
    G01 X2.2507 Y1.9925
    G01 X2.2541 Y1.9974
    G01 X2.2563 Y2.0030
    G01 X2.2575 Y2.0088
    G01 X2.2575 Y2.0148
    G01 X2.2563 Y2.0207
    G01 X2.2541 Y2.0262
    G01 X2.2507 Y2.0311
    G01 X2.2472 Y2.0347
    G01 X2.2780 Y2.0656
    G01 X3.1756 Y2.0656
    G01 X3.1756 Y2.0648
    G01 X3.1998 Y2.0406
    G01 X3.2340 Y2.0406
    G01 X3.2583 Y2.0648
    G01 X3.2583 Y2.0990
    G01 X3.2577 Y2.0996
    G01 X3.3072 Y2.1490
    G01 X3.4578 Y2.1490
    G01 X3.5270 Y2.0798
    G01 X3.5270 Y1.1402
    G01 X3.3383 Y0.9516
    G01 X3.3239 Y0.9516
    G01 X3.1367 Y1.1388
    G01 X3.1336 Y1.1418
    G01 X3.1299 Y1.1440
    G01 X3.1258 Y1.1451
    G01 X3.0978 Y1.1451
    G01 X3.0838 Y1.1591
    G01 X3.0587 Y1.1591
    G01 X3.0409 Y1.1413
    G01 X3.0409 Y1.1162
    G01 X3.0587 Y1.0984
    G01 X3.0838 Y1.0984
    G01 X3.0978 Y1.1124
    G01 X3.1169 Y1.1124
    G01 X3.2851 Y0.9442
    G01 X3.2815 Y0.9406
    G01 X3.2782 Y0.9356
    G01 X3.2759 Y0.9301
    G01 X3.2748 Y0.9242
    G01 X3.2748 Y0.9183
    G01 X3.2759 Y0.9124
    G01 X3.2782 Y0.9069
    G01 X3.2815 Y0.9019
    G01 X3.2858 Y0.8977
    G01 X3.2907 Y0.8944
    G01 X3.2963 Y0.8921
    G01 X3.3021 Y0.8909
    G01 X3.3601 Y0.8909
    G01 X3.3659 Y0.8921
    G01 X3.3715 Y0.8944
    G01 X3.3764 Y0.8977
    G01 X3.3807 Y0.9019
    G01 X3.3827 Y0.9049
    G01 X3.6070 Y0.9049
    G01 X3.7667 Y0.7452
    G01 X3.7654 Y0.7444
    G01 X3.7607 Y0.7396
    G01 X3.7569 Y0.7340
    G01 X3.7543 Y0.7277
    G01 X3.7530 Y0.7211
    G01 X3.7530 Y0.7143
    G01 X3.7543 Y0.7077
    G01 X3.7569 Y0.7015
    G01 X3.7607 Y0.6958
    G01 X3.7654 Y0.6910
    G01 X3.7711 Y0.6873
    G01 X3.7773 Y0.6847
    G01 X3.7839 Y0.6834
    G01 X3.8010 Y0.6834
    G01 X3.8010 Y0.6520
    G01 X3.7839 Y0.6520
    G01 X3.7773 Y0.6507
    G01 X3.7711 Y0.6481
    G01 X3.7654 Y0.6444
    G01 X3.7607 Y0.6396
    G01 X3.7569 Y0.6340
    G01 X3.7543 Y0.6277
    G01 X3.7530 Y0.6211
    G01 X3.7530 Y0.6143
    G01 X3.7543 Y0.6077
    G01 X3.7569 Y0.6015
    G01 X3.7607 Y0.5958
    G01 X3.7654 Y0.5910
    G01 X3.7711 Y0.5873
    G01 X3.7773 Y0.5847
    G01 X3.7839 Y0.5834
    G01 X3.8010 Y0.5834
    G01 X3.8010 Y0.5520
    G01 X3.7839 Y0.5520
    G01 X3.7773 Y0.5507
    G01 X3.7711 Y0.5481
    G01 X3.7654 Y0.5444
    G01 X3.7607 Y0.5396
    G01 X3.7569 Y0.5340
    G01 X3.6270 Y0.5340
    G01 X3.6228 Y0.5329
    G01 X3.6191 Y0.5308
    G01 X3.3944 Y0.3061
    G01 X3.3938 Y0.3064
    G01 X3.3872 Y0.3086
    G01 X3.3803 Y0.3097
    G01 X3.3733 Y0.3097
    G01 X3.3664 Y0.3086
    G01 X3.3598 Y0.3064
    G01 X3.3535 Y0.3033
    G01 X3.3479 Y0.2992
    G01 X3.3430 Y0.2942
    G01 X3.3389 Y0.2886
    G01 X3.3357 Y0.2824
    G01 X3.3335 Y0.2757
    G01 X3.3324 Y0.2688
    G01 X3.3324 Y0.2619
    G01 X3.3335 Y0.2550
    G01 X3.3357 Y0.2483
    G01 X3.3389 Y0.2421
    G01 X3.3430 Y0.2365
    G01 X3.3479 Y0.2315
    G01 X3.3535 Y0.2274
    G01 X3.3598 Y0.2243
    G01 X3.3664 Y0.2221
    G01 X3.3733 Y0.2210
    G01 X3.3803 Y0.2210
    G01 X3.3872 Y0.2221
    G01 X3.3938 Y0.2243
    G01 X3.4000 Y0.2274
    G01 X3.4057 Y0.2315
    G01 X3.4106 Y0.2365
    G01 X3.4147 Y0.2421
    G01 X3.4179 Y0.2483
    G01 X3.4200 Y0.2550
    G01 X3.4211 Y0.2619
    G01 X3.4211 Y0.2688
    G01 X3.4200 Y0.2757
    G01 X3.4179 Y0.2824
    G01 X3.4175 Y0.2830
    G01 X3.6359 Y0.5014
    G01 X3.7569 Y0.5014
    G01 X3.7607 Y0.4958
    G01 X3.7654 Y0.4910
    G01 X3.7711 Y0.4873
    G01 X3.7773 Y0.4847
    G01 X3.7839 Y0.4834
    G01 X3.8507 Y0.4834
    G01 X3.8573 Y0.4847
    G01 X3.8636 Y0.4873
    G01 X3.8692 Y0.4910
    G01 X3.8740 Y0.4958
    G01 X3.8777 Y0.5015
    G01 X3.8803 Y0.5077
    G01 X3.8817 Y0.5143
    G01 X3.8817 Y0.5211
    G01 X3.8803 Y0.5277
    G01 X3.8777 Y0.5340
    G01 X3.8740 Y0.5396
    G01 X3.8692 Y0.5444
    G01 X3.8636 Y0.5481
    G01 X3.8573 Y0.5507
    G01 X3.8507 Y0.5520
    G01 X3.8337 Y0.5520
    G01 X3.8337 Y0.5834
    G01 X3.8507 Y0.5834
    G01 X3.8573 Y0.5847
    G01 X3.8636 Y0.5873
    G01 X3.8692 Y0.5910
    G01 X3.8740 Y0.5958
    G01 X3.8777 Y0.6015
    G01 X3.8803 Y0.6077
    G01 X3.8817 Y0.6143
    G01 X3.8817 Y0.6211
    G01 X3.8803 Y0.6277
    G01 X3.8777 Y0.6340
    G01 X3.8740 Y0.6396
    G01 X3.8692 Y0.6444
    G01 X3.8636 Y0.6481
    G01 X3.8573 Y0.6507
    G01 X3.8507 Y0.6520
    G01 X3.8337 Y0.6520
    G01 X3.8337 Y0.6834
    G01 X3.8507 Y0.6834
    G01 X3.8573 Y0.6847
    G01 X3.8636 Y0.6873
    G01 X3.8692 Y0.6910
    G01 X3.8740 Y0.6958
    G01 X3.8777 Y0.7015
    G01 X3.8803 Y0.7077
    G01 X3.8817 Y0.7143
    G01 X3.8817 Y0.7211
    G01 X3.8803 Y0.7277
    G01 X3.8777 Y0.7340
    G01 X3.8740 Y0.7396
    G01 X3.8692 Y0.7444
    G01 X3.8636 Y0.7481
    G01 X3.8573 Y0.7507
    G01 X3.8507 Y0.7520
    G01 X3.8061 Y0.7520
    G01 X3.6268 Y0.9313
    G01 X3.6238 Y0.9343
    G01 X3.6201 Y0.9365
    G01 X3.6159 Y0.9376
    G01 X3.3827 Y0.9376
    G01 X3.3807 Y0.9406
    G01 X3.3771 Y0.9442
    G01 X3.5564 Y1.1234
    G01 X3.5585 Y1.1272
    G01 X3.5596 Y1.1313
    G01 X3.5596 Y2.0888
    G01 X3.5585 Y2.0929
    G01 X3.5564 Y2.0966
    G01 X3.5533 Y2.0997
    G01 X3.4776 Y2.1754
    G01 X3.4746 Y2.1784
    G01 X3.4709 Y2.1806
    G01 X3.4667 Y2.1817
    G01 X3.2982 Y2.1817
    G01 X3.2941 Y2.1806
    G01 X3.2904 Y2.1784
    G01 X3.2873 Y2.1754
    G01 X3.2346 Y2.1227
    G01 X3.2340 Y2.1232
    G01 X3.1998 Y2.1232
    G01 X3.1993 Y2.1227
    G01 X2.9691 Y2.3528
    G01 X2.9691 Y2.7885
    G01 X3.0729 Y2.8923
    G01 X3.1480 Y2.8923
    G01 X3.1480 Y2.8915
    G01 X3.1723 Y2.8673
    G01 X3.2065 Y2.8673
    G01 X3.2307 Y2.8915
    G00 Z0.0787
    G00 X1.0216 Y2.4915
    G01 Z-0.0039 F5.91
    G01 X1.0216 Y2.4923 F7.87
    G01 X1.3976 Y2.4923
    G01 X1.5552 Y2.3347
    G01 X1.5516 Y2.3311
    G01 X1.5483 Y2.3262
    G01 X1.5460 Y2.3207
    G01 X1.5449 Y2.3148
    G01 X1.5449 Y2.3088
    G01 X1.5460 Y2.3030
    G01 X1.5483 Y2.2974
    G01 X1.5516 Y2.2925
    G01 X1.5558 Y2.2883
    G01 X1.5608 Y2.2849
    G01 X1.5663 Y2.2826
    G01 X1.5722 Y2.2815
    G01 X1.6302 Y2.2815
    G01 X1.6360 Y2.2826
    G01 X1.6415 Y2.2849
    G01 X1.6465 Y2.2883
    G01 X1.6507 Y2.2925
    G01 X1.6541 Y2.2974
    G01 X1.6563 Y2.3030
    G01 X1.6575 Y2.3088
    G01 X1.6575 Y2.3148
    G01 X1.6563 Y2.3207
    G01 X1.6541 Y2.3262
    G01 X1.6507 Y2.3311
    G01 X1.6465 Y2.3354
    G01 X1.6415 Y2.3387
    G01 X1.6360 Y2.3410
    G01 X1.6302 Y2.3421
    G01 X1.5939 Y2.3421
    G01 X1.4174 Y2.5187
    G01 X1.4144 Y2.5217
    G01 X1.4106 Y2.5239
    G01 X1.4065 Y2.5250
    G01 X1.0216 Y2.5250
    G01 X1.0216 Y2.5258
    G01 X0.9974 Y2.5500
    G01 X0.9632 Y2.5500
    G01 X0.9390 Y2.5258
    G01 X0.9390 Y2.4915
    G01 X0.9632 Y2.4673
    G01 X0.9974 Y2.4673
    G01 X1.0216 Y2.4915
    G00 Z0.0787
    G00 X0.9216 Y2.4915
    G01 Z-0.0039 F5.91
    G01 X0.9216 Y2.5258 F7.87
    G01 X0.8974 Y2.5500
    G01 X0.8632 Y2.5500
    G01 X0.8390 Y2.5258
    G01 X0.8390 Y2.4915
    G01 X0.8632 Y2.4673
    G01 X0.8974 Y2.4673
    G01 X0.9216 Y2.4915
    G00 Z0.0787
    G00 X1.0216 Y2.5915
    G01 Z-0.0039 F5.91
    G01 X1.0216 Y2.5923 F7.87
    G01 X1.4976 Y2.5923
    G01 X1.5552 Y2.5347
    G01 X1.5516 Y2.5311
    G01 X1.5483 Y2.5262
    G01 X1.5460 Y2.5207
    G01 X1.5449 Y2.5148
    G01 X1.5449 Y2.5088
    G01 X1.5460 Y2.5030
    G01 X1.5483 Y2.4974
    G01 X1.5516 Y2.4925
    G01 X1.5558 Y2.4883
    G01 X1.5608 Y2.4849
    G01 X1.5663 Y2.4826
    G01 X1.5722 Y2.4815
    G01 X1.6302 Y2.4815
    G01 X1.6360 Y2.4826
    G01 X1.6415 Y2.4849
    G01 X1.6465 Y2.4883
    G01 X1.6507 Y2.4925
    G01 X1.6541 Y2.4974
    G01 X1.6563 Y2.5030
    G01 X1.6575 Y2.5088
    G01 X1.6575 Y2.5148
    G01 X1.6563 Y2.5207
    G01 X1.6541 Y2.5262
    G01 X1.6507 Y2.5311
    G01 X1.6465 Y2.5354
    G01 X1.6415 Y2.5387
    G01 X1.6360 Y2.5410
    G01 X1.6302 Y2.5421
    G01 X1.5939 Y2.5421
    G01 X1.5174 Y2.6187
    G01 X1.5144 Y2.6217
    G01 X1.5106 Y2.6239
    G01 X1.5065 Y2.6250
    G01 X1.0216 Y2.6250
    G01 X1.0216 Y2.6258
    G01 X0.9974 Y2.6500
    G01 X0.9632 Y2.6500
    G01 X0.9390 Y2.6258
    G01 X0.9390 Y2.5915
    G01 X0.9632 Y2.5673
    G01 X0.9974 Y2.5673
    G01 X1.0216 Y2.5915
    G00 Z0.0787
    G00 X0.9216 Y2.5915
    G01 Z-0.0039 F5.91
    G01 X0.9216 Y2.6258 F7.87
    G01 X0.8974 Y2.6500
    G01 X0.8632 Y2.6500
    G01 X0.8390 Y2.6258
    G01 X0.8390 Y2.5915
    G01 X0.8632 Y2.5673
    G01 X0.8974 Y2.5673
    G01 X0.9216 Y2.5915
    G00 Z0.0787
    G00 X0.9216 Y2.6915
    G01 Z-0.0039 F5.91
    G01 X0.9216 Y2.7258 F7.87
    G01 X0.8974 Y2.7500
    G01 X0.8632 Y2.7500
    G01 X0.8390 Y2.7258
    G01 X0.8390 Y2.6915
    G01 X0.8632 Y2.6673
    G01 X0.8974 Y2.6673
    G01 X0.9216 Y2.6915
    G00 Z0.0787
    G00 X1.0216 Y2.7915
    G01 Z-0.0039 F5.91
    G01 X1.0216 Y2.8258 F7.87
    G01 X0.9974 Y2.8500
    G01 X0.9632 Y2.8500
    G01 X0.9390 Y2.8258
    G01 X0.9390 Y2.7915
    G01 X0.9632 Y2.7673
    G01 X0.9974 Y2.7673
    G01 X1.0216 Y2.7915
    G00 Z0.0787
    G00 X0.9216 Y2.7915
    G01 Z-0.0039 F5.91
    G01 X0.9216 Y2.8258 F7.87
    G01 X0.8974 Y2.8500
    G01 X0.8632 Y2.8500
    G01 X0.8390 Y2.8258
    G01 X0.8390 Y2.7915
    G01 X0.8632 Y2.7673
    G01 X0.8974 Y2.7673
    G01 X0.9216 Y2.7915
    G00 Z0.0787
    G00 X1.0216 Y2.8915
    G01 Z-0.0039 F5.91
    G01 X1.0216 Y2.9258 F7.87
    G01 X0.9974 Y2.9500
    G01 X0.9966 Y2.9500
    G01 X0.9966 Y2.9588
    G01 X0.9955 Y2.9630
    G01 X0.9934 Y2.9667
    G01 X0.9903 Y2.9698
    G01 X0.9155 Y3.0446
    G01 X0.9118 Y3.0467
    G01 X0.9077 Y3.0478
    G01 X0.8246 Y3.0478
    G01 X0.8205 Y3.0467
    G01 X0.8167 Y3.0446
    G01 X0.8137 Y3.0415
    G01 X0.6956 Y2.9234
    G01 X0.6934 Y2.9197
    G01 X0.6923 Y2.9155
    G01 X0.6923 Y2.4048
    G01 X0.4494 Y2.1619
    G01 X0.4475 Y2.1647
    G01 X0.4423 Y2.1699
    G01 X0.4362 Y2.1740
    G01 X0.4294 Y2.1768
    G01 X0.4222 Y2.1782
    G01 X0.4148 Y2.1782
    G01 X0.4076 Y2.1768
    G01 X0.4008 Y2.1740
    G01 X0.3947 Y2.1699
    G01 X0.3895 Y2.1647
    G01 X0.3854 Y2.1586
    G01 X0.3826 Y2.1518
    G01 X0.3812 Y2.1446
    G01 X0.3812 Y2.0712
    G01 X0.3826 Y2.0640
    G01 X0.3854 Y2.0572
    G01 X0.3895 Y2.0511
    G01 X0.3947 Y2.0459
    G01 X0.4008 Y2.0418
    G01 X0.4076 Y2.0390
    G01 X0.4148 Y2.0375
    G01 X0.4222 Y2.0375
    G01 X0.4294 Y2.0390
    G01 X0.4362 Y2.0418
    G01 X0.4423 Y2.0459
    G01 X0.4475 Y2.0511
    G01 X0.4516 Y2.0572
    G01 X0.4544 Y2.0640
    G01 X0.4558 Y2.0712
    G01 X0.4558 Y2.1221
    G01 X0.7187 Y2.3850
    G01 X0.7217 Y2.3880
    G01 X0.7239 Y2.3917
    G01 X0.7250 Y2.3959
    G01 X0.7250 Y2.9066
    G01 X0.8335 Y3.0152
    G01 X0.8987 Y3.0152
    G01 X0.9639 Y2.9500
    G01 X0.9632 Y2.9500
    G01 X0.9390 Y2.9258
    G01 X0.9390 Y2.8915
    G01 X0.9632 Y2.8673
    G01 X0.9974 Y2.8673
    G01 X1.0216 Y2.8915
    G00 Z0.0787
    G00 X3.3583 Y1.6648
    G01 Z-0.0039 F5.91
    G01 X3.3583 Y1.6990 F7.87
    G01 X3.3340 Y1.7232
    G01 X3.2998 Y1.7232
    G01 X3.2756 Y1.6990
    G01 X3.2756 Y1.6648
    G01 X3.2998 Y1.6406
    G01 X3.3340 Y1.6406
    G01 X3.3583 Y1.6648
    G00 Z0.0787
    G00 X3.2583 Y1.6648
    G01 Z-0.0039 F5.91
    G01 X3.2583 Y1.6990 F7.87
    G01 X3.2340 Y1.7232
    G01 X3.1998 Y1.7232
    G01 X3.1756 Y1.6990
    G01 X3.1756 Y1.6982
    G01 X2.5459 Y1.6982
    G01 X2.5417 Y1.6971
    G01 X2.5380 Y1.6950
    G01 X2.4224 Y1.5793
    G01 X2.1052 Y1.5793
    G01 X2.0636 Y1.6209
    G01 X2.0636 Y1.7255
    G01 X2.1335 Y1.7955
    G01 X2.1496 Y1.7955
    G01 X2.1516 Y1.7925
    G01 X2.1558 Y1.7883
    G01 X2.1608 Y1.7849
    G01 X2.1663 Y1.7826
    G01 X2.1722 Y1.7815
    G01 X2.2302 Y1.7815
    G01 X2.2360 Y1.7826
    G01 X2.2415 Y1.7849
    G01 X2.2465 Y1.7883
    G01 X2.2507 Y1.7925
    G01 X2.2541 Y1.7974
    G01 X2.2563 Y1.8030
    G01 X2.2575 Y1.8088
    G01 X2.2575 Y1.8148
    G01 X2.2563 Y1.8207
    G01 X2.2541 Y1.8262
    G01 X2.2507 Y1.8311
    G01 X2.2465 Y1.8354
    G01 X2.2415 Y1.8387
    G01 X2.2360 Y1.8410
    G01 X2.2302 Y1.8421
    G01 X2.1722 Y1.8421
    G01 X2.1663 Y1.8410
    G01 X2.1608 Y1.8387
    G01 X2.1558 Y1.8354
    G01 X2.1516 Y1.8311
    G01 X2.1496 Y1.8281
    G01 X2.1246 Y1.8281
    G01 X2.1205 Y1.8270
    G01 X2.1167 Y1.8249
    G01 X2.1137 Y1.8218
    G01 X2.0342 Y1.7423
    G01 X2.0320 Y1.7386
    G01 X2.0309 Y1.7344
    G01 X2.0309 Y1.6120
    G01 X2.0320 Y1.6079
    G01 X2.0342 Y1.6041
    G01 X2.0372 Y1.6011
    G01 X2.0884 Y1.5499
    G01 X2.0921 Y1.5478
    G01 X2.0963 Y1.5467
    G01 X2.4313 Y1.5467
    G01 X2.4354 Y1.5478
    G01 X2.4392 Y1.5499
    G01 X2.4422 Y1.5530
    G01 X2.5548 Y1.6656
    G01 X3.1756 Y1.6656
    G01 X3.1756 Y1.6648
    G01 X3.1998 Y1.6406
    G01 X3.2340 Y1.6406
    G01 X3.2583 Y1.6648
    G00 Z0.0787
    G00 X3.3583 Y1.7648
    G01 Z-0.0039 F5.91
    G01 X3.3583 Y1.7990 F7.87
    G01 X3.3340 Y1.8232
    G01 X3.2998 Y1.8232
    G01 X3.2756 Y1.7990
    G01 X3.2756 Y1.7648
    G01 X3.2998 Y1.7406
    G01 X3.3340 Y1.7406
    G01 X3.3583 Y1.7648
    G00 Z0.0787
    G00 X3.3583 Y1.8648
    G01 Z-0.0039 F5.91
    G01 X3.3583 Y1.8990 F7.87
    G01 X3.3340 Y1.9232
    G01 X3.2998 Y1.9232
    G01 X3.2756 Y1.8990
    G01 X3.2756 Y1.8648
    G01 X3.2998 Y1.8406
    G01 X3.3340 Y1.8406
    G01 X3.3583 Y1.8648
    G00 Z0.0787
    G00 X3.2583 Y1.8648
    G01 Z-0.0039 F5.91
    G01 X3.2583 Y1.8990 F7.87
    G01 X3.2340 Y1.9232
    G01 X3.1998 Y1.9232
    G01 X3.1756 Y1.8990
    G01 X3.1756 Y1.8785
    G01 X2.1002 Y1.8785
    G01 X2.0961 Y1.8774
    G01 X2.0923 Y1.8753
    G01 X1.9585 Y1.7414
    G01 X1.9554 Y1.7384
    G01 X1.9533 Y1.7346
    G01 X1.9522 Y1.7305
    G01 X1.9522 Y1.5333
    G01 X1.9533 Y1.5291
    G01 X1.9554 Y1.5254
    G01 X2.0942 Y1.3866
    G01 X2.0973 Y1.3836
    G01 X2.1010 Y1.3814
    G01 X2.1051 Y1.3803
    G01 X2.1882 Y1.3803
    G01 X2.1923 Y1.3814
    G01 X2.2302 Y1.3815
    G01 X2.2360 Y1.3826
    G01 X2.2415 Y1.3849
    G01 X2.2465 Y1.3883
    G01 X2.2507 Y1.3925
    G01 X2.2541 Y1.3974
    G01 X2.2563 Y1.4030
    G01 X2.2575 Y1.4088
    G01 X2.2575 Y1.4148
    G01 X2.2563 Y1.4207
    G01 X2.2541 Y1.4262
    G01 X2.2507 Y1.4311
    G01 X2.2465 Y1.4354
    G01 X2.2415 Y1.4387
    G01 X2.2360 Y1.4410
    G01 X2.2302 Y1.4421
    G01 X2.1722 Y1.4421
    G01 X2.1663 Y1.4410
    G01 X2.1608 Y1.4387
    G01 X2.1558 Y1.4354
    G01 X2.1516 Y1.4311
    G01 X2.1483 Y1.4262
    G01 X2.1460 Y1.4207
    G01 X2.1449 Y1.4148
    G01 X2.1449 Y1.4130
    G01 X2.1140 Y1.4130
    G01 X1.9848 Y1.5422
    G01 X1.9848 Y1.7216
    G01 X2.1091 Y1.8459
    G01 X3.1945 Y1.8459
    G01 X3.1998 Y1.8406
    G01 X3.2340 Y1.8406
    G01 X3.2583 Y1.8648
    G00 Z0.0787
    G00 X3.3583 Y1.9648
    G01 Z-0.0039 F5.91
    G01 X3.3583 Y1.9990 F7.87
    G01 X3.3340 Y2.0232
    G01 X3.2998 Y2.0232
    G01 X3.2756 Y1.9990
    G01 X3.2756 Y1.9648
    G01 X3.2998 Y1.9406
    G01 X3.3340 Y1.9406
    G01 X3.3583 Y1.9648
    G00 Z0.0787
    G00 X3.3583 Y2.0648
    G01 Z-0.0039 F5.91
    G01 X3.3583 Y2.0990 F7.87
    G01 X3.3340 Y2.1232
    G01 X3.2998 Y2.1232
    G01 X3.2756 Y2.0990
    G01 X3.2756 Y2.0648
    G01 X3.2998 Y2.0406
    G01 X3.3340 Y2.0406
    G01 X3.3583 Y2.0648
    G00 Z0.0787
    G00 X1.0335 Y1.5467
    G01 Z-0.0039 F5.91
    G01 X1.0335 Y1.5809 F7.87
    G01 X1.0092 Y1.6051
    G01 X0.9750 Y1.6051
    G01 X0.9508 Y1.5809
    G01 X0.9508 Y1.5467
    G01 X0.9750 Y1.5224
    G01 X1.0092 Y1.5224
    G01 X1.0098 Y1.5230
    G01 X1.5980 Y0.9349
    G01 X1.6010 Y0.9318
    G01 X1.6047 Y0.9297
    G01 X1.6089 Y0.9286
    G01 X1.8132 Y0.9286
    G01 X1.8173 Y0.9297
    G01 X1.8211 Y0.9318
    G01 X1.9847 Y1.0955
    G01 X2.1496 Y1.0955
    G01 X2.1516 Y1.0925
    G01 X2.1558 Y1.0883
    G01 X2.1608 Y1.0849
    G01 X2.1663 Y1.0826
    G01 X2.1722 Y1.0815
    G01 X2.2302 Y1.0815
    G01 X2.2360 Y1.0826
    G01 X2.2415 Y1.0849
    G01 X2.2465 Y1.0883
    G01 X2.2507 Y1.0925
    G01 X2.2541 Y1.0974
    G01 X2.2563 Y1.1030
    G01 X2.2575 Y1.1088
    G01 X2.2575 Y1.1148
    G01 X2.2563 Y1.1207
    G01 X2.2541 Y1.1262
    G01 X2.2507 Y1.1311
    G01 X2.2465 Y1.1354
    G01 X2.2415 Y1.1387
    G01 X2.2360 Y1.1410
    G01 X2.2302 Y1.1421
    G01 X2.1722 Y1.1421
    G01 X2.1663 Y1.1410
    G01 X2.1608 Y1.1387
    G01 X2.1558 Y1.1354
    G01 X2.1516 Y1.1311
    G01 X2.1496 Y1.1281
    G01 X1.9758 Y1.1281
    G01 X1.9716 Y1.1270
    G01 X1.9679 Y1.1249
    G01 X1.9649 Y1.1218
    G01 X1.8043 Y0.9612
    G01 X1.6178 Y0.9612
    G01 X1.0329 Y1.5461
    G01 X1.0335 Y1.5467
    G00 Z0.0787
    G00 X0.9335 Y1.5467
    G01 Z-0.0039 F5.91
    G01 X0.9335 Y1.5809 F7.87
    G01 X0.9092 Y1.6051
    G01 X0.8750 Y1.6051
    G01 X0.8508 Y1.5809
    G01 X0.8508 Y1.5467
    G01 X0.8750 Y1.5224
    G01 X0.9092 Y1.5224
    G01 X0.9335 Y1.5467
    G00 Z0.0787
    G00 X1.0335 Y1.6467
    G01 Z-0.0039 F5.91
    G01 X1.0335 Y1.6474 F7.87
    G01 X1.1424 Y1.6474
    G01 X1.5552 Y1.2347
    G01 X1.5516 Y1.2311
    G01 X1.5483 Y1.2262
    G01 X1.5460 Y1.2207
    G01 X1.5449 Y1.2148
    G01 X1.5449 Y1.2088
    G01 X1.5460 Y1.2030
    G01 X1.5483 Y1.1974
    G01 X1.5516 Y1.1925
    G01 X1.5558 Y1.1883
    G01 X1.5608 Y1.1849
    G01 X1.5663 Y1.1826
    G01 X1.5722 Y1.1815
    G01 X1.6302 Y1.1815
    G01 X1.6360 Y1.1826
    G01 X1.6415 Y1.1849
    G01 X1.6465 Y1.1883
    G01 X1.6507 Y1.1925
    G01 X1.6541 Y1.1974
    G01 X1.6563 Y1.2030
    G01 X1.6575 Y1.2088
    G01 X1.6575 Y1.2148
    G01 X1.6563 Y1.2207
    G01 X1.6541 Y1.2262
    G01 X1.6507 Y1.2311
    G01 X1.6465 Y1.2354
    G01 X1.6415 Y1.2387
    G01 X1.6360 Y1.2410
    G01 X1.6302 Y1.2421
    G01 X1.5939 Y1.2421
    G01 X1.1623 Y1.6738
    G01 X1.1592 Y1.6768
    G01 X1.1555 Y1.6790
    G01 X1.1514 Y1.6801
    G01 X1.0335 Y1.6801
    G01 X1.0335 Y1.6809
    G01 X1.0092 Y1.7051
    G01 X0.9750 Y1.7051
    G01 X0.9508 Y1.6809
    G01 X0.9508 Y1.6467
    G01 X0.9750 Y1.6224
    G01 X1.0092 Y1.6224
    G01 X1.0335 Y1.6467
    G00 Z0.0787
    G00 X0.9335 Y1.6467
    G01 Z-0.0039 F5.91
    G01 X0.9335 Y1.6809 F7.87
    G01 X0.9092 Y1.7051
    G01 X0.8750 Y1.7051
    G01 X0.8508 Y1.6809
    G01 X0.8508 Y1.6467
    G01 X0.8750 Y1.6224
    G01 X0.9092 Y1.6224
    G01 X0.9335 Y1.6467
    G00 Z0.0787
    G00 X1.0335 Y1.7467
    G01 Z-0.0039 F5.91
    G01 X1.0335 Y1.7474 F7.87
    G01 X1.2424 Y1.7474
    G01 X1.5552 Y1.4347
    G01 X1.5516 Y1.4311
    G01 X1.5483 Y1.4262
    G01 X1.5460 Y1.4207
    G01 X1.5449 Y1.4148
    G01 X1.5449 Y1.4088
    G01 X1.5460 Y1.4030
    G01 X1.5483 Y1.3974
    G01 X1.5516 Y1.3925
    G01 X1.5558 Y1.3883
    G01 X1.5608 Y1.3849
    G01 X1.5663 Y1.3826
    G01 X1.5722 Y1.3815
    G01 X1.6302 Y1.3815
    G01 X1.6360 Y1.3826
    G01 X1.6415 Y1.3849
    G01 X1.6465 Y1.3883
    G01 X1.6507 Y1.3925
    G01 X1.6541 Y1.3974
    G01 X1.6563 Y1.4030
    G01 X1.6575 Y1.4088
    G01 X1.6575 Y1.4148
    G01 X1.6563 Y1.4207
    G01 X1.6541 Y1.4262
    G01 X1.6507 Y1.4311
    G01 X1.6465 Y1.4354
    G01 X1.6415 Y1.4387
    G01 X1.6360 Y1.4410
    G01 X1.6302 Y1.4421
    G01 X1.5939 Y1.4421
    G01 X1.2623 Y1.7738
    G01 X1.2592 Y1.7768
    G01 X1.2555 Y1.7790
    G01 X1.2514 Y1.7801
    G01 X1.0335 Y1.7801
    G01 X1.0335 Y1.7809
    G01 X1.0092 Y1.8051
    G01 X0.9750 Y1.8051
    G01 X0.9508 Y1.7809
    G01 X0.9508 Y1.7467
    G01 X0.9750 Y1.7224
    G01 X1.0092 Y1.7224
    G01 X1.0335 Y1.7467
    G00 Z0.0787
    G00 X0.9335 Y1.7467
    G01 Z-0.0039 F5.91
    G01 X0.9335 Y1.7809 F7.87
    G01 X0.9092 Y1.8051
    G01 X0.8750 Y1.8051
    G01 X0.8508 Y1.7809
    G01 X0.8508 Y1.7467
    G01 X0.8750 Y1.7224
    G01 X0.9092 Y1.7224
    G01 X0.9335 Y1.7467
    G00 Z0.0787
    G00 X1.0335 Y1.8467
    G01 Z-0.0039 F5.91
    G01 X1.0335 Y1.8474 F7.87
    G01 X1.3424 Y1.8474
    G01 X1.5552 Y1.6347
    G01 X1.5516 Y1.6311
    G01 X1.5483 Y1.6262
    G01 X1.5460 Y1.6207
    G01 X1.5449 Y1.6148
    G01 X1.5449 Y1.6088
    G01 X1.5460 Y1.6030
    G01 X1.5483 Y1.5974
    G01 X1.5516 Y1.5925
    G01 X1.5558 Y1.5883
    G01 X1.5608 Y1.5849
    G01 X1.5663 Y1.5826
    G01 X1.5722 Y1.5815
    G01 X1.6302 Y1.5815
    G01 X1.6360 Y1.5826
    G01 X1.6415 Y1.5849
    G01 X1.6465 Y1.5883
    G01 X1.6507 Y1.5925
    G01 X1.6541 Y1.5974
    G01 X1.6563 Y1.6030
    G01 X1.6575 Y1.6088
    G01 X1.6575 Y1.6148
    G01 X1.6563 Y1.6207
    G01 X1.6541 Y1.6262
    G01 X1.6507 Y1.6311
    G01 X1.6465 Y1.6354
    G01 X1.6415 Y1.6387
    G01 X1.6360 Y1.6410
    G01 X1.6302 Y1.6421
    G01 X1.5939 Y1.6421
    G01 X1.3623 Y1.8738
    G01 X1.3592 Y1.8768
    G01 X1.3555 Y1.8790
    G01 X1.3514 Y1.8801
    G01 X1.0335 Y1.8801
    G01 X1.0335 Y1.8809
    G01 X1.0092 Y1.9051
    G01 X0.9750 Y1.9051
    G01 X0.9508 Y1.8809
    G01 X0.9508 Y1.8467
    G01 X0.9750 Y1.8224
    G01 X1.0092 Y1.8224
    G01 X1.0335 Y1.8467
    G00 Z0.0787
    G00 X0.9335 Y1.8467
    G01 Z-0.0039 F5.91
    G01 X0.9335 Y1.8809 F7.87
    G01 X0.9092 Y1.9051
    G01 X0.8750 Y1.9051
    G01 X0.8508 Y1.8809
    G01 X0.8508 Y1.8467
    G01 X0.8750 Y1.8224
    G01 X0.9092 Y1.8224
    G01 X0.9335 Y1.8467
    G00 Z0.0787
    G00 X1.9449 Y0.3112
    G01 Z-0.0039 F5.91
    G01 X1.9449 Y0.3455 F7.87
    G01 X1.9207 Y0.3697
    G01 X1.8864 Y0.3697
    G01 X1.8622 Y0.3455
    G01 X1.8622 Y0.3112
    G01 X1.8864 Y0.2870
    G01 X1.9207 Y0.2870
    G01 X1.9449 Y0.3112
    G00 Z0.0787
    G00 X2.0449 Y0.2112
    G01 Z-0.0039 F5.91
    G01 X2.0449 Y0.2455 F7.87
    G01 X2.0207 Y0.2697
    G01 X1.9864 Y0.2697
    G01 X1.9622 Y0.2455
    G01 X1.9622 Y0.2112
    G01 X1.9864 Y0.1870
    G01 X2.0207 Y0.1870
    G01 X2.0449 Y0.2112
    G00 Z0.0787
    G00 X2.0449 Y0.3112
    G01 Z-0.0039 F5.91
    G01 X2.0449 Y0.3455 F7.87
    G01 X2.0207 Y0.3697
    G01 X2.0199 Y0.3697
    G01 X2.0199 Y0.7763
    G01 X2.2037 Y0.9601
    G01 X2.2254 Y0.9601
    G01 X2.2270 Y0.9608
    G01 X2.2282 Y0.9620
    G01 X2.2289 Y0.9636
    G01 X2.2289 Y1.0049
    G01 X2.2282 Y1.0065
    G01 X2.2270 Y1.0077
    G01 X2.2254 Y1.0084
    G01 X2.1841 Y1.0084
    G01 X2.1825 Y1.0077
    G01 X2.1812 Y1.0065
    G01 X2.1806 Y1.0049
    G01 X2.1806 Y0.9832
    G01 X1.9905 Y0.7931
    G01 X1.9883 Y0.7894
    G01 X1.9872 Y0.7852
    G01 X1.9872 Y0.3697
    G01 X1.9864 Y0.3697
    G01 X1.9622 Y0.3455
    G01 X1.9622 Y0.3112
    G01 X1.9864 Y0.2870
    G01 X2.0207 Y0.2870
    G01 X2.0449 Y0.3112
    G00 Z0.0787
    G00 X2.1449 Y0.2112
    G01 Z-0.0039 F5.91
    G01 X2.1449 Y0.2455 F7.87
    G01 X2.1207 Y0.2697
    G01 X2.0864 Y0.2697
    G01 X2.0622 Y0.2455
    G01 X2.0622 Y0.2112
    G01 X2.0864 Y0.1870
    G01 X2.1207 Y0.1870
    G01 X2.1449 Y0.2112
    G00 Z0.0787
    G00 X2.2449 Y0.2112
    G01 Z-0.0039 F5.91
    G01 X2.2449 Y0.2455 F7.87
    G01 X2.2207 Y0.2697
    G01 X2.1864 Y0.2697
    G01 X2.1622 Y0.2455
    G01 X2.1622 Y0.2112
    G01 X2.1864 Y0.1870
    G01 X2.2207 Y0.1870
    G01 X2.2449 Y0.2112
    G00 Z0.0787
    G00 X2.2449 Y0.3112
    G01 Z-0.0039 F5.91
    G01 X2.2449 Y0.3455 F7.87
    G01 X2.2207 Y0.3697
    G01 X2.1864 Y0.3697
    G01 X2.1622 Y0.3455
    G01 X2.1622 Y0.3112
    G01 X2.1864 Y0.2870
    G01 X2.2207 Y0.2870
    G01 X2.2449 Y0.3112
    G00 Z0.0787
    G00 X2.3449 Y0.2112
    G01 Z-0.0039 F5.91
    G01 X2.3449 Y0.2455 F7.87
    G01 X2.3207 Y0.2697
    G01 X2.2864 Y0.2697
    G01 X2.2622 Y0.2455
    G01 X2.2622 Y0.2112
    G01 X2.2685 Y0.2050
    G01 X2.1980 Y0.1344
    G01 X1.9753 Y0.1344
    G01 X1.9217 Y0.1880
    G01 X1.9449 Y0.2112
    G01 X1.9449 Y0.2455
    G01 X1.9207 Y0.2697
    G01 X1.8864 Y0.2697
    G01 X1.8622 Y0.2455
    G01 X1.8622 Y0.2112
    G01 X1.8864 Y0.1870
    G01 X1.8872 Y0.1870
    G01 X1.8872 Y0.1809
    G01 X1.8883 Y0.1768
    G01 X1.8905 Y0.1730
    G01 X1.9554 Y0.1081
    G01 X1.9585 Y0.1050
    G01 X1.9622 Y0.1029
    G01 X1.9664 Y0.1018
    G01 X2.2069 Y0.1018
    G01 X2.2110 Y0.1029
    G01 X2.2148 Y0.1050
    G01 X2.2967 Y0.1870
    G01 X2.3207 Y0.1870
    G01 X2.3449 Y0.2112
    G00 Z0.0787
    G00 X2.3449 Y0.3112
    G01 Z-0.0039 F5.91
    G01 X2.3449 Y0.3455 F7.87
    G01 X2.3207 Y0.3697
    G01 X2.2864 Y0.3697
    G01 X2.2622 Y0.3455
    G01 X2.2622 Y0.3112
    G01 X2.2864 Y0.2870
    G01 X2.3207 Y0.2870
    G01 X2.3449 Y0.3112
    G00 Z0.0787
    G00 X2.7121 Y1.1032
    G01 Z-0.0039 F5.91
    G01 X2.6951 Y1.1032 F7.87
    G01 X2.6951 Y1.1346
    G01 X2.7121 Y1.1346
    G01 X2.7188 Y1.1359
    G01 X2.7250 Y1.1385
    G01 X2.7306 Y1.1422
    G01 X2.7354 Y1.1470
    G01 X2.7392 Y1.1526
    G01 X2.7418 Y1.1589
    G01 X2.7431 Y1.1655
    G01 X2.7431 Y1.1723
    G01 X2.7422 Y1.1766
    G01 X3.0640 Y1.4984
    G01 X3.0838 Y1.4984
    G01 X3.0978 Y1.5124
    G01 X3.3274 Y1.5124
    G01 X3.3335 Y1.5063
    G01 X3.3586 Y1.5063
    G01 X3.3764 Y1.5241
    G01 X3.3764 Y1.5492
    G01 X3.3586 Y1.5669
    G01 X3.3335 Y1.5669
    G01 X3.3157 Y1.5492
    G01 X3.3157 Y1.5451
    G01 X3.0978 Y1.5451
    G01 X3.0838 Y1.5591
    G01 X3.0587 Y1.5591
    G01 X3.0409 Y1.5413
    G01 X3.0409 Y1.5215
    G01 X2.7206 Y1.2012
    G01 X2.7188 Y1.2019
    G01 X2.7121 Y1.2032
    G01 X2.6454 Y1.2032
    G01 X2.6387 Y1.2019
    G01 X2.6325 Y1.1993
    G01 X2.6269 Y1.1956
    G01 X2.6221 Y1.1908
    G01 X2.6183 Y1.1852
    G01 X2.6157 Y1.1789
    G01 X2.6144 Y1.1723
    G01 X2.6144 Y1.1655
    G01 X2.6157 Y1.1589
    G01 X2.6183 Y1.1526
    G01 X2.6221 Y1.1470
    G01 X2.6269 Y1.1422
    G01 X2.6325 Y1.1385
    G01 X2.6387 Y1.1359
    G01 X2.6454 Y1.1346
    G01 X2.6624 Y1.1346
    G01 X2.6624 Y1.1032
    G01 X2.6454 Y1.1032
    G01 X2.6387 Y1.1019
    G01 X2.6325 Y1.0993
    G01 X2.6269 Y1.0956
    G01 X2.6221 Y1.0908
    G01 X2.6183 Y1.0852
    G01 X2.6157 Y1.0789
    G01 X2.6144 Y1.0723
    G01 X2.6144 Y1.0655
    G01 X2.6157 Y1.0589
    G01 X2.6183 Y1.0526
    G01 X2.6221 Y1.0470
    G01 X2.6269 Y1.0422
    G01 X2.6325 Y1.0385
    G01 X2.6387 Y1.0359
    G01 X2.6454 Y1.0346
    G01 X2.6624 Y1.0346
    G01 X2.6624 Y1.0032
    G01 X2.6454 Y1.0032
    G01 X2.6387 Y1.0019
    G01 X2.6325 Y0.9993
    G01 X2.6269 Y0.9956
    G01 X2.6221 Y0.9908
    G01 X2.6183 Y0.9852
    G01 X2.6157 Y0.9789
    G01 X2.6144 Y0.9723
    G01 X2.6144 Y0.9655
    G01 X2.6157 Y0.9589
    G01 X2.6183 Y0.9526
    G01 X2.6221 Y0.9470
    G01 X2.6269 Y0.9422
    G01 X2.6325 Y0.9385
    G01 X2.6387 Y0.9359
    G01 X2.6454 Y0.9346
    G01 X2.7121 Y0.9346
    G01 X2.7188 Y0.9359
    G01 X2.7250 Y0.9385
    G01 X2.7306 Y0.9422
    G01 X2.7354 Y0.9470
    G01 X2.7392 Y0.9526
    G01 X2.7418 Y0.9589
    G01 X2.7431 Y0.9655
    G01 X2.7431 Y0.9723
    G01 X2.7418 Y0.9789
    G01 X2.7392 Y0.9852
    G01 X2.7354 Y0.9908
    G01 X2.7306 Y0.9956
    G01 X2.7250 Y0.9993
    G01 X2.7188 Y1.0019
    G01 X2.7121 Y1.0032
    G01 X2.6951 Y1.0032
    G01 X2.6951 Y1.0346
    G01 X2.7121 Y1.0346
    G01 X2.7188 Y1.0359
    G01 X2.7250 Y1.0385
    G01 X2.7306 Y1.0422
    G01 X2.7354 Y1.0470
    G01 X2.7392 Y1.0526
    G01 X2.7418 Y1.0589
    G01 X2.7431 Y1.0655
    G01 X2.7431 Y1.0723
    G01 X2.7418 Y1.0789
    G01 X2.7392 Y1.0852
    G01 X2.7354 Y1.0908
    G01 X2.7306 Y1.0956
    G01 X2.7250 Y1.0993
    G01 X2.7188 Y1.1019
    G01 X2.7121 Y1.1032
    G00 Z0.0787
    G00 X3.3764 Y1.1241
    G01 Z-0.0039 F5.91
    G01 X3.3764 Y1.1492 F7.87
    G01 X3.3586 Y1.1669
    G01 X3.3335 Y1.1669
    G01 X3.3157 Y1.1492
    G01 X3.3157 Y1.1241
    G01 X3.3335 Y1.1063
    G01 X3.3586 Y1.1063
    G01 X3.3764 Y1.1241
    G00 Z0.0787
    G00 X2.7496 Y0.3215
    G01 Z-0.0039 F5.91
    G01 X2.7496 Y0.3467 F7.87
    G01 X2.7319 Y0.3644
    G01 X2.7067 Y0.3644
    G01 X2.6890 Y0.3467
    G01 X2.6890 Y0.3215
    G01 X2.7067 Y0.3038
    G01 X2.7319 Y0.3038
    G01 X2.7496 Y0.3215
    G00 Z0.0787
    G00 X0.2812 Y2.1446
    G01 Z-0.0039 F5.91
    G01 X0.2812 Y2.0712 F7.87
    G01 X0.2826 Y2.0640
    G01 X0.2854 Y2.0572
    G01 X0.2895 Y2.0511
    G01 X0.2947 Y2.0459
    G01 X0.3008 Y2.0418
    G01 X0.3076 Y2.0390
    G01 X0.3148 Y2.0375
    G01 X0.3222 Y2.0375
    G01 X0.3294 Y2.0390
    G01 X0.3362 Y2.0418
    G01 X0.3423 Y2.0459
    G01 X0.3475 Y2.0511
    G01 X0.3516 Y2.0572
    G01 X0.3544 Y2.0640
    G01 X0.3558 Y2.0712
    G01 X0.3558 Y2.1446
    G01 X0.3544 Y2.1518
    G01 X0.3516 Y2.1586
    G01 X0.3475 Y2.1647
    G01 X0.3423 Y2.1699
    G01 X0.3362 Y2.1740
    G01 X0.3294 Y2.1768
    G01 X0.3222 Y2.1782
    G01 X0.3148 Y2.1782
    G01 X0.3076 Y2.1768
    G01 X0.3008 Y2.1740
    G01 X0.2947 Y2.1699
    G01 X0.2895 Y2.1647
    G01 X0.2854 Y2.1586
    G01 X0.2826 Y2.1518
    G01 X0.2812 Y2.1446
    G00 Z0.0787
    G00 X0.4910 Y0.4287
    G01 Z-0.0039 F5.91
    G01 X0.4177 Y0.4287 F7.87
    G01 X0.4104 Y0.4272
    G01 X0.4036 Y0.4244
    G01 X0.3975 Y0.4203
    G01 X0.3923 Y0.4151
    G01 X0.3882 Y0.4090
    G01 X0.3854 Y0.4022
    G01 X0.3840 Y0.3950
    G01 X0.3840 Y0.3877
    G01 X0.3854 Y0.3804
    G01 X0.3882 Y0.3737
    G01 X0.3923 Y0.3675
    G01 X0.3975 Y0.3623
    G01 X0.4036 Y0.3583
    G01 X0.4104 Y0.3554
    G01 X0.4177 Y0.3540
    G01 X0.4910 Y0.3540
    G01 X0.4982 Y0.3554
    G01 X0.5050 Y0.3583
    G01 X0.5111 Y0.3623
    G01 X0.5163 Y0.3675
    G01 X0.5204 Y0.3737
    G01 X0.5232 Y0.3804
    G01 X0.5247 Y0.3877
    G01 X0.5247 Y0.3950
    G01 X0.5232 Y0.4022
    G01 X0.5204 Y0.4090
    G01 X0.5163 Y0.4151
    G01 X0.5111 Y0.4203
    G01 X0.5050 Y0.4244
    G01 X0.4982 Y0.4272
    G01 X0.4910 Y0.4287
    G00 Z0.0787
    G00 X0.4910 Y0.5287
    G01 Z-0.0039 F5.91
    G01 X0.4177 Y0.5287 F7.87
    G01 X0.4104 Y0.5272
    G01 X0.4036 Y0.5244
    G01 X0.3975 Y0.5203
    G01 X0.3923 Y0.5151
    G01 X0.3882 Y0.5090
    G01 X0.3854 Y0.5022
    G01 X0.3840 Y0.4950
    G01 X0.3840 Y0.4877
    G01 X0.3854 Y0.4804
    G01 X0.3882 Y0.4737
    G01 X0.3923 Y0.4675
    G01 X0.3975 Y0.4623
    G01 X0.4036 Y0.4583
    G01 X0.4104 Y0.4554
    G01 X0.4177 Y0.4540
    G01 X0.4910 Y0.4540
    G01 X0.4982 Y0.4554
    G01 X0.5050 Y0.4583
    G01 X0.5111 Y0.4623
    G01 X0.5163 Y0.4675
    G01 X0.5204 Y0.4737
    G01 X0.5232 Y0.4804
    G01 X0.5247 Y0.4877
    G01 X0.5247 Y0.4950
    G01 X0.5232 Y0.5022
    G01 X0.5204 Y0.5090
    G01 X0.5163 Y0.5151
    G01 X0.5111 Y0.5203
    G01 X0.5050 Y0.5244
    G01 X0.4982 Y0.5272
    G01 X0.4910 Y0.5287
    G00 Z0.0787
    G00 X0.4910 Y0.9236
    G01 Z-0.0039 F5.91
    G01 X0.4177 Y0.9236 F7.87
    G01 X0.4104 Y0.9221
    G01 X0.4036 Y0.9193
    G01 X0.3975 Y0.9152
    G01 X0.3923 Y0.9100
    G01 X0.3882 Y0.9039
    G01 X0.3854 Y0.8971
    G01 X0.3840 Y0.8899
    G01 X0.3840 Y0.8825
    G01 X0.3854 Y0.8753
    G01 X0.3882 Y0.8685
    G01 X0.3923 Y0.8624
    G01 X0.3975 Y0.8572
    G01 X0.4036 Y0.8531
    G01 X0.4104 Y0.8503
    G01 X0.4177 Y0.8489
    G01 X0.4910 Y0.8489
    G01 X0.4982 Y0.8503
    G01 X0.5050 Y0.8531
    G01 X0.5111 Y0.8572
    G01 X0.5163 Y0.8624
    G01 X0.5204 Y0.8685
    G01 X0.5232 Y0.8753
    G01 X0.5247 Y0.8825
    G01 X0.5247 Y0.8899
    G01 X0.5232 Y0.8971
    G01 X0.5204 Y0.9039
    G01 X0.5163 Y0.9100
    G01 X0.5111 Y0.9152
    G01 X0.5050 Y0.9193
    G01 X0.4982 Y0.9221
    G01 X0.4910 Y0.9236
    G00 Z0.0787
    G00 X1.0280 Y2.2055
    G01 Z-0.0039 F5.91
    G01 X1.0280 Y2.2253 F7.87
    G01 X1.0698 Y2.2671
    G01 X1.5228 Y2.2671
    G01 X1.5552 Y2.2347
    G01 X1.5516 Y2.2311
    G01 X1.5483 Y2.2262
    G01 X1.5460 Y2.2207
    G01 X1.5449 Y2.2148
    G01 X1.5449 Y2.2088
    G01 X1.5460 Y2.2030
    G01 X1.5483 Y2.1974
    G01 X1.5516 Y2.1925
    G01 X1.5558 Y2.1883
    G01 X1.5608 Y2.1849
    G01 X1.5663 Y2.1826
    G01 X1.5722 Y2.1815
    G01 X1.6302 Y2.1815
    G01 X1.6360 Y2.1826
    G01 X1.6415 Y2.1849
    G01 X1.6465 Y2.1883
    G01 X1.6507 Y2.1925
    G01 X1.6541 Y2.1974
    G01 X1.6563 Y2.2030
    G01 X1.6575 Y2.2088
    G01 X1.6575 Y2.2148
    G01 X1.6563 Y2.2207
    G01 X1.6541 Y2.2262
    G01 X1.6507 Y2.2311
    G01 X1.6465 Y2.2354
    G01 X1.6415 Y2.2387
    G01 X1.6360 Y2.2410
    G01 X1.6302 Y2.2421
    G01 X1.5939 Y2.2421
    G01 X1.5426 Y2.2935
    G01 X1.5396 Y2.2965
    G01 X1.5358 Y2.2987
    G01 X1.5317 Y2.2998
    G01 X1.0608 Y2.2998
    G01 X1.0567 Y2.2987
    G01 X1.0530 Y2.2965
    G01 X1.0049 Y2.2484
    G01 X0.9851 Y2.2484
    G01 X0.9673 Y2.2307
    G01 X0.9673 Y2.2055
    G01 X0.9851 Y2.1878
    G01 X1.0102 Y2.1878
    G01 X1.0280 Y2.2055
    G00 Z0.0787
    G00 X3.3601 Y0.8516
    G01 Z-0.0039 F5.91
    G01 X3.3021 Y0.8516 F7.87
    G01 X3.2963 Y0.8504
    G01 X3.2907 Y0.8481
    G01 X3.2858 Y0.8448
    G01 X3.2815 Y0.8406
    G01 X3.2782 Y0.8356
    G01 X3.2759 Y0.8301
    G01 X3.2748 Y0.8242
    G01 X3.2748 Y0.8183
    G01 X3.2759 Y0.8124
    G01 X3.2782 Y0.8069
    G01 X3.2815 Y0.8019
    G01 X3.2858 Y0.7977
    G01 X3.2907 Y0.7944
    G01 X3.2963 Y0.7921
    G01 X3.3021 Y0.7909
    G01 X3.3601 Y0.7909
    G01 X3.3659 Y0.7921
    G01 X3.3715 Y0.7944
    G01 X3.3764 Y0.7977
    G01 X3.3807 Y0.8019
    G01 X3.3840 Y0.8069
    G01 X3.3863 Y0.8124
    G01 X3.3874 Y0.8183
    G01 X3.3874 Y0.8242
    G01 X3.3863 Y0.8301
    G01 X3.3840 Y0.8356
    G01 X3.3807 Y0.8406
    G01 X3.3764 Y0.8448
    G01 X3.3715 Y0.8481
    G01 X3.3659 Y0.8504
    G01 X3.3601 Y0.8516
    G00 Z0.0787
    G00 X3.3601 Y0.7516
    G01 Z-0.0039 F5.91
    G01 X3.3021 Y0.7516 F7.87
    G01 X3.2963 Y0.7504
    G01 X3.2907 Y0.7481
    G01 X3.2858 Y0.7448
    G01 X3.2815 Y0.7406
    G01 X3.2782 Y0.7356
    G01 X3.2759 Y0.7301
    G01 X3.2748 Y0.7242
    G01 X3.2748 Y0.7183
    G01 X3.2759 Y0.7124
    G01 X3.2782 Y0.7069
    G01 X3.2815 Y0.7019
    G01 X3.2858 Y0.6977
    G01 X3.2907 Y0.6944
    G01 X3.2963 Y0.6921
    G01 X3.3021 Y0.6909
    G01 X3.3601 Y0.6909
    G01 X3.3659 Y0.6921
    G01 X3.3715 Y0.6944
    G01 X3.3764 Y0.6977
    G01 X3.3807 Y0.7019
    G01 X3.3840 Y0.7069
    G01 X3.3863 Y0.7124
    G01 X3.3874 Y0.7183
    G01 X3.3874 Y0.7242
    G01 X3.3863 Y0.7301
    G01 X3.3840 Y0.7356
    G01 X3.3807 Y0.7406
    G01 X3.3764 Y0.7448
    G01 X3.3715 Y0.7481
    G01 X3.3659 Y0.7504
    G01 X3.3601 Y0.7516
    G00 Z0.0787
    G00 X3.3601 Y0.6516
    G01 Z-0.0039 F5.91
    G01 X3.3021 Y0.6516 F7.87
    G01 X3.2963 Y0.6504
    G01 X3.2907 Y0.6481
    G01 X3.2858 Y0.6448
    G01 X3.2815 Y0.6406
    G01 X3.2782 Y0.6356
    G01 X3.2759 Y0.6301
    G01 X3.2748 Y0.6242
    G01 X3.2748 Y0.6183
    G01 X3.2759 Y0.6124
    G01 X3.2782 Y0.6069
    G01 X3.2815 Y0.6019
    G01 X3.2851 Y0.5984
    G01 X2.9572 Y0.2704
    G01 X2.7449 Y0.2704
    G01 X2.7429 Y0.2734
    G01 X2.7386 Y0.2777
    G01 X2.7337 Y0.2810
    G01 X2.7281 Y0.2833
    G01 X2.7223 Y0.2844
    G01 X2.7163 Y0.2844
    G01 X2.7104 Y0.2833
    G01 X2.7049 Y0.2810
    G01 X2.7000 Y0.2777
    G01 X2.6957 Y0.2734
    G01 X2.6924 Y0.2685
    G01 X2.6901 Y0.2629
    G01 X2.6890 Y0.2571
    G01 X2.6890 Y0.2511
    G01 X2.6901 Y0.2452
    G01 X2.6924 Y0.2397
    G01 X2.6957 Y0.2348
    G01 X2.7000 Y0.2305
    G01 X2.7049 Y0.2272
    G01 X2.7104 Y0.2249
    G01 X2.7163 Y0.2238
    G01 X2.7223 Y0.2238
    G01 X2.7281 Y0.2249
    G01 X2.7337 Y0.2272
    G01 X2.7386 Y0.2305
    G01 X2.7429 Y0.2348
    G01 X2.7449 Y0.2378
    G01 X2.9661 Y0.2378
    G01 X2.9702 Y0.2389
    G01 X2.9740 Y0.2410
    G01 X2.9770 Y0.2441
    G01 X3.3239 Y0.5909
    G01 X3.3601 Y0.5909
    G01 X3.3659 Y0.5921
    G01 X3.3715 Y0.5944
    G01 X3.3764 Y0.5977
    G01 X3.3807 Y0.6019
    G01 X3.3840 Y0.6069
    G01 X3.3863 Y0.6124
    G01 X3.3874 Y0.6183
    G01 X3.3874 Y0.6242
    G01 X3.3863 Y0.6301
    G01 X3.3840 Y0.6356
    G01 X3.3807 Y0.6406
    G01 X3.3764 Y0.6448
    G01 X3.3715 Y0.6481
    G01 X3.3659 Y0.6504
    G01 X3.3601 Y0.6516
    G00 Z0.0787
    G00 X3.0601 Y0.6516
    G01 Z-0.0039 F5.91
    G01 X3.0021 Y0.6516 F7.87
    G01 X2.9963 Y0.6504
    G01 X2.9907 Y0.6481
    G01 X2.9858 Y0.6448
    G01 X2.9815 Y0.6406
    G01 X2.9782 Y0.6356
    G01 X2.9765 Y0.6314
    G01 X2.7403 Y0.6314
    G01 X2.7263 Y0.6454
    G01 X2.7012 Y0.6454
    G01 X2.6834 Y0.6277
    G01 X2.6834 Y0.6026
    G01 X2.7012 Y0.5848
    G01 X2.7263 Y0.5848
    G01 X2.7403 Y0.5988
    G01 X2.9847 Y0.5988
    G01 X2.9858 Y0.5977
    G01 X2.9907 Y0.5944
    G01 X2.9963 Y0.5921
    G01 X3.0021 Y0.5909
    G01 X3.0601 Y0.5909
    G01 X3.0659 Y0.5921
    G01 X3.0715 Y0.5944
    G01 X3.0764 Y0.5977
    G01 X3.0807 Y0.6019
    G01 X3.0840 Y0.6069
    G01 X3.0863 Y0.6124
    G01 X3.0874 Y0.6183
    G01 X3.0874 Y0.6242
    G01 X3.0863 Y0.6301
    G01 X3.0840 Y0.6356
    G01 X3.0807 Y0.6406
    G01 X3.0764 Y0.6448
    G01 X3.0715 Y0.6481
    G01 X3.0659 Y0.6504
    G01 X3.0601 Y0.6516
    G00 Z0.0787
    G00 X3.0601 Y0.7516
    G01 Z-0.0039 F5.91
    G01 X3.0021 Y0.7516 F7.87
    G01 X2.9963 Y0.7504
    G01 X2.9907 Y0.7481
    G01 X2.9858 Y0.7448
    G01 X2.9815 Y0.7406
    G01 X2.9782 Y0.7356
    G01 X2.9759 Y0.7301
    G01 X2.9748 Y0.7242
    G01 X2.9748 Y0.7183
    G01 X2.9759 Y0.7124
    G01 X2.9782 Y0.7069
    G01 X2.9815 Y0.7019
    G01 X2.9858 Y0.6977
    G01 X2.9907 Y0.6944
    G01 X2.9963 Y0.6921
    G01 X3.0021 Y0.6909
    G01 X3.0601 Y0.6909
    G01 X3.0659 Y0.6921
    G01 X3.0715 Y0.6944
    G01 X3.0764 Y0.6977
    G01 X3.0807 Y0.7019
    G01 X3.0840 Y0.7069
    G01 X3.0863 Y0.7124
    G01 X3.0874 Y0.7183
    G01 X3.0874 Y0.7242
    G01 X3.0863 Y0.7301
    G01 X3.0840 Y0.7356
    G01 X3.0807 Y0.7406
    G01 X3.0764 Y0.7448
    G01 X3.0715 Y0.7481
    G01 X3.0659 Y0.7504
    G01 X3.0601 Y0.7516
    G00 Z0.0787
    G00 X3.0601 Y0.8516
    G01 Z-0.0039 F5.91
    G01 X3.0021 Y0.8516 F7.87
    G01 X2.9963 Y0.8504
    G01 X2.9907 Y0.8481
    G01 X2.9858 Y0.8448
    G01 X2.9815 Y0.8406
    G01 X2.9795 Y0.8376
    G01 X2.8378 Y0.8376
    G01 X2.8336 Y0.8365
    G01 X2.8299 Y0.8343
    G01 X2.8269 Y0.8313
    G01 X2.7203 Y0.7247
    G01 X2.7168 Y0.7254
    G01 X2.7108 Y0.7254
    G01 X2.7049 Y0.7243
    G01 X2.6994 Y0.7220
    G01 X2.6944 Y0.7187
    G01 X2.6902 Y0.7145
    G01 X2.6869 Y0.7095
    G01 X2.6846 Y0.7040
    G01 X2.6834 Y0.6981
    G01 X2.6834 Y0.6921
    G01 X2.6846 Y0.6863
    G01 X2.6869 Y0.6808
    G01 X2.6902 Y0.6758
    G01 X2.6944 Y0.6716
    G01 X2.6994 Y0.6682
    G01 X2.7049 Y0.6660
    G01 X2.7108 Y0.6648
    G01 X2.7168 Y0.6648
    G01 X2.7226 Y0.6660
    G01 X2.7281 Y0.6682
    G01 X2.7331 Y0.6716
    G01 X2.7373 Y0.6758
    G01 X2.7407 Y0.6808
    G01 X2.7429 Y0.6863
    G01 X2.7441 Y0.6921
    G01 X2.7441 Y0.6981
    G01 X2.7434 Y0.7016
    G01 X2.8467 Y0.8049
    G01 X2.9795 Y0.8049
    G01 X2.9815 Y0.8019
    G01 X2.9858 Y0.7977
    G01 X2.9907 Y0.7944
    G01 X2.9963 Y0.7921
    G01 X3.0021 Y0.7909
    G01 X3.0601 Y0.7909
    G01 X3.0659 Y0.7921
    G01 X3.0715 Y0.7944
    G01 X3.0764 Y0.7977
    G01 X3.0807 Y0.8019
    G01 X3.0840 Y0.8069
    G01 X3.0863 Y0.8124
    G01 X3.0874 Y0.8183
    G01 X3.0874 Y0.8242
    G01 X3.0863 Y0.8301
    G01 X3.0840 Y0.8356
    G01 X3.0807 Y0.8406
    G01 X3.0764 Y0.8448
    G01 X3.0715 Y0.8481
    G01 X3.0659 Y0.8504
    G01 X3.0601 Y0.8516
    G00 Z0.0787
    G00 X3.0601 Y0.9516
    G01 Z-0.0039 F5.91
    G01 X3.0021 Y0.9516 F7.87
    G01 X2.9963 Y0.9504
    G01 X2.9907 Y0.9481
    G01 X2.9858 Y0.9448
    G01 X2.9815 Y0.9406
    G01 X2.9782 Y0.9356
    G01 X2.9759 Y0.9301
    G01 X2.9748 Y0.9242
    G01 X2.9748 Y0.9183
    G01 X2.9759 Y0.9124
    G01 X2.9782 Y0.9069
    G01 X2.9815 Y0.9019
    G01 X2.9858 Y0.8977
    G01 X2.9907 Y0.8944
    G01 X2.9963 Y0.8921
    G01 X3.0021 Y0.8909
    G01 X3.0601 Y0.8909
    G01 X3.0659 Y0.8921
    G01 X3.0715 Y0.8944
    G01 X3.0764 Y0.8977
    G01 X3.0807 Y0.9019
    G01 X3.0840 Y0.9069
    G01 X3.0863 Y0.9124
    G01 X3.0874 Y0.9183
    G01 X3.0874 Y0.9242
    G01 X3.0863 Y0.9301
    G01 X3.0840 Y0.9356
    G01 X3.0807 Y0.9406
    G01 X3.0764 Y0.9448
    G01 X3.0715 Y0.9481
    G01 X3.0659 Y0.9504
    G01 X3.0601 Y0.9516
    G00 Z0.0787
    G00 X0.2683 Y0.7056
    G01 Z-0.0039 F5.91
    G01 X0.2683 Y0.7125 F7.87
    G01 X0.2673 Y0.7194
    G01 X0.2651 Y0.7261
    G01 X0.2648 Y0.7267
    G01 X0.3644 Y0.8263
    G01 X0.3674 Y0.8293
    G01 X0.3695 Y0.8331
    G01 X0.3707 Y0.8372
    G01 X0.3707 Y1.0169
    G01 X0.4060 Y1.0522
    G01 X0.4104 Y1.0503
    G01 X0.4177 Y1.0489
    G01 X0.4910 Y1.0489
    G01 X0.4982 Y1.0503
    G01 X0.5050 Y1.0531
    G01 X0.5111 Y1.0572
    G01 X0.5163 Y1.0624
    G01 X0.5204 Y1.0685
    G01 X0.5232 Y1.0753
    G01 X0.5247 Y1.0825
    G01 X0.5247 Y1.0899
    G01 X0.5232 Y1.0971
    G01 X0.5204 Y1.1039
    G01 X0.5163 Y1.1100
    G01 X0.5111 Y1.1152
    G01 X0.5050 Y1.1193
    G01 X0.4982 Y1.1221
    G01 X0.4910 Y1.1236
    G01 X0.4177 Y1.1236
    G01 X0.4104 Y1.1221
    G01 X0.4036 Y1.1193
    G01 X0.3975 Y1.1152
    G01 X0.3923 Y1.1100
    G01 X0.3882 Y1.1039
    G01 X0.3854 Y1.0971
    G01 X0.3840 Y1.0899
    G01 X0.3840 Y1.0825
    G01 X0.3850 Y1.0774
    G01 X0.3413 Y1.0336
    G01 X0.3391 Y1.0299
    G01 X0.3380 Y1.0258
    G01 X0.3380 Y0.8461
    G01 X0.2417 Y0.7498
    G01 X0.2410 Y0.7501
    G01 X0.2344 Y0.7523
    G01 X0.2275 Y0.7534
    G01 X0.2205 Y0.7534
    G01 X0.2136 Y0.7523
    G01 X0.2070 Y0.7501
    G01 X0.2008 Y0.7470
    G01 X0.1951 Y0.7429
    G01 X0.1902 Y0.7379
    G01 X0.1861 Y0.7323
    G01 X0.1829 Y0.7261
    G01 X0.1808 Y0.7194
    G01 X0.1797 Y0.7125
    G01 X0.1797 Y0.7056
    G01 X0.1808 Y0.6987
    G01 X0.1829 Y0.6920
    G01 X0.1861 Y0.6858
    G01 X0.1902 Y0.6802
    G01 X0.1951 Y0.6752
    G01 X0.2008 Y0.6711
    G01 X0.2070 Y0.6680
    G01 X0.2136 Y0.6658
    G01 X0.2205 Y0.6647
    G01 X0.2275 Y0.6647
    G01 X0.2344 Y0.6658
    G01 X0.2410 Y0.6680
    G01 X0.2473 Y0.6711
    G01 X0.2529 Y0.6752
    G01 X0.2578 Y0.6802
    G01 X0.2619 Y0.6858
    G01 X0.2651 Y0.6920
    G01 X0.2673 Y0.6987
    G01 X0.2683 Y0.7056
    G00 Z0.0787
    G00 X0.1832 Y0.5565
    G01 Z-0.0039 F5.91
    G01 X0.1816 Y0.5559 F7.87
    G01 X0.1803 Y0.5547
    G01 X0.1797 Y0.5531
    G01 X0.1797 Y0.4713
    G01 X0.1803 Y0.4698
    G01 X0.1816 Y0.4685
    G01 X0.1832 Y0.4679
    G01 X0.2649 Y0.4679
    G01 X0.2665 Y0.4685
    G01 X0.2677 Y0.4698
    G01 X0.2683 Y0.4713
    G01 X0.2683 Y0.5334
    G01 X0.3099 Y0.5750
    G01 X0.3877 Y0.5750
    G01 X0.3882 Y0.5737
    G01 X0.3923 Y0.5675
    G01 X0.3975 Y0.5623
    G01 X0.4036 Y0.5583
    G01 X0.4104 Y0.5554
    G01 X0.4177 Y0.5540
    G01 X0.4910 Y0.5540
    G01 X0.4982 Y0.5554
    G01 X0.5050 Y0.5583
    G01 X0.5111 Y0.5623
    G01 X0.5163 Y0.5675
    G01 X0.5204 Y0.5737
    G01 X0.5232 Y0.5804
    G01 X0.5247 Y0.5877
    G01 X0.5247 Y0.5950
    G01 X0.5232 Y0.6022
    G01 X0.5204 Y0.6090
    G01 X0.5163 Y0.6151
    G01 X0.5111 Y0.6203
    G01 X0.5050 Y0.6244
    G01 X0.4982 Y0.6272
    G01 X0.4910 Y0.6287
    G01 X0.4177 Y0.6287
    G01 X0.4104 Y0.6272
    G01 X0.4036 Y0.6244
    G01 X0.3975 Y0.6203
    G01 X0.3923 Y0.6151
    G01 X0.3882 Y0.6090
    G01 X0.3877 Y0.6077
    G01 X0.3010 Y0.6077
    G01 X0.2968 Y0.6066
    G01 X0.2931 Y0.6044
    G01 X0.2901 Y0.6014
    G01 X0.2453 Y0.5565
    G01 X0.1832 Y0.5565
    G00 Z0.0787
    G00 X3.5293 Y0.3062
    G01 Z-0.0039 F5.91
    G01 X3.5293 Y0.2245 F7.87
    G01 X3.5300 Y0.2229
    G01 X3.5312 Y0.2217
    G01 X3.5328 Y0.2210
    G01 X3.6145 Y0.2210
    G01 X3.6161 Y0.2217
    G01 X3.6173 Y0.2229
    G01 X3.6180 Y0.2245
    G01 X3.6180 Y0.3062
    G01 X3.6173 Y0.3078
    G01 X3.6161 Y0.3090
    G01 X3.6145 Y0.3097
    G01 X3.5328 Y0.3097
    G01 X3.5312 Y0.3090
    G01 X3.5300 Y0.3078
    G01 X3.5293 Y0.3062
    G00 Z0.0787
    G00 X0.2683 Y1.3237
    G01 Z-0.0039 F5.91
    G01 X0.2683 Y1.3307 F7.87
    G01 X0.2673 Y1.3375
    G01 X0.2651 Y1.3442
    G01 X0.2619 Y1.3504
    G01 X0.2578 Y1.3560
    G01 X0.2529 Y1.3610
    G01 X0.2473 Y1.3651
    G01 X0.2410 Y1.3682
    G01 X0.2344 Y1.3704
    G01 X0.2275 Y1.3715
    G01 X0.2205 Y1.3715
    G01 X0.2136 Y1.3704
    G01 X0.2070 Y1.3682
    G01 X0.2064 Y1.3679
    G01 X0.1344 Y1.4398
    G01 X0.1344 Y1.8043
    G01 X0.1993 Y1.8691
    G01 X0.2008 Y1.8680
    G01 X0.2070 Y1.8648
    G01 X0.2136 Y1.8627
    G01 X0.2205 Y1.8616
    G01 X0.2275 Y1.8616
    G01 X0.2344 Y1.8627
    G01 X0.2410 Y1.8648
    G01 X0.2473 Y1.8680
    G01 X0.2529 Y1.8721
    G01 X0.2578 Y1.8770
    G01 X0.2619 Y1.8827
    G01 X0.2651 Y1.8889
    G01 X0.2673 Y1.8955
    G01 X0.2683 Y1.9024
    G01 X0.2683 Y1.9094
    G01 X0.2673 Y1.9163
    G01 X0.2651 Y1.9229
    G01 X0.2619 Y1.9291
    G01 X0.2578 Y1.9348
    G01 X0.2529 Y1.9397
    G01 X0.2473 Y1.9438
    G01 X0.2410 Y1.9470
    G01 X0.2344 Y1.9491
    G01 X0.2275 Y1.9502
    G01 X0.2205 Y1.9502
    G01 X0.2136 Y1.9491
    G01 X0.2070 Y1.9470
    G01 X0.2008 Y1.9438
    G01 X0.1951 Y1.9397
    G01 X0.1902 Y1.9348
    G01 X0.1861 Y1.9291
    G01 X0.1829 Y1.9229
    G01 X0.1808 Y1.9163
    G01 X0.1797 Y1.9094
    G01 X0.1797 Y1.9024
    G01 X0.1806 Y1.8966
    G01 X0.1050 Y1.8211
    G01 X0.1029 Y1.8173
    G01 X0.1018 Y1.8132
    G01 X0.1018 Y1.4309
    G01 X0.1029 Y1.4268
    G01 X0.1050 Y1.4230
    G01 X0.1081 Y1.4200
    G01 X0.1833 Y1.3448
    G01 X0.1829 Y1.3442
    G01 X0.1808 Y1.3375
    G01 X0.1797 Y1.3307
    G01 X0.1797 Y1.3237
    G01 X0.1808 Y1.3168
    G01 X0.1829 Y1.3101
    G01 X0.1861 Y1.3039
    G01 X0.1902 Y1.2983
    G01 X0.1951 Y1.2934
    G01 X0.2008 Y1.2893
    G01 X0.2070 Y1.2861
    G01 X0.2136 Y1.2839
    G01 X0.2205 Y1.2828
    G01 X0.2275 Y1.2828
    G01 X0.2344 Y1.2839
    G01 X0.2410 Y1.2861
    G01 X0.2473 Y1.2893
    G01 X0.2529 Y1.2934
    G01 X0.2578 Y1.2983
    G01 X0.2619 Y1.3039
    G01 X0.2651 Y1.3101
    G01 X0.2673 Y1.3168
    G01 X0.2683 Y1.3237
    G00 Z0.0787
    G00 X0.2649 Y1.1746
    G01 Z-0.0039 F5.91
    G01 X0.1832 Y1.1746 F7.87
    G01 X0.1816 Y1.1740
    G01 X0.1803 Y1.1728
    G01 X0.1797 Y1.1712
    G01 X0.1797 Y1.0895
    G01 X0.1803 Y1.0879
    G01 X0.1816 Y1.0866
    G01 X0.1832 Y1.0860
    G01 X0.2649 Y1.0860
    G01 X0.2665 Y1.0866
    G01 X0.2677 Y1.0879
    G01 X0.2683 Y1.0895
    G01 X0.2683 Y1.1712
    G01 X0.2677 Y1.1728
    G01 X0.2665 Y1.1740
    G01 X0.2649 Y1.1746
    G00 Z0.0787
    G00 X0.2649 Y1.7534
    G01 Z-0.0039 F5.91
    G01 X0.1832 Y1.7534 F7.87
    G01 X0.1816 Y1.7527
    G01 X0.1803 Y1.7515
    G01 X0.1797 Y1.7499
    G01 X0.1797 Y1.6682
    G01 X0.1803 Y1.6666
    G01 X0.1816 Y1.6654
    G01 X0.1832 Y1.6647
    G01 X0.2649 Y1.6647
    G01 X0.2665 Y1.6654
    G01 X0.2677 Y1.6666
    G01 X0.2683 Y1.6682
    G01 X0.2683 Y1.7499
    G01 X0.2677 Y1.7515
    G01 X0.2665 Y1.7527
    G01 X0.2649 Y1.7534
    G00 Z0.0787
    G00 X2.2302 Y3.0421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y3.0421 F7.87
    G01 X2.1663 Y3.0410
    G01 X2.1608 Y3.0387
    G01 X2.1558 Y3.0354
    G01 X2.1516 Y3.0311
    G01 X2.1483 Y3.0262
    G01 X2.1460 Y3.0207
    G01 X2.1449 Y3.0148
    G01 X2.1449 Y3.0088
    G01 X2.1460 Y3.0030
    G01 X2.1483 Y2.9974
    G01 X2.1516 Y2.9925
    G01 X2.1558 Y2.9883
    G01 X2.1608 Y2.9849
    G01 X2.1663 Y2.9826
    G01 X2.1722 Y2.9815
    G01 X2.2302 Y2.9815
    G01 X2.2360 Y2.9826
    G01 X2.2415 Y2.9849
    G01 X2.2465 Y2.9883
    G01 X2.2507 Y2.9925
    G01 X2.2541 Y2.9974
    G01 X2.2563 Y3.0030
    G01 X2.2575 Y3.0088
    G01 X2.2575 Y3.0148
    G01 X2.2563 Y3.0207
    G01 X2.2541 Y3.0262
    G01 X2.2507 Y3.0311
    G01 X2.2465 Y3.0354
    G01 X2.2415 Y3.0387
    G01 X2.2360 Y3.0410
    G01 X2.2302 Y3.0421
    G00 Z0.0787
    G00 X2.2302 Y2.8421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y2.8421 F7.87
    G01 X2.1663 Y2.8410
    G01 X2.1608 Y2.8387
    G01 X2.1558 Y2.8354
    G01 X2.1516 Y2.8311
    G01 X2.1483 Y2.8262
    G01 X2.1460 Y2.8207
    G01 X2.1449 Y2.8148
    G01 X2.1449 Y2.8088
    G01 X2.1460 Y2.8030
    G01 X2.1483 Y2.7974
    G01 X2.1516 Y2.7925
    G01 X2.1558 Y2.7883
    G01 X2.1608 Y2.7849
    G01 X2.1663 Y2.7826
    G01 X2.1722 Y2.7815
    G01 X2.2302 Y2.7815
    G01 X2.2360 Y2.7826
    G01 X2.2415 Y2.7849
    G01 X2.2465 Y2.7883
    G01 X2.2507 Y2.7925
    G01 X2.2541 Y2.7974
    G01 X2.2563 Y2.8030
    G01 X2.2575 Y2.8088
    G01 X2.2575 Y2.8148
    G01 X2.2563 Y2.8207
    G01 X2.2541 Y2.8262
    G01 X2.2507 Y2.8311
    G01 X2.2465 Y2.8354
    G01 X2.2415 Y2.8387
    G01 X2.2360 Y2.8410
    G01 X2.2302 Y2.8421
    G00 Z0.0787
    G00 X2.2302 Y2.7421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y2.7421 F7.87
    G01 X2.1663 Y2.7410
    G01 X2.1608 Y2.7387
    G01 X2.1558 Y2.7354
    G01 X2.1516 Y2.7311
    G01 X2.1496 Y2.7281
    G01 X2.1375 Y2.7281
    G01 X2.0242 Y2.8414
    G01 X2.0242 Y2.9460
    G01 X2.1327 Y3.0545
    G01 X3.3791 Y3.0545
    G01 X3.4482 Y2.9854
    G01 X3.4482 Y2.8808
    G01 X3.3120 Y2.7445
    G01 X3.3065 Y2.7500
    G01 X3.2723 Y2.7500
    G01 X3.2480 Y2.7258
    G01 X3.2480 Y2.6915
    G01 X3.2723 Y2.6673
    G01 X3.3065 Y2.6673
    G01 X3.3307 Y2.6915
    G01 X3.3307 Y2.7171
    G01 X3.4746 Y2.8609
    G01 X3.4776 Y2.8640
    G01 X3.4798 Y2.8677
    G01 X3.4809 Y2.8719
    G01 X3.4809 Y2.9943
    G01 X3.4798 Y2.9984
    G01 X3.4776 Y3.0022
    G01 X3.3989 Y3.0809
    G01 X3.3959 Y3.0839
    G01 X3.3921 Y3.0861
    G01 X3.3880 Y3.0872
    G01 X2.1238 Y3.0872
    G01 X2.1197 Y3.0861
    G01 X2.1160 Y3.0839
    G01 X1.9978 Y2.9658
    G01 X1.9948 Y2.9628
    G01 X1.9927 Y2.9591
    G01 X1.9915 Y2.9549
    G01 X1.9915 Y2.8325
    G01 X1.9927 Y2.8283
    G01 X1.9948 Y2.8246
    G01 X2.1176 Y2.7018
    G01 X2.1207 Y2.6987
    G01 X2.1244 Y2.6966
    G01 X2.1286 Y2.6955
    G01 X2.1496 Y2.6955
    G01 X2.1516 Y2.6925
    G01 X2.1558 Y2.6883
    G01 X2.1608 Y2.6849
    G01 X2.1663 Y2.6826
    G01 X2.1722 Y2.6815
    G01 X2.2302 Y2.6815
    G01 X2.2360 Y2.6826
    G01 X2.2415 Y2.6849
    G01 X2.2465 Y2.6883
    G01 X2.2507 Y2.6925
    G01 X2.2541 Y2.6974
    G01 X2.2563 Y2.7030
    G01 X2.2575 Y2.7088
    G01 X2.2575 Y2.7148
    G01 X2.2563 Y2.7207
    G01 X2.2541 Y2.7262
    G01 X2.2507 Y2.7311
    G01 X2.2465 Y2.7354
    G01 X2.2415 Y2.7387
    G01 X2.2360 Y2.7410
    G01 X2.2302 Y2.7421
    G00 Z0.0787
    G00 X2.2302 Y2.6421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y2.6421 F7.87
    G01 X2.1663 Y2.6410
    G01 X2.1608 Y2.6387
    G01 X2.1558 Y2.6354
    G01 X2.1516 Y2.6311
    G01 X2.1483 Y2.6262
    G01 X2.1460 Y2.6207
    G01 X2.1449 Y2.6148
    G01 X2.1449 Y2.6088
    G01 X2.1460 Y2.6030
    G01 X2.1483 Y2.5974
    G01 X2.1516 Y2.5925
    G01 X2.1558 Y2.5883
    G01 X2.1608 Y2.5849
    G01 X2.1663 Y2.5826
    G01 X2.1722 Y2.5815
    G01 X2.2302 Y2.5815
    G01 X2.2360 Y2.5826
    G01 X2.2415 Y2.5849
    G01 X2.2465 Y2.5883
    G01 X2.2507 Y2.5925
    G01 X2.2541 Y2.5974
    G01 X2.2563 Y2.6030
    G01 X2.2575 Y2.6088
    G01 X2.2575 Y2.6148
    G01 X2.2563 Y2.6207
    G01 X2.2541 Y2.6262
    G01 X2.2507 Y2.6311
    G01 X2.2465 Y2.6354
    G01 X2.2415 Y2.6387
    G01 X2.2360 Y2.6410
    G01 X2.2302 Y2.6421
    G00 Z0.0787
    G00 X2.2302 Y2.5421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y2.5421 F7.87
    G01 X2.1663 Y2.5410
    G01 X2.1608 Y2.5387
    G01 X2.1558 Y2.5354
    G01 X2.1516 Y2.5311
    G01 X2.1483 Y2.5262
    G01 X2.1460 Y2.5207
    G01 X2.1449 Y2.5148
    G01 X2.1449 Y2.5088
    G01 X2.1460 Y2.5030
    G01 X2.1483 Y2.4974
    G01 X2.1516 Y2.4925
    G01 X2.1558 Y2.4883
    G01 X2.1608 Y2.4849
    G01 X2.1663 Y2.4826
    G01 X2.1722 Y2.4815
    G01 X2.2302 Y2.4815
    G01 X2.2360 Y2.4826
    G01 X2.2415 Y2.4849
    G01 X2.2465 Y2.4883
    G01 X2.2507 Y2.4925
    G01 X2.2541 Y2.4974
    G01 X2.2563 Y2.5030
    G01 X2.2575 Y2.5088
    G01 X2.2575 Y2.5148
    G01 X2.2563 Y2.5207
    G01 X2.2541 Y2.5262
    G01 X2.2507 Y2.5311
    G01 X2.2465 Y2.5354
    G01 X2.2415 Y2.5387
    G01 X2.2360 Y2.5410
    G01 X2.2302 Y2.5421
    G00 Z0.0787
    G00 X2.2302 Y2.4421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y2.4421 F7.87
    G01 X2.1663 Y2.4410
    G01 X2.1608 Y2.4387
    G01 X2.1558 Y2.4354
    G01 X2.1516 Y2.4311
    G01 X2.1483 Y2.4262
    G01 X2.1460 Y2.4207
    G01 X2.1449 Y2.4148
    G01 X2.1449 Y2.4088
    G01 X2.1460 Y2.4030
    G01 X2.1483 Y2.3974
    G01 X2.1516 Y2.3925
    G01 X2.1558 Y2.3883
    G01 X2.1608 Y2.3849
    G01 X2.1663 Y2.3826
    G01 X2.1722 Y2.3815
    G01 X2.2302 Y2.3815
    G01 X2.2360 Y2.3826
    G01 X2.2415 Y2.3849
    G01 X2.2465 Y2.3883
    G01 X2.2507 Y2.3925
    G01 X2.2541 Y2.3974
    G01 X2.2563 Y2.4030
    G01 X2.2575 Y2.4088
    G01 X2.2575 Y2.4148
    G01 X2.2563 Y2.4207
    G01 X2.2541 Y2.4262
    G01 X2.2507 Y2.4311
    G01 X2.2465 Y2.4354
    G01 X2.2415 Y2.4387
    G01 X2.2360 Y2.4410
    G01 X2.2302 Y2.4421
    G00 Z0.0787
    G00 X2.2302 Y2.3421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y2.3421 F7.87
    G01 X2.1663 Y2.3410
    G01 X2.1608 Y2.3387
    G01 X2.1558 Y2.3354
    G01 X2.1516 Y2.3311
    G01 X2.1483 Y2.3262
    G01 X2.1460 Y2.3207
    G01 X2.1449 Y2.3148
    G01 X2.1449 Y2.3088
    G01 X2.1460 Y2.3030
    G01 X2.1483 Y2.2974
    G01 X2.1516 Y2.2925
    G01 X2.1558 Y2.2883
    G01 X2.1608 Y2.2849
    G01 X2.1663 Y2.2826
    G01 X2.1722 Y2.2815
    G01 X2.2302 Y2.2815
    G01 X2.2360 Y2.2826
    G01 X2.2415 Y2.2849
    G01 X2.2465 Y2.2883
    G01 X2.2507 Y2.2925
    G01 X2.2541 Y2.2974
    G01 X2.2563 Y2.3030
    G01 X2.2575 Y2.3088
    G01 X2.2575 Y2.3148
    G01 X2.2563 Y2.3207
    G01 X2.2541 Y2.3262
    G01 X2.2507 Y2.3311
    G01 X2.2465 Y2.3354
    G01 X2.2415 Y2.3387
    G01 X2.2360 Y2.3410
    G01 X2.2302 Y2.3421
    G00 Z0.0787
    G00 X2.2302 Y2.2421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y2.2421 F7.87
    G01 X2.1663 Y2.2410
    G01 X2.1608 Y2.2387
    G01 X2.1558 Y2.2354
    G01 X2.1516 Y2.2311
    G01 X2.1483 Y2.2262
    G01 X2.1460 Y2.2207
    G01 X2.1449 Y2.2148
    G01 X2.1449 Y2.2088
    G01 X2.1460 Y2.2030
    G01 X2.1483 Y2.1974
    G01 X2.1516 Y2.1925
    G01 X2.1558 Y2.1883
    G01 X2.1608 Y2.1849
    G01 X2.1663 Y2.1826
    G01 X2.1722 Y2.1815
    G01 X2.2302 Y2.1815
    G01 X2.2360 Y2.1826
    G01 X2.2415 Y2.1849
    G01 X2.2465 Y2.1883
    G01 X2.2507 Y2.1925
    G01 X2.2541 Y2.1974
    G01 X2.2563 Y2.2030
    G01 X2.2575 Y2.2088
    G01 X2.2575 Y2.2148
    G01 X2.2563 Y2.2207
    G01 X2.2541 Y2.2262
    G01 X2.2507 Y2.2311
    G01 X2.2465 Y2.2354
    G01 X2.2415 Y2.2387
    G01 X2.2360 Y2.2410
    G01 X2.2302 Y2.2421
    G00 Z0.0787
    G00 X2.2302 Y2.1421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y2.1421 F7.87
    G01 X2.1663 Y2.1410
    G01 X2.1608 Y2.1387
    G01 X2.1558 Y2.1354
    G01 X2.1516 Y2.1311
    G01 X2.1483 Y2.1262
    G01 X2.1460 Y2.1207
    G01 X2.1449 Y2.1148
    G01 X2.1449 Y2.1088
    G01 X2.1460 Y2.1030
    G01 X2.1483 Y2.0974
    G01 X2.1516 Y2.0925
    G01 X2.1558 Y2.0883
    G01 X2.1608 Y2.0849
    G01 X2.1663 Y2.0826
    G01 X2.1722 Y2.0815
    G01 X2.2302 Y2.0815
    G01 X2.2360 Y2.0826
    G01 X2.2415 Y2.0849
    G01 X2.2465 Y2.0883
    G01 X2.2507 Y2.0925
    G01 X2.2541 Y2.0974
    G01 X2.2563 Y2.1030
    G01 X2.2575 Y2.1088
    G01 X2.2575 Y2.1148
    G01 X2.2563 Y2.1207
    G01 X2.2541 Y2.1262
    G01 X2.2507 Y2.1311
    G01 X2.2465 Y2.1354
    G01 X2.2415 Y2.1387
    G01 X2.2360 Y2.1410
    G01 X2.2302 Y2.1421
    G00 Z0.0787
    G00 X2.2302 Y1.9421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y1.9421 F7.87
    G01 X2.1663 Y1.9410
    G01 X2.1608 Y1.9387
    G01 X2.1558 Y1.9354
    G01 X2.1516 Y1.9311
    G01 X2.1483 Y1.9262
    G01 X2.1460 Y1.9207
    G01 X2.1449 Y1.9148
    G01 X2.1449 Y1.9088
    G01 X2.1460 Y1.9030
    G01 X2.1483 Y1.8974
    G01 X2.1516 Y1.8925
    G01 X2.1558 Y1.8883
    G01 X2.1608 Y1.8849
    G01 X2.1663 Y1.8826
    G01 X2.1722 Y1.8815
    G01 X2.2302 Y1.8815
    G01 X2.2360 Y1.8826
    G01 X2.2415 Y1.8849
    G01 X2.2465 Y1.8883
    G01 X2.2507 Y1.8925
    G01 X2.2541 Y1.8974
    G01 X2.2563 Y1.9030
    G01 X2.2575 Y1.9088
    G01 X2.2575 Y1.9148
    G01 X2.2563 Y1.9207
    G01 X2.2541 Y1.9262
    G01 X2.2507 Y1.9311
    G01 X2.2465 Y1.9354
    G01 X2.2415 Y1.9387
    G01 X2.2360 Y1.9410
    G01 X2.2302 Y1.9421
    G00 Z0.0787
    G00 X2.2302 Y1.7421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y1.7421 F7.87
    G01 X2.1663 Y1.7410
    G01 X2.1608 Y1.7387
    G01 X2.1558 Y1.7354
    G01 X2.1516 Y1.7311
    G01 X2.1483 Y1.7262
    G01 X2.1460 Y1.7207
    G01 X2.1449 Y1.7148
    G01 X2.1449 Y1.7088
    G01 X2.1460 Y1.7030
    G01 X2.1483 Y1.6974
    G01 X2.1516 Y1.6925
    G01 X2.1558 Y1.6883
    G01 X2.1608 Y1.6849
    G01 X2.1663 Y1.6826
    G01 X2.1722 Y1.6815
    G01 X2.2302 Y1.6815
    G01 X2.2360 Y1.6826
    G01 X2.2415 Y1.6849
    G01 X2.2465 Y1.6883
    G01 X2.2507 Y1.6925
    G01 X2.2541 Y1.6974
    G01 X2.2563 Y1.7030
    G01 X2.2575 Y1.7088
    G01 X2.2575 Y1.7148
    G01 X2.2563 Y1.7207
    G01 X2.2541 Y1.7262
    G01 X2.2507 Y1.7311
    G01 X2.2465 Y1.7354
    G01 X2.2415 Y1.7387
    G01 X2.2360 Y1.7410
    G01 X2.2302 Y1.7421
    G00 Z0.0787
    G00 X2.1722 Y1.6421
    G01 Z-0.0039 F5.91
    G01 X2.1663 Y1.6410 F7.87
    G01 X2.1608 Y1.6387
    G01 X2.1558 Y1.6354
    G01 X2.1516 Y1.6311
    G01 X2.1483 Y1.6262
    G01 X2.1460 Y1.6207
    G01 X2.1449 Y1.6148
    G01 X2.1449 Y1.6088
    G01 X2.1460 Y1.6030
    G01 X2.1483 Y1.5974
    G01 X2.1516 Y1.5925
    G01 X2.1558 Y1.5883
    G01 X2.1608 Y1.5849
    G01 X2.1663 Y1.5826
    G01 X2.1722 Y1.5815
    G01 X2.2302 Y1.5815
    G01 X2.2360 Y1.5826
    G01 X2.2415 Y1.5849
    G01 X2.2465 Y1.5883
    G01 X2.2507 Y1.5925
    G01 X2.2541 Y1.5974
    G01 X2.2563 Y1.6030
    G01 X2.2575 Y1.6088
    G01 X2.2575 Y1.6148
    G01 X2.2563 Y1.6207
    G01 X2.2541 Y1.6262
    G01 X2.2507 Y1.6311
    G01 X2.2472 Y1.6347
    G01 X2.3780 Y1.7656
    G01 X3.1756 Y1.7656
    G01 X3.1756 Y1.7648
    G01 X3.1998 Y1.7406
    G01 X3.2340 Y1.7406
    G01 X3.2583 Y1.7648
    G01 X3.2583 Y1.7990
    G01 X3.2340 Y1.8232
    G01 X3.1998 Y1.8232
    G01 X3.1756 Y1.7990
    G01 X3.1756 Y1.7982
    G01 X2.3691 Y1.7982
    G01 X2.3650 Y1.7971
    G01 X2.3612 Y1.7950
    G01 X2.3582 Y1.7919
    G01 X2.2084 Y1.6421
    G01 X2.1722 Y1.6421
    G00 Z0.0787
    G00 X2.2302 Y1.5421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y1.5421 F7.87
    G01 X2.1663 Y1.5410
    G01 X2.1608 Y1.5387
    G01 X2.1558 Y1.5354
    G01 X2.1516 Y1.5311
    G01 X2.1483 Y1.5262
    G01 X2.1460 Y1.5207
    G01 X2.1449 Y1.5148
    G01 X2.1449 Y1.5088
    G01 X2.1460 Y1.5030
    G01 X2.1483 Y1.4974
    G01 X2.1516 Y1.4925
    G01 X2.1558 Y1.4883
    G01 X2.1608 Y1.4849
    G01 X2.1663 Y1.4826
    G01 X2.1722 Y1.4815
    G01 X2.2084 Y1.4815
    G01 X2.3459 Y1.3440
    G01 X2.3459 Y0.9910
    G01 X2.0905 Y0.7356
    G01 X2.0883 Y0.7319
    G01 X2.0872 Y0.7277
    G01 X2.0872 Y0.3697
    G01 X2.0864 Y0.3697
    G01 X2.0622 Y0.3455
    G01 X2.0622 Y0.3112
    G01 X2.0864 Y0.2870
    G01 X2.1207 Y0.2870
    G01 X2.1449 Y0.3112
    G01 X2.1449 Y0.3455
    G01 X2.1207 Y0.3697
    G01 X2.1199 Y0.3697
    G01 X2.1199 Y0.7188
    G01 X2.3722 Y0.9712
    G01 X2.3753 Y0.9742
    G01 X2.3774 Y0.9779
    G01 X2.3785 Y0.9821
    G01 X2.3785 Y1.3529
    G01 X2.3774 Y1.3571
    G01 X2.3753 Y1.3608
    G01 X2.2472 Y1.4889
    G01 X2.2507 Y1.4925
    G01 X2.2541 Y1.4974
    G01 X2.2563 Y1.5030
    G01 X2.2575 Y1.5088
    G01 X2.2575 Y1.5148
    G01 X2.2563 Y1.5207
    G01 X2.2541 Y1.5262
    G01 X2.2507 Y1.5311
    G01 X2.2465 Y1.5354
    G01 X2.2415 Y1.5387
    G01 X2.2360 Y1.5410
    G01 X2.2302 Y1.5421
    G00 Z0.0787
    G00 X2.2302 Y1.3421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y1.3421 F7.87
    G01 X2.1663 Y1.3410
    G01 X2.1608 Y1.3387
    G01 X2.1558 Y1.3354
    G01 X2.1516 Y1.3311
    G01 X2.1483 Y1.3262
    G01 X2.1460 Y1.3207
    G01 X2.1449 Y1.3148
    G01 X2.1449 Y1.3088
    G01 X2.1460 Y1.3030
    G01 X2.1483 Y1.2974
    G01 X2.1516 Y1.2925
    G01 X2.1558 Y1.2883
    G01 X2.1608 Y1.2849
    G01 X2.1663 Y1.2826
    G01 X2.1722 Y1.2815
    G01 X2.2302 Y1.2815
    G01 X2.2360 Y1.2826
    G01 X2.2415 Y1.2849
    G01 X2.2465 Y1.2883
    G01 X2.2507 Y1.2925
    G01 X2.2541 Y1.2974
    G01 X2.2563 Y1.3030
    G01 X2.2575 Y1.3088
    G01 X2.2575 Y1.3148
    G01 X2.2563 Y1.3207
    G01 X2.2541 Y1.3262
    G01 X2.2507 Y1.3311
    G01 X2.2465 Y1.3354
    G01 X2.2415 Y1.3387
    G01 X2.2360 Y1.3410
    G01 X2.2302 Y1.3421
    G00 Z0.0787
    G00 X2.2302 Y1.2421
    G01 Z-0.0039 F5.91
    G01 X2.1722 Y1.2421 F7.87
    G01 X2.1663 Y1.2410
    G01 X2.1608 Y1.2387
    G01 X2.1558 Y1.2354
    G01 X2.1516 Y1.2311
    G01 X2.1496 Y1.2281
    G01 X2.1414 Y1.2281
    G01 X1.9455 Y1.4241
    G01 X1.9455 Y1.8200
    G01 X2.0737 Y1.9482
    G01 X3.1921 Y1.9482
    G01 X3.1998 Y1.9406
    G01 X3.2340 Y1.9406
    G01 X3.2583 Y1.9648
    G01 X3.2583 Y1.9990
    G01 X3.2340 Y2.0232
    G01 X3.1998 Y2.0232
    G01 X3.1756 Y1.9990
    G01 X3.1756 Y1.9809
    G01 X2.0648 Y1.9809
    G01 X2.0606 Y1.9798
    G01 X2.0569 Y1.9776
    G01 X1.9191 Y1.8398
    G01 X1.9161 Y1.8368
    G01 X1.9139 Y1.8331
    G01 X1.9128 Y1.8289
    G01 X1.9128 Y1.4152
    G01 X1.9139 Y1.4110
    G01 X1.9161 Y1.4073
    G01 X2.1216 Y1.2018
    G01 X2.1246 Y1.1987
    G01 X2.1283 Y1.1966
    G01 X2.1325 Y1.1955
    G01 X2.1496 Y1.1955
    G01 X2.1516 Y1.1925
    G01 X2.1558 Y1.1883
    G01 X2.1608 Y1.1849
    G01 X2.1663 Y1.1826
    G01 X2.1722 Y1.1815
    G01 X2.2302 Y1.1815
    G01 X2.2360 Y1.1826
    G01 X2.2415 Y1.1849
    G01 X2.2465 Y1.1883
    G01 X2.2507 Y1.1925
    G01 X2.2541 Y1.1974
    G01 X2.2563 Y1.2030
    G01 X2.2575 Y1.2088
    G01 X2.2575 Y1.2148
    G01 X2.2563 Y1.2207
    G01 X2.2541 Y1.2262
    G01 X2.2507 Y1.2311
    G01 X2.2465 Y1.2354
    G01 X2.2415 Y1.2387
    G01 X2.2360 Y1.2410
    G01 X2.2302 Y1.2421
    G00 Z0.0787
    G00 X1.6302 Y1.1421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y1.1421 F7.87
    G01 X1.5663 Y1.1410
    G01 X1.5608 Y1.1387
    G01 X1.5558 Y1.1354
    G01 X1.5516 Y1.1311
    G01 X1.5483 Y1.1262
    G01 X1.5460 Y1.1207
    G01 X1.5449 Y1.1148
    G01 X1.5449 Y1.1088
    G01 X1.5460 Y1.1030
    G01 X1.5483 Y1.0974
    G01 X1.5516 Y1.0925
    G01 X1.5558 Y1.0883
    G01 X1.5608 Y1.0849
    G01 X1.5663 Y1.0826
    G01 X1.5722 Y1.0815
    G01 X1.6302 Y1.0815
    G01 X1.6360 Y1.0826
    G01 X1.6415 Y1.0849
    G01 X1.6465 Y1.0883
    G01 X1.6507 Y1.0925
    G01 X1.6541 Y1.0974
    G01 X1.6563 Y1.1030
    G01 X1.6575 Y1.1088
    G01 X1.6575 Y1.1148
    G01 X1.6563 Y1.1207
    G01 X1.6541 Y1.1262
    G01 X1.6507 Y1.1311
    G01 X1.6465 Y1.1354
    G01 X1.6415 Y1.1387
    G01 X1.6360 Y1.1410
    G01 X1.6302 Y1.1421
    G00 Z0.0787
    G00 X1.6302 Y1.3421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y1.3421 F7.87
    G01 X1.5663 Y1.3410
    G01 X1.5608 Y1.3387
    G01 X1.5558 Y1.3354
    G01 X1.5516 Y1.3311
    G01 X1.5483 Y1.3262
    G01 X1.5460 Y1.3207
    G01 X1.5449 Y1.3148
    G01 X1.5449 Y1.3088
    G01 X1.5460 Y1.3030
    G01 X1.5483 Y1.2974
    G01 X1.5516 Y1.2925
    G01 X1.5558 Y1.2883
    G01 X1.5608 Y1.2849
    G01 X1.5663 Y1.2826
    G01 X1.5722 Y1.2815
    G01 X1.6302 Y1.2815
    G01 X1.6360 Y1.2826
    G01 X1.6415 Y1.2849
    G01 X1.6465 Y1.2883
    G01 X1.6507 Y1.2925
    G01 X1.6541 Y1.2974
    G01 X1.6563 Y1.3030
    G01 X1.6575 Y1.3088
    G01 X1.6575 Y1.3148
    G01 X1.6563 Y1.3207
    G01 X1.6541 Y1.3262
    G01 X1.6507 Y1.3311
    G01 X1.6465 Y1.3354
    G01 X1.6415 Y1.3387
    G01 X1.6360 Y1.3410
    G01 X1.6302 Y1.3421
    G00 Z0.0787
    G00 X1.6302 Y1.5421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y1.5421 F7.87
    G01 X1.5663 Y1.5410
    G01 X1.5608 Y1.5387
    G01 X1.5558 Y1.5354
    G01 X1.5516 Y1.5311
    G01 X1.5483 Y1.5262
    G01 X1.5460 Y1.5207
    G01 X1.5449 Y1.5148
    G01 X1.5449 Y1.5088
    G01 X1.5460 Y1.5030
    G01 X1.5483 Y1.4974
    G01 X1.5516 Y1.4925
    G01 X1.5558 Y1.4883
    G01 X1.5608 Y1.4849
    G01 X1.5663 Y1.4826
    G01 X1.5722 Y1.4815
    G01 X1.6302 Y1.4815
    G01 X1.6360 Y1.4826
    G01 X1.6415 Y1.4849
    G01 X1.6465 Y1.4883
    G01 X1.6507 Y1.4925
    G01 X1.6541 Y1.4974
    G01 X1.6563 Y1.5030
    G01 X1.6575 Y1.5088
    G01 X1.6575 Y1.5148
    G01 X1.6563 Y1.5207
    G01 X1.6541 Y1.5262
    G01 X1.6507 Y1.5311
    G01 X1.6465 Y1.5354
    G01 X1.6415 Y1.5387
    G01 X1.6360 Y1.5410
    G01 X1.6302 Y1.5421
    G00 Z0.0787
    G00 X1.6302 Y1.7421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y1.7421 F7.87
    G01 X1.5663 Y1.7410
    G01 X1.5608 Y1.7387
    G01 X1.5558 Y1.7354
    G01 X1.5516 Y1.7311
    G01 X1.5483 Y1.7262
    G01 X1.5460 Y1.7207
    G01 X1.5449 Y1.7148
    G01 X1.5449 Y1.7088
    G01 X1.5460 Y1.7030
    G01 X1.5483 Y1.6974
    G01 X1.5516 Y1.6925
    G01 X1.5558 Y1.6883
    G01 X1.5608 Y1.6849
    G01 X1.5663 Y1.6826
    G01 X1.5722 Y1.6815
    G01 X1.6302 Y1.6815
    G01 X1.6360 Y1.6826
    G01 X1.6415 Y1.6849
    G01 X1.6465 Y1.6883
    G01 X1.6507 Y1.6925
    G01 X1.6541 Y1.6974
    G01 X1.6563 Y1.7030
    G01 X1.6575 Y1.7088
    G01 X1.6575 Y1.7148
    G01 X1.6563 Y1.7207
    G01 X1.6541 Y1.7262
    G01 X1.6507 Y1.7311
    G01 X1.6465 Y1.7354
    G01 X1.6415 Y1.7387
    G01 X1.6360 Y1.7410
    G01 X1.6302 Y1.7421
    G00 Z0.0787
    G00 X1.6302 Y1.8421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y1.8421 F7.87
    G01 X1.5663 Y1.8410
    G01 X1.5608 Y1.8387
    G01 X1.5558 Y1.8354
    G01 X1.5516 Y1.8311
    G01 X1.5483 Y1.8262
    G01 X1.5460 Y1.8207
    G01 X1.5449 Y1.8148
    G01 X1.5449 Y1.8088
    G01 X1.5460 Y1.8030
    G01 X1.5483 Y1.7974
    G01 X1.5516 Y1.7925
    G01 X1.5558 Y1.7883
    G01 X1.5608 Y1.7849
    G01 X1.5663 Y1.7826
    G01 X1.5722 Y1.7815
    G01 X1.6302 Y1.7815
    G01 X1.6360 Y1.7826
    G01 X1.6415 Y1.7849
    G01 X1.6465 Y1.7883
    G01 X1.6507 Y1.7925
    G01 X1.6541 Y1.7974
    G01 X1.6563 Y1.8030
    G01 X1.6575 Y1.8088
    G01 X1.6575 Y1.8148
    G01 X1.6563 Y1.8207
    G01 X1.6541 Y1.8262
    G01 X1.6507 Y1.8311
    G01 X1.6465 Y1.8354
    G01 X1.6415 Y1.8387
    G01 X1.6360 Y1.8410
    G01 X1.6302 Y1.8421
    G00 Z0.0787
    G00 X1.6302 Y1.9421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y1.9421 F7.87
    G01 X1.5663 Y1.9410
    G01 X1.5608 Y1.9387
    G01 X1.5558 Y1.9354
    G01 X1.5516 Y1.9311
    G01 X1.5483 Y1.9262
    G01 X1.5460 Y1.9207
    G01 X1.5449 Y1.9148
    G01 X1.5449 Y1.9088
    G01 X1.5460 Y1.9030
    G01 X1.5483 Y1.8974
    G01 X1.5516 Y1.8925
    G01 X1.5558 Y1.8883
    G01 X1.5608 Y1.8849
    G01 X1.5663 Y1.8826
    G01 X1.5722 Y1.8815
    G01 X1.6302 Y1.8815
    G01 X1.6360 Y1.8826
    G01 X1.6415 Y1.8849
    G01 X1.6465 Y1.8883
    G01 X1.6507 Y1.8925
    G01 X1.6541 Y1.8974
    G01 X1.6563 Y1.9030
    G01 X1.6575 Y1.9088
    G01 X1.6575 Y1.9148
    G01 X1.6563 Y1.9207
    G01 X1.6541 Y1.9262
    G01 X1.6507 Y1.9311
    G01 X1.6465 Y1.9354
    G01 X1.6415 Y1.9387
    G01 X1.6360 Y1.9410
    G01 X1.6302 Y1.9421
    G00 Z0.0787
    G00 X1.6302 Y2.0421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y2.0421 F7.87
    G01 X1.5663 Y2.0410
    G01 X1.5608 Y2.0387
    G01 X1.5558 Y2.0354
    G01 X1.5516 Y2.0311
    G01 X1.5496 Y2.0281
    G01 X1.0380 Y2.0281
    G01 X1.0339 Y2.0270
    G01 X1.0301 Y2.0249
    G01 X1.0098 Y2.0046
    G01 X1.0092 Y2.0051
    G01 X0.9750 Y2.0051
    G01 X0.9508 Y1.9809
    G01 X0.9508 Y1.9467
    G01 X0.9750 Y1.9224
    G01 X1.0092 Y1.9224
    G01 X1.0335 Y1.9467
    G01 X1.0335 Y1.9809
    G01 X1.0329 Y1.9815
    G01 X1.0469 Y1.9955
    G01 X1.5496 Y1.9955
    G01 X1.5516 Y1.9925
    G01 X1.5558 Y1.9883
    G01 X1.5608 Y1.9849
    G01 X1.5663 Y1.9826
    G01 X1.5722 Y1.9815
    G01 X1.6302 Y1.9815
    G01 X1.6360 Y1.9826
    G01 X1.6415 Y1.9849
    G01 X1.6465 Y1.9883
    G01 X1.6507 Y1.9925
    G01 X1.6527 Y1.9955
    G01 X1.9746 Y1.9955
    G01 X1.9787 Y1.9966
    G01 X1.9825 Y1.9987
    G01 X2.0068 Y2.0231
    G01 X2.0285 Y2.0231
    G01 X2.0301 Y2.0238
    G01 X2.0314 Y2.0250
    G01 X2.0320 Y2.0266
    G01 X2.0320 Y2.0679
    G01 X2.0314 Y2.0695
    G01 X2.0301 Y2.0707
    G01 X2.0285 Y2.0714
    G01 X1.9872 Y2.0714
    G01 X1.9856 Y2.0707
    G01 X1.9844 Y2.0695
    G01 X1.9837 Y2.0679
    G01 X1.9837 Y2.0462
    G01 X1.9657 Y2.0281
    G01 X1.6527 Y2.0281
    G01 X1.6507 Y2.0311
    G01 X1.6465 Y2.0354
    G01 X1.6415 Y2.0387
    G01 X1.6360 Y2.0410
    G01 X1.6302 Y2.0421
    G00 Z0.0787
    G00 X1.6302 Y2.4421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y2.4421 F7.87
    G01 X1.5663 Y2.4410
    G01 X1.5608 Y2.4387
    G01 X1.5558 Y2.4354
    G01 X1.5516 Y2.4311
    G01 X1.5483 Y2.4262
    G01 X1.5460 Y2.4207
    G01 X1.5449 Y2.4148
    G01 X1.5449 Y2.4088
    G01 X1.5460 Y2.4030
    G01 X1.5483 Y2.3974
    G01 X1.5516 Y2.3925
    G01 X1.5558 Y2.3883
    G01 X1.5608 Y2.3849
    G01 X1.5663 Y2.3826
    G01 X1.5722 Y2.3815
    G01 X1.6302 Y2.3815
    G01 X1.6360 Y2.3826
    G01 X1.6415 Y2.3849
    G01 X1.6465 Y2.3883
    G01 X1.6507 Y2.3925
    G01 X1.6541 Y2.3974
    G01 X1.6563 Y2.4030
    G01 X1.6575 Y2.4088
    G01 X1.6575 Y2.4148
    G01 X1.6563 Y2.4207
    G01 X1.6541 Y2.4262
    G01 X1.6507 Y2.4311
    G01 X1.6465 Y2.4354
    G01 X1.6415 Y2.4387
    G01 X1.6360 Y2.4410
    G01 X1.6302 Y2.4421
    G00 Z0.0787
    G00 X1.6302 Y2.6421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y2.6421 F7.87
    G01 X1.5663 Y2.6410
    G01 X1.5608 Y2.6387
    G01 X1.5558 Y2.6354
    G01 X1.5516 Y2.6311
    G01 X1.5483 Y2.6262
    G01 X1.5460 Y2.6207
    G01 X1.5449 Y2.6148
    G01 X1.5449 Y2.6088
    G01 X1.5460 Y2.6030
    G01 X1.5483 Y2.5974
    G01 X1.5516 Y2.5925
    G01 X1.5558 Y2.5883
    G01 X1.5608 Y2.5849
    G01 X1.5663 Y2.5826
    G01 X1.5722 Y2.5815
    G01 X1.6302 Y2.5815
    G01 X1.6360 Y2.5826
    G01 X1.6415 Y2.5849
    G01 X1.6465 Y2.5883
    G01 X1.6507 Y2.5925
    G01 X1.6541 Y2.5974
    G01 X1.6563 Y2.6030
    G01 X1.6575 Y2.6088
    G01 X1.6575 Y2.6148
    G01 X1.6563 Y2.6207
    G01 X1.6541 Y2.6262
    G01 X1.6507 Y2.6311
    G01 X1.6465 Y2.6354
    G01 X1.6415 Y2.6387
    G01 X1.6360 Y2.6410
    G01 X1.6302 Y2.6421
    G00 Z0.0787
    G00 X1.6302 Y2.7421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y2.7421 F7.87
    G01 X1.5663 Y2.7410
    G01 X1.5608 Y2.7387
    G01 X1.5558 Y2.7354
    G01 X1.5516 Y2.7311
    G01 X1.5483 Y2.7262
    G01 X1.5478 Y2.7250
    G01 X1.1339 Y2.7250
    G01 X1.1942 Y2.7852
    G01 X1.1963 Y2.7890
    G01 X1.1974 Y2.7931
    G01 X1.1974 Y2.9943
    G01 X1.1963 Y2.9984
    G01 X1.1942 Y3.0022
    G01 X1.1911 Y3.0052
    G01 X1.1124 Y3.0839
    G01 X1.1087 Y3.0861
    G01 X1.1045 Y3.0872
    G01 X0.7459 Y3.0872
    G01 X0.7417 Y3.0861
    G01 X0.7380 Y3.0839
    G01 X0.7350 Y3.0809
    G01 X0.6169 Y2.9628
    G01 X0.6147 Y2.9591
    G01 X0.6136 Y2.9549
    G01 X0.6136 Y2.6839
    G01 X0.2054 Y2.2758
    G01 X0.2033 Y2.2721
    G01 X0.2022 Y2.2679
    G01 X0.2022 Y2.1745
    G01 X0.2008 Y2.1740
    G01 X0.1947 Y2.1699
    G01 X0.1895 Y2.1647
    G01 X0.1854 Y2.1586
    G01 X0.1826 Y2.1518
    G01 X0.1812 Y2.1446
    G01 X0.1812 Y2.0712
    G01 X0.1826 Y2.0640
    G01 X0.1854 Y2.0572
    G01 X0.1895 Y2.0511
    G01 X0.1947 Y2.0459
    G01 X0.2008 Y2.0418
    G01 X0.2076 Y2.0390
    G01 X0.2148 Y2.0375
    G01 X0.2222 Y2.0375
    G01 X0.2294 Y2.0390
    G01 X0.2362 Y2.0418
    G01 X0.2423 Y2.0459
    G01 X0.2475 Y2.0511
    G01 X0.2516 Y2.0572
    G01 X0.2544 Y2.0640
    G01 X0.2558 Y2.0712
    G01 X0.2558 Y2.1446
    G01 X0.2544 Y2.1518
    G01 X0.2516 Y2.1586
    G01 X0.2475 Y2.1647
    G01 X0.2423 Y2.1699
    G01 X0.2362 Y2.1740
    G01 X0.2348 Y2.1745
    G01 X0.2348 Y2.2590
    G01 X0.6399 Y2.6641
    G01 X0.6430 Y2.6671
    G01 X0.6451 Y2.6709
    G01 X0.6463 Y2.6750
    G01 X0.6463 Y2.9460
    G01 X0.7548 Y3.0545
    G01 X1.0956 Y3.0545
    G01 X1.1648 Y2.9854
    G01 X1.1648 Y2.8020
    G01 X1.0877 Y2.7250
    G01 X1.0216 Y2.7250
    G01 X1.0216 Y2.7258
    G01 X0.9974 Y2.7500
    G01 X0.9632 Y2.7500
    G01 X0.9390 Y2.7258
    G01 X0.9390 Y2.6915
    G01 X0.9632 Y2.6673
    G01 X0.9974 Y2.6673
    G01 X1.0216 Y2.6915
    G01 X1.0216 Y2.6923
    G01 X1.5518 Y2.6923
    G01 X1.5558 Y2.6883
    G01 X1.5608 Y2.6849
    G01 X1.5663 Y2.6826
    G01 X1.5722 Y2.6815
    G01 X1.6302 Y2.6815
    G01 X1.6360 Y2.6826
    G01 X1.6415 Y2.6849
    G01 X1.6465 Y2.6883
    G01 X1.6507 Y2.6925
    G01 X1.6541 Y2.6974
    G01 X1.6563 Y2.7030
    G01 X1.6575 Y2.7088
    G01 X1.6575 Y2.7148
    G01 X1.6563 Y2.7207
    G01 X1.6541 Y2.7262
    G01 X1.6507 Y2.7311
    G01 X1.6465 Y2.7354
    G01 X1.6415 Y2.7387
    G01 X1.6360 Y2.7410
    G01 X1.6302 Y2.7421
    G00 Z0.0787
    G00 X1.6302 Y2.8421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y2.8421 F7.87
    G01 X1.5663 Y2.8410
    G01 X1.5608 Y2.8387
    G01 X1.5558 Y2.8354
    G01 X1.5516 Y2.8311
    G01 X1.5483 Y2.8262
    G01 X1.5460 Y2.8207
    G01 X1.5449 Y2.8148
    G01 X1.5449 Y2.8088
    G01 X1.5460 Y2.8030
    G01 X1.5483 Y2.7974
    G01 X1.5516 Y2.7925
    G01 X1.5558 Y2.7883
    G01 X1.5608 Y2.7849
    G01 X1.5663 Y2.7826
    G01 X1.5722 Y2.7815
    G01 X1.6302 Y2.7815
    G01 X1.6360 Y2.7826
    G01 X1.6415 Y2.7849
    G01 X1.6465 Y2.7883
    G01 X1.6507 Y2.7925
    G01 X1.6541 Y2.7974
    G01 X1.6563 Y2.8030
    G01 X1.6575 Y2.8088
    G01 X1.6575 Y2.8148
    G01 X1.6563 Y2.8207
    G01 X1.6541 Y2.8262
    G01 X1.6507 Y2.8311
    G01 X1.6465 Y2.8354
    G01 X1.6415 Y2.8387
    G01 X1.6360 Y2.8410
    G01 X1.6302 Y2.8421
    G00 Z0.0787
    G00 X1.6302 Y2.9421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y2.9421 F7.87
    G01 X1.5663 Y2.9410
    G01 X1.5608 Y2.9387
    G01 X1.5558 Y2.9354
    G01 X1.5516 Y2.9311
    G01 X1.5483 Y2.9262
    G01 X1.5460 Y2.9207
    G01 X1.5449 Y2.9148
    G01 X1.5449 Y2.9088
    G01 X1.5460 Y2.9030
    G01 X1.5483 Y2.8974
    G01 X1.5516 Y2.8925
    G01 X1.5558 Y2.8883
    G01 X1.5608 Y2.8849
    G01 X1.5663 Y2.8826
    G01 X1.5722 Y2.8815
    G01 X1.6302 Y2.8815
    G01 X1.6360 Y2.8826
    G01 X1.6415 Y2.8849
    G01 X1.6465 Y2.8883
    G01 X1.6507 Y2.8925
    G01 X1.6541 Y2.8974
    G01 X1.6563 Y2.9030
    G01 X1.6575 Y2.9088
    G01 X1.6575 Y2.9148
    G01 X1.6563 Y2.9207
    G01 X1.6541 Y2.9262
    G01 X1.6507 Y2.9311
    G01 X1.6465 Y2.9354
    G01 X1.6415 Y2.9387
    G01 X1.6360 Y2.9410
    G01 X1.6302 Y2.9421
    G00 Z0.0787
    G00 X1.6302 Y3.0421
    G01 Z-0.0039 F5.91
    G01 X1.5722 Y3.0421 F7.87
    G01 X1.5663 Y3.0410
    G01 X1.5608 Y3.0387
    G01 X1.5558 Y3.0354
    G01 X1.5516 Y3.0311
    G01 X1.5483 Y3.0262
    G01 X1.5460 Y3.0207
    G01 X1.5449 Y3.0148
    G01 X1.5449 Y3.0088
    G01 X1.5460 Y3.0030
    G01 X1.5483 Y2.9974
    G01 X1.5516 Y2.9925
    G01 X1.5558 Y2.9883
    G01 X1.5608 Y2.9849
    G01 X1.5663 Y2.9826
    G01 X1.5722 Y2.9815
    G01 X1.6302 Y2.9815
    G01 X1.6360 Y2.9826
    G01 X1.6415 Y2.9849
    G01 X1.6465 Y2.9883
    G01 X1.6507 Y2.9925
    G01 X1.6541 Y2.9974
    G01 X1.6563 Y3.0030
    G01 X1.6575 Y3.0088
    G01 X1.6575 Y3.0148
    G01 X1.6563 Y3.0207
    G01 X1.6541 Y3.0262
    G01 X1.6507 Y3.0311
    G01 X1.6465 Y3.0354
    G01 X1.6415 Y3.0387
    G01 X1.6360 Y3.0410
    G01 X1.6302 Y3.0421
    G00 Z0.0787
    G00 X1.3273 Y2.9439
    G01 Z-0.0039 F5.91
    G01 X1.3273 Y2.9482 F7.87
    G01 X1.8263 Y2.9482
    G01 X1.8263 Y2.9439
    G01 X1.8269 Y2.9423
    G01 X1.8281 Y2.9411
    G01 X1.8297 Y2.9404
    G01 X1.8711 Y2.9404
    G01 X1.8727 Y2.9411
    G01 X1.8739 Y2.9423
    G01 X1.8745 Y2.9439
    G01 X1.8745 Y2.9852
    G01 X1.8739 Y2.9868
    G01 X1.8727 Y2.9880
    G01 X1.8711 Y2.9887
    G01 X1.8297 Y2.9887
    G01 X1.8281 Y2.9880
    G01 X1.8269 Y2.9868
    G01 X1.8263 Y2.9852
    G01 X1.8263 Y2.9809
    G01 X1.3273 Y2.9809
    G01 X1.3273 Y2.9852
    G01 X1.3266 Y2.9868
    G01 X1.3254 Y2.9880
    G01 X1.3238 Y2.9887
    G01 X1.2825 Y2.9887
    G01 X1.2809 Y2.9880
    G01 X1.2797 Y2.9868
    G01 X1.2790 Y2.9852
    G01 X1.2790 Y2.9439
    G01 X1.2797 Y2.9423
    G01 X1.2809 Y2.9411
    G01 X1.2825 Y2.9404
    G01 X1.3238 Y2.9404
    G01 X1.3254 Y2.9411
    G01 X1.3266 Y2.9423
    G01 X1.3273 Y2.9439
    G00 Z0.0787
    G00 X2.0238 Y1.6119
    G01 Z-0.0039 F5.91
    G01 X2.0247 Y1.6073 F7.87
    G01 X2.0265 Y1.6031
    G01 X2.0291 Y1.5992
    G01 X2.0323 Y1.5960
    G01 X2.0835 Y1.5448
    G01 X2.0873 Y1.5422
    G01 X2.0916 Y1.5405
    G01 X2.0961 Y1.5396
    G01 X2.1500 Y1.5396
    G01 X2.1461 Y1.5357
    G01 X2.1420 Y1.5295
    G01 X2.1392 Y1.5227
    G01 X2.1378 Y1.5155
    G01 X2.1378 Y1.5081
    G01 X2.1392 Y1.5009
    G01 X2.1420 Y1.4941
    G01 X2.1461 Y1.4880
    G01 X2.1513 Y1.4827
    G01 X2.1575 Y1.4787
    G01 X2.1643 Y1.4758
    G01 X2.1715 Y1.4744
    G01 X2.2055 Y1.4744
    G01 X2.2306 Y1.4492
    G01 X2.1715 Y1.4492
    G01 X2.1643 Y1.4478
    G01 X2.1575 Y1.4450
    G01 X2.1513 Y1.4409
    G01 X2.1461 Y1.4357
    G01 X2.1420 Y1.4295
    G01 X2.1392 Y1.4227
    G01 X2.1387 Y1.4201
    G01 X2.1170 Y1.4201
    G01 X1.9919 Y1.5451
    G01 X1.9919 Y1.7186
    G01 X2.1121 Y1.8388
    G01 X2.1492 Y1.8388
    G01 X2.1461 Y1.8357
    G01 X2.1458 Y1.8352
    G01 X2.1245 Y1.8352
    G01 X2.1199 Y1.8343
    G01 X2.1157 Y1.8326
    G01 X2.1118 Y1.8300
    G01 X2.1086 Y1.8267
    G01 X2.0291 Y1.7472
    G01 X2.0265 Y1.7434
    G01 X2.0247 Y1.7391
    G01 X2.0238 Y1.7346
    G01 X2.0238 Y1.7300
    G01 X2.0238 Y1.6119
    G00 Z0.0787
    G00 X1.9526 Y1.8171
    G01 Z-0.0039 F5.91
    G01 X2.0766 Y1.9411 F7.87
    G01 X2.1517 Y1.9411
    G01 X2.1513 Y1.9409
    G01 X2.1461 Y1.9357
    G01 X2.1420 Y1.9295
    G01 X2.1392 Y1.9227
    G01 X2.1378 Y1.9155
    G01 X2.1378 Y1.9081
    G01 X2.1392 Y1.9009
    G01 X2.1420 Y1.8941
    G01 X2.1461 Y1.8880
    G01 X2.1485 Y1.8856
    G01 X2.1001 Y1.8856
    G01 X2.0955 Y1.8847
    G01 X2.0913 Y1.8830
    G01 X2.0874 Y1.8804
    G01 X1.9536 Y1.7465
    G01 X1.9526 Y1.7455
    G01 X1.9526 Y1.8171
    G00 Z0.0787
    G00 X2.1969 Y2.0492
    G01 Z-0.0039 F5.91
    G01 X2.1717 Y2.0744 F7.87
    G01 X2.2306 Y2.0744
    G01 X2.2055 Y2.0492
    G01 X2.1969 Y2.0492
    G00 Z0.0787
    G00 X1.3336 Y2.9888
    G01 Z-0.0039 F5.91
    G01 X1.3321 Y2.9914 F7.87
    G01 X1.3300 Y2.9935
    G01 X1.3274 Y2.9950
    G01 X1.3245 Y2.9958
    G01 X1.2818 Y2.9958
    G01 X1.2789 Y2.9950
    G01 X1.2763 Y2.9935
    G01 X1.2742 Y2.9914
    G01 X1.2727 Y2.9888
    G01 X1.2719 Y2.9859
    G01 X1.2719 Y2.9433
    G01 X1.2727 Y2.9403
    G01 X1.2742 Y2.9377
    G01 X1.2763 Y2.9356
    G01 X1.2789 Y2.9341
    G01 X1.2818 Y2.9333
    G01 X1.3245 Y2.9333
    G01 X1.3274 Y2.9341
    G01 X1.3300 Y2.9356
    G01 X1.3321 Y2.9377
    G01 X1.3336 Y2.9403
    G01 X1.3338 Y2.9411
    G01 X1.5517 Y2.9411
    G01 X1.5513 Y2.9409
    G01 X1.5461 Y2.9357
    G01 X1.5420 Y2.9295
    G01 X1.5392 Y2.9227
    G01 X1.5378 Y2.9155
    G01 X1.5378 Y2.9081
    G01 X1.5392 Y2.9009
    G01 X1.5420 Y2.8941
    G01 X1.5461 Y2.8880
    G01 X1.5513 Y2.8827
    G01 X1.5575 Y2.8787
    G01 X1.5643 Y2.8758
    G01 X1.5715 Y2.8744
    G01 X1.6309 Y2.8744
    G01 X1.6381 Y2.8758
    G01 X1.6449 Y2.8787
    G01 X1.6510 Y2.8827
    G01 X1.6562 Y2.8880
    G01 X1.6603 Y2.8941
    G01 X1.6632 Y2.9009
    G01 X1.6646 Y2.9081
    G01 X1.6646 Y2.9155
    G01 X1.6632 Y2.9227
    G01 X1.6603 Y2.9295
    G01 X1.6562 Y2.9357
    G01 X1.6510 Y2.9409
    G01 X1.6506 Y2.9411
    G01 X1.8197 Y2.9411
    G01 X1.8199 Y2.9403
    G01 X1.8214 Y2.9377
    G01 X1.8236 Y2.9356
    G01 X1.8262 Y2.9341
    G01 X1.8291 Y2.9333
    G01 X1.8717 Y2.9333
    G01 X1.8746 Y2.9341
    G01 X1.8772 Y2.9356
    G01 X1.8793 Y2.9377
    G01 X1.8808 Y2.9403
    G01 X1.8816 Y2.9433
    G01 X1.8816 Y2.9859
    G01 X1.8808 Y2.9888
    G01 X1.8793 Y2.9914
    G01 X1.8772 Y2.9935
    G01 X1.8746 Y2.9950
    G01 X1.8717 Y2.9958
    G01 X1.8291 Y2.9958
    G01 X1.8262 Y2.9950
    G01 X1.8236 Y2.9935
    G01 X1.8214 Y2.9914
    G01 X1.8199 Y2.9888
    G01 X1.8197 Y2.9880
    G01 X1.6563 Y2.9880
    G01 X1.6603 Y2.9941
    G01 X1.6632 Y3.0009
    G01 X1.6646 Y3.0081
    G01 X1.6646 Y3.0155
    G01 X1.6632 Y3.0227
    G01 X1.6603 Y3.0295
    G01 X1.6562 Y3.0357
    G01 X1.6510 Y3.0409
    G01 X1.6449 Y3.0450
    G01 X1.6381 Y3.0478
    G01 X1.6309 Y3.0492
    G01 X1.5715 Y3.0492
    G01 X1.5643 Y3.0478
    G01 X1.5575 Y3.0450
    G01 X1.5513 Y3.0409
    G01 X1.5461 Y3.0357
    G01 X1.5420 Y3.0295
    G01 X1.5392 Y3.0227
    G01 X1.5378 Y3.0155
    G01 X1.5378 Y3.0081
    G01 X1.5392 Y3.0009
    G01 X1.5420 Y2.9941
    G01 X1.5461 Y2.9880
    G01 X1.3338 Y2.9880
    G01 X1.3336 Y2.9888
    G00 Z0.0787
    G00 X1.6309 Y2.8492
    G01 Z-0.0039 F5.91
    G01 X1.5715 Y2.8492 F7.87
    G01 X1.5643 Y2.8478
    G01 X1.5575 Y2.8450
    G01 X1.5513 Y2.8409
    G01 X1.5461 Y2.8357
    G01 X1.5420 Y2.8295
    G01 X1.5392 Y2.8227
    G01 X1.5378 Y2.8155
    G01 X1.5378 Y2.8081
    G01 X1.5392 Y2.8009
    G01 X1.5420 Y2.7941
    G01 X1.5461 Y2.7880
    G01 X1.5513 Y2.7827
    G01 X1.5575 Y2.7787
    G01 X1.5643 Y2.7758
    G01 X1.5715 Y2.7744
    G01 X1.6309 Y2.7744
    G01 X1.6381 Y2.7758
    G01 X1.6449 Y2.7787
    G01 X1.6510 Y2.7827
    G01 X1.6562 Y2.7880
    G01 X1.6603 Y2.7941
    G01 X1.6632 Y2.8009
    G01 X1.6646 Y2.8081
    G01 X1.6646 Y2.8155
    G01 X1.6632 Y2.8227
    G01 X1.6603 Y2.8295
    G01 X1.6562 Y2.8357
    G01 X1.6510 Y2.8409
    G01 X1.6449 Y2.8450
    G01 X1.6381 Y2.8478
    G01 X1.6309 Y2.8492
    G00 Z0.0787
    G00 X1.6309 Y2.7492
    G01 Z-0.0039 F5.91
    G01 X1.5715 Y2.7492 F7.87
    G01 X1.5643 Y2.7478
    G01 X1.5575 Y2.7450
    G01 X1.5513 Y2.7409
    G01 X1.5461 Y2.7357
    G01 X1.5437 Y2.7321
    G01 X1.1510 Y2.7321
    G01 X1.1993 Y2.7803
    G01 X1.2019 Y2.7842
    G01 X1.2036 Y2.7884
    G01 X1.2045 Y2.7930
    G01 X1.2045 Y2.9944
    G01 X1.2036 Y2.9990
    G01 X1.2019 Y3.0032
    G01 X1.1993 Y3.0071
    G01 X1.1960 Y3.0103
    G01 X1.1173 Y3.0891
    G01 X1.1135 Y3.0916
    G01 X1.1092 Y3.0934
    G01 X1.1047 Y3.0943
    G01 X0.7457 Y3.0943
    G01 X0.7412 Y3.0934
    G01 X0.7369 Y3.0916
    G01 X0.7331 Y3.0891
    G01 X0.7298 Y3.0858
    G01 X0.6117 Y2.9677
    G01 X0.6092 Y2.9638
    G01 X0.6074 Y2.9596
    G01 X0.6065 Y2.9551
    G01 X0.6065 Y2.6869
    G01 X0.2003 Y2.2807
    G01 X0.1978 Y2.2768
    G01 X0.1960 Y2.2726
    G01 X0.1951 Y2.2681
    G01 X0.1951 Y2.1788
    G01 X0.1896 Y2.1748
    G01 X0.1846 Y2.1698
    G01 X0.1805 Y2.1642
    G01 X0.1773 Y2.1579
    G01 X0.1752 Y2.1513
    G01 X0.1741 Y2.1444
    G01 X0.1741 Y2.0714
    G01 X0.1752 Y2.0645
    G01 X0.1773 Y2.0578
    G01 X0.1805 Y2.0516
    G01 X0.1846 Y2.0459
    G01 X0.1896 Y2.0410
    G01 X0.1952 Y2.0369
    G01 X0.2015 Y2.0337
    G01 X0.2081 Y2.0315
    G01 X0.2150 Y2.0305
    G01 X0.2220 Y2.0305
    G01 X0.2289 Y2.0315
    G01 X0.2356 Y2.0337
    G01 X0.2418 Y2.0369
    G01 X0.2474 Y2.0410
    G01 X0.2524 Y2.0459
    G01 X0.2565 Y2.0516
    G01 X0.2597 Y2.0578
    G01 X0.2618 Y2.0645
    G01 X0.2629 Y2.0714
    G01 X0.2629 Y2.1444
    G01 X0.2618 Y2.1513
    G01 X0.2597 Y2.1579
    G01 X0.2565 Y2.1642
    G01 X0.2524 Y2.1698
    G01 X0.2474 Y2.1748
    G01 X0.2419 Y2.1788
    G01 X0.2419 Y2.2560
    G01 X0.6448 Y2.6590
    G01 X0.6481 Y2.6622
    G01 X0.6507 Y2.6661
    G01 X0.6524 Y2.6703
    G01 X0.6533 Y2.6749
    G01 X0.6533 Y2.9431
    G01 X0.7577 Y3.0474
    G01 X0.8096 Y3.0474
    G01 X0.8086 Y3.0464
    G01 X0.6905 Y2.9283
    G01 X0.6879 Y2.9245
    G01 X0.6861 Y2.9202
    G01 X0.6852 Y2.9157
    G01 X0.6852 Y2.4077
    G01 X0.4499 Y2.1723
    G01 X0.4474 Y2.1748
    G01 X0.4418 Y2.1789
    G01 X0.4356 Y2.1820
    G01 X0.4289 Y2.1842
    G01 X0.4220 Y2.1853
    G01 X0.4150 Y2.1853
    G01 X0.4081 Y2.1842
    G01 X0.4015 Y2.1820
    G01 X0.3952 Y2.1789
    G01 X0.3896 Y2.1748
    G01 X0.3846 Y2.1698
    G01 X0.3805 Y2.1642
    G01 X0.3773 Y2.1579
    G01 X0.3752 Y2.1513
    G01 X0.3741 Y2.1444
    G01 X0.3741 Y2.0714
    G01 X0.3752 Y2.0645
    G01 X0.3773 Y2.0578
    G01 X0.3805 Y2.0516
    G01 X0.3846 Y2.0459
    G01 X0.3896 Y2.0410
    G01 X0.3952 Y2.0369
    G01 X0.4015 Y2.0337
    G01 X0.4081 Y2.0315
    G01 X0.4150 Y2.0305
    G01 X0.4220 Y2.0305
    G01 X0.4289 Y2.0315
    G01 X0.4356 Y2.0337
    G01 X0.4418 Y2.0369
    G01 X0.4474 Y2.0410
    G01 X0.4524 Y2.0459
    G01 X0.4565 Y2.0516
    G01 X0.4597 Y2.0578
    G01 X0.4618 Y2.0645
    G01 X0.4629 Y2.0714
    G01 X0.4629 Y2.1192
    G01 X0.7236 Y2.3798
    G01 X0.7269 Y2.3831
    G01 X0.7294 Y2.3869
    G01 X0.7312 Y2.3912
    G01 X0.7321 Y2.3957
    G01 X0.7321 Y2.9037
    G01 X0.8365 Y3.0081
    G01 X0.8958 Y3.0081
    G01 X0.9535 Y2.9504
    G01 X0.9319 Y2.9287
    G01 X0.9319 Y2.8886
    G01 X0.9603 Y2.8602
    G01 X1.0004 Y2.8602
    G01 X1.0287 Y2.8886
    G01 X1.0287 Y2.9287
    G01 X1.0037 Y2.9537
    G01 X1.0037 Y2.9590
    G01 X1.0028 Y2.9635
    G01 X1.0011 Y2.9678
    G01 X0.9985 Y2.9716
    G01 X0.9952 Y2.9749
    G01 X0.9227 Y3.0474
    G01 X1.0927 Y3.0474
    G01 X1.1577 Y2.9824
    G01 X1.1577 Y2.8050
    G01 X1.0848 Y2.7321
    G01 X1.0254 Y2.7321
    G01 X1.0004 Y2.7571
    G01 X0.9603 Y2.7571
    G01 X0.9319 Y2.7287
    G01 X0.9319 Y2.6886
    G01 X0.9603 Y2.6602
    G01 X1.0004 Y2.6602
    G01 X1.0254 Y2.6852
    G01 X1.5488 Y2.6852
    G01 X1.5513 Y2.6827
    G01 X1.5575 Y2.6787
    G01 X1.5643 Y2.6758
    G01 X1.5715 Y2.6744
    G01 X1.6309 Y2.6744
    G01 X1.6381 Y2.6758
    G01 X1.6449 Y2.6787
    G01 X1.6510 Y2.6827
    G01 X1.6562 Y2.6880
    G01 X1.6603 Y2.6941
    G01 X1.6632 Y2.7009
    G01 X1.6646 Y2.7081
    G01 X1.6646 Y2.7155
    G01 X1.6632 Y2.7227
    G01 X1.6603 Y2.7295
    G01 X1.6562 Y2.7357
    G01 X1.6510 Y2.7409
    G01 X1.6449 Y2.7450
    G01 X1.6381 Y2.7478
    G01 X1.6309 Y2.7492
    G00 Z0.0787
    G00 X1.6309 Y1.9492
    G01 Z-0.0039 F5.91
    G01 X1.5715 Y1.9492 F7.87
    G01 X1.5643 Y1.9478
    G01 X1.5575 Y1.9450
    G01 X1.5513 Y1.9409
    G01 X1.5461 Y1.9357
    G01 X1.5420 Y1.9295
    G01 X1.5392 Y1.9227
    G01 X1.5378 Y1.9155
    G01 X1.5378 Y1.9081
    G01 X1.5392 Y1.9009
    G01 X1.5420 Y1.8941
    G01 X1.5461 Y1.8880
    G01 X1.5513 Y1.8827
    G01 X1.5575 Y1.8787
    G01 X1.5643 Y1.8758
    G01 X1.5715 Y1.8744
    G01 X1.6309 Y1.8744
    G01 X1.6381 Y1.8758
    G01 X1.6449 Y1.8787
    G01 X1.6510 Y1.8827
    G01 X1.6562 Y1.8880
    G01 X1.6603 Y1.8941
    G01 X1.6632 Y1.9009
    G01 X1.6646 Y1.9081
    G01 X1.6646 Y1.9155
    G01 X1.6632 Y1.9227
    G01 X1.6603 Y1.9295
    G01 X1.6562 Y1.9357
    G01 X1.6510 Y1.9409
    G01 X1.6449 Y1.9450
    G01 X1.6381 Y1.9478
    G01 X1.6309 Y1.9492
    G00 Z0.0787
    G00 X1.6309 Y1.8492
    G01 Z-0.0039 F5.91
    G01 X1.5715 Y1.8492 F7.87
    G01 X1.5643 Y1.8478
    G01 X1.5575 Y1.8450
    G01 X1.5513 Y1.8409
    G01 X1.5461 Y1.8357
    G01 X1.5420 Y1.8295
    G01 X1.5392 Y1.8227
    G01 X1.5378 Y1.8155
    G01 X1.5378 Y1.8081
    G01 X1.5392 Y1.8009
    G01 X1.5420 Y1.7941
    G01 X1.5461 Y1.7880
    G01 X1.5513 Y1.7827
    G01 X1.5575 Y1.7787
    G01 X1.5643 Y1.7758
    G01 X1.5715 Y1.7744
    G01 X1.6309 Y1.7744
    G01 X1.6381 Y1.7758
    G01 X1.6449 Y1.7787
    G01 X1.6510 Y1.7827
    G01 X1.6562 Y1.7880
    G01 X1.6603 Y1.7941
    G01 X1.6632 Y1.8009
    G01 X1.6646 Y1.8081
    G01 X1.6646 Y1.8155
    G01 X1.6632 Y1.8227
    G01 X1.6603 Y1.8295
    G01 X1.6562 Y1.8357
    G01 X1.6510 Y1.8409
    G01 X1.6449 Y1.8450
    G01 X1.6381 Y1.8478
    G01 X1.6309 Y1.8492
    G00 Z0.0787
    G00 X1.6309 Y1.1492
    G01 Z-0.0039 F5.91
    G01 X1.5715 Y1.1492 F7.87
    G01 X1.5643 Y1.1478
    G01 X1.5575 Y1.1450
    G01 X1.5513 Y1.1409
    G01 X1.5461 Y1.1357
    G01 X1.5420 Y1.1295
    G01 X1.5392 Y1.1227
    G01 X1.5378 Y1.1155
    G01 X1.5378 Y1.1081
    G01 X1.5392 Y1.1009
    G01 X1.5420 Y1.0941
    G01 X1.5461 Y1.0880
    G01 X1.5513 Y1.0827
    G01 X1.5575 Y1.0787
    G01 X1.5643 Y1.0758
    G01 X1.5715 Y1.0744
    G01 X1.6309 Y1.0744
    G01 X1.6381 Y1.0758
    G01 X1.6449 Y1.0787
    G01 X1.6510 Y1.0827
    G01 X1.6562 Y1.0880
    G01 X1.6603 Y1.0941
    G01 X1.6632 Y1.1009
    G01 X1.6646 Y1.1081
    G01 X1.6646 Y1.1155
    G01 X1.6632 Y1.1227
    G01 X1.6603 Y1.1295
    G01 X1.6562 Y1.1357
    G01 X1.6510 Y1.1409
    G01 X1.6449 Y1.1450
    G01 X1.6381 Y1.1478
    G01 X1.6309 Y1.1492
    G00 Z0.0787
    G00 X2.2309 Y1.3492
    G01 Z-0.0039 F5.91
    G01 X2.1715 Y1.3492 F7.87
    G01 X2.1643 Y1.3478
    G01 X2.1575 Y1.3450
    G01 X2.1513 Y1.3409
    G01 X2.1461 Y1.3357
    G01 X2.1420 Y1.3295
    G01 X2.1392 Y1.3227
    G01 X2.1378 Y1.3155
    G01 X2.1378 Y1.3081
    G01 X2.1392 Y1.3009
    G01 X2.1420 Y1.2941
    G01 X2.1461 Y1.2880
    G01 X2.1513 Y1.2827
    G01 X2.1575 Y1.2787
    G01 X2.1643 Y1.2758
    G01 X2.1715 Y1.2744
    G01 X2.2309 Y1.2744
    G01 X2.2381 Y1.2758
    G01 X2.2449 Y1.2787
    G01 X2.2510 Y1.2827
    G01 X2.2562 Y1.2880
    G01 X2.2603 Y1.2941
    G01 X2.2632 Y1.3009
    G01 X2.2646 Y1.3081
    G01 X2.2646 Y1.3155
    G01 X2.2632 Y1.3227
    G01 X2.2603 Y1.3295
    G01 X2.2562 Y1.3357
    G01 X2.2510 Y1.3409
    G01 X2.2449 Y1.3450
    G01 X2.2381 Y1.3478
    G01 X2.2309 Y1.3492
    G00 Z0.0787
    G00 X2.2309 Y2.2492
    G01 Z-0.0039 F5.91
    G01 X2.1715 Y2.2492 F7.87
    G01 X2.1643 Y2.2478
    G01 X2.1575 Y2.2450
    G01 X2.1513 Y2.2409
    G01 X2.1461 Y2.2357
    G01 X2.1420 Y2.2295
    G01 X2.1392 Y2.2227
    G01 X2.1378 Y2.2155
    G01 X2.1378 Y2.2081
    G01 X2.1392 Y2.2009
    G01 X2.1420 Y2.1941
    G01 X2.1461 Y2.1880
    G01 X2.1513 Y2.1827
    G01 X2.1575 Y2.1787
    G01 X2.1643 Y2.1758
    G01 X2.1715 Y2.1744
    G01 X2.2309 Y2.1744
    G01 X2.2381 Y2.1758
    G01 X2.2449 Y2.1787
    G01 X2.2510 Y2.1827
    G01 X2.2562 Y2.1880
    G01 X2.2603 Y2.1941
    G01 X2.2632 Y2.2009
    G01 X2.2646 Y2.2081
    G01 X2.2646 Y2.2155
    G01 X2.2632 Y2.2227
    G01 X2.2603 Y2.2295
    G01 X2.2562 Y2.2357
    G01 X2.2510 Y2.2409
    G01 X2.2449 Y2.2450
    G01 X2.2381 Y2.2478
    G01 X2.2309 Y2.2492
    G00 Z0.0787
    G00 X2.2309 Y2.3492
    G01 Z-0.0039 F5.91
    G01 X2.1715 Y2.3492 F7.87
    G01 X2.1643 Y2.3478
    G01 X2.1575 Y2.3450
    G01 X2.1513 Y2.3409
    G01 X2.1461 Y2.3357
    G01 X2.1420 Y2.3295
    G01 X2.1392 Y2.3227
    G01 X2.1378 Y2.3155
    G01 X2.1378 Y2.3081
    G01 X2.1392 Y2.3009
    G01 X2.1420 Y2.2941
    G01 X2.1461 Y2.2880
    G01 X2.1513 Y2.2827
    G01 X2.1575 Y2.2787
    G01 X2.1643 Y2.2758
    G01 X2.1715 Y2.2744
    G01 X2.2309 Y2.2744
    G01 X2.2381 Y2.2758
    G01 X2.2449 Y2.2787
    G01 X2.2510 Y2.2827
    G01 X2.2562 Y2.2880
    G01 X2.2603 Y2.2941
    G01 X2.2632 Y2.3009
    G01 X2.2646 Y2.3081
    G01 X2.2646 Y2.3155
    G01 X2.2632 Y2.3227
    G01 X2.2603 Y2.3295
    G01 X2.2562 Y2.3357
    G01 X2.2510 Y2.3409
    G01 X2.2449 Y2.3450
    G01 X2.2381 Y2.3478
    G01 X2.2309 Y2.3492
    G00 Z0.0787
    G00 X2.2309 Y2.4492
    G01 Z-0.0039 F5.91
    G01 X2.1715 Y2.4492 F7.87
    G01 X2.1643 Y2.4478
    G01 X2.1575 Y2.4450
    G01 X2.1513 Y2.4409
    G01 X2.1461 Y2.4357
    G01 X2.1420 Y2.4295
    G01 X2.1392 Y2.4227
    G01 X2.1378 Y2.4155
    G01 X2.1378 Y2.4081
    G01 X2.1392 Y2.4009
    G01 X2.1420 Y2.3941
    G01 X2.1461 Y2.3880
    G01 X2.1513 Y2.3827
    G01 X2.1575 Y2.3787
    G01 X2.1643 Y2.3758
    G01 X2.1715 Y2.3744
    G01 X2.2309 Y2.3744
    G01 X2.2381 Y2.3758
    G01 X2.2449 Y2.3787
    G01 X2.2510 Y2.3827
    G01 X2.2562 Y2.3880
    G01 X2.2603 Y2.3941
    G01 X2.2632 Y2.4009
    G01 X2.2646 Y2.4081
    G01 X2.2646 Y2.4155
    G01 X2.2632 Y2.4227
    G01 X2.2603 Y2.4295
    G01 X2.2562 Y2.4357
    G01 X2.2510 Y2.4409
    G01 X2.2449 Y2.4450
    G01 X2.2381 Y2.4478
    G01 X2.2309 Y2.4492
    G00 Z0.0787
    G00 X2.2309 Y2.5492
    G01 Z-0.0039 F5.91
    G01 X2.1715 Y2.5492 F7.87
    G01 X2.1643 Y2.5478
    G01 X2.1575 Y2.5450
    G01 X2.1513 Y2.5409
    G01 X2.1461 Y2.5357
    G01 X2.1420 Y2.5295
    G01 X2.1392 Y2.5227
    G01 X2.1378 Y2.5155
    G01 X2.1378 Y2.5081
    G01 X2.1392 Y2.5009
    G01 X2.1420 Y2.4941
    G01 X2.1461 Y2.4880
    G01 X2.1513 Y2.4827
    G01 X2.1575 Y2.4787
    G01 X2.1643 Y2.4758
    G01 X2.1715 Y2.4744
    G01 X2.2309 Y2.4744
    G01 X2.2381 Y2.4758
    G01 X2.2449 Y2.4787
    G01 X2.2510 Y2.4827
    G01 X2.2562 Y2.4880
    G01 X2.2603 Y2.4941
    G01 X2.2632 Y2.5009
    G01 X2.2646 Y2.5081
    G01 X2.2646 Y2.5155
    G01 X2.2632 Y2.5227
    G01 X2.2603 Y2.5295
    G01 X2.2562 Y2.5357
    G01 X2.2510 Y2.5409
    G01 X2.2449 Y2.5450
    G01 X2.2381 Y2.5478
    G01 X2.2309 Y2.5492
    G00 Z0.0787
    G00 X2.2309 Y2.6492
    G01 Z-0.0039 F5.91
    G01 X2.1715 Y2.6492 F7.87
    G01 X2.1643 Y2.6478
    G01 X2.1575 Y2.6450
    G01 X2.1513 Y2.6409
    G01 X2.1461 Y2.6357
    G01 X2.1420 Y2.6295
    G01 X2.1392 Y2.6227
    G01 X2.1378 Y2.6155
    G01 X2.1378 Y2.6081
    G01 X2.1392 Y2.6009
    G01 X2.1420 Y2.5941
    G01 X2.1461 Y2.5880
    G01 X2.1513 Y2.5827
    G01 X2.1575 Y2.5787
    G01 X2.1643 Y2.5758
    G01 X2.1715 Y2.5744
    G01 X2.2309 Y2.5744
    G01 X2.2381 Y2.5758
    G01 X2.2449 Y2.5787
    G01 X2.2510 Y2.5827
    G01 X2.2562 Y2.5880
    G01 X2.2603 Y2.5941
    G01 X2.2632 Y2.6009
    G01 X2.2646 Y2.6081
    G01 X2.2646 Y2.6155
    G01 X2.2632 Y2.6227
    G01 X2.2603 Y2.6295
    G01 X2.2562 Y2.6357
    G01 X2.2510 Y2.6409
    G01 X2.2449 Y2.6450
    G01 X2.2381 Y2.6478
    G01 X2.2309 Y2.6492
    G00 Z0.0787
    G00 X2.2309 Y2.8492
    G01 Z-0.0039 F5.91
    G01 X2.1715 Y2.8492 F7.87
    G01 X2.1643 Y2.8478
    G01 X2.1575 Y2.8450
    G01 X2.1513 Y2.8409
    G01 X2.1461 Y2.8357
    G01 X2.1420 Y2.8295
    G01 X2.1392 Y2.8227
    G01 X2.1378 Y2.8155
    G01 X2.1378 Y2.8081
    G01 X2.1392 Y2.8009
    G01 X2.1420 Y2.7941
    G01 X2.1461 Y2.7880
    G01 X2.1513 Y2.7827
    G01 X2.1575 Y2.7787
    G01 X2.1643 Y2.7758
    G01 X2.1715 Y2.7744
    G01 X2.2309 Y2.7744
    G01 X2.2381 Y2.7758
    G01 X2.2449 Y2.7787
    G01 X2.2510 Y2.7827
    G01 X2.2562 Y2.7880
    G01 X2.2603 Y2.7941
    G01 X2.2632 Y2.8009
    G01 X2.2646 Y2.8081
    G01 X2.2646 Y2.8155
    G01 X2.2632 Y2.8227
    G01 X2.2603 Y2.8295
    G01 X2.2562 Y2.8357
    G01 X2.2510 Y2.8409
    G01 X2.2449 Y2.8450
    G01 X2.2381 Y2.8478
    G01 X2.2309 Y2.8492
    G00 Z0.0787
    G00 X2.1575 Y3.0450
    G01 Z-0.0039 F5.91
    G01 X2.1513 Y3.0409 F7.87
    G01 X2.1461 Y3.0357
    G01 X2.1420 Y3.0295
    G01 X2.1392 Y3.0227
    G01 X2.1378 Y3.0155
    G01 X2.1378 Y3.0081
    G01 X2.1392 Y3.0009
    G01 X2.1420 Y2.9941
    G01 X2.1461 Y2.9880
    G01 X2.1513 Y2.9827
    G01 X2.1575 Y2.9787
    G01 X2.1643 Y2.9758
    G01 X2.1715 Y2.9744
    G01 X2.2309 Y2.9744
    G01 X2.2381 Y2.9758
    G01 X2.2449 Y2.9787
    G01 X2.2510 Y2.9827
    G01 X2.2562 Y2.9880
    G01 X2.2603 Y2.9941
    G01 X2.2632 Y3.0009
    G01 X2.2646 Y3.0081
    G01 X2.2646 Y3.0155
    G01 X2.2632 Y3.0227
    G01 X2.2603 Y3.0295
    G01 X2.2562 Y3.0357
    G01 X2.2510 Y3.0409
    G01 X2.2449 Y3.0450
    G01 X2.2389 Y3.0474
    G01 X2.9750 Y3.0474
    G01 X2.9739 Y3.0464
    G01 X2.8627 Y2.9352
    G01 X2.2565 Y2.9352
    G01 X2.2562 Y2.9357
    G01 X2.2510 Y2.9409
    G01 X2.2449 Y2.9450
    G01 X2.2381 Y2.9478
    G01 X2.2309 Y2.9492
    G01 X2.1715 Y2.9492
    G01 X2.1643 Y2.9478
    G01 X2.1575 Y2.9450
    G01 X2.1513 Y2.9409
    G01 X2.1461 Y2.9357
    G01 X2.1420 Y2.9295
    G01 X2.1392 Y2.9227
    G01 X2.1378 Y2.9155
    G01 X2.1378 Y2.9081
    G01 X2.1392 Y2.9009
    G01 X2.1420 Y2.8941
    G01 X2.1461 Y2.8880
    G01 X2.1513 Y2.8827
    G01 X2.1575 Y2.8787
    G01 X2.1643 Y2.8758
    G01 X2.1715 Y2.8744
    G01 X2.2309 Y2.8744
    G01 X2.2381 Y2.8758
    G01 X2.2449 Y2.8787
    G01 X2.2510 Y2.8827
    G01 X2.2562 Y2.8880
    G01 X2.2565 Y2.8884
    G01 X2.8747 Y2.8884
    G01 X2.8793 Y2.8893
    G01 X2.8835 Y2.8911
    G01 X2.8874 Y2.8936
    G01 X3.0018 Y3.0081
    G01 X3.2974 Y3.0081
    G01 X3.3624 Y2.9431
    G01 X3.3624 Y2.9148
    G01 X3.3378 Y2.8902
    G01 X3.3378 Y2.9287
    G01 X3.3094 Y2.9571
    G01 X3.2693 Y2.9571
    G01 X3.2410 Y2.9287
    G01 X3.2410 Y2.8886
    G01 X3.2693 Y2.8602
    G01 X3.3078 Y2.8602
    G01 X3.3047 Y2.8571
    G01 X3.2693 Y2.8571
    G01 X3.2410 Y2.8287
    G01 X3.2410 Y2.7886
    G01 X3.2693 Y2.7602
    G01 X3.3094 Y2.7602
    G01 X3.3378 Y2.7886
    G01 X3.3378 Y2.8240
    G01 X3.4040 Y2.8902
    G01 X3.4066 Y2.8940
    G01 X3.4083 Y2.8983
    G01 X3.4092 Y2.9028
    G01 X3.4092 Y2.9551
    G01 X3.4083 Y2.9596
    G01 X3.4066 Y2.9638
    G01 X3.4040 Y2.9677
    G01 X3.4008 Y2.9709
    G01 X3.3243 Y3.0474
    G01 X3.3761 Y3.0474
    G01 X3.4411 Y2.9824
    G01 X3.4411 Y2.8837
    G01 X3.3120 Y2.7545
    G01 X3.3094 Y2.7571
    G01 X3.2693 Y2.7571
    G01 X3.2410 Y2.7287
    G01 X3.2410 Y2.6886
    G01 X3.2693 Y2.6602
    G01 X3.3094 Y2.6602
    G01 X3.3378 Y2.6886
    G01 X3.3378 Y2.7141
    G01 X3.4795 Y2.8558
    G01 X3.4828 Y2.8591
    G01 X3.4853 Y2.8629
    G01 X3.4871 Y2.8672
    G01 X3.4880 Y2.8717
    G01 X3.4880 Y2.9944
    G01 X3.4871 Y2.9990
    G01 X3.4853 Y3.0032
    G01 X3.4828 Y3.0071
    G01 X3.4040 Y3.0858
    G01 X3.4008 Y3.0891
    G01 X3.3969 Y3.0916
    G01 X3.3927 Y3.0934
    G01 X3.3881 Y3.0943
    G01 X2.1237 Y3.0943
    G01 X2.1192 Y3.0934
    G01 X2.1149 Y3.0916
    G01 X2.1111 Y3.0891
    G01 X1.9929 Y2.9709
    G01 X1.9897 Y2.9677
    G01 X1.9871 Y2.9638
    G01 X1.9854 Y2.9596
    G01 X1.9845 Y2.9551
    G01 X1.9845 Y2.8323
    G01 X1.9854 Y2.8278
    G01 X1.9871 Y2.8236
    G01 X1.9897 Y2.8197
    G01 X2.1125 Y2.6969
    G01 X2.1158 Y2.6936
    G01 X2.1196 Y2.6911
    G01 X2.1239 Y2.6893
    G01 X2.1284 Y2.6884
    G01 X2.1458 Y2.6884
    G01 X2.1461 Y2.6880
    G01 X2.1513 Y2.6827
    G01 X2.1575 Y2.6787
    G01 X2.1643 Y2.6758
    G01 X2.1715 Y2.6744
    G01 X2.2309 Y2.6744
    G01 X2.2381 Y2.6758
    G01 X2.2449 Y2.6787
    G01 X2.2510 Y2.6827
    G01 X2.2562 Y2.6880
    G01 X2.2603 Y2.6941
    G01 X2.2632 Y2.7009
    G01 X2.2646 Y2.7081
    G01 X2.2646 Y2.7155
    G01 X2.2632 Y2.7227
    G01 X2.2603 Y2.7295
    G01 X2.2562 Y2.7357
    G01 X2.2510 Y2.7409
    G01 X2.2449 Y2.7450
    G01 X2.2381 Y2.7478
    G01 X2.2309 Y2.7492
    G01 X2.1715 Y2.7492
    G01 X2.1643 Y2.7478
    G01 X2.1575 Y2.7450
    G01 X2.1513 Y2.7409
    G01 X2.1461 Y2.7357
    G01 X2.1458 Y2.7352
    G01 X2.1404 Y2.7352
    G01 X2.0313 Y2.8443
    G01 X2.0313 Y2.9431
    G01 X2.1357 Y3.0474
    G01 X2.1634 Y3.0474
    G01 X2.1575 Y3.0450
    G00 Z0.0787
    G00 X0.2655 Y1.7605
    G01 Z-0.0039 F5.91
    G01 X0.1825 Y1.7605 F7.87
    G01 X0.1796 Y1.7597
    G01 X0.1770 Y1.7582
    G01 X0.1749 Y1.7561
    G01 X0.1734 Y1.7535
    G01 X0.1726 Y1.7506
    G01 X0.1726 Y1.6676
    G01 X0.1734 Y1.6646
    G01 X0.1749 Y1.6620
    G01 X0.1770 Y1.6599
    G01 X0.1796 Y1.6584
    G01 X0.1825 Y1.6576
    G01 X0.2655 Y1.6576
    G01 X0.2684 Y1.6584
    G01 X0.2710 Y1.6599
    G01 X0.2732 Y1.6620
    G01 X0.2747 Y1.6646
    G01 X0.2754 Y1.6676
    G01 X0.2754 Y1.7506
    G01 X0.2747 Y1.7535
    G01 X0.2732 Y1.7561
    G01 X0.2710 Y1.7582
    G01 X0.2684 Y1.7597
    G01 X0.2655 Y1.7605
    G00 Z0.0787
    G00 X0.2655 Y1.1817
    G01 Z-0.0039 F5.91
    G01 X0.1825 Y1.1817 F7.87
    G01 X0.1796 Y1.1810
    G01 X0.1770 Y1.1795
    G01 X0.1749 Y1.1773
    G01 X0.1734 Y1.1747
    G01 X0.1726 Y1.1718
    G01 X0.1726 Y1.0888
    G01 X0.1734 Y1.0859
    G01 X0.1749 Y1.0833
    G01 X0.1770 Y1.0812
    G01 X0.1796 Y1.0797
    G01 X0.1825 Y1.0789
    G01 X0.2655 Y1.0789
    G01 X0.2684 Y1.0797
    G01 X0.2710 Y1.0812
    G01 X0.2732 Y1.0833
    G01 X0.2747 Y1.0859
    G01 X0.2754 Y1.0888
    G01 X0.2754 Y1.1718
    G01 X0.2747 Y1.1747
    G01 X0.2732 Y1.1773
    G01 X0.2710 Y1.1795
    G01 X0.2684 Y1.1810
    G01 X0.2655 Y1.1817
    G00 Z0.0787
    G00 X0.2754 Y1.3231
    G01 Z-0.0039 F5.91
    G01 X0.2754 Y1.3312 F7.87
    G01 X0.2742 Y1.3392
    G01 X0.2717 Y1.3469
    G01 X0.2680 Y1.3541
    G01 X0.2632 Y1.3607
    G01 X0.2575 Y1.3664
    G01 X0.2510 Y1.3711
    G01 X0.2438 Y1.3748
    G01 X0.2361 Y1.3773
    G01 X0.2281 Y1.3786
    G01 X0.2200 Y1.3786
    G01 X0.2120 Y1.3773
    G01 X0.2082 Y1.3761
    G01 X0.1415 Y1.4428
    G01 X0.1415 Y1.8013
    G01 X0.2004 Y1.8602
    G01 X0.2043 Y1.8583
    G01 X0.2120 Y1.8558
    G01 X0.2200 Y1.8545
    G01 X0.2281 Y1.8545
    G01 X0.2361 Y1.8558
    G01 X0.2438 Y1.8583
    G01 X0.2510 Y1.8619
    G01 X0.2575 Y1.8667
    G01 X0.2632 Y1.8724
    G01 X0.2680 Y1.8790
    G01 X0.2717 Y1.8862
    G01 X0.2742 Y1.8939
    G01 X0.2754 Y1.9019
    G01 X0.2754 Y1.9100
    G01 X0.2742 Y1.9179
    G01 X0.2717 Y1.9256
    G01 X0.2680 Y1.9329
    G01 X0.2632 Y1.9394
    G01 X0.2575 Y1.9451
    G01 X0.2510 Y1.9499
    G01 X0.2438 Y1.9536
    G01 X0.2361 Y1.9561
    G01 X0.2281 Y1.9573
    G01 X0.2200 Y1.9573
    G01 X0.2120 Y1.9561
    G01 X0.2043 Y1.9536
    G01 X0.1971 Y1.9499
    G01 X0.1905 Y1.9451
    G01 X0.1848 Y1.9394
    G01 X0.1800 Y1.9329
    G01 X0.1764 Y1.9256
    G01 X0.1739 Y1.9179
    G01 X0.1726 Y1.9100
    G01 X0.1726 Y1.9019
    G01 X0.1730 Y1.8991
    G01 X0.0999 Y1.8260
    G01 X0.0974 Y1.8221
    G01 X0.0956 Y1.8179
    G01 X0.0947 Y1.8133
    G01 X0.0947 Y1.4308
    G01 X0.0956 Y1.4262
    G01 X0.0974 Y1.4220
    G01 X0.0999 Y1.4181
    G01 X0.1032 Y1.4149
    G01 X0.1751 Y1.3430
    G01 X0.1739 Y1.3392
    G01 X0.1726 Y1.3312
    G01 X0.1726 Y1.3231
    G01 X0.1739 Y1.3151
    G01 X0.1764 Y1.3074
    G01 X0.1800 Y1.3002
    G01 X0.1848 Y1.2937
    G01 X0.1905 Y1.2879
    G01 X0.1971 Y1.2832
    G01 X0.2043 Y1.2795
    G01 X0.2120 Y1.2770
    G01 X0.2200 Y1.2757
    G01 X0.2281 Y1.2757
    G01 X0.2361 Y1.2770
    G01 X0.2438 Y1.2795
    G01 X0.2510 Y1.2832
    G01 X0.2575 Y1.2879
    G01 X0.2632 Y1.2937
    G01 X0.2680 Y1.3002
    G01 X0.2717 Y1.3074
    G01 X0.2742 Y1.3151
    G01 X0.2754 Y1.3231
    G00 Z0.0787
    G00 X3.5222 Y0.3069
    G01 Z-0.0039 F5.91
    G01 X3.5222 Y0.2239 F7.87
    G01 X3.5230 Y0.2209
    G01 X3.5245 Y0.2183
    G01 X3.5266 Y0.2162
    G01 X3.5292 Y0.2147
    G01 X3.5321 Y0.2139
    G01 X3.6151 Y0.2139
    G01 X3.6180 Y0.2147
    G01 X3.6206 Y0.2162
    G01 X3.6228 Y0.2183
    G01 X3.6243 Y0.2209
    G01 X3.6250 Y0.2239
    G01 X3.6250 Y0.3069
    G01 X3.6243 Y0.3098
    G01 X3.6228 Y0.3124
    G01 X3.6206 Y0.3145
    G01 X3.6180 Y0.3160
    G01 X3.6151 Y0.3168
    G01 X3.5321 Y0.3168
    G01 X3.5292 Y0.3160
    G01 X3.5266 Y0.3145
    G01 X3.5245 Y0.3124
    G01 X3.5230 Y0.3098
    G01 X3.5222 Y0.3069
    G00 Z0.0787
    G00 X0.1825 Y0.5636
    G01 Z-0.0039 F5.91
    G01 X0.1796 Y0.5628 F7.87
    G01 X0.1770 Y0.5613
    G01 X0.1749 Y0.5592
    G01 X0.1734 Y0.5566
    G01 X0.1726 Y0.5537
    G01 X0.1726 Y0.4707
    G01 X0.1734 Y0.4678
    G01 X0.1749 Y0.4652
    G01 X0.1770 Y0.4631
    G01 X0.1796 Y0.4616
    G01 X0.1825 Y0.4608
    G01 X0.2655 Y0.4608
    G01 X0.2684 Y0.4616
    G01 X0.2710 Y0.4631
    G01 X0.2732 Y0.4652
    G01 X0.2747 Y0.4678
    G01 X0.2754 Y0.4707
    G01 X0.2754 Y0.5305
    G01 X0.3128 Y0.5679
    G01 X0.3834 Y0.5679
    G01 X0.3875 Y0.5624
    G01 X0.3924 Y0.5575
    G01 X0.3981 Y0.5533
    G01 X0.4043 Y0.5502
    G01 X0.4109 Y0.5480
    G01 X0.4178 Y0.5469
    G01 X0.4908 Y0.5469
    G01 X0.4977 Y0.5480
    G01 X0.5044 Y0.5502
    G01 X0.5106 Y0.5533
    G01 X0.5163 Y0.5575
    G01 X0.5212 Y0.5624
    G01 X0.5253 Y0.5681
    G01 X0.5285 Y0.5743
    G01 X0.5307 Y0.5809
    G01 X0.5317 Y0.5878
    G01 X0.5317 Y0.5948
    G01 X0.5307 Y0.6017
    G01 X0.5285 Y0.6084
    G01 X0.5253 Y0.6146
    G01 X0.5212 Y0.6203
    G01 X0.5163 Y0.6252
    G01 X0.5106 Y0.6293
    G01 X0.5044 Y0.6325
    G01 X0.4977 Y0.6347
    G01 X0.4908 Y0.6358
    G01 X0.4178 Y0.6358
    G01 X0.4109 Y0.6347
    G01 X0.4043 Y0.6325
    G01 X0.3981 Y0.6293
    G01 X0.3924 Y0.6252
    G01 X0.3875 Y0.6203
    G01 X0.3834 Y0.6148
    G01 X0.3008 Y0.6148
    G01 X0.2963 Y0.6139
    G01 X0.2921 Y0.6121
    G01 X0.2882 Y0.6095
    G01 X0.2850 Y0.6063
    G01 X0.2423 Y0.5636
    G01 X0.1825 Y0.5636
    G00 Z0.0787
    G00 X3.0608 Y0.9587
    G01 Z-0.0039 F5.91
    G01 X3.0014 Y0.9587 F7.87
    G01 X2.9942 Y0.9572
    G01 X2.9874 Y0.9544
    G01 X2.9812 Y0.9503
    G01 X2.9760 Y0.9451
    G01 X2.9719 Y0.9390
    G01 X2.9691 Y0.9322
    G01 X2.9677 Y0.9249
    G01 X2.9677 Y0.9176
    G01 X2.9691 Y0.9103
    G01 X2.9719 Y0.9035
    G01 X2.9760 Y0.8974
    G01 X2.9812 Y0.8922
    G01 X2.9874 Y0.8881
    G01 X2.9942 Y0.8853
    G01 X3.0014 Y0.8838
    G01 X3.0608 Y0.8838
    G01 X3.0680 Y0.8853
    G01 X3.0748 Y0.8881
    G01 X3.0810 Y0.8922
    G01 X3.0862 Y0.8974
    G01 X3.0903 Y0.9035
    G01 X3.0931 Y0.9103
    G01 X3.0945 Y0.9176
    G01 X3.0945 Y0.9249
    G01 X3.0931 Y0.9322
    G01 X3.0903 Y0.9390
    G01 X3.0862 Y0.9451
    G01 X3.0810 Y0.9503
    G01 X3.0748 Y0.9544
    G01 X3.0680 Y0.9572
    G01 X3.0608 Y0.9587
    G00 Z0.0787
    G00 X3.0608 Y0.8587
    G01 Z-0.0039 F5.91
    G01 X3.0014 Y0.8587 F7.87
    G01 X2.9942 Y0.8572
    G01 X2.9874 Y0.8544
    G01 X2.9812 Y0.8503
    G01 X2.9760 Y0.8451
    G01 X2.9757 Y0.8447
    G01 X2.8376 Y0.8447
    G01 X2.8331 Y0.8438
    G01 X2.8288 Y0.8420
    G01 X2.8250 Y0.8394
    G01 X2.8217 Y0.8362
    G01 X2.7180 Y0.7324
    G01 X2.7175 Y0.7325
    G01 X2.7101 Y0.7325
    G01 X2.7029 Y0.7311
    G01 X2.6961 Y0.7283
    G01 X2.6899 Y0.7242
    G01 X2.6847 Y0.7190
    G01 X2.6806 Y0.7128
    G01 X2.6778 Y0.7060
    G01 X2.6764 Y0.6988
    G01 X2.6764 Y0.6914
    G01 X2.6778 Y0.6842
    G01 X2.6806 Y0.6774
    G01 X2.6847 Y0.6713
    G01 X2.6899 Y0.6661
    G01 X2.6961 Y0.6620
    G01 X2.7029 Y0.6591
    G01 X2.7101 Y0.6577
    G01 X2.7175 Y0.6577
    G01 X2.7247 Y0.6591
    G01 X2.7315 Y0.6620
    G01 X2.7376 Y0.6661
    G01 X2.7428 Y0.6713
    G01 X2.7469 Y0.6774
    G01 X2.7498 Y0.6842
    G01 X2.7512 Y0.6914
    G01 X2.7512 Y0.6988
    G01 X2.7511 Y0.6993
    G01 X2.8496 Y0.7978
    G01 X2.9757 Y0.7978
    G01 X2.9760 Y0.7974
    G01 X2.9812 Y0.7922
    G01 X2.9874 Y0.7881
    G01 X2.9942 Y0.7853
    G01 X3.0014 Y0.7838
    G01 X3.0608 Y0.7838
    G01 X3.0680 Y0.7853
    G01 X3.0748 Y0.7881
    G01 X3.0810 Y0.7922
    G01 X3.0862 Y0.7974
    G01 X3.0903 Y0.8035
    G01 X3.0931 Y0.8103
    G01 X3.0945 Y0.8176
    G01 X3.0945 Y0.8249
    G01 X3.0931 Y0.8322
    G01 X3.0903 Y0.8390
    G01 X3.0862 Y0.8451
    G01 X3.0810 Y0.8503
    G01 X3.0748 Y0.8544
    G01 X3.0680 Y0.8572
    G01 X3.0608 Y0.8587
    G00 Z0.0787
    G00 X3.0608 Y0.7587
    G01 Z-0.0039 F5.91
    G01 X3.0014 Y0.7587 F7.87
    G01 X2.9942 Y0.7572
    G01 X2.9874 Y0.7544
    G01 X2.9812 Y0.7503
    G01 X2.9760 Y0.7451
    G01 X2.9719 Y0.7390
    G01 X2.9691 Y0.7322
    G01 X2.9677 Y0.7249
    G01 X2.9677 Y0.7176
    G01 X2.9691 Y0.7103
    G01 X2.9719 Y0.7035
    G01 X2.9760 Y0.6974
    G01 X2.9812 Y0.6922
    G01 X2.9874 Y0.6881
    G01 X2.9942 Y0.6853
    G01 X3.0014 Y0.6838
    G01 X3.0608 Y0.6838
    G01 X3.0680 Y0.6853
    G01 X3.0748 Y0.6881
    G01 X3.0810 Y0.6922
    G01 X3.0862 Y0.6974
    G01 X3.0903 Y0.7035
    G01 X3.0931 Y0.7103
    G01 X3.0945 Y0.7176
    G01 X3.0945 Y0.7249
    G01 X3.0931 Y0.7322
    G01 X3.0903 Y0.7390
    G01 X3.0862 Y0.7451
    G01 X3.0810 Y0.7503
    G01 X3.0748 Y0.7544
    G01 X3.0680 Y0.7572
    G01 X3.0608 Y0.7587
    G00 Z0.0787
    G00 X3.0608 Y0.6587
    G01 Z-0.0039 F5.91
    G01 X3.0014 Y0.6587 F7.87
    G01 X2.9942 Y0.6572
    G01 X2.9874 Y0.6544
    G01 X2.9812 Y0.6503
    G01 X2.9760 Y0.6451
    G01 X2.9719 Y0.6390
    G01 X2.9718 Y0.6385
    G01 X2.7433 Y0.6385
    G01 X2.7293 Y0.6525
    G01 X2.6983 Y0.6525
    G01 X2.6764 Y0.6306
    G01 X2.6764 Y0.5996
    G01 X2.6983 Y0.5777
    G01 X2.7293 Y0.5777
    G01 X2.7433 Y0.5917
    G01 X2.9820 Y0.5917
    G01 X2.9874 Y0.5881
    G01 X2.9942 Y0.5853
    G01 X3.0014 Y0.5838
    G01 X3.0608 Y0.5838
    G01 X3.0680 Y0.5853
    G01 X3.0748 Y0.5881
    G01 X3.0810 Y0.5922
    G01 X3.0862 Y0.5974
    G01 X3.0903 Y0.6035
    G01 X3.0931 Y0.6103
    G01 X3.0945 Y0.6176
    G01 X3.0945 Y0.6249
    G01 X3.0931 Y0.6322
    G01 X3.0903 Y0.6390
    G01 X3.0862 Y0.6451
    G01 X3.0810 Y0.6503
    G01 X3.0748 Y0.6544
    G01 X3.0680 Y0.6572
    G01 X3.0608 Y0.6587
    G00 Z0.0787
    G00 X3.3608 Y0.6587
    G01 Z-0.0039 F5.91
    G01 X3.3014 Y0.6587 F7.87
    G01 X3.2942 Y0.6572
    G01 X3.2874 Y0.6544
    G01 X3.2812 Y0.6503
    G01 X3.2760 Y0.6451
    G01 X3.2719 Y0.6390
    G01 X3.2691 Y0.6322
    G01 X3.2677 Y0.6249
    G01 X3.2677 Y0.6176
    G01 X3.2691 Y0.6103
    G01 X3.2719 Y0.6035
    G01 X3.2753 Y0.5985
    G01 X2.9542 Y0.2775
    G01 X2.7486 Y0.2775
    G01 X2.7484 Y0.2779
    G01 X2.7431 Y0.2832
    G01 X2.7370 Y0.2873
    G01 X2.7302 Y0.2901
    G01 X2.7230 Y0.2915
    G01 X2.7156 Y0.2915
    G01 X2.7084 Y0.2901
    G01 X2.7016 Y0.2873
    G01 X2.6954 Y0.2832
    G01 X2.6902 Y0.2779
    G01 X2.6861 Y0.2718
    G01 X2.6833 Y0.2650
    G01 X2.6819 Y0.2578
    G01 X2.6819 Y0.2504
    G01 X2.6833 Y0.2432
    G01 X2.6861 Y0.2364
    G01 X2.6902 Y0.2302
    G01 X2.6954 Y0.2250
    G01 X2.7016 Y0.2209
    G01 X2.7084 Y0.2181
    G01 X2.7156 Y0.2167
    G01 X2.7230 Y0.2167
    G01 X2.7302 Y0.2181
    G01 X2.7370 Y0.2209
    G01 X2.7431 Y0.2250
    G01 X2.7484 Y0.2302
    G01 X2.7486 Y0.2307
    G01 X2.9662 Y0.2307
    G01 X2.9708 Y0.2316
    G01 X2.9750 Y0.2333
    G01 X2.9789 Y0.2359
    G01 X2.9821 Y0.2392
    G01 X3.3268 Y0.5838
    G01 X3.3608 Y0.5838
    G01 X3.3680 Y0.5853
    G01 X3.3748 Y0.5881
    G01 X3.3810 Y0.5922
    G01 X3.3862 Y0.5974
    G01 X3.3903 Y0.6035
    G01 X3.3931 Y0.6103
    G01 X3.3945 Y0.6176
    G01 X3.3945 Y0.6249
    G01 X3.3931 Y0.6322
    G01 X3.3903 Y0.6390
    G01 X3.3862 Y0.6451
    G01 X3.3810 Y0.6503
    G01 X3.3748 Y0.6544
    G01 X3.3680 Y0.6572
    G01 X3.3608 Y0.6587
    G00 Z0.0787
    G00 X3.3608 Y0.7587
    G01 Z-0.0039 F5.91
    G01 X3.3014 Y0.7587 F7.87
    G01 X3.2942 Y0.7572
    G01 X3.2874 Y0.7544
    G01 X3.2812 Y0.7503
    G01 X3.2760 Y0.7451
    G01 X3.2719 Y0.7390
    G01 X3.2691 Y0.7322
    G01 X3.2677 Y0.7249
    G01 X3.2677 Y0.7176
    G01 X3.2691 Y0.7103
    G01 X3.2719 Y0.7035
    G01 X3.2760 Y0.6974
    G01 X3.2812 Y0.6922
    G01 X3.2874 Y0.6881
    G01 X3.2942 Y0.6853
    G01 X3.3014 Y0.6838
    G01 X3.3608 Y0.6838
    G01 X3.3680 Y0.6853
    G01 X3.3748 Y0.6881
    G01 X3.3810 Y0.6922
    G01 X3.3862 Y0.6974
    G01 X3.3903 Y0.7035
    G01 X3.3931 Y0.7103
    G01 X3.3945 Y0.7176
    G01 X3.3945 Y0.7249
    G01 X3.3931 Y0.7322
    G01 X3.3903 Y0.7390
    G01 X3.3862 Y0.7451
    G01 X3.3810 Y0.7503
    G01 X3.3748 Y0.7544
    G01 X3.3680 Y0.7572
    G01 X3.3608 Y0.7587
    G00 Z0.0787
    G00 X3.3608 Y0.8587
    G01 Z-0.0039 F5.91
    G01 X3.3014 Y0.8587 F7.87
    G01 X3.2942 Y0.8572
    G01 X3.2874 Y0.8544
    G01 X3.2812 Y0.8503
    G01 X3.2760 Y0.8451
    G01 X3.2719 Y0.8390
    G01 X3.2691 Y0.8322
    G01 X3.2677 Y0.8249
    G01 X3.2677 Y0.8176
    G01 X3.2691 Y0.8103
    G01 X3.2719 Y0.8035
    G01 X3.2760 Y0.7974
    G01 X3.2812 Y0.7922
    G01 X3.2874 Y0.7881
    G01 X3.2942 Y0.7853
    G01 X3.3014 Y0.7838
    G01 X3.3608 Y0.7838
    G01 X3.3680 Y0.7853
    G01 X3.3748 Y0.7881
    G01 X3.3810 Y0.7922
    G01 X3.3862 Y0.7974
    G01 X3.3903 Y0.8035
    G01 X3.3931 Y0.8103
    G01 X3.3945 Y0.8176
    G01 X3.3945 Y0.8249
    G01 X3.3931 Y0.8322
    G01 X3.3903 Y0.8390
    G01 X3.3862 Y0.8451
    G01 X3.3810 Y0.8503
    G01 X3.3748 Y0.8544
    G01 X3.3680 Y0.8572
    G01 X3.3608 Y0.8587
    G00 Z0.0787
    G00 X0.4908 Y1.1306
    G01 Z-0.0039 F5.91
    G01 X0.4178 Y1.1306 F7.87
    G01 X0.4109 Y1.1295
    G01 X0.4043 Y1.1274
    G01 X0.3981 Y1.1242
    G01 X0.3924 Y1.1201
    G01 X0.3875 Y1.1152
    G01 X0.3833 Y1.1095
    G01 X0.3802 Y1.1033
    G01 X0.3780 Y1.0966
    G01 X0.3769 Y1.0897
    G01 X0.3769 Y1.0827
    G01 X0.3774 Y1.0798
    G01 X0.3361 Y1.0386
    G01 X0.3336 Y1.0347
    G01 X0.3318 Y1.0305
    G01 X0.3309 Y1.0259
    G01 X0.3309 Y0.8491
    G01 X0.2398 Y0.7580
    G01 X0.2361 Y0.7592
    G01 X0.2281 Y0.7605
    G01 X0.2200 Y0.7605
    G01 X0.2120 Y0.7592
    G01 X0.2043 Y0.7567
    G01 X0.1971 Y0.7530
    G01 X0.1905 Y0.7483
    G01 X0.1848 Y0.7426
    G01 X0.1800 Y0.7360
    G01 X0.1764 Y0.7288
    G01 X0.1739 Y0.7211
    G01 X0.1726 Y0.7131
    G01 X0.1726 Y0.7050
    G01 X0.1739 Y0.6970
    G01 X0.1764 Y0.6893
    G01 X0.1800 Y0.6821
    G01 X0.1848 Y0.6756
    G01 X0.1905 Y0.6698
    G01 X0.1971 Y0.6651
    G01 X0.2043 Y0.6614
    G01 X0.2120 Y0.6589
    G01 X0.2200 Y0.6576
    G01 X0.2281 Y0.6576
    G01 X0.2361 Y0.6589
    G01 X0.2438 Y0.6614
    G01 X0.2510 Y0.6651
    G01 X0.2575 Y0.6698
    G01 X0.2632 Y0.6756
    G01 X0.2680 Y0.6821
    G01 X0.2717 Y0.6893
    G01 X0.2742 Y0.6970
    G01 X0.2754 Y0.7050
    G01 X0.2754 Y0.7131
    G01 X0.2742 Y0.7211
    G01 X0.2729 Y0.7249
    G01 X0.3693 Y0.8212
    G01 X0.3725 Y0.8244
    G01 X0.3751 Y0.8283
    G01 X0.3768 Y0.8325
    G01 X0.3777 Y0.8371
    G01 X0.3777 Y0.8774
    G01 X0.3780 Y0.8758
    G01 X0.3802 Y0.8692
    G01 X0.3833 Y0.8629
    G01 X0.3875 Y0.8573
    G01 X0.3924 Y0.8523
    G01 X0.3981 Y0.8482
    G01 X0.4043 Y0.8451
    G01 X0.4109 Y0.8429
    G01 X0.4178 Y0.8418
    G01 X0.4908 Y0.8418
    G01 X0.4977 Y0.8429
    G01 X0.5044 Y0.8451
    G01 X0.5106 Y0.8482
    G01 X0.5163 Y0.8523
    G01 X0.5212 Y0.8573
    G01 X0.5253 Y0.8629
    G01 X0.5285 Y0.8692
    G01 X0.5307 Y0.8758
    G01 X0.5317 Y0.8827
    G01 X0.5317 Y0.8897
    G01 X0.5307 Y0.8966
    G01 X0.5285 Y0.9033
    G01 X0.5253 Y0.9095
    G01 X0.5212 Y0.9152
    G01 X0.5163 Y0.9201
    G01 X0.5106 Y0.9242
    G01 X0.5044 Y0.9274
    G01 X0.4977 Y0.9295
    G01 X0.4908 Y0.9306
    G01 X0.4178 Y0.9306
    G01 X0.4109 Y0.9295
    G01 X0.4043 Y0.9274
    G01 X0.3981 Y0.9242
    G01 X0.3924 Y0.9201
    G01 X0.3875 Y0.9152
    G01 X0.3833 Y0.9095
    G01 X0.3802 Y0.9033
    G01 X0.3780 Y0.8966
    G01 X0.3777 Y0.8950
    G01 X0.3777 Y0.9774
    G01 X0.3780 Y0.9758
    G01 X0.3802 Y0.9692
    G01 X0.3833 Y0.9629
    G01 X0.3875 Y0.9573
    G01 X0.3924 Y0.9523
    G01 X0.3981 Y0.9482
    G01 X0.4043 Y0.9451
    G01 X0.4109 Y0.9429
    G01 X0.4178 Y0.9418
    G01 X0.4908 Y0.9418
    G01 X0.4977 Y0.9429
    G01 X0.5044 Y0.9451
    G01 X0.5106 Y0.9482
    G01 X0.5163 Y0.9523
    G01 X0.5212 Y0.9573
    G01 X0.5252 Y0.9628
    G01 X0.6576 Y0.9628
    G01 X0.9267 Y0.6937
    G01 X0.9300 Y0.6905
    G01 X0.9338 Y0.6879
    G01 X0.9381 Y0.6861
    G01 X0.9426 Y0.6852
    G01 X1.2501 Y0.6852
    G01 X1.4295 Y0.5059
    G01 X1.4284 Y0.5026
    G01 X1.4274 Y0.4962
    G01 X1.4274 Y0.4897
    G01 X1.4284 Y0.4832
    G01 X1.4304 Y0.4770
    G01 X1.4334 Y0.4712
    G01 X1.4372 Y0.4659
    G01 X1.4418 Y0.4613
    G01 X1.4471 Y0.4575
    G01 X1.4529 Y0.4545
    G01 X1.4591 Y0.4525
    G01 X1.4656 Y0.4515
    G01 X1.5321 Y0.4515
    G01 X1.5385 Y0.4525
    G01 X1.5447 Y0.4545
    G01 X1.5505 Y0.4575
    G01 X1.5558 Y0.4613
    G01 X1.5604 Y0.4659
    G01 X1.5642 Y0.4712
    G01 X1.5672 Y0.4770
    G01 X1.5692 Y0.4832
    G01 X1.5702 Y0.4897
    G01 X1.5702 Y0.4962
    G01 X1.5692 Y0.5026
    G01 X1.5672 Y0.5088
    G01 X1.5642 Y0.5146
    G01 X1.5604 Y0.5199
    G01 X1.5558 Y0.5245
    G01 X1.5505 Y0.5283
    G01 X1.5447 Y0.5313
    G01 X1.5385 Y0.5333
    G01 X1.5321 Y0.5343
    G01 X1.4867 Y0.5343
    G01 X1.4822 Y0.5352
    G01 X1.4664 Y0.5352
    G01 X1.2748 Y0.7269
    G01 X1.2709 Y0.7294
    G01 X1.2667 Y0.7312
    G01 X1.2621 Y0.7321
    G01 X0.9546 Y0.7321
    G01 X0.6823 Y1.0044
    G01 X0.6784 Y1.0070
    G01 X0.6742 Y1.0087
    G01 X0.6696 Y1.0096
    G01 X0.5252 Y1.0096
    G01 X0.5212 Y1.0152
    G01 X0.5163 Y1.0201
    G01 X0.5106 Y1.0242
    G01 X0.5044 Y1.0274
    G01 X0.4977 Y1.0295
    G01 X0.4908 Y1.0306
    G01 X0.4178 Y1.0306
    G01 X0.4109 Y1.0295
    G01 X0.4043 Y1.0274
    G01 X0.3981 Y1.0242
    G01 X0.3924 Y1.0201
    G01 X0.3875 Y1.0152
    G01 X0.3833 Y1.0095
    G01 X0.3802 Y1.0033
    G01 X0.3780 Y0.9966
    G01 X0.3777 Y0.9950
    G01 X0.3777 Y1.0139
    G01 X0.4078 Y1.0439
    G01 X0.4109 Y1.0429
    G01 X0.4178 Y1.0418
    G01 X0.4908 Y1.0418
    G01 X0.4977 Y1.0429
    G01 X0.5044 Y1.0451
    G01 X0.5106 Y1.0482
    G01 X0.5163 Y1.0523
    G01 X0.5212 Y1.0573
    G01 X0.5253 Y1.0629
    G01 X0.5285 Y1.0692
    G01 X0.5307 Y1.0758
    G01 X0.5317 Y1.0827
    G01 X0.5317 Y1.0897
    G01 X0.5307 Y1.0966
    G01 X0.5285 Y1.1033
    G01 X0.5253 Y1.1095
    G01 X0.5212 Y1.1152
    G01 X0.5163 Y1.1201
    G01 X0.5106 Y1.1242
    G01 X0.5044 Y1.1274
    G01 X0.4977 Y1.1295
    G01 X0.4908 Y1.1306
    G00 Z0.0787
    G00 X0.4908 Y0.5358
    G01 Z-0.0039 F5.91
    G01 X0.4178 Y0.5358 F7.87
    G01 X0.4109 Y0.5347
    G01 X0.4043 Y0.5325
    G01 X0.3981 Y0.5293
    G01 X0.3924 Y0.5252
    G01 X0.3875 Y0.5203
    G01 X0.3833 Y0.5146
    G01 X0.3802 Y0.5084
    G01 X0.3780 Y0.5017
    G01 X0.3769 Y0.4948
    G01 X0.3769 Y0.4878
    G01 X0.3780 Y0.4809
    G01 X0.3802 Y0.4743
    G01 X0.3833 Y0.4681
    G01 X0.3875 Y0.4624
    G01 X0.3924 Y0.4575
    G01 X0.3981 Y0.4533
    G01 X0.4043 Y0.4502
    G01 X0.4109 Y0.4480
    G01 X0.4178 Y0.4469
    G01 X0.4908 Y0.4469
    G01 X0.4977 Y0.4480
    G01 X0.5044 Y0.4502
    G01 X0.5106 Y0.4533
    G01 X0.5163 Y0.4575
    G01 X0.5212 Y0.4624
    G01 X0.5253 Y0.4681
    G01 X0.5285 Y0.4743
    G01 X0.5307 Y0.4809
    G01 X0.5317 Y0.4878
    G01 X0.5317 Y0.4948
    G01 X0.5307 Y0.5017
    G01 X0.5285 Y0.5084
    G01 X0.5253 Y0.5146
    G01 X0.5212 Y0.5203
    G01 X0.5163 Y0.5252
    G01 X0.5106 Y0.5293
    G01 X0.5044 Y0.5325
    G01 X0.4977 Y0.5347
    G01 X0.4908 Y0.5358
    G00 Z0.0787
    G00 X0.4908 Y0.4358
    G01 Z-0.0039 F5.91
    G01 X0.4178 Y0.4358 F7.87
    G01 X0.4109 Y0.4347
    G01 X0.4043 Y0.4325
    G01 X0.3981 Y0.4293
    G01 X0.3924 Y0.4252
    G01 X0.3875 Y0.4203
    G01 X0.3833 Y0.4146
    G01 X0.3802 Y0.4084
    G01 X0.3780 Y0.4017
    G01 X0.3769 Y0.3948
    G01 X0.3769 Y0.3878
    G01 X0.3780 Y0.3809
    G01 X0.3802 Y0.3743
    G01 X0.3833 Y0.3681
    G01 X0.3875 Y0.3624
    G01 X0.3924 Y0.3575
    G01 X0.3981 Y0.3533
    G01 X0.4043 Y0.3502
    G01 X0.4109 Y0.3480
    G01 X0.4178 Y0.3469
    G01 X0.4908 Y0.3469
    G01 X0.4977 Y0.3480
    G01 X0.5044 Y0.3502
    G01 X0.5106 Y0.3533
    G01 X0.5163 Y0.3575
    G01 X0.5212 Y0.3624
    G01 X0.5253 Y0.3681
    G01 X0.5285 Y0.3743
    G01 X0.5307 Y0.3809
    G01 X0.5317 Y0.3878
    G01 X0.5317 Y0.3948
    G01 X0.5307 Y0.4017
    G01 X0.5285 Y0.4084
    G01 X0.5253 Y0.4146
    G01 X0.5212 Y0.4203
    G01 X0.5163 Y0.4252
    G01 X0.5106 Y0.4293
    G01 X0.5044 Y0.4325
    G01 X0.4977 Y0.4347
    G01 X0.4908 Y0.4358
    G00 Z0.0787
    G00 X0.2741 Y2.1444
    G01 Z-0.0039 F5.91
    G01 X0.2741 Y2.0714 F7.87
    G01 X0.2752 Y2.0645
    G01 X0.2773 Y2.0578
    G01 X0.2805 Y2.0516
    G01 X0.2846 Y2.0459
    G01 X0.2896 Y2.0410
    G01 X0.2952 Y2.0369
    G01 X0.3015 Y2.0337
    G01 X0.3081 Y2.0315
    G01 X0.3150 Y2.0305
    G01 X0.3220 Y2.0305
    G01 X0.3289 Y2.0315
    G01 X0.3356 Y2.0337
    G01 X0.3418 Y2.0369
    G01 X0.3474 Y2.0410
    G01 X0.3524 Y2.0459
    G01 X0.3565 Y2.0516
    G01 X0.3597 Y2.0578
    G01 X0.3618 Y2.0645
    G01 X0.3629 Y2.0714
    G01 X0.3629 Y2.1444
    G01 X0.3618 Y2.1513
    G01 X0.3597 Y2.1579
    G01 X0.3565 Y2.1642
    G01 X0.3524 Y2.1698
    G01 X0.3474 Y2.1748
    G01 X0.3418 Y2.1789
    G01 X0.3356 Y2.1820
    G01 X0.3289 Y2.1842
    G01 X0.3220 Y2.1853
    G01 X0.3150 Y2.1853
    G01 X0.3081 Y2.1842
    G01 X0.3015 Y2.1820
    G01 X0.2952 Y2.1789
    G01 X0.2896 Y2.1748
    G01 X0.2846 Y2.1698
    G01 X0.2805 Y2.1642
    G01 X0.2773 Y2.1579
    G01 X0.2752 Y2.1513
    G01 X0.2741 Y2.1444
    G00 Z0.0787
    G00 X2.7567 Y0.3186
    G01 Z-0.0039 F5.91
    G01 X2.7567 Y0.3496 F7.87
    G01 X2.7348 Y0.3715
    G01 X2.7038 Y0.3715
    G01 X2.6819 Y0.3496
    G01 X2.6819 Y0.3186
    G01 X2.7038 Y0.2967
    G01 X2.7348 Y0.2967
    G01 X2.7567 Y0.3186
    G00 Z0.0787
    G00 X3.3835 Y1.1211
    G01 Z-0.0039 F5.91
    G01 X3.3835 Y1.1521 F7.87
    G01 X3.3616 Y1.1740
    G01 X3.3306 Y1.1740
    G01 X3.3086 Y1.1521
    G01 X3.3086 Y1.1211
    G01 X3.3306 Y1.0992
    G01 X3.3616 Y1.0992
    G01 X3.3835 Y1.1211
    G00 Z0.0787
    G00 X2.7120 Y1.1103
    G01 Z-0.0039 F5.91
    G01 X2.7022 Y1.1103 F7.87
    G01 X2.7022 Y1.1275
    G01 X2.7120 Y1.1275
    G01 X2.7184 Y1.1285
    G01 X2.7246 Y1.1305
    G01 X2.7304 Y1.1335
    G01 X2.7357 Y1.1373
    G01 X2.7403 Y1.1419
    G01 X2.7442 Y1.1472
    G01 X2.7471 Y1.1530
    G01 X2.7491 Y1.1592
    G01 X2.7502 Y1.1656
    G01 X2.7502 Y1.1722
    G01 X2.7498 Y1.1742
    G01 X3.0670 Y1.4913
    G01 X3.0868 Y1.4913
    G01 X3.1008 Y1.5053
    G01 X3.3244 Y1.5053
    G01 X3.3306 Y1.4992
    G01 X3.3616 Y1.4992
    G01 X3.3835 Y1.5211
    G01 X3.3835 Y1.5521
    G01 X3.3616 Y1.5740
    G01 X3.3306 Y1.5740
    G01 X3.3087 Y1.5522
    G01 X3.1008 Y1.5522
    G01 X3.0868 Y1.5662
    G01 X3.0558 Y1.5662
    G01 X3.0338 Y1.5442
    G01 X3.0338 Y1.5244
    G01 X2.7186 Y1.2092
    G01 X2.7184 Y1.2093
    G01 X2.7120 Y1.2103
    G01 X2.6455 Y1.2103
    G01 X2.6390 Y1.2093
    G01 X2.6328 Y1.2073
    G01 X2.6270 Y1.2043
    G01 X2.6218 Y1.2005
    G01 X2.6171 Y1.1959
    G01 X2.6133 Y1.1906
    G01 X2.6104 Y1.1848
    G01 X2.6083 Y1.1786
    G01 X2.6073 Y1.1722
    G01 X2.6073 Y1.1656
    G01 X2.6083 Y1.1592
    G01 X2.6104 Y1.1530
    G01 X2.6133 Y1.1472
    G01 X2.6171 Y1.1419
    G01 X2.6218 Y1.1373
    G01 X2.6270 Y1.1335
    G01 X2.6328 Y1.1305
    G01 X2.6390 Y1.1285
    G01 X2.6455 Y1.1275
    G01 X2.6553 Y1.1275
    G01 X2.6553 Y1.1103
    G01 X2.6455 Y1.1103
    G01 X2.6390 Y1.1093
    G01 X2.6328 Y1.1073
    G01 X2.6270 Y1.1043
    G01 X2.6218 Y1.1005
    G01 X2.6171 Y1.0959
    G01 X2.6133 Y1.0906
    G01 X2.6104 Y1.0848
    G01 X2.6083 Y1.0786
    G01 X2.6073 Y1.0722
    G01 X2.6073 Y1.0656
    G01 X2.6083 Y1.0592
    G01 X2.6104 Y1.0530
    G01 X2.6133 Y1.0472
    G01 X2.6171 Y1.0419
    G01 X2.6218 Y1.0373
    G01 X2.6270 Y1.0335
    G01 X2.6328 Y1.0305
    G01 X2.6390 Y1.0285
    G01 X2.6455 Y1.0275
    G01 X2.6553 Y1.0275
    G01 X2.6553 Y1.0103
    G01 X2.6455 Y1.0103
    G01 X2.6390 Y1.0093
    G01 X2.6328 Y1.0073
    G01 X2.6270 Y1.0043
    G01 X2.6218 Y1.0005
    G01 X2.6171 Y0.9959
    G01 X2.6133 Y0.9906
    G01 X2.6104 Y0.9848
    G01 X2.6083 Y0.9786
    G01 X2.6073 Y0.9722
    G01 X2.6073 Y0.9656
    G01 X2.6083 Y0.9592
    G01 X2.6104 Y0.9530
    G01 X2.6133 Y0.9472
    G01 X2.6171 Y0.9419
    G01 X2.6218 Y0.9373
    G01 X2.6270 Y0.9335
    G01 X2.6328 Y0.9305
    G01 X2.6390 Y0.9285
    G01 X2.6455 Y0.9275
    G01 X2.7120 Y0.9275
    G01 X2.7184 Y0.9285
    G01 X2.7246 Y0.9305
    G01 X2.7304 Y0.9335
    G01 X2.7357 Y0.9373
    G01 X2.7403 Y0.9419
    G01 X2.7442 Y0.9472
    G01 X2.7471 Y0.9530
    G01 X2.7491 Y0.9592
    G01 X2.7502 Y0.9656
    G01 X2.7502 Y0.9722
    G01 X2.7491 Y0.9786
    G01 X2.7471 Y0.9848
    G01 X2.7442 Y0.9906
    G01 X2.7403 Y0.9959
    G01 X2.7357 Y1.0005
    G01 X2.7304 Y1.0043
    G01 X2.7246 Y1.0073
    G01 X2.7184 Y1.0093
    G01 X2.7120 Y1.0103
    G01 X2.7022 Y1.0103
    G01 X2.7022 Y1.0275
    G01 X2.7120 Y1.0275
    G01 X2.7184 Y1.0285
    G01 X2.7246 Y1.0305
    G01 X2.7304 Y1.0335
    G01 X2.7357 Y1.0373
    G01 X2.7403 Y1.0419
    G01 X2.7442 Y1.0472
    G01 X2.7471 Y1.0530
    G01 X2.7491 Y1.0592
    G01 X2.7502 Y1.0656
    G01 X2.7502 Y1.0722
    G01 X2.7491 Y1.0786
    G01 X2.7471 Y1.0848
    G01 X2.7442 Y1.0906
    G01 X2.7403 Y1.0959
    G01 X2.7357 Y1.1005
    G01 X2.7304 Y1.1043
    G01 X2.7246 Y1.1073
    G01 X2.7184 Y1.1093
    G01 X2.7120 Y1.1103
    G00 Z0.0787
    G00 X2.3520 Y0.3083
    G01 Z-0.0039 F5.91
    G01 X2.3520 Y0.3484 F7.87
    G01 X2.3236 Y0.3768
    G01 X2.2835 Y0.3768
    G01 X2.2551 Y0.3484
    G01 X2.2551 Y0.3083
    G01 X2.2835 Y0.2799
    G01 X2.3236 Y0.2799
    G01 X2.3520 Y0.3083
    G00 Z0.0787
    G00 X2.3520 Y0.2083
    G01 Z-0.0039 F5.91
    G01 X2.3520 Y0.2484 F7.87
    G01 X2.3236 Y0.2768
    G01 X2.2835 Y0.2768
    G01 X2.2551 Y0.2484
    G01 X2.2551 Y0.2083
    G01 X2.2585 Y0.2050
    G01 X2.1950 Y0.1415
    G01 X1.9782 Y0.1415
    G01 X1.9317 Y0.1880
    G01 X1.9520 Y0.2083
    G01 X1.9520 Y0.2484
    G01 X1.9236 Y0.2768
    G01 X1.8835 Y0.2768
    G01 X1.8551 Y0.2484
    G01 X1.8551 Y0.2083
    G01 X1.8801 Y0.1833
    G01 X1.8801 Y0.1808
    G01 X1.8810 Y0.1762
    G01 X1.8828 Y0.1720
    G01 X1.8854 Y0.1681
    G01 X1.9503 Y0.1032
    G01 X1.9536 Y0.0999
    G01 X1.9574 Y0.0974
    G01 X1.9617 Y0.0956
    G01 X1.9662 Y0.0947
    G01 X2.2070 Y0.0947
    G01 X2.2116 Y0.0956
    G01 X2.2158 Y0.0974
    G01 X2.2197 Y0.0999
    G01 X2.2997 Y0.1799
    G01 X2.3236 Y0.1799
    G01 X2.3520 Y0.2083
    G00 Z0.0787
    G00 X2.2520 Y0.3083
    G01 Z-0.0039 F5.91
    G01 X2.2520 Y0.3484 F7.87
    G01 X2.2236 Y0.3768
    G01 X2.1835 Y0.3768
    G01 X2.1551 Y0.3484
    G01 X2.1551 Y0.3083
    G01 X2.1835 Y0.2799
    G01 X2.2236 Y0.2799
    G01 X2.2520 Y0.3083
    G00 Z0.0787
    G00 X2.2520 Y0.2083
    G01 Z-0.0039 F5.91
    G01 X2.2520 Y0.2484 F7.87
    G01 X2.2236 Y0.2768
    G01 X2.1835 Y0.2768
    G01 X2.1551 Y0.2484
    G01 X2.1551 Y0.2083
    G01 X2.1835 Y0.1799
    G01 X2.2236 Y0.1799
    G01 X2.2520 Y0.2083
    G00 Z0.0787
    G00 X2.1520 Y0.2083
    G01 Z-0.0039 F5.91
    G01 X2.1520 Y0.2484 F7.87
    G01 X2.1236 Y0.2768
    G01 X2.0835 Y0.2768
    G01 X2.0551 Y0.2484
    G01 X2.0551 Y0.2083
    G01 X2.0835 Y0.1799
    G01 X2.1236 Y0.1799
    G01 X2.1520 Y0.2083
    G00 Z0.0787
    G00 X2.0520 Y0.3083
    G01 Z-0.0039 F5.91
    G01 X2.0520 Y0.3484 F7.87
    G01 X2.0270 Y0.3734
    G01 X2.0270 Y0.7734
    G01 X2.2066 Y0.9530
    G01 X2.2260 Y0.9530
    G01 X2.2289 Y0.9538
    G01 X2.2315 Y0.9553
    G01 X2.2337 Y0.9574
    G01 X2.2352 Y0.9600
    G01 X2.2360 Y0.9629
    G01 X2.2360 Y1.0056
    G01 X2.2352 Y1.0085
    G01 X2.2337 Y1.0111
    G01 X2.2315 Y1.0132
    G01 X2.2289 Y1.0147
    G01 X2.2260 Y1.0155
    G01 X2.1834 Y1.0155
    G01 X2.1805 Y1.0147
    G01 X2.1779 Y1.0132
    G01 X2.1758 Y1.0111
    G01 X2.1743 Y1.0085
    G01 X2.1735 Y1.0056
    G01 X2.1735 Y0.9861
    G01 X1.9854 Y0.7980
    G01 X1.9828 Y0.7942
    G01 X1.9810 Y0.7899
    G01 X1.9801 Y0.7854
    G01 X1.9801 Y0.3734
    G01 X1.9551 Y0.3484
    G01 X1.9551 Y0.3083
    G01 X1.9835 Y0.2799
    G01 X2.0236 Y0.2799
    G01 X2.0520 Y0.3083
    G00 Z0.0787
    G00 X2.0520 Y0.2083
    G01 Z-0.0039 F5.91
    G01 X2.0520 Y0.2484 F7.87
    G01 X2.0236 Y0.2768
    G01 X1.9835 Y0.2768
    G01 X1.9551 Y0.2484
    G01 X1.9551 Y0.2083
    G01 X1.9835 Y0.1799
    G01 X2.0236 Y0.1799
    G01 X2.0520 Y0.2083
    G00 Z0.0787
    G00 X1.9520 Y0.3083
    G01 Z-0.0039 F5.91
    G01 X1.9520 Y0.3484 F7.87
    G01 X1.9236 Y0.3768
    G01 X1.8835 Y0.3768
    G01 X1.8551 Y0.3484
    G01 X1.8551 Y0.3083
    G01 X1.8835 Y0.2799
    G01 X1.9236 Y0.2799
    G01 X1.9520 Y0.3083
    G00 Z0.0787
    G00 X0.9405 Y1.8437
    G01 Z-0.0039 F5.91
    G01 X0.9405 Y1.8838 F7.87
    G01 X0.9122 Y1.9122
    G01 X0.8721 Y1.9122
    G01 X0.8437 Y1.8838
    G01 X0.8437 Y1.8437
    G01 X0.8721 Y1.8154
    G01 X0.9122 Y1.8154
    G01 X0.9405 Y1.8437
    G00 Z0.0787
    G00 X1.0122 Y1.9122
    G01 Z-0.0039 F5.91
    G01 X0.9721 Y1.9122 F7.87
    G01 X0.9437 Y1.8838
    G01 X0.9437 Y1.8437
    G01 X0.9721 Y1.8154
    G01 X1.0122 Y1.8154
    G01 X1.0372 Y1.8404
    G01 X1.3395 Y1.8404
    G01 X1.5454 Y1.6345
    G01 X1.5420 Y1.6295
    G01 X1.5392 Y1.6227
    G01 X1.5378 Y1.6155
    G01 X1.5378 Y1.6081
    G01 X1.5392 Y1.6009
    G01 X1.5420 Y1.5941
    G01 X1.5461 Y1.5880
    G01 X1.5513 Y1.5827
    G01 X1.5575 Y1.5787
    G01 X1.5643 Y1.5758
    G01 X1.5715 Y1.5744
    G01 X1.6309 Y1.5744
    G01 X1.6381 Y1.5758
    G01 X1.6449 Y1.5787
    G01 X1.6510 Y1.5827
    G01 X1.6562 Y1.5880
    G01 X1.6603 Y1.5941
    G01 X1.6632 Y1.6009
    G01 X1.6646 Y1.6081
    G01 X1.6646 Y1.6155
    G01 X1.6632 Y1.6227
    G01 X1.6603 Y1.6295
    G01 X1.6562 Y1.6357
    G01 X1.6510 Y1.6409
    G01 X1.6449 Y1.6450
    G01 X1.6381 Y1.6478
    G01 X1.6309 Y1.6492
    G01 X1.5969 Y1.6492
    G01 X1.5717 Y1.6744
    G01 X1.6309 Y1.6744
    G01 X1.6381 Y1.6758
    G01 X1.6449 Y1.6787
    G01 X1.6510 Y1.6827
    G01 X1.6562 Y1.6880
    G01 X1.6603 Y1.6941
    G01 X1.6632 Y1.7009
    G01 X1.6646 Y1.7081
    G01 X1.6646 Y1.7155
    G01 X1.6632 Y1.7227
    G01 X1.6603 Y1.7295
    G01 X1.6562 Y1.7357
    G01 X1.6510 Y1.7409
    G01 X1.6449 Y1.7450
    G01 X1.6381 Y1.7478
    G01 X1.6309 Y1.7492
    G01 X1.5715 Y1.7492
    G01 X1.5643 Y1.7478
    G01 X1.5575 Y1.7450
    G01 X1.5513 Y1.7409
    G01 X1.5461 Y1.7357
    G01 X1.5420 Y1.7295
    G01 X1.5392 Y1.7227
    G01 X1.5378 Y1.7155
    G01 X1.5378 Y1.7083
    G01 X1.3674 Y1.8787
    G01 X1.3641 Y1.8820
    G01 X1.3603 Y1.8845
    G01 X1.3560 Y1.8863
    G01 X1.3515 Y1.8872
    G01 X1.0372 Y1.8872
    G01 X1.0122 Y1.9122
    G00 Z0.0787
    G00 X0.9405 Y1.7437
    G01 Z-0.0039 F5.91
    G01 X0.9405 Y1.7838 F7.87
    G01 X0.9122 Y1.8122
    G01 X0.8721 Y1.8122
    G01 X0.8437 Y1.7838
    G01 X0.8437 Y1.7437
    G01 X0.8721 Y1.7154
    G01 X0.9122 Y1.7154
    G01 X0.9405 Y1.7437
    G00 Z0.0787
    G00 X1.0122 Y1.8122
    G01 Z-0.0039 F5.91
    G01 X0.9721 Y1.8122 F7.87
    G01 X0.9437 Y1.7838
    G01 X0.9437 Y1.7437
    G01 X0.9721 Y1.7154
    G01 X1.0122 Y1.7154
    G01 X1.0372 Y1.7404
    G01 X1.2395 Y1.7404
    G01 X1.5454 Y1.4345
    G01 X1.5420 Y1.4295
    G01 X1.5392 Y1.4227
    G01 X1.5378 Y1.4155
    G01 X1.5378 Y1.4081
    G01 X1.5392 Y1.4009
    G01 X1.5420 Y1.3941
    G01 X1.5461 Y1.3880
    G01 X1.5513 Y1.3827
    G01 X1.5575 Y1.3787
    G01 X1.5643 Y1.3758
    G01 X1.5715 Y1.3744
    G01 X1.6309 Y1.3744
    G01 X1.6381 Y1.3758
    G01 X1.6449 Y1.3787
    G01 X1.6510 Y1.3827
    G01 X1.6562 Y1.3880
    G01 X1.6603 Y1.3941
    G01 X1.6632 Y1.4009
    G01 X1.6646 Y1.4081
    G01 X1.6646 Y1.4155
    G01 X1.6632 Y1.4227
    G01 X1.6603 Y1.4295
    G01 X1.6562 Y1.4357
    G01 X1.6510 Y1.4409
    G01 X1.6449 Y1.4450
    G01 X1.6381 Y1.4478
    G01 X1.6309 Y1.4492
    G01 X1.5969 Y1.4492
    G01 X1.5717 Y1.4744
    G01 X1.6309 Y1.4744
    G01 X1.6381 Y1.4758
    G01 X1.6449 Y1.4787
    G01 X1.6510 Y1.4827
    G01 X1.6562 Y1.4880
    G01 X1.6603 Y1.4941
    G01 X1.6632 Y1.5009
    G01 X1.6646 Y1.5081
    G01 X1.6646 Y1.5155
    G01 X1.6632 Y1.5227
    G01 X1.6603 Y1.5295
    G01 X1.6562 Y1.5357
    G01 X1.6510 Y1.5409
    G01 X1.6449 Y1.5450
    G01 X1.6381 Y1.5478
    G01 X1.6309 Y1.5492
    G01 X1.5715 Y1.5492
    G01 X1.5643 Y1.5478
    G01 X1.5575 Y1.5450
    G01 X1.5513 Y1.5409
    G01 X1.5461 Y1.5357
    G01 X1.5420 Y1.5295
    G01 X1.5392 Y1.5227
    G01 X1.5378 Y1.5155
    G01 X1.5378 Y1.5083
    G01 X1.2674 Y1.7787
    G01 X1.2641 Y1.7820
    G01 X1.2603 Y1.7845
    G01 X1.2560 Y1.7863
    G01 X1.2515 Y1.7872
    G01 X1.0372 Y1.7872
    G01 X1.0122 Y1.8122
    G00 Z0.0787
    G00 X0.9405 Y1.6437
    G01 Z-0.0039 F5.91
    G01 X0.9405 Y1.6838 F7.87
    G01 X0.9122 Y1.7122
    G01 X0.8721 Y1.7122
    G01 X0.8437 Y1.6838
    G01 X0.8437 Y1.6437
    G01 X0.8721 Y1.6154
    G01 X0.9122 Y1.6154
    G01 X0.9405 Y1.6437
    G00 Z0.0787
    G00 X1.0122 Y1.7122
    G01 Z-0.0039 F5.91
    G01 X0.9721 Y1.7122 F7.87
    G01 X0.9437 Y1.6838
    G01 X0.9437 Y1.6437
    G01 X0.9721 Y1.6154
    G01 X1.0122 Y1.6154
    G01 X1.0372 Y1.6404
    G01 X1.1395 Y1.6404
    G01 X1.5454 Y1.2345
    G01 X1.5420 Y1.2295
    G01 X1.5392 Y1.2227
    G01 X1.5378 Y1.2155
    G01 X1.5378 Y1.2081
    G01 X1.5392 Y1.2009
    G01 X1.5420 Y1.1941
    G01 X1.5461 Y1.1880
    G01 X1.5513 Y1.1827
    G01 X1.5575 Y1.1787
    G01 X1.5643 Y1.1758
    G01 X1.5715 Y1.1744
    G01 X1.6309 Y1.1744
    G01 X1.6381 Y1.1758
    G01 X1.6449 Y1.1787
    G01 X1.6510 Y1.1827
    G01 X1.6562 Y1.1880
    G01 X1.6603 Y1.1941
    G01 X1.6632 Y1.2009
    G01 X1.6646 Y1.2081
    G01 X1.6646 Y1.2155
    G01 X1.6632 Y1.2227
    G01 X1.6603 Y1.2295
    G01 X1.6562 Y1.2357
    G01 X1.6510 Y1.2409
    G01 X1.6449 Y1.2450
    G01 X1.6381 Y1.2478
    G01 X1.6309 Y1.2492
    G01 X1.5969 Y1.2492
    G01 X1.5717 Y1.2744
    G01 X1.6309 Y1.2744
    G01 X1.6381 Y1.2758
    G01 X1.6449 Y1.2787
    G01 X1.6510 Y1.2827
    G01 X1.6562 Y1.2880
    G01 X1.6603 Y1.2941
    G01 X1.6632 Y1.3009
    G01 X1.6646 Y1.3081
    G01 X1.6646 Y1.3155
    G01 X1.6632 Y1.3227
    G01 X1.6603 Y1.3295
    G01 X1.6562 Y1.3357
    G01 X1.6510 Y1.3409
    G01 X1.6449 Y1.3450
    G01 X1.6381 Y1.3478
    G01 X1.6309 Y1.3492
    G01 X1.5715 Y1.3492
    G01 X1.5643 Y1.3478
    G01 X1.5575 Y1.3450
    G01 X1.5513 Y1.3409
    G01 X1.5461 Y1.3357
    G01 X1.5420 Y1.3295
    G01 X1.5392 Y1.3227
    G01 X1.5378 Y1.3155
    G01 X1.5378 Y1.3083
    G01 X1.1674 Y1.6787
    G01 X1.1641 Y1.6820
    G01 X1.1603 Y1.6845
    G01 X1.1560 Y1.6863
    G01 X1.1515 Y1.6872
    G01 X1.0372 Y1.6872
    G01 X1.0122 Y1.7122
    G00 Z0.0787
    G00 X0.9405 Y1.5437
    G01 Z-0.0039 F5.91
    G01 X0.9405 Y1.5838 F7.87
    G01 X0.9122 Y1.6122
    G01 X0.8721 Y1.6122
    G01 X0.8437 Y1.5838
    G01 X0.8437 Y1.5437
    G01 X0.8721 Y1.5154
    G01 X0.9122 Y1.5154
    G01 X0.9405 Y1.5437
    G00 Z0.0787
    G00 X1.0405 Y1.5838
    G01 Z-0.0039 F5.91
    G01 X1.0122 Y1.6122 F7.87
    G01 X0.9721 Y1.6122
    G01 X0.9437 Y1.5838
    G01 X0.9437 Y1.5437
    G01 X0.9721 Y1.5154
    G01 X1.0074 Y1.5154
    G01 X1.5928 Y0.9300
    G01 X1.5961 Y0.9267
    G01 X1.5999 Y0.9241
    G01 X1.6042 Y0.9224
    G01 X1.6087 Y0.9215
    G01 X1.8133 Y0.9215
    G01 X1.8179 Y0.9224
    G01 X1.8221 Y0.9241
    G01 X1.8260 Y0.9267
    G01 X1.9877 Y1.0884
    G01 X2.1458 Y1.0884
    G01 X2.1461 Y1.0880
    G01 X2.1513 Y1.0827
    G01 X2.1575 Y1.0787
    G01 X2.1643 Y1.0758
    G01 X2.1715 Y1.0744
    G01 X2.2309 Y1.0744
    G01 X2.2381 Y1.0758
    G01 X2.2449 Y1.0787
    G01 X2.2510 Y1.0827
    G01 X2.2562 Y1.0880
    G01 X2.2603 Y1.0941
    G01 X2.2632 Y1.1009
    G01 X2.2646 Y1.1081
    G01 X2.2646 Y1.1155
    G01 X2.2632 Y1.1227
    G01 X2.2603 Y1.1295
    G01 X2.2562 Y1.1357
    G01 X2.2510 Y1.1409
    G01 X2.2449 Y1.1450
    G01 X2.2381 Y1.1478
    G01 X2.2309 Y1.1492
    G01 X2.1715 Y1.1492
    G01 X2.1643 Y1.1478
    G01 X2.1575 Y1.1450
    G01 X2.1513 Y1.1409
    G01 X2.1461 Y1.1357
    G01 X2.1458 Y1.1352
    G01 X1.9756 Y1.1352
    G01 X1.9711 Y1.1343
    G01 X1.9669 Y1.1326
    G01 X1.9630 Y1.1300
    G01 X1.9598 Y1.1267
    G01 X1.8013 Y0.9683
    G01 X1.6207 Y0.9683
    G01 X1.0405 Y1.5485
    G01 X1.0405 Y1.5838
    G00 Z0.0787
    G00 X3.3653 Y1.9618
    G01 Z-0.0039 F5.91
    G01 X3.3653 Y2.0019 F7.87
    G01 X3.3370 Y2.0303
    G01 X3.2969 Y2.0303
    G01 X3.2685 Y2.0019
    G01 X3.2685 Y1.9618
    G01 X3.2969 Y1.9335
    G01 X3.3370 Y1.9335
    G01 X3.3653 Y1.9618
    G00 Z0.0787
    G00 X3.3653 Y1.8618
    G01 Z-0.0039 F5.91
    G01 X3.3653 Y1.9019 F7.87
    G01 X3.3370 Y1.9303
    G01 X3.2969 Y1.9303
    G01 X3.2685 Y1.9019
    G01 X3.2685 Y1.8618
    G01 X3.2969 Y1.8335
    G01 X3.3370 Y1.8335
    G01 X3.3653 Y1.8618
    G00 Z0.0787
    G00 X3.3653 Y1.7618
    G01 Z-0.0039 F5.91
    G01 X3.3653 Y1.8019 F7.87
    G01 X3.3370 Y1.8303
    G01 X3.2969 Y1.8303
    G01 X3.2685 Y1.8019
    G01 X3.2685 Y1.7618
    G01 X3.2969 Y1.7335
    G01 X3.3370 Y1.7335
    G01 X3.3653 Y1.7618
    G00 Z0.0787
    G00 X3.3653 Y1.6618
    G01 Z-0.0039 F5.91
    G01 X3.3653 Y1.7019 F7.87
    G01 X3.3370 Y1.7303
    G01 X3.2969 Y1.7303
    G01 X3.2685 Y1.7019
    G01 X3.2685 Y1.6618
    G01 X3.2969 Y1.6335
    G01 X3.3370 Y1.6335
    G01 X3.3653 Y1.6618
    G00 Z0.0787
    G00 X1.0287 Y2.7886
    G01 Z-0.0039 F5.91
    G01 X1.0287 Y2.8287 F7.87
    G01 X1.0004 Y2.8571
    G01 X0.9603 Y2.8571
    G01 X0.9319 Y2.8287
    G01 X0.9319 Y2.7886
    G01 X0.9603 Y2.7602
    G01 X1.0004 Y2.7602
    G01 X1.0287 Y2.7886
    G00 Z0.0787
    G00 X0.9287 Y2.6886
    G01 Z-0.0039 F5.91
    G01 X0.9287 Y2.7287 F7.87
    G01 X0.9004 Y2.7571
    G01 X0.8603 Y2.7571
    G01 X0.8319 Y2.7287
    G01 X0.8319 Y2.6886
    G01 X0.8603 Y2.6602
    G01 X0.9004 Y2.6602
    G01 X0.9287 Y2.6886
    G00 Z0.0787
    G00 X0.9287 Y2.5886
    G01 Z-0.0039 F5.91
    G01 X0.9287 Y2.6287 F7.87
    G01 X0.9004 Y2.6571
    G01 X0.8603 Y2.6571
    G01 X0.8319 Y2.6287
    G01 X0.8319 Y2.5886
    G01 X0.8603 Y2.5602
    G01 X0.9004 Y2.5602
    G01 X0.9287 Y2.5886
    G00 Z0.0787
    G00 X1.0004 Y2.6571
    G01 Z-0.0039 F5.91
    G01 X0.9603 Y2.6571 F7.87
    G01 X0.9319 Y2.6287
    G01 X0.9319 Y2.5886
    G01 X0.9603 Y2.5602
    G01 X1.0004 Y2.5602
    G01 X1.0254 Y2.5852
    G01 X1.4946 Y2.5852
    G01 X1.5454 Y2.5345
    G01 X1.5420 Y2.5295
    G01 X1.5392 Y2.5227
    G01 X1.5378 Y2.5155
    G01 X1.5378 Y2.5081
    G01 X1.5392 Y2.5009
    G01 X1.5420 Y2.4941
    G01 X1.5461 Y2.4880
    G01 X1.5513 Y2.4827
    G01 X1.5575 Y2.4787
    G01 X1.5643 Y2.4758
    G01 X1.5715 Y2.4744
    G01 X1.6309 Y2.4744
    G01 X1.6381 Y2.4758
    G01 X1.6449 Y2.4787
    G01 X1.6510 Y2.4827
    G01 X1.6562 Y2.4880
    G01 X1.6603 Y2.4941
    G01 X1.6632 Y2.5009
    G01 X1.6646 Y2.5081
    G01 X1.6646 Y2.5155
    G01 X1.6632 Y2.5227
    G01 X1.6603 Y2.5295
    G01 X1.6562 Y2.5357
    G01 X1.6510 Y2.5409
    G01 X1.6449 Y2.5450
    G01 X1.6381 Y2.5478
    G01 X1.6309 Y2.5492
    G01 X1.5969 Y2.5492
    G01 X1.5717 Y2.5744
    G01 X1.6309 Y2.5744
    G01 X1.6381 Y2.5758
    G01 X1.6449 Y2.5787
    G01 X1.6510 Y2.5827
    G01 X1.6562 Y2.5880
    G01 X1.6603 Y2.5941
    G01 X1.6632 Y2.6009
    G01 X1.6646 Y2.6081
    G01 X1.6646 Y2.6155
    G01 X1.6632 Y2.6227
    G01 X1.6603 Y2.6295
    G01 X1.6562 Y2.6357
    G01 X1.6510 Y2.6409
    G01 X1.6449 Y2.6450
    G01 X1.6381 Y2.6478
    G01 X1.6309 Y2.6492
    G01 X1.5715 Y2.6492
    G01 X1.5643 Y2.6478
    G01 X1.5575 Y2.6450
    G01 X1.5513 Y2.6409
    G01 X1.5461 Y2.6357
    G01 X1.5420 Y2.6295
    G01 X1.5392 Y2.6227
    G01 X1.5378 Y2.6155
    G01 X1.5378 Y2.6083
    G01 X1.5225 Y2.6236
    G01 X1.5193 Y2.6269
    G01 X1.5154 Y2.6294
    G01 X1.5112 Y2.6312
    G01 X1.5066 Y2.6321
    G01 X1.0254 Y2.6321
    G01 X1.0004 Y2.6571
    G00 Z0.0787
    G00 X0.9287 Y2.4886
    G01 Z-0.0039 F5.91
    G01 X0.9287 Y2.5287 F7.87
    G01 X0.9004 Y2.5571
    G01 X0.8603 Y2.5571
    G01 X0.8319 Y2.5287
    G01 X0.8319 Y2.4886
    G01 X0.8603 Y2.4602
    G01 X0.9004 Y2.4602
    G01 X0.9287 Y2.4886
    G00 Z0.0787
    G00 X1.0004 Y2.5571
    G01 Z-0.0039 F5.91
    G01 X0.9603 Y2.5571 F7.87
    G01 X0.9319 Y2.5287
    G01 X0.9319 Y2.4886
    G01 X0.9603 Y2.4602
    G01 X1.0004 Y2.4602
    G01 X1.0254 Y2.4852
    G01 X1.3946 Y2.4852
    G01 X1.5454 Y2.3345
    G01 X1.5420 Y2.3295
    G01 X1.5392 Y2.3227
    G01 X1.5378 Y2.3155
    G01 X1.5378 Y2.3081
    G01 X1.5384 Y2.3052
    G01 X1.5364 Y2.3060
    G01 X1.5318 Y2.3069
    G01 X1.0607 Y2.3069
    G01 X1.0562 Y2.3060
    G01 X1.0519 Y2.3042
    G01 X1.0481 Y2.3017
    G01 X1.0019 Y2.2555
    G01 X0.9821 Y2.2555
    G01 X0.9602 Y2.2336
    G01 X0.9602 Y2.2026
    G01 X0.9821 Y2.1807
    G01 X1.0131 Y2.1807
    G01 X1.0351 Y2.2026
    G01 X1.0351 Y2.2224
    G01 X1.0727 Y2.2600
    G01 X1.5198 Y2.2600
    G01 X1.5454 Y2.2345
    G01 X1.5420 Y2.2295
    G01 X1.5392 Y2.2227
    G01 X1.5378 Y2.2155
    G01 X1.5378 Y2.2081
    G01 X1.5392 Y2.2009
    G01 X1.5420 Y2.1941
    G01 X1.5456 Y2.1888
    G01 X1.4664 Y2.1888
    G01 X1.4351 Y2.2201
    G01 X1.4351 Y2.2336
    G01 X1.4131 Y2.2555
    G01 X1.3821 Y2.2555
    G01 X1.3602 Y2.2336
    G01 X1.3602 Y2.2026
    G01 X1.3821 Y2.1807
    G01 X1.4082 Y2.1807
    G01 X1.4418 Y2.1472
    G01 X1.4456 Y2.1446
    G01 X1.4499 Y2.1428
    G01 X1.4544 Y2.1419
    G01 X1.5379 Y2.1419
    G01 X1.5446 Y2.1352
    G01 X1.0379 Y2.1352
    G01 X1.0333 Y2.1343
    G01 X1.0291 Y2.1326
    G01 X1.0252 Y2.1300
    G01 X1.0220 Y2.1267
    G01 X0.9155 Y2.0203
    G01 X0.9155 Y2.2992
    G01 X0.9146 Y2.3037
    G01 X0.9129 Y2.3079
    G01 X0.9103 Y2.3118
    G01 X0.9071 Y2.3150
    G01 X0.8108 Y2.4113
    G01 X0.8108 Y2.8060
    G01 X0.8319 Y2.8271
    G01 X0.8319 Y2.7886
    G01 X0.8603 Y2.7602
    G01 X0.9004 Y2.7602
    G01 X0.9287 Y2.7886
    G01 X0.9287 Y2.8287
    G01 X0.9004 Y2.8571
    G01 X0.8619 Y2.8571
    G01 X0.8650 Y2.8602
    G01 X0.9004 Y2.8602
    G01 X0.9287 Y2.8886
    G01 X0.9287 Y2.9287
    G01 X0.9004 Y2.9571
    G01 X0.8603 Y2.9571
    G01 X0.8319 Y2.9287
    G01 X0.8319 Y2.8934
    G01 X0.7725 Y2.8339
    G01 X0.7692 Y2.8307
    G01 X0.7666 Y2.8268
    G01 X0.7649 Y2.8226
    G01 X0.7640 Y2.8181
    G01 X0.7640 Y2.3993
    G01 X0.7649 Y2.3947
    G01 X0.7666 Y2.3905
    G01 X0.7692 Y2.3866
    G01 X0.8687 Y2.2872
    G01 X0.8687 Y2.0088
    G01 X0.8437 Y1.9838
    G01 X0.8437 Y1.9437
    G01 X0.8721 Y1.9154
    G01 X0.9122 Y1.9154
    G01 X0.9405 Y1.9437
    G01 X0.9405 Y1.9791
    G01 X0.9437 Y1.9822
    G01 X0.9437 Y1.9437
    G01 X0.9721 Y1.9154
    G01 X1.0122 Y1.9154
    G01 X1.0405 Y1.9437
    G01 X1.0405 Y1.9791
    G01 X1.0499 Y1.9884
    G01 X1.5458 Y1.9884
    G01 X1.5461 Y1.9880
    G01 X1.5513 Y1.9827
    G01 X1.5575 Y1.9787
    G01 X1.5643 Y1.9758
    G01 X1.5715 Y1.9744
    G01 X1.6309 Y1.9744
    G01 X1.6381 Y1.9758
    G01 X1.6449 Y1.9787
    G01 X1.6510 Y1.9827
    G01 X1.6562 Y1.9880
    G01 X1.6565 Y1.9884
    G01 X1.9747 Y1.9884
    G01 X1.9793 Y1.9893
    G01 X1.9835 Y1.9911
    G01 X1.9874 Y1.9936
    G01 X2.0098 Y2.0160
    G01 X2.0292 Y2.0160
    G01 X2.0321 Y2.0168
    G01 X2.0347 Y2.0183
    G01 X2.0368 Y2.0204
    G01 X2.0383 Y2.0230
    G01 X2.0391 Y2.0259
    G01 X2.0391 Y2.0686
    G01 X2.0383 Y2.0715
    G01 X2.0368 Y2.0741
    G01 X2.0347 Y2.0762
    G01 X2.0321 Y2.0777
    G01 X2.0292 Y2.0785
    G01 X1.9866 Y2.0785
    G01 X1.9837 Y2.0777
    G01 X1.9811 Y2.0762
    G01 X1.9789 Y2.0741
    G01 X1.9774 Y2.0715
    G01 X1.9766 Y2.0686
    G01 X1.9766 Y2.0491
    G01 X1.9627 Y2.0352
    G01 X1.6565 Y2.0352
    G01 X1.6562 Y2.0357
    G01 X1.6510 Y2.0409
    G01 X1.6449 Y2.0450
    G01 X1.6381 Y2.0478
    G01 X1.6309 Y2.0492
    G01 X1.5715 Y2.0492
    G01 X1.5643 Y2.0478
    G01 X1.5575 Y2.0450
    G01 X1.5513 Y2.0409
    G01 X1.5461 Y2.0357
    G01 X1.5458 Y2.0352
    G01 X1.0379 Y2.0352
    G01 X1.0333 Y2.0343
    G01 X1.0291 Y2.0326
    G01 X1.0252 Y2.0300
    G01 X1.0074 Y2.0122
    G01 X0.9737 Y2.0122
    G01 X1.0499 Y2.0884
    G01 X1.5458 Y2.0884
    G01 X1.5461 Y2.0880
    G01 X1.5513 Y2.0827
    G01 X1.5575 Y2.0787
    G01 X1.5643 Y2.0758
    G01 X1.5715 Y2.0744
    G01 X1.6309 Y2.0744
    G01 X1.6381 Y2.0758
    G01 X1.6449 Y2.0787
    G01 X1.6510 Y2.0827
    G01 X1.6562 Y2.0880
    G01 X1.6565 Y2.0884
    G01 X2.0915 Y2.0884
    G01 X2.1454 Y2.0345
    G01 X2.1420 Y2.0295
    G01 X2.1392 Y2.0227
    G01 X2.1378 Y2.0155
    G01 X2.1378 Y2.0081
    G01 X2.1392 Y2.0009
    G01 X2.1420 Y1.9941
    G01 X2.1461 Y1.9880
    G01 X2.0646 Y1.9880
    G01 X2.0601 Y1.9871
    G01 X2.0558 Y1.9853
    G01 X2.0520 Y1.9828
    G01 X1.9142 Y1.8450
    G01 X1.9109 Y1.8417
    G01 X1.9084 Y1.8379
    G01 X1.9066 Y1.8336
    G01 X1.9057 Y1.8291
    G01 X1.9057 Y1.4150
    G01 X1.9066 Y1.4105
    G01 X1.9084 Y1.4062
    G01 X1.9109 Y1.4024
    G01 X2.1165 Y1.1969
    G01 X2.1197 Y1.1936
    G01 X2.1236 Y1.1911
    G01 X2.1278 Y1.1893
    G01 X2.1323 Y1.1884
    G01 X2.1458 Y1.1884
    G01 X2.1461 Y1.1880
    G01 X2.1513 Y1.1827
    G01 X2.1575 Y1.1787
    G01 X2.1643 Y1.1758
    G01 X2.1715 Y1.1744
    G01 X2.2309 Y1.1744
    G01 X2.2381 Y1.1758
    G01 X2.2449 Y1.1787
    G01 X2.2510 Y1.1827
    G01 X2.2562 Y1.1880
    G01 X2.2603 Y1.1941
    G01 X2.2632 Y1.2009
    G01 X2.2646 Y1.2081
    G01 X2.2646 Y1.2155
    G01 X2.2632 Y1.2227
    G01 X2.2603 Y1.2295
    G01 X2.2562 Y1.2357
    G01 X2.2510 Y1.2409
    G01 X2.2449 Y1.2450
    G01 X2.2381 Y1.2478
    G01 X2.2309 Y1.2492
    G01 X2.1715 Y1.2492
    G01 X2.1643 Y1.2478
    G01 X2.1575 Y1.2450
    G01 X2.1513 Y1.2409
    G01 X2.1461 Y1.2357
    G01 X2.1458 Y1.2352
    G01 X2.1443 Y1.2352
    G01 X1.9526 Y1.4270
    G01 X1.9526 Y1.5183
    G01 X2.0891 Y1.3817
    G01 X2.0924 Y1.3785
    G01 X2.0962 Y1.3759
    G01 X2.1005 Y1.3741
    G01 X2.1050 Y1.3732
    G01 X2.1883 Y1.3732
    G01 X2.1929 Y1.3741
    G01 X2.1935 Y1.3744
    G01 X2.2309 Y1.3744
    G01 X2.2381 Y1.3758
    G01 X2.2449 Y1.3787
    G01 X2.2510 Y1.3827
    G01 X2.2562 Y1.3880
    G01 X2.2603 Y1.3941
    G01 X2.2632 Y1.4009
    G01 X2.2646 Y1.4081
    G01 X2.2646 Y1.4153
    G01 X2.3388 Y1.3411
    G01 X2.3388 Y0.9940
    G01 X2.0854 Y0.7405
    G01 X2.0828 Y0.7367
    G01 X2.0810 Y0.7324
    G01 X2.0801 Y0.7279
    G01 X2.0801 Y0.3734
    G01 X2.0551 Y0.3484
    G01 X2.0551 Y0.3083
    G01 X2.0835 Y0.2799
    G01 X2.1236 Y0.2799
    G01 X2.1520 Y0.3083
    G01 X2.1520 Y0.3484
    G01 X2.1270 Y0.3734
    G01 X2.1270 Y0.7159
    G01 X2.3771 Y0.9661
    G01 X2.3804 Y0.9693
    G01 X2.3830 Y0.9732
    G01 X2.3847 Y0.9774
    G01 X2.3856 Y0.9819
    G01 X2.3856 Y1.3531
    G01 X2.3847 Y1.3576
    G01 X2.3830 Y1.3619
    G01 X2.3804 Y1.3657
    G01 X2.2570 Y1.4891
    G01 X2.2603 Y1.4941
    G01 X2.2632 Y1.5009
    G01 X2.2646 Y1.5081
    G01 X2.2646 Y1.5155
    G01 X2.2632 Y1.5227
    G01 X2.2603 Y1.5295
    G01 X2.2562 Y1.5357
    G01 X2.2523 Y1.5396
    G01 X2.4314 Y1.5396
    G01 X2.4360 Y1.5405
    G01 X2.4402 Y1.5422
    G01 X2.4441 Y1.5448
    G01 X2.4473 Y1.5481
    G01 X2.5577 Y1.6585
    G01 X3.1719 Y1.6585
    G01 X3.1969 Y1.6335
    G01 X3.2370 Y1.6335
    G01 X3.2653 Y1.6618
    G01 X3.2653 Y1.7019
    G01 X3.2370 Y1.7303
    G01 X3.1969 Y1.7303
    G01 X3.1719 Y1.7053
    G01 X2.5457 Y1.7053
    G01 X2.5412 Y1.7044
    G01 X2.5369 Y1.7026
    G01 X2.5331 Y1.7001
    G01 X2.4194 Y1.5864
    G01 X2.2547 Y1.5864
    G01 X2.2562 Y1.5880
    G01 X2.2603 Y1.5941
    G01 X2.2632 Y1.6009
    G01 X2.2646 Y1.6081
    G01 X2.2646 Y1.6155
    G01 X2.2632 Y1.6227
    G01 X2.2603 Y1.6295
    G01 X2.2570 Y1.6345
    G01 X2.3810 Y1.7585
    G01 X3.1719 Y1.7585
    G01 X3.1969 Y1.7335
    G01 X3.2370 Y1.7335
    G01 X3.2653 Y1.7618
    G01 X3.2653 Y1.8019
    G01 X3.2370 Y1.8303
    G01 X3.1969 Y1.8303
    G01 X3.1719 Y1.8053
    G01 X2.3690 Y1.8053
    G01 X2.3644 Y1.8044
    G01 X2.3602 Y1.8026
    G01 X2.3563 Y1.8001
    G01 X2.3531 Y1.7968
    G01 X2.2646 Y1.7083
    G01 X2.2646 Y1.7155
    G01 X2.2632 Y1.7227
    G01 X2.2603 Y1.7295
    G01 X2.2562 Y1.7357
    G01 X2.2510 Y1.7409
    G01 X2.2449 Y1.7450
    G01 X2.2381 Y1.7478
    G01 X2.2309 Y1.7492
    G01 X2.1715 Y1.7492
    G01 X2.1643 Y1.7478
    G01 X2.1575 Y1.7450
    G01 X2.1513 Y1.7409
    G01 X2.1461 Y1.7357
    G01 X2.1420 Y1.7295
    G01 X2.1392 Y1.7227
    G01 X2.1378 Y1.7155
    G01 X2.1378 Y1.7081
    G01 X2.1392 Y1.7009
    G01 X2.1420 Y1.6941
    G01 X2.1461 Y1.6880
    G01 X2.1513 Y1.6827
    G01 X2.1575 Y1.6787
    G01 X2.1643 Y1.6758
    G01 X2.1715 Y1.6744
    G01 X2.2306 Y1.6744
    G01 X2.2055 Y1.6492
    G01 X2.1715 Y1.6492
    G01 X2.1643 Y1.6478
    G01 X2.1575 Y1.6450
    G01 X2.1513 Y1.6409
    G01 X2.1461 Y1.6357
    G01 X2.1420 Y1.6295
    G01 X2.1392 Y1.6227
    G01 X2.1378 Y1.6155
    G01 X2.1378 Y1.6081
    G01 X2.1392 Y1.6009
    G01 X2.1420 Y1.5941
    G01 X2.1461 Y1.5880
    G01 X2.1477 Y1.5864
    G01 X2.1081 Y1.5864
    G01 X2.0707 Y1.6239
    G01 X2.0707 Y1.7226
    G01 X2.1365 Y1.7884
    G01 X2.1458 Y1.7884
    G01 X2.1461 Y1.7880
    G01 X2.1513 Y1.7827
    G01 X2.1575 Y1.7787
    G01 X2.1643 Y1.7758
    G01 X2.1715 Y1.7744
    G01 X2.2309 Y1.7744
    G01 X2.2381 Y1.7758
    G01 X2.2449 Y1.7787
    G01 X2.2510 Y1.7827
    G01 X2.2562 Y1.7880
    G01 X2.2603 Y1.7941
    G01 X2.2632 Y1.8009
    G01 X2.2646 Y1.8081
    G01 X2.2646 Y1.8155
    G01 X2.2632 Y1.8227
    G01 X2.2603 Y1.8295
    G01 X2.2562 Y1.8357
    G01 X2.2531 Y1.8388
    G01 X3.1916 Y1.8388
    G01 X3.1969 Y1.8335
    G01 X3.2370 Y1.8335
    G01 X3.2653 Y1.8618
    G01 X3.2653 Y1.9019
    G01 X3.2370 Y1.9303
    G01 X3.1969 Y1.9303
    G01 X3.1685 Y1.9019
    G01 X3.1685 Y1.8856
    G01 X2.2539 Y1.8856
    G01 X2.2562 Y1.8880
    G01 X2.2603 Y1.8941
    G01 X2.2632 Y1.9009
    G01 X2.2646 Y1.9081
    G01 X2.2646 Y1.9155
    G01 X2.2632 Y1.9227
    G01 X2.2603 Y1.9295
    G01 X2.2562 Y1.9357
    G01 X2.2510 Y1.9409
    G01 X2.2506 Y1.9411
    G01 X3.1892 Y1.9411
    G01 X3.1969 Y1.9335
    G01 X3.2370 Y1.9335
    G01 X3.2653 Y1.9618
    G01 X3.2653 Y2.0019
    G01 X3.2370 Y2.0303
    G01 X3.1969 Y2.0303
    G01 X3.1685 Y2.0019
    G01 X3.1685 Y1.9880
    G01 X2.2563 Y1.9880
    G01 X2.2603 Y1.9941
    G01 X2.2632 Y2.0009
    G01 X2.2646 Y2.0081
    G01 X2.2646 Y2.0155
    G01 X2.2632 Y2.0227
    G01 X2.2603 Y2.0295
    G01 X2.2570 Y2.0345
    G01 X2.2810 Y2.0585
    G01 X3.1719 Y2.0585
    G01 X3.1969 Y2.0335
    G01 X3.2370 Y2.0335
    G01 X3.2653 Y2.0618
    G01 X3.2653 Y2.0972
    G01 X3.2685 Y2.1004
    G01 X3.2685 Y2.0618
    G01 X3.2969 Y2.0335
    G01 X3.3370 Y2.0335
    G01 X3.3653 Y2.0618
    G01 X3.3653 Y2.1019
    G01 X3.3370 Y2.1303
    G01 X3.2985 Y2.1303
    G01 X3.3101 Y2.1419
    G01 X3.4549 Y2.1419
    G01 X3.5199 Y2.0769
    G01 X3.5199 Y1.1432
    G01 X3.3354 Y0.9587
    G01 X3.3268 Y0.9587
    G01 X3.1418 Y1.1437
    G01 X3.1386 Y1.1469
    G01 X3.1347 Y1.1495
    G01 X3.1305 Y1.1513
    G01 X3.1259 Y1.1522
    G01 X3.1008 Y1.1522
    G01 X3.0868 Y1.1662
    G01 X3.0558 Y1.1662
    G01 X3.0338 Y1.1442
    G01 X3.0338 Y1.1132
    G01 X3.0558 Y1.0913
    G01 X3.0868 Y1.0913
    G01 X3.1008 Y1.1053
    G01 X3.1139 Y1.1053
    G01 X3.2753 Y0.9440
    G01 X3.2719 Y0.9390
    G01 X3.2691 Y0.9322
    G01 X3.2677 Y0.9249
    G01 X3.2677 Y0.9176
    G01 X3.2691 Y0.9103
    G01 X3.2719 Y0.9035
    G01 X3.2760 Y0.8974
    G01 X3.2812 Y0.8922
    G01 X3.2874 Y0.8881
    G01 X3.2942 Y0.8853
    G01 X3.3014 Y0.8838
    G01 X3.3608 Y0.8838
    G01 X3.3680 Y0.8853
    G01 X3.3748 Y0.8881
    G01 X3.3810 Y0.8922
    G01 X3.3862 Y0.8974
    G01 X3.3865 Y0.8978
    G01 X3.6041 Y0.8978
    G01 X3.7565 Y0.7454
    G01 X3.7557 Y0.7447
    G01 X3.7519 Y0.7394
    G01 X3.7489 Y0.7336
    G01 X3.7469 Y0.7274
    G01 X3.7459 Y0.7210
    G01 X3.7459 Y0.7145
    G01 X3.7469 Y0.7080
    G01 X3.7489 Y0.7018
    G01 X3.7519 Y0.6960
    G01 X3.7557 Y0.6907
    G01 X3.7603 Y0.6861
    G01 X3.7656 Y0.6823
    G01 X3.7714 Y0.6793
    G01 X3.7776 Y0.6773
    G01 X3.7841 Y0.6763
    G01 X3.7939 Y0.6763
    G01 X3.7939 Y0.6591
    G01 X3.7841 Y0.6591
    G01 X3.7776 Y0.6581
    G01 X3.7714 Y0.6561
    G01 X3.7656 Y0.6531
    G01 X3.7603 Y0.6493
    G01 X3.7557 Y0.6447
    G01 X3.7519 Y0.6394
    G01 X3.7489 Y0.6336
    G01 X3.7469 Y0.6274
    G01 X3.7459 Y0.6210
    G01 X3.7459 Y0.6145
    G01 X3.7469 Y0.6080
    G01 X3.7489 Y0.6018
    G01 X3.7519 Y0.5960
    G01 X3.7557 Y0.5907
    G01 X3.7603 Y0.5861
    G01 X3.7656 Y0.5823
    G01 X3.7714 Y0.5793
    G01 X3.7776 Y0.5773
    G01 X3.7841 Y0.5763
    G01 X3.7939 Y0.5763
    G01 X3.7939 Y0.5591
    G01 X3.7841 Y0.5591
    G01 X3.7776 Y0.5581
    G01 X3.7714 Y0.5561
    G01 X3.7656 Y0.5531
    G01 X3.7603 Y0.5493
    G01 X3.7557 Y0.5447
    G01 X3.7531 Y0.5411
    G01 X3.6268 Y0.5411
    G01 X3.6223 Y0.5402
    G01 X3.6180 Y0.5385
    G01 X3.6142 Y0.5359
    G01 X3.3926 Y0.3143
    G01 X3.3888 Y0.3155
    G01 X3.3808 Y0.3168
    G01 X3.3727 Y0.3168
    G01 X3.3647 Y0.3155
    G01 X3.3570 Y0.3130
    G01 X3.3498 Y0.3093
    G01 X3.3433 Y0.3046
    G01 X3.3376 Y0.2989
    G01 X3.3328 Y0.2923
    G01 X3.3291 Y0.2851
    G01 X3.3266 Y0.2774
    G01 X3.3254 Y0.2694
    G01 X3.3254 Y0.2613
    G01 X3.3266 Y0.2533
    G01 X3.3291 Y0.2456
    G01 X3.3328 Y0.2384
    G01 X3.3376 Y0.2319
    G01 X3.3433 Y0.2261
    G01 X3.3498 Y0.2214
    G01 X3.3570 Y0.2177
    G01 X3.3647 Y0.2152
    G01 X3.3727 Y0.2139
    G01 X3.3808 Y0.2139
    G01 X3.3888 Y0.2152
    G01 X3.3965 Y0.2177
    G01 X3.4037 Y0.2214
    G01 X3.4103 Y0.2261
    G01 X3.4160 Y0.2319
    G01 X3.4207 Y0.2384
    G01 X3.4244 Y0.2456
    G01 X3.4269 Y0.2533
    G01 X3.4282 Y0.2613
    G01 X3.4282 Y0.2694
    G01 X3.4269 Y0.2774
    G01 X3.4257 Y0.2812
    G01 X3.6388 Y0.4943
    G01 X3.7531 Y0.4943
    G01 X3.7557 Y0.4907
    G01 X3.7603 Y0.4861
    G01 X3.7656 Y0.4823
    G01 X3.7714 Y0.4793
    G01 X3.7776 Y0.4773
    G01 X3.7841 Y0.4763
    G01 X3.8506 Y0.4763
    G01 X3.8570 Y0.4773
    G01 X3.8632 Y0.4793
    G01 X3.8690 Y0.4823
    G01 X3.8743 Y0.4861
    G01 X3.8789 Y0.4907
    G01 X3.8827 Y0.4960
    G01 X3.8857 Y0.5018
    G01 X3.8877 Y0.5080
    G01 X3.8887 Y0.5145
    G01 X3.8887 Y0.5210
    G01 X3.8877 Y0.5274
    G01 X3.8857 Y0.5336
    G01 X3.8827 Y0.5394
    G01 X3.8789 Y0.5447
    G01 X3.8743 Y0.5493
    G01 X3.8690 Y0.5531
    G01 X3.8632 Y0.5561
    G01 X3.8570 Y0.5581
    G01 X3.8506 Y0.5591
    G01 X3.8407 Y0.5591
    G01 X3.8407 Y0.5763
    G01 X3.8506 Y0.5763
    G01 X3.8570 Y0.5773
    G01 X3.8632 Y0.5793
    G01 X3.8690 Y0.5823
    G01 X3.8743 Y0.5861
    G01 X3.8789 Y0.5907
    G01 X3.8827 Y0.5960
    G01 X3.8857 Y0.6018
    G01 X3.8877 Y0.6080
    G01 X3.8887 Y0.6145
    G01 X3.8887 Y0.6210
    G01 X3.8877 Y0.6274
    G01 X3.8857 Y0.6336
    G01 X3.8827 Y0.6394
    G01 X3.8789 Y0.6447
    G01 X3.8743 Y0.6493
    G01 X3.8690 Y0.6531
    G01 X3.8632 Y0.6561
    G01 X3.8570 Y0.6581
    G01 X3.8506 Y0.6591
    G01 X3.8407 Y0.6591
    G01 X3.8407 Y0.6763
    G01 X3.8506 Y0.6763
    G01 X3.8570 Y0.6773
    G01 X3.8632 Y0.6793
    G01 X3.8690 Y0.6823
    G01 X3.8743 Y0.6861
    G01 X3.8789 Y0.6907
    G01 X3.8827 Y0.6960
    G01 X3.8857 Y0.7018
    G01 X3.8877 Y0.7080
    G01 X3.8887 Y0.7145
    G01 X3.8887 Y0.7210
    G01 X3.8877 Y0.7274
    G01 X3.8857 Y0.7336
    G01 X3.8827 Y0.7394
    G01 X3.8789 Y0.7447
    G01 X3.8743 Y0.7493
    G01 X3.8690 Y0.7531
    G01 X3.8632 Y0.7561
    G01 X3.8570 Y0.7581
    G01 X3.8506 Y0.7591
    G01 X3.8090 Y0.7591
    G01 X3.6320 Y0.9362
    G01 X3.6287 Y0.9394
    G01 X3.6249 Y0.9420
    G01 X3.6206 Y0.9438
    G01 X3.6161 Y0.9447
    G01 X3.3876 Y0.9447
    G01 X3.5615 Y1.1185
    G01 X3.5641 Y1.1224
    G01 X3.5658 Y1.1266
    G01 X3.5667 Y1.1312
    G01 X3.5667 Y2.0889
    G01 X3.5658 Y2.0934
    G01 X3.5641 Y2.0977
    G01 X3.5615 Y2.1015
    G01 X3.5582 Y2.1048
    G01 X3.4828 Y2.1803
    G01 X3.4795 Y2.1835
    G01 X3.4757 Y2.1861
    G01 X3.4714 Y2.1879
    G01 X3.4669 Y2.1888
    G01 X3.2981 Y2.1888
    G01 X3.2936 Y2.1879
    G01 X3.2893 Y2.1861
    G01 X3.2855 Y2.1835
    G01 X3.2822 Y2.1803
    G01 X3.2322 Y2.1303
    G01 X3.2016 Y2.1303
    G01 X2.9762 Y2.3558
    G01 X2.9762 Y2.7856
    G01 X3.0758 Y2.8852
    G01 X3.1443 Y2.8852
    G01 X3.1693 Y2.8602
    G01 X3.2094 Y2.8602
    G01 X3.2378 Y2.8886
    G01 X3.2378 Y2.9287
    G01 X3.2094 Y2.9571
    G01 X3.1693 Y2.9571
    G01 X3.1443 Y2.9321
    G01 X3.0638 Y2.9321
    G01 X3.0593 Y2.9312
    G01 X3.0550 Y2.9294
    G01 X3.0512 Y2.9269
    G01 X2.9378 Y2.8135
    G01 X2.9346 Y2.8102
    G01 X2.9320 Y2.8064
    G01 X2.9302 Y2.8021
    G01 X2.9293 Y2.7976
    G01 X2.9293 Y2.3438
    G01 X2.9302 Y2.3392
    G01 X2.9320 Y2.3350
    G01 X2.9346 Y2.3311
    G01 X3.1604 Y2.1053
    G01 X2.2690 Y2.1053
    G01 X2.2644 Y2.1044
    G01 X2.2638 Y2.1042
    G01 X2.2646 Y2.1081
    G01 X2.2646 Y2.1155
    G01 X2.2632 Y2.1227
    G01 X2.2603 Y2.1295
    G01 X2.2562 Y2.1357
    G01 X2.2510 Y2.1409
    G01 X2.2449 Y2.1450
    G01 X2.2381 Y2.1478
    G01 X2.2309 Y2.1492
    G01 X2.1715 Y2.1492
    G01 X2.1643 Y2.1478
    G01 X2.1575 Y2.1450
    G01 X2.1513 Y2.1409
    G01 X2.1461 Y2.1357
    G01 X2.1420 Y2.1295
    G01 X2.1392 Y2.1227
    G01 X2.1378 Y2.1155
    G01 X2.1378 Y2.1083
    G01 X2.1194 Y2.1267
    G01 X2.1161 Y2.1300
    G01 X2.1123 Y2.1326
    G01 X2.1080 Y2.1343
    G01 X2.1035 Y2.1352
    G01 X1.6565 Y2.1352
    G01 X1.6562 Y2.1357
    G01 X1.6510 Y2.1409
    G01 X1.6449 Y2.1450
    G01 X1.6381 Y2.1478
    G01 X1.6309 Y2.1492
    G01 X1.5969 Y2.1492
    G01 X1.5717 Y2.1744
    G01 X1.6309 Y2.1744
    G01 X1.6381 Y2.1758
    G01 X1.6449 Y2.1787
    G01 X1.6510 Y2.1827
    G01 X1.6562 Y2.1880
    G01 X1.6603 Y2.1941
    G01 X1.6632 Y2.2009
    G01 X1.6646 Y2.2081
    G01 X1.6646 Y2.2155
    G01 X1.6632 Y2.2227
    G01 X1.6603 Y2.2295
    G01 X1.6562 Y2.2357
    G01 X1.6510 Y2.2409
    G01 X1.6449 Y2.2450
    G01 X1.6381 Y2.2478
    G01 X1.6309 Y2.2492
    G01 X1.5969 Y2.2492
    G01 X1.5717 Y2.2744
    G01 X1.6309 Y2.2744
    G01 X1.6381 Y2.2758
    G01 X1.6449 Y2.2787
    G01 X1.6510 Y2.2827
    G01 X1.6562 Y2.2880
    G01 X1.6603 Y2.2941
    G01 X1.6632 Y2.3009
    G01 X1.6646 Y2.3081
    G01 X1.6646 Y2.3155
    G01 X1.6632 Y2.3227
    G01 X1.6603 Y2.3295
    G01 X1.6562 Y2.3357
    G01 X1.6510 Y2.3409
    G01 X1.6449 Y2.3450
    G01 X1.6381 Y2.3478
    G01 X1.6309 Y2.3492
    G01 X1.5969 Y2.3492
    G01 X1.5717 Y2.3744
    G01 X1.6309 Y2.3744
    G01 X1.6381 Y2.3758
    G01 X1.6449 Y2.3787
    G01 X1.6510 Y2.3827
    G01 X1.6562 Y2.3880
    G01 X1.6603 Y2.3941
    G01 X1.6632 Y2.4009
    G01 X1.6646 Y2.4081
    G01 X1.6646 Y2.4155
    G01 X1.6632 Y2.4227
    G01 X1.6603 Y2.4295
    G01 X1.6562 Y2.4357
    G01 X1.6510 Y2.4409
    G01 X1.6449 Y2.4450
    G01 X1.6381 Y2.4478
    G01 X1.6309 Y2.4492
    G01 X1.5715 Y2.4492
    G01 X1.5643 Y2.4478
    G01 X1.5575 Y2.4450
    G01 X1.5513 Y2.4409
    G01 X1.5461 Y2.4357
    G01 X1.5420 Y2.4295
    G01 X1.5392 Y2.4227
    G01 X1.5378 Y2.4155
    G01 X1.5378 Y2.4083
    G01 X1.4225 Y2.5236
    G01 X1.4193 Y2.5269
    G01 X1.4154 Y2.5294
    G01 X1.4112 Y2.5312
    G01 X1.4066 Y2.5321
    G01 X1.0254 Y2.5321
    G01 X1.0004 Y2.5571
    G00 Z0.0787
    G00 X3.2378 Y2.7886
    G01 Z-0.0039 F5.91
    G01 X3.2378 Y2.8287 F7.87
    G01 X3.2094 Y2.8571
    G01 X3.1693 Y2.8571
    G01 X3.1410 Y2.8287
    G01 X3.1410 Y2.7886
    G01 X3.1693 Y2.7602
    G01 X3.2094 Y2.7602
    G01 X3.2378 Y2.7886
    G00 Z0.0787
    G00 X3.2378 Y2.6886
    G01 Z-0.0039 F5.91
    G01 X3.2378 Y2.7287 F7.87
    G01 X3.2094 Y2.7571
    G01 X3.1693 Y2.7571
    G01 X3.1410 Y2.7287
    G01 X3.1410 Y2.6886
    G01 X3.1693 Y2.6602
    G01 X3.2094 Y2.6602
    G01 X3.2378 Y2.6886
    G00 Z0.0787
    G00 X3.2378 Y2.5886
    G01 Z-0.0039 F5.91
    G01 X3.2378 Y2.6287 F7.87
    G01 X3.2094 Y2.6571
    G01 X3.1693 Y2.6571
    G01 X3.1410 Y2.6287
    G01 X3.1410 Y2.5886
    G01 X3.1693 Y2.5602
    G01 X3.2094 Y2.5602
    G01 X3.2378 Y2.5886
    G00 Z0.0787
    G00 X3.3378 Y2.5886
    G01 Z-0.0039 F5.91
    G01 X3.3378 Y2.6287 F7.87
    G01 X3.3094 Y2.6571
    G01 X3.2693 Y2.6571
    G01 X3.2410 Y2.6287
    G01 X3.2410 Y2.5886
    G01 X3.2693 Y2.5602
    G01 X3.3094 Y2.5602
    G01 X3.3378 Y2.5886
    G00 Z0.0787
    G00 X3.2378 Y2.4886
    G01 Z-0.0039 F5.91
    G01 X3.2378 Y2.5287 F7.87
    G01 X3.2094 Y2.5571
    G01 X3.1693 Y2.5571
    G01 X3.1410 Y2.5287
    G01 X3.1410 Y2.4886
    G01 X3.1693 Y2.4602
    G01 X3.2094 Y2.4602
    G01 X3.2378 Y2.4886
    G00 Z0.0787
    G00 X3.3378 Y2.4886
    G01 Z-0.0039 F5.91
    G01 X3.3378 Y2.5287 F7.87
    G01 X3.3094 Y2.5571
    G01 X3.2693 Y2.5571
    G01 X3.2410 Y2.5287
    G01 X3.2410 Y2.4886
    G01 X3.2693 Y2.4602
    G01 X3.3094 Y2.4602
    G01 X3.3378 Y2.4886
    G00 Z0.0787
    G00 X3.7884 Y0.8515
    G01 Z-0.0039 F5.91
    G01 X3.8549 Y0.8515 F7.87
    G01 X3.8614 Y0.8525
    G01 X3.8676 Y0.8545
    G01 X3.8734 Y0.8575
    G01 X3.8786 Y0.8613
    G01 X3.8832 Y0.8659
    G01 X3.8871 Y0.8712
    G01 X3.8900 Y0.8770
    G01 X3.8921 Y0.8832
    G01 X3.8931 Y0.8897
    G01 X3.8931 Y0.8962
    G01 X3.8921 Y0.9026
    G01 X3.8900 Y0.9088
    G01 X3.8871 Y0.9146
    G01 X3.8832 Y0.9199
    G01 X3.8786 Y0.9245
    G01 X3.8734 Y0.9283
    G01 X3.8676 Y0.9313
    G01 X3.8614 Y0.9333
    G01 X3.8549 Y0.9343
    G01 X3.7884 Y0.9343
    G01 X3.7820 Y0.9333
    G01 X3.7758 Y0.9313
    G01 X3.7699 Y0.9283
    G01 X3.7647 Y0.9245
    G01 X3.7601 Y0.9199
    G01 X3.7562 Y0.9146
    G01 X3.7533 Y0.9088
    G01 X3.7513 Y0.9026
    G01 X3.7502 Y0.8962
    G01 X3.7502 Y0.8897
    G01 X3.7513 Y0.8832
    G01 X3.7533 Y0.8770
    G01 X3.7562 Y0.8712
    G01 X3.7601 Y0.8659
    G01 X3.7647 Y0.8613
    G01 X3.7699 Y0.8575
    G01 X3.7758 Y0.8545
    G01 X3.7820 Y0.8525
    G01 X3.7884 Y0.8515
    G00 Z0.0787
    G00 X3.7884 Y0.9515
    G01 Z-0.0039 F5.91
    G01 X3.8549 Y0.9515 F7.87
    G01 X3.8614 Y0.9525
    G01 X3.8676 Y0.9545
    G01 X3.8734 Y0.9575
    G01 X3.8786 Y0.9613
    G01 X3.8832 Y0.9659
    G01 X3.8871 Y0.9712
    G01 X3.8900 Y0.9770
    G01 X3.8921 Y0.9832
    G01 X3.8931 Y0.9897
    G01 X3.8931 Y0.9962
    G01 X3.8921 Y1.0026
    G01 X3.8900 Y1.0088
    G01 X3.8871 Y1.0146
    G01 X3.8832 Y1.0199
    G01 X3.8786 Y1.0245
    G01 X3.8734 Y1.0283
    G01 X3.8676 Y1.0313
    G01 X3.8614 Y1.0333
    G01 X3.8549 Y1.0343
    G01 X3.7884 Y1.0343
    G01 X3.7820 Y1.0333
    G01 X3.7758 Y1.0313
    G01 X3.7699 Y1.0283
    G01 X3.7647 Y1.0245
    G01 X3.7601 Y1.0199
    G01 X3.7562 Y1.0146
    G01 X3.7533 Y1.0088
    G01 X3.7513 Y1.0026
    G01 X3.7502 Y0.9962
    G01 X3.7502 Y0.9897
    G01 X3.7513 Y0.9832
    G01 X3.7533 Y0.9770
    G01 X3.7562 Y0.9712
    G01 X3.7601 Y0.9659
    G01 X3.7647 Y0.9613
    G01 X3.7699 Y0.9575
    G01 X3.7758 Y0.9545
    G01 X3.7820 Y0.9525
    G01 X3.7884 Y0.9515
    G00 Z0.0787
    G00 X3.7884 Y1.0515
    G01 Z-0.0039 F5.91
    G01 X3.8549 Y1.0515 F7.87
    G01 X3.8614 Y1.0525
    G01 X3.8676 Y1.0545
    G01 X3.8734 Y1.0575
    G01 X3.8786 Y1.0613
    G01 X3.8832 Y1.0659
    G01 X3.8871 Y1.0712
    G01 X3.8900 Y1.0770
    G01 X3.8921 Y1.0832
    G01 X3.8931 Y1.0897
    G01 X3.8931 Y1.0962
    G01 X3.8921 Y1.1026
    G01 X3.8900 Y1.1088
    G01 X3.8871 Y1.1146
    G01 X3.8832 Y1.1199
    G01 X3.8786 Y1.1245
    G01 X3.8734 Y1.1283
    G01 X3.8676 Y1.1313
    G01 X3.8614 Y1.1333
    G01 X3.8549 Y1.1343
    G01 X3.7884 Y1.1343
    G01 X3.7820 Y1.1333
    G01 X3.7758 Y1.1313
    G01 X3.7699 Y1.1283
    G01 X3.7647 Y1.1245
    G01 X3.7601 Y1.1199
    G01 X3.7562 Y1.1146
    G01 X3.7533 Y1.1088
    G01 X3.7513 Y1.1026
    G01 X3.7502 Y1.0962
    G01 X3.7502 Y1.0897
    G01 X3.7513 Y1.0832
    G01 X3.7533 Y1.0770
    G01 X3.7562 Y1.0712
    G01 X3.7601 Y1.0659
    G01 X3.7647 Y1.0613
    G01 X3.7699 Y1.0575
    G01 X3.7758 Y1.0545
    G01 X3.7820 Y1.0525
    G01 X3.7884 Y1.0515
    G00 Z0.0787
    G00 X1.4656 Y0.5515
    G01 Z-0.0039 F5.91
    G01 X1.5321 Y0.5515 F7.87
    G01 X1.5385 Y0.5525
    G01 X1.5447 Y0.5545
    G01 X1.5505 Y0.5575
    G01 X1.5558 Y0.5613
    G01 X1.5604 Y0.5659
    G01 X1.5642 Y0.5712
    G01 X1.5672 Y0.5770
    G01 X1.5692 Y0.5832
    G01 X1.5702 Y0.5897
    G01 X1.5702 Y0.5962
    G01 X1.5692 Y0.6026
    G01 X1.5672 Y0.6088
    G01 X1.5642 Y0.6146
    G01 X1.5604 Y0.6199
    G01 X1.5558 Y0.6245
    G01 X1.5505 Y0.6283
    G01 X1.5447 Y0.6313
    G01 X1.5385 Y0.6333
    G01 X1.5321 Y0.6343
    G01 X1.4656 Y0.6343
    G01 X1.4591 Y0.6333
    G01 X1.4529 Y0.6313
    G01 X1.4471 Y0.6283
    G01 X1.4418 Y0.6245
    G01 X1.4372 Y0.6199
    G01 X1.4334 Y0.6146
    G01 X1.4304 Y0.6088
    G01 X1.4284 Y0.6026
    G01 X1.4274 Y0.5962
    G01 X1.4274 Y0.5897
    G01 X1.4284 Y0.5832
    G01 X1.4304 Y0.5770
    G01 X1.4334 Y0.5712
    G01 X1.4372 Y0.5659
    G01 X1.4418 Y0.5613
    G01 X1.4471 Y0.5575
    G01 X1.4529 Y0.5545
    G01 X1.4591 Y0.5525
    G01 X1.4656 Y0.5515
    G00 Z0.0787
    G00 X1.4656 Y0.6515
    G01 Z-0.0039 F5.91
    G01 X1.5321 Y0.6515 F7.87
    G01 X1.5385 Y0.6525
    G01 X1.5447 Y0.6545
    G01 X1.5505 Y0.6575
    G01 X1.5558 Y0.6613
    G01 X1.5604 Y0.6659
    G01 X1.5642 Y0.6712
    G01 X1.5672 Y0.6770
    G01 X1.5692 Y0.6832
    G01 X1.5702 Y0.6897
    G01 X1.5702 Y0.6962
    G01 X1.5692 Y0.7026
    G01 X1.5672 Y0.7088
    G01 X1.5642 Y0.7146
    G01 X1.5604 Y0.7199
    G01 X1.5558 Y0.7245
    G01 X1.5505 Y0.7283
    G01 X1.5447 Y0.7313
    G01 X1.5385 Y0.7333
    G01 X1.5321 Y0.7343
    G01 X1.4656 Y0.7343
    G01 X1.4591 Y0.7333
    G01 X1.4529 Y0.7313
    G01 X1.4471 Y0.7283
    G01 X1.4418 Y0.7245
    G01 X1.4372 Y0.7199
    G01 X1.4334 Y0.7146
    G01 X1.4304 Y0.7088
    G01 X1.4284 Y0.7026
    G01 X1.4274 Y0.6962
    G01 X1.4274 Y0.6897
    G01 X1.4284 Y0.6832
    G01 X1.4304 Y0.6770
    G01 X1.4334 Y0.6712
    G01 X1.4372 Y0.6659
    G01 X1.4418 Y0.6613
    G01 X1.4471 Y0.6575
    G01 X1.4529 Y0.6545
    G01 X1.4591 Y0.6525
    G01 X1.4656 Y0.6515
    G00 Z0.0787
    G00 X0.9088 Y2.5587
    G01 Z-0.0039 F5.91
    G01 X0.9303 Y2.5802 F7.87
    G01 X0.9518 Y2.5587
    G01 X0.9303 Y2.5372
    G01 X0.9088 Y2.5587
    G00 Z0.0787
    G00 X0.9088 Y2.6587
    G01 Z-0.0039 F5.91
    G01 X0.9303 Y2.6802 F7.87
    G01 X0.9518 Y2.6587
    G01 X0.9303 Y2.6372
    G01 X0.9088 Y2.6587
    G00 Z0.0787
    G00 X0.9088 Y2.7587
    G01 Z-0.0039 F5.91
    G01 X0.9303 Y2.7802 F7.87
    G01 X0.9518 Y2.7587
    G01 X0.9303 Y2.7372
    G01 X0.9088 Y2.7587
    G00 Z0.0787
    G00 X0.9088 Y2.8587
    G01 Z-0.0039 F5.91
    G01 X0.9303 Y2.8802 F7.87
    G01 X0.9518 Y2.8587
    G01 X0.9303 Y2.8372
    G01 X0.9088 Y2.8587
    G00 Z0.0787
    G00 X0.9206 Y1.6138
    G01 Z-0.0039 F5.91
    G01 X0.9421 Y1.6353 F7.87
    G01 X0.9636 Y1.6138
    G01 X0.9421 Y1.5923
    G01 X0.9206 Y1.6138
    G00 Z0.0787
    G00 X0.9206 Y1.7138
    G01 Z-0.0039 F5.91
    G01 X0.9421 Y1.7353 F7.87
    G01 X0.9636 Y1.7138
    G01 X0.9421 Y1.6923
    G01 X0.9206 Y1.7138
    G00 Z0.0787
    G00 X0.9206 Y1.8138
    G01 Z-0.0039 F5.91
    G01 X0.9421 Y1.8353 F7.87
    G01 X0.9636 Y1.8138
    G01 X0.9421 Y1.7923
    G01 X0.9206 Y1.8138
    G00 Z0.0787
    G00 X0.9206 Y1.9138
    G01 Z-0.0039 F5.91
    G01 X0.9421 Y1.9353 F7.87
    G01 X0.9636 Y1.9138
    G01 X0.9421 Y1.8923
    G01 X0.9206 Y1.9138
    G00 Z0.0787
    G00 X1.5363 Y2.3335
    G01 Z-0.0039 F5.91
    G01 X1.5339 Y2.3289 F7.87
    G01 X1.5318 Y2.3222
    G01 X1.5307 Y2.3153
    G01 X1.5307 Y2.3140
    G01 X1.0600 Y2.3140
    G01 X1.0541 Y2.3128
    G01 X1.0485 Y2.3105
    G01 X1.0435 Y2.3072
    G01 X0.9990 Y2.2626
    G01 X0.9792 Y2.2626
    G01 X0.9531 Y2.2365
    G01 X0.9531 Y2.1997
    G01 X0.9792 Y2.1736
    G01 X1.0161 Y2.1736
    G01 X1.0421 Y2.1997
    G01 X1.0421 Y2.2195
    G01 X1.0756 Y2.2530
    G01 X1.3695 Y2.2530
    G01 X1.3531 Y2.2365
    G01 X1.3531 Y2.1997
    G01 X1.3792 Y2.1736
    G01 X1.4053 Y2.1736
    G01 X1.4366 Y2.1423
    G01 X1.0372 Y2.1423
    G01 X1.0313 Y2.1411
    G01 X1.0257 Y2.1388
    G01 X1.0207 Y2.1355
    G01 X1.0165 Y2.1313
    G01 X0.9226 Y2.0374
    G01 X0.9226 Y2.2999
    G01 X0.9215 Y2.3057
    G01 X0.9192 Y2.3113
    G01 X0.9158 Y2.3163
    G01 X0.9116 Y2.3205
    G01 X0.8179 Y2.4142
    G01 X0.8179 Y2.8031
    G01 X0.8248 Y2.8100
    G01 X0.8248 Y2.7857
    G01 X0.8518 Y2.7587
    G01 X0.8248 Y2.7317
    G01 X0.8248 Y2.6857
    G01 X0.8518 Y2.6587
    G01 X0.8248 Y2.6317
    G01 X0.8248 Y2.5857
    G01 X0.8518 Y2.5587
    G01 X0.8248 Y2.5317
    G01 X0.8248 Y2.4857
    G01 X0.8573 Y2.4532
    G01 X0.9033 Y2.4532
    G01 X0.9303 Y2.4802
    G01 X0.9573 Y2.4532
    G01 X1.0033 Y2.4532
    G01 X1.0283 Y2.4782
    G01 X1.3917 Y2.4782
    G01 X1.5363 Y2.3335
    G00 Z0.0787
    G00 X1.5363 Y2.2335
    G01 Z-0.0039 F5.91
    G01 X1.5339 Y2.2289 F7.87
    G01 X1.5318 Y2.2222
    G01 X1.5307 Y2.2153
    G01 X1.5307 Y2.2083
    G01 X1.5318 Y2.2014
    G01 X1.5336 Y2.1959
    G01 X1.4693 Y2.1959
    G01 X1.4421 Y2.2230
    G01 X1.4421 Y2.2365
    G01 X1.4257 Y2.2530
    G01 X1.5169 Y2.2530
    G01 X1.5363 Y2.2335
    G00 Z0.0787
    G00 X2.2706 Y2.0014
    G01 Z-0.0039 F5.91
    G01 X2.2717 Y2.0083 F7.87
    G01 X2.2717 Y2.0153
    G01 X2.2706 Y2.0222
    G01 X2.2684 Y2.0289
    G01 X2.2661 Y2.0335
    G01 X2.2839 Y2.0514
    G01 X3.1689 Y2.0514
    G01 X3.1884 Y2.0319
    G01 X3.1614 Y2.0049
    G01 X3.1614 Y1.9951
    G01 X2.2685 Y1.9951
    G01 X2.2706 Y2.0014
    G00 Z0.0787
    G00 X2.1998 Y2.0563
    G01 Z-0.0039 F5.91
    G01 X2.1888 Y2.0673 F7.87
    G01 X2.2135 Y2.0673
    G01 X2.2025 Y2.0563
    G01 X2.1998 Y2.0563
    G00 Z0.0787
    G00 X1.9596 Y1.8141
    G01 Z-0.0039 F5.91
    G01 X2.0796 Y1.9341 F7.87
    G01 X2.1366 Y1.9341
    G01 X2.1339 Y1.9289
    G01 X2.1318 Y1.9222
    G01 X2.1307 Y1.9153
    G01 X2.1307 Y1.9083
    G01 X2.1318 Y1.9014
    G01 X2.1339 Y1.8947
    G01 X2.1350 Y1.8927
    G01 X2.0994 Y1.8927
    G01 X2.0935 Y1.8915
    G01 X2.0879 Y1.8892
    G01 X2.0829 Y1.8859
    G01 X1.9596 Y1.7626
    G01 X1.9596 Y1.8141
    G00 Z0.0787
    G00 X2.2684 Y1.8947
    G01 Z-0.0039 F5.91
    G01 X2.2706 Y1.9014 F7.87
    G01 X2.2717 Y1.9083
    G01 X2.2717 Y1.9153
    G01 X2.2706 Y1.9222
    G01 X2.2684 Y1.9289
    G01 X2.2658 Y1.9341
    G01 X3.1863 Y1.9341
    G01 X3.1884 Y1.9319
    G01 X3.1614 Y1.9049
    G01 X3.1614 Y1.8927
    G01 X2.2674 Y1.8927
    G01 X2.2684 Y1.8947
    G00 Z0.0787
    G00 X1.5462 Y2.0779
    G01 Z-0.0039 F5.91
    G01 X1.5519 Y2.0737 F7.87
    G01 X1.5581 Y2.0706
    G01 X1.5648 Y2.0684
    G01 X1.5717 Y2.0673
    G01 X1.6307 Y2.0673
    G01 X1.6376 Y2.0684
    G01 X1.6443 Y2.0706
    G01 X1.6505 Y2.0737
    G01 X1.6562 Y2.0779
    G01 X1.6596 Y2.0813
    G01 X1.9761 Y2.0813
    G01 X1.9733 Y2.0784
    G01 X1.9708 Y2.0742
    G01 X1.9696 Y2.0695
    G01 X1.9696 Y2.0521
    G01 X1.9598 Y2.0423
    G01 X1.6596 Y2.0423
    G01 X1.6562 Y2.0458
    G01 X1.6505 Y2.0499
    G01 X1.6443 Y2.0531
    G01 X1.6376 Y2.0552
    G01 X1.6307 Y2.0563
    G01 X1.5717 Y2.0563
    G01 X1.5648 Y2.0552
    G01 X1.5581 Y2.0531
    G01 X1.5519 Y2.0499
    G01 X1.5462 Y2.0458
    G01 X1.5427 Y2.0423
    G01 X1.0372 Y2.0423
    G01 X1.0313 Y2.0411
    G01 X1.0257 Y2.0388
    G01 X1.0207 Y2.0355
    G01 X1.0045 Y2.0193
    G01 X0.9908 Y2.0193
    G01 X1.0528 Y2.0813
    G01 X1.5427 Y2.0813
    G01 X1.5462 Y2.0779
    G00 Z0.0787
    G00 X3.4341 Y2.9795
    G01 Z-0.0039 F5.91
    G01 X3.4341 Y2.8867 F7.87
    G01 X3.3449 Y2.7975
    G01 X3.3449 Y2.8210
    G01 X3.4095 Y2.8857
    G01 X3.4129 Y2.8907
    G01 X3.4152 Y2.8962
    G01 X3.4163 Y2.9021
    G01 X3.4163 Y2.9558
    G01 X3.4152 Y2.9617
    G01 X3.4129 Y2.9672
    G01 X3.4095 Y2.9722
    G01 X3.4053 Y2.9765
    G01 X3.3414 Y3.0404
    G01 X3.3732 Y3.0404
    G01 X3.4341 Y2.9795
    G00 Z0.0787
    G00 X0.3878 Y0.9469
    G01 Z-0.0039 F5.91
    G01 X0.3943 Y0.9422 F7.87
    G01 X0.4016 Y0.9385
    G01 X0.4085 Y0.9362
    G01 X0.4016 Y0.9340
    G01 X0.3943 Y0.9303
    G01 X0.3878 Y0.9255
    G01 X0.3848 Y0.9226
    G01 X0.3848 Y0.9499
    G01 X0.3878 Y0.9469
    G00 Z0.0787
    G00 X2.2535 Y0.2999
    G01 Z-0.0039 F5.91
    G01 X2.2750 Y0.2783 F7.87
    G01 X2.2535 Y0.2568
    G01 X2.2320 Y0.2783
    G01 X2.2535 Y0.2999
    G00 Z0.0787
    G00 X2.1535 Y0.2999
    G01 Z-0.0039 F5.91
    G01 X2.1750 Y0.2783 F7.87
    G01 X2.1535 Y0.2568
    G01 X2.1320 Y0.2783
    G01 X2.1535 Y0.2999
    G00 Z0.0787
    G00 X2.0535 Y0.2999
    G01 Z-0.0039 F5.91
    G01 X2.0750 Y0.2783 F7.87
    G01 X2.0535 Y0.2568
    G01 X2.0320 Y0.2783
    G01 X2.0535 Y0.2999
    G00 Z0.0787
    G00 X1.9535 Y0.2999
    G01 Z-0.0039 F5.91
    G01 X1.9750 Y0.2783 F7.87
    G01 X1.9535 Y0.2568
    G01 X1.9320 Y0.2783
    G01 X1.9535 Y0.2999
    G00 Z0.0787
    G00 X1.9811 Y0.1486
    G01 Z-0.0039 F5.91
    G01 X1.9417 Y0.1880 F7.87
    G01 X1.9535 Y0.1999
    G01 X1.9806 Y0.1728
    G01 X2.0265 Y0.1728
    G01 X2.0535 Y0.1999
    G01 X2.0806 Y0.1728
    G01 X2.1265 Y0.1728
    G01 X2.1535 Y0.1999
    G01 X2.1806 Y0.1728
    G01 X2.2163 Y0.1728
    G01 X2.1921 Y0.1486
    G01 X1.9811 Y0.1486
    G00 Z0.0787
    G00 X1.0088 Y2.7587
    G01 Z-0.0039 F5.91
    G01 X1.0358 Y2.7857 F7.87
    G01 X1.0358 Y2.8317
    G01 X1.0088 Y2.8587
    G01 X1.0358 Y2.8857
    G01 X1.0358 Y2.9317
    G01 X1.0108 Y2.9567
    G01 X1.0108 Y2.9597
    G01 X1.0096 Y2.9656
    G01 X1.0073 Y2.9711
    G01 X1.0040 Y2.9761
    G01 X0.9998 Y2.9804
    G01 X0.9398 Y3.0404
    G01 X1.0897 Y3.0404
    G01 X1.1506 Y2.9795
    G01 X1.1506 Y2.8079
    G01 X1.0819 Y2.7392
    G01 X1.0283 Y2.7392
    G01 X1.0088 Y2.7587
    G00 Z0.0787
    G00 X0.6850 Y2.9328
    G01 Z-0.0039 F5.91
    G01 X0.6816 Y2.9278 F7.87
    G01 X0.6793 Y2.9223
    G01 X0.6782 Y2.9164
    G01 X0.6782 Y2.4107
    G01 X0.4495 Y2.1820
    G01 X0.4455 Y2.1849
    G01 X0.4383 Y2.1886
    G01 X0.4306 Y2.1911
    G01 X0.4226 Y2.1924
    G01 X0.4145 Y2.1924
    G01 X0.4064 Y2.1911
    G01 X0.3987 Y2.1886
    G01 X0.3915 Y2.1849
    G01 X0.3850 Y2.1802
    G01 X0.3792 Y2.1744
    G01 X0.3745 Y2.1679
    G01 X0.3708 Y2.1606
    G01 X0.3685 Y2.1537
    G01 X0.3662 Y2.1606
    G01 X0.3626 Y2.1679
    G01 X0.3578 Y2.1744
    G01 X0.3521 Y2.1802
    G01 X0.3455 Y2.1849
    G01 X0.3383 Y2.1886
    G01 X0.3306 Y2.1911
    G01 X0.3226 Y2.1924
    G01 X0.3145 Y2.1924
    G01 X0.3064 Y2.1911
    G01 X0.2987 Y2.1886
    G01 X0.2915 Y2.1849
    G01 X0.2850 Y2.1802
    G01 X0.2792 Y2.1744
    G01 X0.2745 Y2.1679
    G01 X0.2708 Y2.1606
    G01 X0.2685 Y2.1537
    G01 X0.2662 Y2.1606
    G01 X0.2626 Y2.1679
    G01 X0.2578 Y2.1744
    G01 X0.2521 Y2.1802
    G01 X0.2490 Y2.1824
    G01 X0.2490 Y2.2531
    G01 X0.6494 Y2.6535
    G01 X0.6536 Y2.6577
    G01 X0.6570 Y2.6627
    G01 X0.6593 Y2.6683
    G01 X0.6604 Y2.6742
    G01 X0.6604 Y2.9401
    G01 X0.7607 Y3.0404
    G01 X0.7925 Y3.0404
    G01 X0.6850 Y2.9328
    G00 Z0.0787
    G00 X2.1339 Y1.5289
    G01 Z-0.0039 F5.91
    G01 X2.1318 Y1.5222 F7.87
    G01 X2.1307 Y1.5153
    G01 X2.1307 Y1.5083
    G01 X2.1318 Y1.5014
    G01 X2.1339 Y1.4947
    G01 X2.1371 Y1.4885
    G01 X2.1412 Y1.4828
    G01 X2.1462 Y1.4779
    G01 X2.1519 Y1.4737
    G01 X2.1581 Y1.4706
    G01 X2.1648 Y1.4684
    G01 X2.1717 Y1.4673
    G01 X2.2025 Y1.4673
    G01 X2.2135 Y1.4563
    G01 X2.1717 Y1.4563
    G01 X2.1648 Y1.4552
    G01 X2.1581 Y1.4531
    G01 X2.1519 Y1.4499
    G01 X2.1462 Y1.4458
    G01 X2.1412 Y1.4408
    G01 X2.1371 Y1.4351
    G01 X2.1339 Y1.4289
    G01 X2.1334 Y1.4272
    G01 X2.1199 Y1.4272
    G01 X1.9990 Y1.5481
    G01 X1.9990 Y1.7157
    G01 X2.0167 Y1.7334
    G01 X2.0167 Y1.6112
    G01 X2.0179 Y1.6053
    G01 X2.0202 Y1.5997
    G01 X2.0235 Y1.5947
    G01 X2.0278 Y1.5905
    G01 X2.0790 Y1.5393
    G01 X2.0840 Y1.5360
    G01 X2.0895 Y1.5337
    G01 X2.0954 Y1.5325
    G01 X2.1358 Y1.5325
    G01 X2.1339 Y1.5289
    G00 Z0.0787
    G00 X2.1462 Y1.7779
    G01 Z-0.0039 F5.91
    G01 X2.1519 Y1.7737 F7.87
    G01 X2.1581 Y1.7706
    G01 X2.1648 Y1.7684
    G01 X2.1717 Y1.7673
    G01 X2.2307 Y1.7673
    G01 X2.2376 Y1.7684
    G01 X2.2443 Y1.7706
    G01 X2.2505 Y1.7737
    G01 X2.2562 Y1.7779
    G01 X2.2611 Y1.7828
    G01 X2.2652 Y1.7885
    G01 X2.2684 Y1.7947
    G01 X2.2706 Y1.8014
    G01 X2.2717 Y1.8083
    G01 X2.2717 Y1.8153
    G01 X2.2706 Y1.8222
    G01 X2.2684 Y1.8289
    G01 X2.2670 Y1.8317
    G01 X3.1882 Y1.8317
    G01 X3.1689 Y1.8124
    G01 X2.3683 Y1.8124
    G01 X2.3624 Y1.8112
    G01 X2.3568 Y1.8089
    G01 X2.3518 Y1.8056
    G01 X2.3476 Y1.8013
    G01 X2.2701 Y1.7238
    G01 X2.2684 Y1.7289
    G01 X2.2652 Y1.7351
    G01 X2.2611 Y1.7408
    G01 X2.2562 Y1.7458
    G01 X2.2505 Y1.7499
    G01 X2.2443 Y1.7531
    G01 X2.2376 Y1.7552
    G01 X2.2307 Y1.7563
    G01 X2.1717 Y1.7563
    G01 X2.1648 Y1.7552
    G01 X2.1581 Y1.7531
    G01 X2.1519 Y1.7499
    G01 X2.1462 Y1.7458
    G01 X2.1412 Y1.7408
    G01 X2.1371 Y1.7351
    G01 X2.1339 Y1.7289
    G01 X2.1318 Y1.7222
    G01 X2.1307 Y1.7153
    G01 X2.1307 Y1.7083
    G01 X2.1318 Y1.7014
    G01 X2.1339 Y1.6947
    G01 X2.1371 Y1.6885
    G01 X2.1412 Y1.6828
    G01 X2.1462 Y1.6779
    G01 X2.1519 Y1.6737
    G01 X2.1581 Y1.6706
    G01 X2.1648 Y1.6684
    G01 X2.1717 Y1.6673
    G01 X2.2135 Y1.6673
    G01 X2.2025 Y1.6563
    G01 X2.1717 Y1.6563
    G01 X2.1648 Y1.6552
    G01 X2.1581 Y1.6531
    G01 X2.1519 Y1.6499
    G01 X2.1462 Y1.6458
    G01 X2.1412 Y1.6408
    G01 X2.1371 Y1.6351
    G01 X2.1339 Y1.6289
    G01 X2.1318 Y1.6222
    G01 X2.1307 Y1.6153
    G01 X2.1307 Y1.6083
    G01 X2.1318 Y1.6014
    G01 X2.1339 Y1.5947
    G01 X2.1346 Y1.5935
    G01 X2.1111 Y1.5935
    G01 X2.0777 Y1.6268
    G01 X2.0777 Y1.7196
    G01 X2.1394 Y1.7813
    G01 X2.1427 Y1.7813
    G01 X2.1462 Y1.7779
    G00 Z0.0787
    G00 X2.2684 Y1.5947
    G01 Z-0.0039 F5.91
    G01 X2.2706 Y1.6014 F7.87
    G01 X2.2717 Y1.6083
    G01 X2.2717 Y1.6153
    G01 X2.2706 Y1.6222
    G01 X2.2684 Y1.6289
    G01 X2.2661 Y1.6335
    G01 X2.3839 Y1.7514
    G01 X3.1689 Y1.7514
    G01 X3.1884 Y1.7319
    G01 X3.1689 Y1.7124
    G01 X2.5450 Y1.7124
    G01 X2.5391 Y1.7112
    G01 X2.5336 Y1.7089
    G01 X2.5286 Y1.7056
    G01 X2.4165 Y1.5935
    G01 X2.2678 Y1.5935
    G01 X2.2684 Y1.5947
    G00 Z0.0787
    G00 X3.2454 Y2.0319
    G01 Z-0.0039 F5.91
    G01 X3.2669 Y2.0534 F7.87
    G01 X3.2884 Y2.0319
    G01 X3.2669 Y2.0104
    G01 X3.2454 Y2.0319
    G00 Z0.0787
    G00 X3.2454 Y1.9319
    G01 Z-0.0039 F5.91
    G01 X3.2669 Y1.9534 F7.87
    G01 X3.2884 Y1.9319
    G01 X3.2669 Y1.9104
    G01 X3.2454 Y1.9319
    G00 Z0.0787
    G00 X3.2454 Y1.8319
    G01 Z-0.0039 F5.91
    G01 X3.2669 Y1.8534 F7.87
    G01 X3.2884 Y1.8319
    G01 X3.2669 Y1.8104
    G01 X3.2454 Y1.8319
    G00 Z0.0787
    G00 X3.2454 Y1.7319
    G01 Z-0.0039 F5.91
    G01 X3.2669 Y1.7534 F7.87
    G01 X3.2884 Y1.7319
    G01 X3.2669 Y1.7104
    G01 X3.2454 Y1.7319
    G00 Z0.0787
    G00 X3.2179 Y2.8587
    G01 Z-0.0039 F5.91
    G01 X3.2394 Y2.8802 F7.87
    G01 X3.2609 Y2.8587
    G01 X3.2394 Y2.8372
    G01 X3.2179 Y2.8587
    G00 Z0.0787
    G00 X3.2179 Y2.7587
    G01 Z-0.0039 F5.91
    G01 X3.2394 Y2.7802 F7.87
    G01 X3.2609 Y2.7587
    G01 X3.2394 Y2.7372
    G01 X3.2179 Y2.7587
    G00 Z0.0787
    G00 X3.2179 Y2.6587
    G01 Z-0.0039 F5.91
    G01 X3.2394 Y2.6802 F7.87
    G01 X3.2609 Y2.6587
    G01 X3.2394 Y2.6372
    G01 X3.2179 Y2.6587
    G00 Z0.0787
    G00 X3.2179 Y2.5587
    G01 Z-0.0039 F5.91
    G01 X3.2394 Y2.5802 F7.87
    G01 X3.2609 Y2.5587
    G01 X3.2394 Y2.5372
    G01 X3.2179 Y2.5587
    G00 Z0.0787
    G00 X1.3378 Y2.9957
    G01 Z-0.0039 F5.91
    G01 X1.3343 Y2.9992 F7.87
    G01 X1.3301 Y3.0016
    G01 X1.3254 Y3.0029
    G01 X1.2809 Y3.0029
    G01 X1.2762 Y3.0016
    G01 X1.2720 Y2.9992
    G01 X1.2685 Y2.9957
    G01 X1.2661 Y2.9915
    G01 X1.2648 Y2.9868
    G01 X1.2648 Y2.9423
    G01 X1.2661 Y2.9376
    G01 X1.2685 Y2.9334
    G01 X1.2720 Y2.9299
    G01 X1.2762 Y2.9275
    G01 X1.2809 Y2.9263
    G01 X1.3254 Y2.9263
    G01 X1.3301 Y2.9275
    G01 X1.3343 Y2.9299
    G01 X1.3378 Y2.9334
    G01 X1.3382 Y2.9341
    G01 X1.5366 Y2.9341
    G01 X1.5339 Y2.9289
    G01 X1.5318 Y2.9222
    G01 X1.5307 Y2.9153
    G01 X1.5307 Y2.9083
    G01 X1.5318 Y2.9014
    G01 X1.5339 Y2.8947
    G01 X1.5371 Y2.8885
    G01 X1.5412 Y2.8828
    G01 X1.5462 Y2.8779
    G01 X1.5519 Y2.8737
    G01 X1.5581 Y2.8706
    G01 X1.5648 Y2.8684
    G01 X1.5717 Y2.8673
    G01 X1.6307 Y2.8673
    G01 X1.6376 Y2.8684
    G01 X1.6443 Y2.8706
    G01 X1.6505 Y2.8737
    G01 X1.6562 Y2.8779
    G01 X1.6611 Y2.8828
    G01 X1.6652 Y2.8885
    G01 X1.6684 Y2.8947
    G01 X1.6706 Y2.9014
    G01 X1.6717 Y2.9083
    G01 X1.6717 Y2.9153
    G01 X1.6706 Y2.9222
    G01 X1.6684 Y2.9289
    G01 X1.6658 Y2.9341
    G01 X1.8154 Y2.9341
    G01 X1.8158 Y2.9334
    G01 X1.8192 Y2.9299
    G01 X1.8234 Y2.9275
    G01 X1.8281 Y2.9263
    G01 X1.8726 Y2.9263
    G01 X1.8773 Y2.9275
    G01 X1.8816 Y2.9299
    G01 X1.8850 Y2.9334
    G01 X1.8874 Y2.9376
    G01 X1.8887 Y2.9423
    G01 X1.8887 Y2.9868
    G01 X1.8874 Y2.9915
    G01 X1.8850 Y2.9957
    G01 X1.8816 Y2.9992
    G01 X1.8773 Y3.0016
    G01 X1.8726 Y3.0029
    G01 X1.8281 Y3.0029
    G01 X1.8234 Y3.0016
    G01 X1.8192 Y2.9992
    G01 X1.8158 Y2.9957
    G01 X1.8154 Y2.9951
    G01 X1.6685 Y2.9951
    G01 X1.6706 Y3.0014
    G01 X1.6717 Y3.0083
    G01 X1.6717 Y3.0153
    G01 X1.6706 Y3.0222
    G01 X1.6684 Y3.0289
    G01 X1.6652 Y3.0351
    G01 X1.6611 Y3.0408
    G01 X1.6562 Y3.0458
    G01 X1.6505 Y3.0499
    G01 X1.6443 Y3.0531
    G01 X1.6376 Y3.0552
    G01 X1.6307 Y3.0563
    G01 X1.5717 Y3.0563
    G01 X1.5648 Y3.0552
    G01 X1.5581 Y3.0531
    G01 X1.5519 Y3.0499
    G01 X1.5462 Y3.0458
    G01 X1.5412 Y3.0408
    G01 X1.5371 Y3.0351
    G01 X1.5339 Y3.0289
    G01 X1.5318 Y3.0222
    G01 X1.5307 Y3.0153
    G01 X1.5307 Y3.0083
    G01 X1.5318 Y3.0014
    G01 X1.5338 Y2.9951
    G01 X1.3382 Y2.9951
    G01 X1.3378 Y2.9957
    G00 Z0.0787
    G00 X3.0897 Y1.5732
    G01 Z-0.0039 F5.91
    G01 X3.0528 Y1.5732 F7.87
    G01 X3.0268 Y1.5472
    G01 X3.0268 Y1.5274
    G01 X2.7162 Y1.2168
    G01 X2.7126 Y1.2174
    G01 X2.6449 Y1.2174
    G01 X2.6374 Y1.2162
    G01 X2.6301 Y1.2138
    G01 X2.6233 Y1.2104
    G01 X2.6171 Y1.2059
    G01 X2.6117 Y1.2005
    G01 X2.6073 Y1.1943
    G01 X2.6038 Y1.1875
    G01 X2.6014 Y1.1803
    G01 X2.6002 Y1.1727
    G01 X2.6002 Y1.1651
    G01 X2.6014 Y1.1575
    G01 X2.6038 Y1.1503
    G01 X2.6073 Y1.1435
    G01 X2.6117 Y1.1373
    G01 X2.6171 Y1.1319
    G01 X2.6233 Y1.1274
    G01 X2.6301 Y1.1239
    G01 X2.6374 Y1.1216
    G01 X2.6449 Y1.1204
    G01 X2.6482 Y1.1204
    G01 X2.6482 Y1.1174
    G01 X2.6449 Y1.1174
    G01 X2.6374 Y1.1162
    G01 X2.6301 Y1.1138
    G01 X2.6233 Y1.1104
    G01 X2.6171 Y1.1059
    G01 X2.6117 Y1.1005
    G01 X2.6073 Y1.0943
    G01 X2.6038 Y1.0875
    G01 X2.6014 Y1.0803
    G01 X2.6002 Y1.0727
    G01 X2.6002 Y1.0651
    G01 X2.6014 Y1.0575
    G01 X2.6038 Y1.0503
    G01 X2.6073 Y1.0435
    G01 X2.6117 Y1.0373
    G01 X2.6171 Y1.0319
    G01 X2.6233 Y1.0274
    G01 X2.6301 Y1.0239
    G01 X2.6374 Y1.0216
    G01 X2.6449 Y1.0204
    G01 X2.6482 Y1.0204
    G01 X2.6482 Y1.0174
    G01 X2.6449 Y1.0174
    G01 X2.6374 Y1.0162
    G01 X2.6301 Y1.0138
    G01 X2.6233 Y1.0104
    G01 X2.6171 Y1.0059
    G01 X2.6117 Y1.0005
    G01 X2.6073 Y0.9943
    G01 X2.6038 Y0.9875
    G01 X2.6014 Y0.9803
    G01 X2.6002 Y0.9727
    G01 X2.6002 Y0.9651
    G01 X2.6014 Y0.9575
    G01 X2.6038 Y0.9503
    G01 X2.6073 Y0.9435
    G01 X2.6117 Y0.9373
    G01 X2.6171 Y0.9319
    G01 X2.6233 Y0.9274
    G01 X2.6301 Y0.9239
    G01 X2.6374 Y0.9216
    G01 X2.6449 Y0.9204
    G01 X2.7126 Y0.9204
    G01 X2.7201 Y0.9216
    G01 X2.7274 Y0.9239
    G01 X2.7342 Y0.9274
    G01 X2.7403 Y0.9319
    G01 X2.7457 Y0.9373
    G01 X2.7502 Y0.9435
    G01 X2.7537 Y0.9503
    G01 X2.7561 Y0.9575
    G01 X2.7572 Y0.9651
    G01 X2.7572 Y0.9727
    G01 X2.7561 Y0.9803
    G01 X2.7537 Y0.9875
    G01 X2.7502 Y0.9943
    G01 X2.7457 Y1.0005
    G01 X2.7403 Y1.0059
    G01 X2.7342 Y1.0104
    G01 X2.7274 Y1.0138
    G01 X2.7201 Y1.0162
    G01 X2.7126 Y1.0174
    G01 X2.7092 Y1.0174
    G01 X2.7092 Y1.0204
    G01 X2.7126 Y1.0204
    G01 X2.7201 Y1.0216
    G01 X2.7274 Y1.0239
    G01 X2.7342 Y1.0274
    G01 X2.7403 Y1.0319
    G01 X2.7457 Y1.0373
    G01 X2.7502 Y1.0435
    G01 X2.7537 Y1.0503
    G01 X2.7561 Y1.0575
    G01 X2.7572 Y1.0651
    G01 X2.7572 Y1.0727
    G01 X2.7561 Y1.0803
    G01 X2.7537 Y1.0875
    G01 X2.7502 Y1.0943
    G01 X2.7457 Y1.1005
    G01 X2.7403 Y1.1059
    G01 X2.7342 Y1.1104
    G01 X2.7274 Y1.1138
    G01 X2.7201 Y1.1162
    G01 X2.7126 Y1.1174
    G01 X2.7092 Y1.1174
    G01 X2.7092 Y1.1204
    G01 X2.7126 Y1.1204
    G01 X2.7201 Y1.1216
    G01 X2.7274 Y1.1239
    G01 X2.7342 Y1.1274
    G01 X2.7403 Y1.1319
    G01 X2.7457 Y1.1373
    G01 X2.7502 Y1.1435
    G01 X2.7537 Y1.1503
    G01 X2.7561 Y1.1575
    G01 X2.7572 Y1.1651
    G01 X2.7572 Y1.1716
    G01 X3.0699 Y1.4842
    G01 X3.0897 Y1.4842
    G01 X3.1037 Y1.4982
    G01 X3.3215 Y1.4982
    G01 X3.3276 Y1.4921
    G01 X3.3645 Y1.4921
    G01 X3.3906 Y1.5182
    G01 X3.3906 Y1.5550
    G01 X3.3645 Y1.5811
    G01 X3.3276 Y1.5811
    G01 X3.3058 Y1.5592
    G01 X3.1037 Y1.5592
    G01 X3.0897 Y1.5732
    G00 Z0.0787
    G00 X3.3906 Y1.1182
    G01 Z-0.0039 F5.91
    G01 X3.3906 Y1.1550 F7.87
    G01 X3.3645 Y1.1811
    G01 X3.3276 Y1.1811
    G01 X3.3016 Y1.1550
    G01 X3.3016 Y1.1182
    G01 X3.3276 Y1.0921
    G01 X3.3645 Y1.0921
    G01 X3.3906 Y1.1182
    G00 Z0.0787
    G00 X2.7356 Y0.6563
    G01 Z-0.0039 F5.91
    G01 X2.7371 Y0.6571 F7.87
    G01 X2.7428 Y0.6612
    G01 X2.7477 Y0.6661
    G01 X2.7518 Y0.6718
    G01 X2.7550 Y0.6780
    G01 X2.7572 Y0.6847
    G01 X2.7583 Y0.6916
    G01 X2.7583 Y0.6965
    G01 X2.8526 Y0.7908
    G01 X2.9727 Y0.7908
    G01 X2.9761 Y0.7873
    G01 X2.9818 Y0.7832
    G01 X2.9880 Y0.7800
    G01 X2.9947 Y0.7779
    G01 X3.0016 Y0.7768
    G01 X3.0606 Y0.7768
    G01 X3.0675 Y0.7779
    G01 X3.0742 Y0.7800
    G01 X3.0804 Y0.7832
    G01 X3.0861 Y0.7873
    G01 X3.0910 Y0.7923
    G01 X3.0952 Y0.7979
    G01 X3.0983 Y0.8042
    G01 X3.1005 Y0.8108
    G01 X3.1016 Y0.8178
    G01 X3.1016 Y0.8248
    G01 X3.1005 Y0.8317
    G01 X3.0983 Y0.8383
    G01 X3.0952 Y0.8446
    G01 X3.0910 Y0.8503
    G01 X3.0861 Y0.8552
    G01 X3.0804 Y0.8593
    G01 X3.0742 Y0.8625
    G01 X3.0675 Y0.8647
    G01 X3.0606 Y0.8658
    G01 X3.0016 Y0.8658
    G01 X2.9947 Y0.8647
    G01 X2.9880 Y0.8625
    G01 X2.9818 Y0.8593
    G01 X2.9761 Y0.8552
    G01 X2.9727 Y0.8518
    G01 X2.8369 Y0.8518
    G01 X2.8310 Y0.8506
    G01 X2.8255 Y0.8483
    G01 X2.8205 Y0.8450
    G01 X2.8162 Y0.8407
    G01 X2.7151 Y0.7396
    G01 X2.7103 Y0.7396
    G01 X2.7034 Y0.7385
    G01 X2.6967 Y0.7364
    G01 X2.6905 Y0.7332
    G01 X2.6848 Y0.7291
    G01 X2.6798 Y0.7241
    G01 X2.6757 Y0.7184
    G01 X2.6725 Y0.7122
    G01 X2.6704 Y0.7055
    G01 X2.6693 Y0.6986
    G01 X2.6693 Y0.6916
    G01 X2.6704 Y0.6847
    G01 X2.6725 Y0.6780
    G01 X2.6757 Y0.6718
    G01 X2.6798 Y0.6661
    G01 X2.6848 Y0.6612
    G01 X2.6905 Y0.6571
    G01 X2.6920 Y0.6563
    G01 X2.6693 Y0.6336
    G01 X2.6693 Y0.5967
    G01 X2.6953 Y0.5706
    G01 X2.7322 Y0.5706
    G01 X2.7462 Y0.5846
    G01 X2.9798 Y0.5846
    G01 X2.9818 Y0.5832
    G01 X2.9880 Y0.5800
    G01 X2.9947 Y0.5779
    G01 X3.0016 Y0.5768
    G01 X3.0606 Y0.5768
    G01 X3.0675 Y0.5779
    G01 X3.0742 Y0.5800
    G01 X3.0804 Y0.5832
    G01 X3.0861 Y0.5873
    G01 X3.0910 Y0.5923
    G01 X3.0952 Y0.5979
    G01 X3.0983 Y0.6042
    G01 X3.1005 Y0.6108
    G01 X3.1016 Y0.6178
    G01 X3.1016 Y0.6248
    G01 X3.1005 Y0.6317
    G01 X3.0983 Y0.6383
    G01 X3.0952 Y0.6446
    G01 X3.0910 Y0.6503
    G01 X3.0861 Y0.6552
    G01 X3.0804 Y0.6593
    G01 X3.0742 Y0.6625
    G01 X3.0675 Y0.6647
    G01 X3.0606 Y0.6658
    G01 X3.0016 Y0.6658
    G01 X2.9947 Y0.6647
    G01 X2.9880 Y0.6625
    G01 X2.9818 Y0.6593
    G01 X2.9761 Y0.6552
    G01 X2.9712 Y0.6503
    G01 X2.9678 Y0.6456
    G01 X2.7462 Y0.6456
    G01 X2.7356 Y0.6563
    G00 Z0.0787
    G00 X3.3606 Y0.8658
    G01 Z-0.0039 F5.91
    G01 X3.3016 Y0.8658 F7.87
    G01 X3.2947 Y0.8647
    G01 X3.2880 Y0.8625
    G01 X3.2818 Y0.8593
    G01 X3.2761 Y0.8552
    G01 X3.2712 Y0.8503
    G01 X3.2670 Y0.8446
    G01 X3.2639 Y0.8383
    G01 X3.2617 Y0.8317
    G01 X3.2606 Y0.8248
    G01 X3.2606 Y0.8178
    G01 X3.2617 Y0.8108
    G01 X3.2639 Y0.8042
    G01 X3.2670 Y0.7979
    G01 X3.2712 Y0.7923
    G01 X3.2761 Y0.7873
    G01 X3.2818 Y0.7832
    G01 X3.2880 Y0.7800
    G01 X3.2947 Y0.7779
    G01 X3.3016 Y0.7768
    G01 X3.3606 Y0.7768
    G01 X3.3675 Y0.7779
    G01 X3.3742 Y0.7800
    G01 X3.3804 Y0.7832
    G01 X3.3861 Y0.7873
    G01 X3.3910 Y0.7923
    G01 X3.3952 Y0.7979
    G01 X3.3983 Y0.8042
    G01 X3.4005 Y0.8108
    G01 X3.4016 Y0.8178
    G01 X3.4016 Y0.8248
    G01 X3.4005 Y0.8317
    G01 X3.3983 Y0.8383
    G01 X3.3952 Y0.8446
    G01 X3.3910 Y0.8503
    G01 X3.3861 Y0.8552
    G01 X3.3804 Y0.8593
    G01 X3.3742 Y0.8625
    G01 X3.3675 Y0.8647
    G01 X3.3606 Y0.8658
    G00 Z0.0787
    G00 X3.3606 Y0.7658
    G01 Z-0.0039 F5.91
    G01 X3.3016 Y0.7658 F7.87
    G01 X3.2947 Y0.7647
    G01 X3.2880 Y0.7625
    G01 X3.2818 Y0.7593
    G01 X3.2761 Y0.7552
    G01 X3.2712 Y0.7503
    G01 X3.2670 Y0.7446
    G01 X3.2639 Y0.7383
    G01 X3.2617 Y0.7317
    G01 X3.2606 Y0.7248
    G01 X3.2606 Y0.7178
    G01 X3.2617 Y0.7108
    G01 X3.2639 Y0.7042
    G01 X3.2670 Y0.6979
    G01 X3.2712 Y0.6923
    G01 X3.2761 Y0.6873
    G01 X3.2818 Y0.6832
    G01 X3.2880 Y0.6800
    G01 X3.2947 Y0.6779
    G01 X3.3016 Y0.6768
    G01 X3.3606 Y0.6768
    G01 X3.3675 Y0.6779
    G01 X3.3742 Y0.6800
    G01 X3.3804 Y0.6832
    G01 X3.3861 Y0.6873
    G01 X3.3910 Y0.6923
    G01 X3.3952 Y0.6979
    G01 X3.3983 Y0.7042
    G01 X3.4005 Y0.7108
    G01 X3.4016 Y0.7178
    G01 X3.4016 Y0.7248
    G01 X3.4005 Y0.7317
    G01 X3.3983 Y0.7383
    G01 X3.3952 Y0.7446
    G01 X3.3910 Y0.7503
    G01 X3.3861 Y0.7552
    G01 X3.3804 Y0.7593
    G01 X3.3742 Y0.7625
    G01 X3.3675 Y0.7647
    G01 X3.3606 Y0.7658
    G00 Z0.0787
    G00 X3.3606 Y0.6658
    G01 Z-0.0039 F5.91
    G01 X3.3016 Y0.6658 F7.87
    G01 X3.2947 Y0.6647
    G01 X3.2880 Y0.6625
    G01 X3.2818 Y0.6593
    G01 X3.2761 Y0.6552
    G01 X3.2712 Y0.6503
    G01 X3.2670 Y0.6446
    G01 X3.2639 Y0.6383
    G01 X3.2617 Y0.6317
    G01 X3.2606 Y0.6248
    G01 X3.2606 Y0.6178
    G01 X3.2617 Y0.6108
    G01 X3.2639 Y0.6042
    G01 X3.2662 Y0.5995
    G01 X2.9513 Y0.2846
    G01 X2.7517 Y0.2846
    G01 X2.7483 Y0.2880
    G01 X2.7426 Y0.2922
    G01 X2.7411 Y0.2929
    G01 X2.7638 Y0.3157
    G01 X2.7638 Y0.3525
    G01 X2.7377 Y0.3786
    G01 X2.7009 Y0.3786
    G01 X2.6748 Y0.3525
    G01 X2.6748 Y0.3157
    G01 X2.6975 Y0.2929
    G01 X2.6960 Y0.2922
    G01 X2.6903 Y0.2880
    G01 X2.6853 Y0.2831
    G01 X2.6812 Y0.2774
    G01 X2.6780 Y0.2712
    G01 X2.6759 Y0.2645
    G01 X2.6748 Y0.2576
    G01 X2.6748 Y0.2506
    G01 X2.6759 Y0.2437
    G01 X2.6780 Y0.2370
    G01 X2.6812 Y0.2308
    G01 X2.6853 Y0.2251
    G01 X2.6903 Y0.2201
    G01 X2.6960 Y0.2160
    G01 X2.7022 Y0.2129
    G01 X2.7089 Y0.2107
    G01 X2.7158 Y0.2096
    G01 X2.7228 Y0.2096
    G01 X2.7297 Y0.2107
    G01 X2.7364 Y0.2129
    G01 X2.7426 Y0.2160
    G01 X2.7483 Y0.2201
    G01 X2.7517 Y0.2236
    G01 X2.9669 Y0.2236
    G01 X2.9728 Y0.2248
    G01 X2.9784 Y0.2271
    G01 X2.9834 Y0.2304
    G01 X2.9876 Y0.2346
    G01 X3.3297 Y0.5768
    G01 X3.3606 Y0.5768
    G01 X3.3675 Y0.5779
    G01 X3.3742 Y0.5800
    G01 X3.3804 Y0.5832
    G01 X3.3861 Y0.5873
    G01 X3.3910 Y0.5923
    G01 X3.3952 Y0.5979
    G01 X3.3983 Y0.6042
    G01 X3.4005 Y0.6108
    G01 X3.4016 Y0.6178
    G01 X3.4016 Y0.6248
    G01 X3.4005 Y0.6317
    G01 X3.3983 Y0.6383
    G01 X3.3952 Y0.6446
    G01 X3.3910 Y0.6503
    G01 X3.3861 Y0.6552
    G01 X3.3804 Y0.6593
    G01 X3.3742 Y0.6625
    G01 X3.3675 Y0.6647
    G01 X3.3606 Y0.6658
    G00 Z0.0787
    G00 X3.0606 Y0.7658
    G01 Z-0.0039 F5.91
    G01 X3.0016 Y0.7658 F7.87
    G01 X2.9947 Y0.7647
    G01 X2.9880 Y0.7625
    G01 X2.9818 Y0.7593
    G01 X2.9761 Y0.7552
    G01 X2.9712 Y0.7503
    G01 X2.9670 Y0.7446
    G01 X2.9639 Y0.7383
    G01 X2.9617 Y0.7317
    G01 X2.9606 Y0.7248
    G01 X2.9606 Y0.7178
    G01 X2.9617 Y0.7108
    G01 X2.9639 Y0.7042
    G01 X2.9670 Y0.6979
    G01 X2.9712 Y0.6923
    G01 X2.9761 Y0.6873
    G01 X2.9818 Y0.6832
    G01 X2.9880 Y0.6800
    G01 X2.9947 Y0.6779
    G01 X3.0016 Y0.6768
    G01 X3.0606 Y0.6768
    G01 X3.0675 Y0.6779
    G01 X3.0742 Y0.6800
    G01 X3.0804 Y0.6832
    G01 X3.0861 Y0.6873
    G01 X3.0910 Y0.6923
    G01 X3.0952 Y0.6979
    G01 X3.0983 Y0.7042
    G01 X3.1005 Y0.7108
    G01 X3.1016 Y0.7178
    G01 X3.1016 Y0.7248
    G01 X3.1005 Y0.7317
    G01 X3.0983 Y0.7383
    G01 X3.0952 Y0.7446
    G01 X3.0910 Y0.7503
    G01 X3.0861 Y0.7552
    G01 X3.0804 Y0.7593
    G01 X3.0742 Y0.7625
    G01 X3.0675 Y0.7647
    G01 X3.0606 Y0.7658
    G00 Z0.0787
    G00 X3.0606 Y0.9658
    G01 Z-0.0039 F5.91
    G01 X3.0016 Y0.9658 F7.87
    G01 X2.9947 Y0.9647
    G01 X2.9880 Y0.9625
    G01 X2.9818 Y0.9593
    G01 X2.9761 Y0.9552
    G01 X2.9712 Y0.9503
    G01 X2.9670 Y0.9446
    G01 X2.9639 Y0.9383
    G01 X2.9617 Y0.9317
    G01 X2.9606 Y0.9248
    G01 X2.9606 Y0.9178
    G01 X2.9617 Y0.9108
    G01 X2.9639 Y0.9042
    G01 X2.9670 Y0.8979
    G01 X2.9712 Y0.8923
    G01 X2.9761 Y0.8873
    G01 X2.9818 Y0.8832
    G01 X2.9880 Y0.8800
    G01 X2.9947 Y0.8779
    G01 X3.0016 Y0.8768
    G01 X3.0606 Y0.8768
    G01 X3.0675 Y0.8779
    G01 X3.0742 Y0.8800
    G01 X3.0804 Y0.8832
    G01 X3.0861 Y0.8873
    G01 X3.0910 Y0.8923
    G01 X3.0952 Y0.8979
    G01 X3.0983 Y0.9042
    G01 X3.1005 Y0.9108
    G01 X3.1016 Y0.9178
    G01 X3.1016 Y0.9248
    G01 X3.1005 Y0.9317
    G01 X3.0983 Y0.9383
    G01 X3.0952 Y0.9446
    G01 X3.0910 Y0.9503
    G01 X3.0861 Y0.9552
    G01 X3.0804 Y0.9593
    G01 X3.0742 Y0.9625
    G01 X3.0675 Y0.9647
    G01 X3.0606 Y0.9658
    G00 Z0.0787
    G00 X0.2825 Y0.7045
    G01 Z-0.0039 F5.91
    G01 X0.2825 Y0.7137 F7.87
    G01 X0.2811 Y0.7228
    G01 X0.2810 Y0.7229
    G01 X0.3738 Y0.8157
    G01 X0.3780 Y0.8199
    G01 X0.3814 Y0.8249
    G01 X0.3837 Y0.8305
    G01 X0.3848 Y0.8364
    G01 X0.3848 Y0.8499
    G01 X0.3878 Y0.8469
    G01 X0.3943 Y0.8422
    G01 X0.4016 Y0.8385
    G01 X0.4093 Y0.8360
    G01 X0.4173 Y0.8347
    G01 X0.4914 Y0.8347
    G01 X0.4994 Y0.8360
    G01 X0.5071 Y0.8385
    G01 X0.5143 Y0.8422
    G01 X0.5209 Y0.8469
    G01 X0.5266 Y0.8527
    G01 X0.5314 Y0.8592
    G01 X0.5351 Y0.8664
    G01 X0.5376 Y0.8742
    G01 X0.5388 Y0.8822
    G01 X0.5388 Y0.8903
    G01 X0.5376 Y0.8983
    G01 X0.5351 Y0.9060
    G01 X0.5314 Y0.9132
    G01 X0.5266 Y0.9198
    G01 X0.5209 Y0.9255
    G01 X0.5143 Y0.9303
    G01 X0.5071 Y0.9340
    G01 X0.5001 Y0.9362
    G01 X0.5071 Y0.9385
    G01 X0.5143 Y0.9422
    G01 X0.5209 Y0.9469
    G01 X0.5266 Y0.9527
    G01 X0.5288 Y0.9557
    G01 X0.6547 Y0.9557
    G01 X0.9212 Y0.6892
    G01 X0.9254 Y0.6850
    G01 X0.9304 Y0.6816
    G01 X0.9360 Y0.6793
    G01 X0.9419 Y0.6782
    G01 X1.2472 Y0.6782
    G01 X1.4215 Y0.5039
    G01 X1.4203 Y0.4967
    G01 X1.4203 Y0.4891
    G01 X1.4215 Y0.4816
    G01 X1.4239 Y0.4743
    G01 X1.4273 Y0.4675
    G01 X1.4318 Y0.4613
    G01 X1.4372 Y0.4559
    G01 X1.4434 Y0.4514
    G01 X1.4502 Y0.4480
    G01 X1.4575 Y0.4456
    G01 X1.4650 Y0.4444
    G01 X1.5326 Y0.4444
    G01 X1.5402 Y0.4456
    G01 X1.5474 Y0.4480
    G01 X1.5542 Y0.4514
    G01 X1.5604 Y0.4559
    G01 X1.5658 Y0.4613
    G01 X1.5703 Y0.4675
    G01 X1.5738 Y0.4743
    G01 X1.5761 Y0.4816
    G01 X1.5773 Y0.4891
    G01 X1.5773 Y0.4967
    G01 X1.5761 Y0.5043
    G01 X1.5738 Y0.5115
    G01 X1.5703 Y0.5183
    G01 X1.5658 Y0.5245
    G01 X1.5604 Y0.5299
    G01 X1.5542 Y0.5344
    G01 X1.5474 Y0.5379
    G01 X1.5402 Y0.5402
    G01 X1.5326 Y0.5414
    G01 X1.4874 Y0.5414
    G01 X1.4829 Y0.5423
    G01 X1.4693 Y0.5423
    G01 X1.4672 Y0.5444
    G01 X1.5326 Y0.5444
    G01 X1.5402 Y0.5456
    G01 X1.5474 Y0.5480
    G01 X1.5542 Y0.5514
    G01 X1.5604 Y0.5559
    G01 X1.5658 Y0.5613
    G01 X1.5703 Y0.5675
    G01 X1.5738 Y0.5743
    G01 X1.5761 Y0.5816
    G01 X1.5773 Y0.5891
    G01 X1.5773 Y0.5967
    G01 X1.5761 Y0.6043
    G01 X1.5738 Y0.6115
    G01 X1.5703 Y0.6183
    G01 X1.5658 Y0.6245
    G01 X1.5604 Y0.6299
    G01 X1.5542 Y0.6344
    G01 X1.5474 Y0.6379
    G01 X1.5402 Y0.6402
    G01 X1.5326 Y0.6414
    G01 X1.4650 Y0.6414
    G01 X1.4575 Y0.6402
    G01 X1.4502 Y0.6379
    G01 X1.4434 Y0.6344
    G01 X1.4372 Y0.6299
    G01 X1.4318 Y0.6245
    G01 X1.4273 Y0.6183
    G01 X1.4239 Y0.6115
    G01 X1.4215 Y0.6043
    G01 X1.4203 Y0.5967
    G01 X1.4203 Y0.5913
    G01 X1.2793 Y0.7324
    G01 X1.2743 Y0.7357
    G01 X1.2687 Y0.7380
    G01 X1.2628 Y0.7392
    G01 X0.9575 Y0.7392
    G01 X0.6868 Y1.0099
    G01 X0.6818 Y1.0133
    G01 X0.6762 Y1.0156
    G01 X0.6703 Y1.0167
    G01 X0.5288 Y1.0167
    G01 X0.5266 Y1.0198
    G01 X0.5209 Y1.0255
    G01 X0.5143 Y1.0303
    G01 X0.5071 Y1.0340
    G01 X0.5001 Y1.0362
    G01 X0.5071 Y1.0385
    G01 X0.5143 Y1.0422
    G01 X0.5209 Y1.0469
    G01 X0.5266 Y1.0527
    G01 X0.5314 Y1.0592
    G01 X0.5351 Y1.0664
    G01 X0.5376 Y1.0742
    G01 X0.5388 Y1.0822
    G01 X0.5388 Y1.0903
    G01 X0.5376 Y1.0983
    G01 X0.5351 Y1.1060
    G01 X0.5314 Y1.1132
    G01 X0.5266 Y1.1198
    G01 X0.5209 Y1.1255
    G01 X0.5143 Y1.1303
    G01 X0.5071 Y1.1340
    G01 X0.4994 Y1.1365
    G01 X0.4914 Y1.1377
    G01 X0.4173 Y1.1377
    G01 X0.4093 Y1.1365
    G01 X0.4016 Y1.1340
    G01 X0.3943 Y1.1303
    G01 X0.3878 Y1.1255
    G01 X0.3820 Y1.1198
    G01 X0.3773 Y1.1132
    G01 X0.3736 Y1.1060
    G01 X0.3711 Y1.0983
    G01 X0.3698 Y1.0903
    G01 X0.3698 Y1.0823
    G01 X0.3306 Y1.0431
    G01 X0.3273 Y1.0381
    G01 X0.3250 Y1.0325
    G01 X0.3238 Y1.0266
    G01 X0.3238 Y0.8520
    G01 X0.2379 Y0.7661
    G01 X0.2377 Y0.7661
    G01 X0.2286 Y0.7676
    G01 X0.2194 Y0.7676
    G01 X0.2103 Y0.7661
    G01 X0.2016 Y0.7633
    G01 X0.1934 Y0.7591
    G01 X0.1859 Y0.7537
    G01 X0.1794 Y0.7472
    G01 X0.1740 Y0.7397
    G01 X0.1698 Y0.7315
    G01 X0.1670 Y0.7228
    G01 X0.1655 Y0.7137
    G01 X0.1655 Y0.7045
    G01 X0.1670 Y0.6954
    G01 X0.1698 Y0.6866
    G01 X0.1740 Y0.6784
    G01 X0.1794 Y0.6709
    G01 X0.1859 Y0.6644
    G01 X0.1934 Y0.6590
    G01 X0.2016 Y0.6548
    G01 X0.2103 Y0.6520
    G01 X0.2194 Y0.6506
    G01 X0.2286 Y0.6506
    G01 X0.2377 Y0.6520
    G01 X0.2465 Y0.6548
    G01 X0.2547 Y0.6590
    G01 X0.2621 Y0.6644
    G01 X0.2686 Y0.6709
    G01 X0.2741 Y0.6784
    G01 X0.2782 Y0.6866
    G01 X0.2811 Y0.6954
    G01 X0.2825 Y0.7045
    G00 Z0.0787
    G00 X0.1816 Y0.5707
    G01 Z-0.0039 F5.91
    G01 X0.1769 Y0.5694 F7.87
    G01 X0.1727 Y0.5670
    G01 X0.1692 Y0.5636
    G01 X0.1668 Y0.5593
    G01 X0.1655 Y0.5546
    G01 X0.1655 Y0.4698
    G01 X0.1668 Y0.4651
    G01 X0.1692 Y0.4608
    G01 X0.1727 Y0.4574
    G01 X0.1769 Y0.4550
    G01 X0.1816 Y0.4537
    G01 X0.2665 Y0.4537
    G01 X0.2712 Y0.4550
    G01 X0.2754 Y0.4574
    G01 X0.2788 Y0.4608
    G01 X0.2813 Y0.4651
    G01 X0.2825 Y0.4698
    G01 X0.2825 Y0.5276
    G01 X0.3158 Y0.5608
    G01 X0.3798 Y0.5608
    G01 X0.3820 Y0.5578
    G01 X0.3878 Y0.5521
    G01 X0.3943 Y0.5473
    G01 X0.4016 Y0.5436
    G01 X0.4085 Y0.5413
    G01 X0.4016 Y0.5391
    G01 X0.3943 Y0.5354
    G01 X0.3878 Y0.5306
    G01 X0.3820 Y0.5249
    G01 X0.3773 Y0.5183
    G01 X0.3736 Y0.5111
    G01 X0.3711 Y0.5034
    G01 X0.3698 Y0.4954
    G01 X0.3698 Y0.4873
    G01 X0.3711 Y0.4793
    G01 X0.3736 Y0.4716
    G01 X0.3773 Y0.4643
    G01 X0.3820 Y0.4578
    G01 X0.3878 Y0.4521
    G01 X0.3943 Y0.4473
    G01 X0.4016 Y0.4436
    G01 X0.4085 Y0.4413
    G01 X0.4016 Y0.4391
    G01 X0.3943 Y0.4354
    G01 X0.3878 Y0.4306
    G01 X0.3820 Y0.4249
    G01 X0.3773 Y0.4183
    G01 X0.3736 Y0.4111
    G01 X0.3711 Y0.4034
    G01 X0.3698 Y0.3954
    G01 X0.3698 Y0.3873
    G01 X0.3711 Y0.3793
    G01 X0.3736 Y0.3716
    G01 X0.3773 Y0.3643
    G01 X0.3820 Y0.3578
    G01 X0.3878 Y0.3521
    G01 X0.3943 Y0.3473
    G01 X0.4016 Y0.3436
    G01 X0.4093 Y0.3411
    G01 X0.4173 Y0.3398
    G01 X0.4914 Y0.3398
    G01 X0.4994 Y0.3411
    G01 X0.5071 Y0.3436
    G01 X0.5143 Y0.3473
    G01 X0.5209 Y0.3521
    G01 X0.5266 Y0.3578
    G01 X0.5314 Y0.3643
    G01 X0.5351 Y0.3716
    G01 X0.5376 Y0.3793
    G01 X0.5388 Y0.3873
    G01 X0.5388 Y0.3954
    G01 X0.5376 Y0.4034
    G01 X0.5351 Y0.4111
    G01 X0.5314 Y0.4183
    G01 X0.5266 Y0.4249
    G01 X0.5209 Y0.4306
    G01 X0.5143 Y0.4354
    G01 X0.5071 Y0.4391
    G01 X0.5001 Y0.4413
    G01 X0.5071 Y0.4436
    G01 X0.5143 Y0.4473
    G01 X0.5209 Y0.4521
    G01 X0.5266 Y0.4578
    G01 X0.5314 Y0.4643
    G01 X0.5351 Y0.4716
    G01 X0.5376 Y0.4793
    G01 X0.5388 Y0.4873
    G01 X0.5388 Y0.4954
    G01 X0.5376 Y0.5034
    G01 X0.5351 Y0.5111
    G01 X0.5314 Y0.5183
    G01 X0.5266 Y0.5249
    G01 X0.5209 Y0.5306
    G01 X0.5143 Y0.5354
    G01 X0.5071 Y0.5391
    G01 X0.5001 Y0.5413
    G01 X0.5071 Y0.5436
    G01 X0.5143 Y0.5473
    G01 X0.5209 Y0.5521
    G01 X0.5266 Y0.5578
    G01 X0.5314 Y0.5643
    G01 X0.5351 Y0.5716
    G01 X0.5376 Y0.5793
    G01 X0.5388 Y0.5873
    G01 X0.5388 Y0.5954
    G01 X0.5376 Y0.6034
    G01 X0.5351 Y0.6111
    G01 X0.5314 Y0.6183
    G01 X0.5266 Y0.6249
    G01 X0.5209 Y0.6306
    G01 X0.5143 Y0.6354
    G01 X0.5071 Y0.6391
    G01 X0.4994 Y0.6416
    G01 X0.4914 Y0.6428
    G01 X0.4173 Y0.6428
    G01 X0.4093 Y0.6416
    G01 X0.4016 Y0.6391
    G01 X0.3943 Y0.6354
    G01 X0.3878 Y0.6306
    G01 X0.3820 Y0.6249
    G01 X0.3798 Y0.6218
    G01 X0.3001 Y0.6218
    G01 X0.2943 Y0.6207
    G01 X0.2887 Y0.6184
    G01 X0.2837 Y0.6150
    G01 X0.2795 Y0.6108
    G01 X0.2394 Y0.5707
    G01 X0.1816 Y0.5707
    G00 Z0.0787
    G00 X3.5151 Y0.3078
    G01 Z-0.0039 F5.91
    G01 X3.5151 Y0.2229 F7.87
    G01 X3.5164 Y0.2182
    G01 X3.5188 Y0.2140
    G01 X3.5223 Y0.2105
    G01 X3.5265 Y0.2081
    G01 X3.5312 Y0.2068
    G01 X3.6161 Y0.2068
    G01 X3.6208 Y0.2081
    G01 X3.6250 Y0.2105
    G01 X3.6284 Y0.2140
    G01 X3.6309 Y0.2182
    G01 X3.6321 Y0.2229
    G01 X3.6321 Y0.3078
    G01 X3.6309 Y0.3125
    G01 X3.6284 Y0.3167
    G01 X3.6250 Y0.3202
    G01 X3.6208 Y0.3226
    G01 X3.6161 Y0.3239
    G01 X3.5312 Y0.3239
    G01 X3.5265 Y0.3226
    G01 X3.5223 Y0.3202
    G01 X3.5188 Y0.3167
    G01 X3.5164 Y0.3125
    G01 X3.5151 Y0.3078
    G00 Z0.0787
    G00 X0.2665 Y1.1888
    G01 Z-0.0039 F5.91
    G01 X0.1816 Y1.1888 F7.87
    G01 X0.1769 Y1.1876
    G01 X0.1727 Y1.1851
    G01 X0.1692 Y1.1817
    G01 X0.1668 Y1.1775
    G01 X0.1655 Y1.1728
    G01 X0.1655 Y1.0879
    G01 X0.1668 Y1.0832
    G01 X0.1692 Y1.0790
    G01 X0.1727 Y1.0755
    G01 X0.1769 Y1.0731
    G01 X0.1816 Y1.0718
    G01 X0.2665 Y1.0718
    G01 X0.2712 Y1.0731
    G01 X0.2754 Y1.0755
    G01 X0.2788 Y1.0790
    G01 X0.2813 Y1.0832
    G01 X0.2825 Y1.0879
    G01 X0.2825 Y1.1728
    G01 X0.2813 Y1.1775
    G01 X0.2788 Y1.1817
    G01 X0.2754 Y1.1851
    G01 X0.2712 Y1.1876
    G01 X0.2665 Y1.1888
    G00 Z0.0787
    G00 X0.2825 Y1.9013
    G01 Z-0.0039 F5.91
    G01 X0.2825 Y1.9105 F7.87
    G01 X0.2811 Y1.9196
    G01 X0.2782 Y1.9284
    G01 X0.2741 Y1.9366
    G01 X0.2686 Y1.9440
    G01 X0.2621 Y1.9505
    G01 X0.2547 Y1.9559
    G01 X0.2465 Y1.9601
    G01 X0.2377 Y1.9630
    G01 X0.2286 Y1.9644
    G01 X0.2194 Y1.9644
    G01 X0.2103 Y1.9630
    G01 X0.2016 Y1.9601
    G01 X0.1934 Y1.9559
    G01 X0.1859 Y1.9505
    G01 X0.1794 Y1.9440
    G01 X0.1740 Y1.9366
    G01 X0.1698 Y1.9284
    G01 X0.1670 Y1.9196
    G01 X0.1655 Y1.9105
    G01 X0.1655 Y1.9016
    G01 X0.0944 Y1.8305
    G01 X0.0911 Y1.8255
    G01 X0.0888 Y1.8199
    G01 X0.0876 Y1.8140
    G01 X0.0876 Y1.4301
    G01 X0.0888 Y1.4242
    G01 X0.0911 Y1.4186
    G01 X0.0944 Y1.4136
    G01 X0.0987 Y1.4094
    G01 X0.1670 Y1.3410
    G01 X0.1670 Y1.3409
    G01 X0.1655 Y1.3318
    G01 X0.1655 Y1.3226
    G01 X0.1670 Y1.3135
    G01 X0.1698 Y1.3047
    G01 X0.1740 Y1.2965
    G01 X0.1794 Y1.2891
    G01 X0.1859 Y1.2825
    G01 X0.1934 Y1.2771
    G01 X0.2016 Y1.2729
    G01 X0.2103 Y1.2701
    G01 X0.2194 Y1.2687
    G01 X0.2286 Y1.2687
    G01 X0.2377 Y1.2701
    G01 X0.2465 Y1.2729
    G01 X0.2547 Y1.2771
    G01 X0.2621 Y1.2825
    G01 X0.2686 Y1.2891
    G01 X0.2741 Y1.2965
    G01 X0.2782 Y1.3047
    G01 X0.2811 Y1.3135
    G01 X0.2825 Y1.3226
    G01 X0.2825 Y1.3318
    G01 X0.2811 Y1.3409
    G01 X0.2782 Y1.3496
    G01 X0.2741 Y1.3578
    G01 X0.2686 Y1.3653
    G01 X0.2621 Y1.3718
    G01 X0.2547 Y1.3772
    G01 X0.2465 Y1.3814
    G01 X0.2377 Y1.3842
    G01 X0.2286 Y1.3857
    G01 X0.2194 Y1.3857
    G01 X0.2103 Y1.3842
    G01 X0.2101 Y1.3842
    G01 X0.1486 Y1.4457
    G01 X0.1486 Y1.7984
    G01 X0.2018 Y1.8516
    G01 X0.2103 Y1.8488
    G01 X0.2194 Y1.8474
    G01 X0.2286 Y1.8474
    G01 X0.2377 Y1.8488
    G01 X0.2465 Y1.8517
    G01 X0.2547 Y1.8559
    G01 X0.2621 Y1.8613
    G01 X0.2686 Y1.8678
    G01 X0.2741 Y1.8752
    G01 X0.2782 Y1.8834
    G01 X0.2811 Y1.8922
    G01 X0.2825 Y1.9013
    G00 Z0.0787
    G00 X0.2665 Y1.7676
    G01 Z-0.0039 F5.91
    G01 X0.1816 Y1.7676 F7.87
    G01 X0.1769 Y1.7663
    G01 X0.1727 Y1.7639
    G01 X0.1692 Y1.7604
    G01 X0.1668 Y1.7562
    G01 X0.1655 Y1.7515
    G01 X0.1655 Y1.6666
    G01 X0.1668 Y1.6619
    G01 X0.1692 Y1.6577
    G01 X0.1727 Y1.6542
    G01 X0.1769 Y1.6518
    G01 X0.1816 Y1.6506
    G01 X0.2665 Y1.6506
    G01 X0.2712 Y1.6518
    G01 X0.2754 Y1.6542
    G01 X0.2788 Y1.6577
    G01 X0.2813 Y1.6619
    G01 X0.2825 Y1.6666
    G01 X0.2825 Y1.7515
    G01 X0.2813 Y1.7562
    G01 X0.2788 Y1.7604
    G01 X0.2754 Y1.7639
    G01 X0.2712 Y1.7663
    G01 X0.2665 Y1.7676
    G00 Z0.0787
    G00 X2.2307 Y2.8563
    G01 Z-0.0039 F5.91
    G01 X2.1717 Y2.8563 F7.87
    G01 X2.1648 Y2.8552
    G01 X2.1581 Y2.8531
    G01 X2.1519 Y2.8499
    G01 X2.1462 Y2.8458
    G01 X2.1412 Y2.8408
    G01 X2.1371 Y2.8351
    G01 X2.1339 Y2.8289
    G01 X2.1318 Y2.8222
    G01 X2.1307 Y2.8153
    G01 X2.1307 Y2.8083
    G01 X2.1318 Y2.8014
    G01 X2.1339 Y2.7947
    G01 X2.1371 Y2.7885
    G01 X2.1412 Y2.7828
    G01 X2.1462 Y2.7779
    G01 X2.1519 Y2.7737
    G01 X2.1581 Y2.7706
    G01 X2.1648 Y2.7684
    G01 X2.1717 Y2.7673
    G01 X2.2307 Y2.7673
    G01 X2.2376 Y2.7684
    G01 X2.2443 Y2.7706
    G01 X2.2505 Y2.7737
    G01 X2.2562 Y2.7779
    G01 X2.2611 Y2.7828
    G01 X2.2652 Y2.7885
    G01 X2.2684 Y2.7947
    G01 X2.2706 Y2.8014
    G01 X2.2717 Y2.8083
    G01 X2.2717 Y2.8153
    G01 X2.2706 Y2.8222
    G01 X2.2684 Y2.8289
    G01 X2.2652 Y2.8351
    G01 X2.2611 Y2.8408
    G01 X2.2562 Y2.8458
    G01 X2.2505 Y2.8499
    G01 X2.2443 Y2.8531
    G01 X2.2376 Y2.8552
    G01 X2.2307 Y2.8563
    G00 Z0.0787
    G00 X2.2307 Y2.7563
    G01 Z-0.0039 F5.91
    G01 X2.1717 Y2.7563 F7.87
    G01 X2.1648 Y2.7552
    G01 X2.1581 Y2.7531
    G01 X2.1519 Y2.7499
    G01 X2.1462 Y2.7458
    G01 X2.1430 Y2.7426
    G01 X2.0384 Y2.8473
    G01 X2.0384 Y2.9401
    G01 X2.1386 Y3.0404
    G01 X2.1409 Y3.0404
    G01 X2.1371 Y3.0351
    G01 X2.1339 Y3.0289
    G01 X2.1318 Y3.0222
    G01 X2.1307 Y3.0153
    G01 X2.1307 Y3.0083
    G01 X2.1318 Y3.0014
    G01 X2.1339 Y2.9947
    G01 X2.1371 Y2.9885
    G01 X2.1412 Y2.9828
    G01 X2.1462 Y2.9779
    G01 X2.1519 Y2.9737
    G01 X2.1581 Y2.9706
    G01 X2.1648 Y2.9684
    G01 X2.1717 Y2.9673
    G01 X2.2307 Y2.9673
    G01 X2.2376 Y2.9684
    G01 X2.2443 Y2.9706
    G01 X2.2505 Y2.9737
    G01 X2.2562 Y2.9779
    G01 X2.2611 Y2.9828
    G01 X2.2652 Y2.9885
    G01 X2.2684 Y2.9947
    G01 X2.2706 Y3.0014
    G01 X2.2717 Y3.0083
    G01 X2.2717 Y3.0153
    G01 X2.2706 Y3.0222
    G01 X2.2684 Y3.0289
    G01 X2.2652 Y3.0351
    G01 X2.2614 Y3.0404
    G01 X2.9579 Y3.0404
    G01 X2.8598 Y2.9423
    G01 X2.2596 Y2.9423
    G01 X2.2562 Y2.9458
    G01 X2.2505 Y2.9499
    G01 X2.2443 Y2.9531
    G01 X2.2376 Y2.9552
    G01 X2.2307 Y2.9563
    G01 X2.1717 Y2.9563
    G01 X2.1648 Y2.9552
    G01 X2.1581 Y2.9531
    G01 X2.1519 Y2.9499
    G01 X2.1462 Y2.9458
    G01 X2.1412 Y2.9408
    G01 X2.1371 Y2.9351
    G01 X2.1339 Y2.9289
    G01 X2.1318 Y2.9222
    G01 X2.1307 Y2.9153
    G01 X2.1307 Y2.9083
    G01 X2.1318 Y2.9014
    G01 X2.1339 Y2.8947
    G01 X2.1371 Y2.8885
    G01 X2.1412 Y2.8828
    G01 X2.1462 Y2.8779
    G01 X2.1519 Y2.8737
    G01 X2.1581 Y2.8706
    G01 X2.1648 Y2.8684
    G01 X2.1717 Y2.8673
    G01 X2.2307 Y2.8673
    G01 X2.2376 Y2.8684
    G01 X2.2443 Y2.8706
    G01 X2.2505 Y2.8737
    G01 X2.2562 Y2.8779
    G01 X2.2596 Y2.8813
    G01 X2.8754 Y2.8813
    G01 X2.8813 Y2.8825
    G01 X2.8869 Y2.8848
    G01 X2.8919 Y2.8881
    G01 X3.0048 Y3.0010
    G01 X3.2945 Y3.0010
    G01 X3.3553 Y2.9401
    G01 X3.3553 Y2.9178
    G01 X3.3449 Y2.9073
    G01 X3.3449 Y2.9317
    G01 X3.3124 Y2.9642
    G01 X3.2664 Y2.9642
    G01 X3.2394 Y2.9372
    G01 X3.2124 Y2.9642
    G01 X3.1664 Y2.9642
    G01 X3.1414 Y2.9392
    G01 X3.0631 Y2.9392
    G01 X3.0572 Y2.9380
    G01 X3.0517 Y2.9357
    G01 X3.0467 Y2.9324
    G01 X2.9333 Y2.8190
    G01 X2.9291 Y2.8147
    G01 X2.9257 Y2.8097
    G01 X2.9234 Y2.8042
    G01 X2.9223 Y2.7983
    G01 X2.9223 Y2.3431
    G01 X2.9234 Y2.3372
    G01 X2.9257 Y2.3316
    G01 X2.9291 Y2.3266
    G01 X3.1433 Y2.1124
    G01 X2.2717 Y2.1124
    G01 X2.2717 Y2.1153
    G01 X2.2706 Y2.1222
    G01 X2.2684 Y2.1289
    G01 X2.2652 Y2.1351
    G01 X2.2611 Y2.1408
    G01 X2.2562 Y2.1458
    G01 X2.2505 Y2.1499
    G01 X2.2443 Y2.1531
    G01 X2.2376 Y2.1552
    G01 X2.2307 Y2.1563
    G01 X2.1717 Y2.1563
    G01 X2.1648 Y2.1552
    G01 X2.1581 Y2.1531
    G01 X2.1519 Y2.1499
    G01 X2.1462 Y2.1458
    G01 X2.1412 Y2.1408
    G01 X2.1371 Y2.1351
    G01 X2.1339 Y2.1289
    G01 X2.1323 Y2.1238
    G01 X2.1249 Y2.1313
    G01 X2.1206 Y2.1355
    G01 X2.1156 Y2.1388
    G01 X2.1101 Y2.1411
    G01 X2.1042 Y2.1423
    G01 X1.6596 Y2.1423
    G01 X1.6562 Y2.1458
    G01 X1.6505 Y2.1499
    G01 X1.6443 Y2.1531
    G01 X1.6376 Y2.1552
    G01 X1.6307 Y2.1563
    G01 X1.5998 Y2.1563
    G01 X1.5888 Y2.1673
    G01 X1.6307 Y2.1673
    G01 X1.6376 Y2.1684
    G01 X1.6443 Y2.1706
    G01 X1.6505 Y2.1737
    G01 X1.6562 Y2.1779
    G01 X1.6611 Y2.1828
    G01 X1.6652 Y2.1885
    G01 X1.6684 Y2.1947
    G01 X1.6706 Y2.2014
    G01 X1.6717 Y2.2083
    G01 X1.6717 Y2.2153
    G01 X1.6706 Y2.2222
    G01 X1.6684 Y2.2289
    G01 X1.6652 Y2.2351
    G01 X1.6611 Y2.2408
    G01 X1.6562 Y2.2458
    G01 X1.6505 Y2.2499
    G01 X1.6443 Y2.2531
    G01 X1.6376 Y2.2552
    G01 X1.6307 Y2.2563
    G01 X1.5998 Y2.2563
    G01 X1.5888 Y2.2673
    G01 X1.6307 Y2.2673
    G01 X1.6376 Y2.2684
    G01 X1.6443 Y2.2706
    G01 X1.6505 Y2.2737
    G01 X1.6562 Y2.2779
    G01 X1.6611 Y2.2828
    G01 X1.6652 Y2.2885
    G01 X1.6684 Y2.2947
    G01 X1.6706 Y2.3014
    G01 X1.6717 Y2.3083
    G01 X1.6717 Y2.3153
    G01 X1.6706 Y2.3222
    G01 X1.6684 Y2.3289
    G01 X1.6652 Y2.3351
    G01 X1.6611 Y2.3408
    G01 X1.6562 Y2.3458
    G01 X1.6505 Y2.3499
    G01 X1.6443 Y2.3531
    G01 X1.6376 Y2.3552
    G01 X1.6307 Y2.3563
    G01 X1.5998 Y2.3563
    G01 X1.5888 Y2.3673
    G01 X1.6307 Y2.3673
    G01 X1.6376 Y2.3684
    G01 X1.6443 Y2.3706
    G01 X1.6505 Y2.3737
    G01 X1.6562 Y2.3779
    G01 X1.6611 Y2.3828
    G01 X1.6652 Y2.3885
    G01 X1.6684 Y2.3947
    G01 X1.6706 Y2.4014
    G01 X1.6717 Y2.4083
    G01 X1.6717 Y2.4153
    G01 X1.6706 Y2.4222
    G01 X1.6684 Y2.4289
    G01 X1.6652 Y2.4351
    G01 X1.6611 Y2.4408
    G01 X1.6562 Y2.4458
    G01 X1.6505 Y2.4499
    G01 X1.6443 Y2.4531
    G01 X1.6376 Y2.4552
    G01 X1.6307 Y2.4563
    G01 X1.5717 Y2.4563
    G01 X1.5648 Y2.4552
    G01 X1.5581 Y2.4531
    G01 X1.5519 Y2.4499
    G01 X1.5462 Y2.4458
    G01 X1.5412 Y2.4408
    G01 X1.5371 Y2.4351
    G01 X1.5339 Y2.4289
    G01 X1.5323 Y2.4238
    G01 X1.4280 Y2.5281
    G01 X1.4238 Y2.5324
    G01 X1.4188 Y2.5357
    G01 X1.4132 Y2.5380
    G01 X1.4073 Y2.5392
    G01 X1.0283 Y2.5392
    G01 X1.0088 Y2.5587
    G01 X1.0283 Y2.5782
    G01 X1.4917 Y2.5782
    G01 X1.5363 Y2.5335
    G01 X1.5339 Y2.5289
    G01 X1.5318 Y2.5222
    G01 X1.5307 Y2.5153
    G01 X1.5307 Y2.5083
    G01 X1.5318 Y2.5014
    G01 X1.5339 Y2.4947
    G01 X1.5371 Y2.4885
    G01 X1.5412 Y2.4828
    G01 X1.5462 Y2.4779
    G01 X1.5519 Y2.4737
    G01 X1.5581 Y2.4706
    G01 X1.5648 Y2.4684
    G01 X1.5717 Y2.4673
    G01 X1.6307 Y2.4673
    G01 X1.6376 Y2.4684
    G01 X1.6443 Y2.4706
    G01 X1.6505 Y2.4737
    G01 X1.6562 Y2.4779
    G01 X1.6611 Y2.4828
    G01 X1.6652 Y2.4885
    G01 X1.6684 Y2.4947
    G01 X1.6706 Y2.5014
    G01 X1.6717 Y2.5083
    G01 X1.6717 Y2.5153
    G01 X1.6706 Y2.5222
    G01 X1.6684 Y2.5289
    G01 X1.6652 Y2.5351
    G01 X1.6611 Y2.5408
    G01 X1.6562 Y2.5458
    G01 X1.6505 Y2.5499
    G01 X1.6443 Y2.5531
    G01 X1.6376 Y2.5552
    G01 X1.6307 Y2.5563
    G01 X1.5998 Y2.5563
    G01 X1.5888 Y2.5673
    G01 X1.6307 Y2.5673
    G01 X1.6376 Y2.5684
    G01 X1.6443 Y2.5706
    G01 X1.6505 Y2.5737
    G01 X1.6562 Y2.5779
    G01 X1.6611 Y2.5828
    G01 X1.6652 Y2.5885
    G01 X1.6684 Y2.5947
    G01 X1.6706 Y2.6014
    G01 X1.6717 Y2.6083
    G01 X1.6717 Y2.6153
    G01 X1.6706 Y2.6222
    G01 X1.6684 Y2.6289
    G01 X1.6652 Y2.6351
    G01 X1.6611 Y2.6408
    G01 X1.6562 Y2.6458
    G01 X1.6505 Y2.6499
    G01 X1.6443 Y2.6531
    G01 X1.6376 Y2.6552
    G01 X1.6307 Y2.6563
    G01 X1.5717 Y2.6563
    G01 X1.5648 Y2.6552
    G01 X1.5581 Y2.6531
    G01 X1.5519 Y2.6499
    G01 X1.5462 Y2.6458
    G01 X1.5412 Y2.6408
    G01 X1.5371 Y2.6351
    G01 X1.5339 Y2.6289
    G01 X1.5323 Y2.6238
    G01 X1.5280 Y2.6281
    G01 X1.5238 Y2.6324
    G01 X1.5188 Y2.6357
    G01 X1.5132 Y2.6380
    G01 X1.5073 Y2.6392
    G01 X1.0283 Y2.6392
    G01 X1.0088 Y2.6587
    G01 X1.0283 Y2.6782
    G01 X1.5459 Y2.6782
    G01 X1.5462 Y2.6779
    G01 X1.5519 Y2.6737
    G01 X1.5581 Y2.6706
    G01 X1.5648 Y2.6684
    G01 X1.5717 Y2.6673
    G01 X1.6307 Y2.6673
    G01 X1.6376 Y2.6684
    G01 X1.6443 Y2.6706
    G01 X1.6505 Y2.6737
    G01 X1.6562 Y2.6779
    G01 X1.6611 Y2.6828
    G01 X1.6652 Y2.6885
    G01 X1.6684 Y2.6947
    G01 X1.6706 Y2.7014
    G01 X1.6717 Y2.7083
    G01 X1.6717 Y2.7153
    G01 X1.6706 Y2.7222
    G01 X1.6684 Y2.7289
    G01 X1.6652 Y2.7351
    G01 X1.6611 Y2.7408
    G01 X1.6562 Y2.7458
    G01 X1.6505 Y2.7499
    G01 X1.6443 Y2.7531
    G01 X1.6376 Y2.7552
    G01 X1.6307 Y2.7563
    G01 X1.5717 Y2.7563
    G01 X1.5648 Y2.7552
    G01 X1.5581 Y2.7531
    G01 X1.5519 Y2.7499
    G01 X1.5462 Y2.7458
    G01 X1.5412 Y2.7408
    G01 X1.5400 Y2.7392
    G01 X1.1681 Y2.7392
    G01 X1.2048 Y2.7758
    G01 X1.2081 Y2.7808
    G01 X1.2104 Y2.7864
    G01 X1.2116 Y2.7923
    G01 X1.2116 Y2.9951
    G01 X1.2104 Y3.0010
    G01 X1.2081 Y3.0066
    G01 X1.2048 Y3.0116
    G01 X1.2005 Y3.0158
    G01 X1.1218 Y3.0946
    G01 X1.1168 Y3.0979
    G01 X1.1113 Y3.1002
    G01 X1.1054 Y3.1014
    G01 X0.7450 Y3.1014
    G01 X0.7391 Y3.1002
    G01 X0.7336 Y3.0979
    G01 X0.7286 Y3.0946
    G01 X0.7243 Y3.0903
    G01 X0.6062 Y2.9722
    G01 X0.6029 Y2.9672
    G01 X0.6006 Y2.9617
    G01 X0.5994 Y2.9558
    G01 X0.5994 Y2.6898
    G01 X0.1948 Y2.2852
    G01 X0.1915 Y2.2802
    G01 X0.1892 Y2.2746
    G01 X0.1880 Y2.2688
    G01 X0.1880 Y2.1824
    G01 X0.1850 Y2.1802
    G01 X0.1792 Y2.1744
    G01 X0.1745 Y2.1679
    G01 X0.1708 Y2.1606
    G01 X0.1683 Y2.1529
    G01 X0.1670 Y2.1449
    G01 X0.1670 Y2.0708
    G01 X0.1683 Y2.0628
    G01 X0.1708 Y2.0551
    G01 X0.1745 Y2.0479
    G01 X0.1792 Y2.0413
    G01 X0.1850 Y2.0356
    G01 X0.1915 Y2.0308
    G01 X0.1987 Y2.0271
    G01 X0.2064 Y2.0246
    G01 X0.2145 Y2.0234
    G01 X0.2226 Y2.0234
    G01 X0.2306 Y2.0246
    G01 X0.2383 Y2.0271
    G01 X0.2455 Y2.0308
    G01 X0.2521 Y2.0356
    G01 X0.2578 Y2.0413
    G01 X0.2626 Y2.0479
    G01 X0.2662 Y2.0551
    G01 X0.2685 Y2.0621
    G01 X0.2708 Y2.0551
    G01 X0.2745 Y2.0479
    G01 X0.2792 Y2.0413
    G01 X0.2850 Y2.0356
    G01 X0.2915 Y2.0308
    G01 X0.2987 Y2.0271
    G01 X0.3064 Y2.0246
    G01 X0.3145 Y2.0234
    G01 X0.3226 Y2.0234
    G01 X0.3306 Y2.0246
    G01 X0.3383 Y2.0271
    G01 X0.3455 Y2.0308
    G01 X0.3521 Y2.0356
    G01 X0.3578 Y2.0413
    G01 X0.3626 Y2.0479
    G01 X0.3662 Y2.0551
    G01 X0.3685 Y2.0621
    G01 X0.3708 Y2.0551
    G01 X0.3745 Y2.0479
    G01 X0.3792 Y2.0413
    G01 X0.3850 Y2.0356
    G01 X0.3915 Y2.0308
    G01 X0.3987 Y2.0271
    G01 X0.4064 Y2.0246
    G01 X0.4145 Y2.0234
    G01 X0.4226 Y2.0234
    G01 X0.4306 Y2.0246
    G01 X0.4383 Y2.0271
    G01 X0.4455 Y2.0308
    G01 X0.4521 Y2.0356
    G01 X0.4578 Y2.0413
    G01 X0.4626 Y2.0479
    G01 X0.4662 Y2.0551
    G01 X0.4687 Y2.0628
    G01 X0.4700 Y2.0708
    G01 X0.4700 Y2.1162
    G01 X0.7281 Y2.3743
    G01 X0.7324 Y2.3786
    G01 X0.7357 Y2.3836
    G01 X0.7380 Y2.3891
    G01 X0.7392 Y2.3950
    G01 X0.7392 Y2.9008
    G01 X0.8394 Y3.0010
    G01 X0.8929 Y3.0010
    G01 X0.9435 Y2.9504
    G01 X0.9303 Y2.9372
    G01 X0.9033 Y2.9642
    G01 X0.8573 Y2.9642
    G01 X0.8248 Y2.9317
    G01 X0.8248 Y2.8963
    G01 X0.7680 Y2.8394
    G01 X0.7637 Y2.8352
    G01 X0.7604 Y2.8302
    G01 X0.7581 Y2.8246
    G01 X0.7569 Y2.8188
    G01 X0.7569 Y2.3986
    G01 X0.7581 Y2.3927
    G01 X0.7604 Y2.3871
    G01 X0.7637 Y2.3821
    G01 X0.8616 Y2.2842
    G01 X0.8616 Y2.0118
    G01 X0.8366 Y1.9868
    G01 X0.8366 Y1.9408
    G01 X0.8636 Y1.9138
    G01 X0.8366 Y1.8868
    G01 X0.8366 Y1.8408
    G01 X0.8636 Y1.8138
    G01 X0.8366 Y1.7868
    G01 X0.8366 Y1.7408
    G01 X0.8636 Y1.7138
    G01 X0.8366 Y1.6868
    G01 X0.8366 Y1.6408
    G01 X0.8636 Y1.6138
    G01 X0.8366 Y1.5868
    G01 X0.8366 Y1.5408
    G01 X0.8691 Y1.5083
    G01 X0.9151 Y1.5083
    G01 X0.9421 Y1.5353
    G01 X0.9691 Y1.5083
    G01 X1.0045 Y1.5083
    G01 X1.5873 Y0.9254
    G01 X1.5916 Y0.9212
    G01 X1.5966 Y0.9178
    G01 X1.6021 Y0.9155
    G01 X1.6080 Y0.9144
    G01 X1.8140 Y0.9144
    G01 X1.8199 Y0.9155
    G01 X1.8255 Y0.9178
    G01 X1.8305 Y0.9212
    G01 X1.9906 Y1.0813
    G01 X2.1427 Y1.0813
    G01 X2.1462 Y1.0779
    G01 X2.1519 Y1.0737
    G01 X2.1581 Y1.0706
    G01 X2.1648 Y1.0684
    G01 X2.1717 Y1.0673
    G01 X2.2307 Y1.0673
    G01 X2.2376 Y1.0684
    G01 X2.2443 Y1.0706
    G01 X2.2505 Y1.0737
    G01 X2.2562 Y1.0779
    G01 X2.2611 Y1.0828
    G01 X2.2652 Y1.0885
    G01 X2.2684 Y1.0947
    G01 X2.2706 Y1.1014
    G01 X2.2717 Y1.1083
    G01 X2.2717 Y1.1153
    G01 X2.2706 Y1.1222
    G01 X2.2684 Y1.1289
    G01 X2.2652 Y1.1351
    G01 X2.2611 Y1.1408
    G01 X2.2562 Y1.1458
    G01 X2.2505 Y1.1499
    G01 X2.2443 Y1.1531
    G01 X2.2376 Y1.1552
    G01 X2.2307 Y1.1563
    G01 X2.1717 Y1.1563
    G01 X2.1648 Y1.1552
    G01 X2.1581 Y1.1531
    G01 X2.1519 Y1.1499
    G01 X2.1462 Y1.1458
    G01 X2.1427 Y1.1423
    G01 X1.9749 Y1.1423
    G01 X1.9691 Y1.1411
    G01 X1.9635 Y1.1388
    G01 X1.9585 Y1.1355
    G01 X1.9543 Y1.1313
    G01 X1.7984 Y0.9754
    G01 X1.6237 Y0.9754
    G01 X1.0476 Y1.5514
    G01 X1.0476 Y1.5868
    G01 X1.0206 Y1.6138
    G01 X1.0401 Y1.6333
    G01 X1.1366 Y1.6333
    G01 X1.5363 Y1.2335
    G01 X1.5339 Y1.2289
    G01 X1.5318 Y1.2222
    G01 X1.5307 Y1.2153
    G01 X1.5307 Y1.2083
    G01 X1.5318 Y1.2014
    G01 X1.5339 Y1.1947
    G01 X1.5371 Y1.1885
    G01 X1.5412 Y1.1828
    G01 X1.5462 Y1.1779
    G01 X1.5519 Y1.1737
    G01 X1.5581 Y1.1706
    G01 X1.5648 Y1.1684
    G01 X1.5717 Y1.1673
    G01 X1.6307 Y1.1673
    G01 X1.6376 Y1.1684
    G01 X1.6443 Y1.1706
    G01 X1.6505 Y1.1737
    G01 X1.6562 Y1.1779
    G01 X1.6611 Y1.1828
    G01 X1.6652 Y1.1885
    G01 X1.6684 Y1.1947
    G01 X1.6706 Y1.2014
    G01 X1.6717 Y1.2083
    G01 X1.6717 Y1.2153
    G01 X1.6706 Y1.2222
    G01 X1.6684 Y1.2289
    G01 X1.6652 Y1.2351
    G01 X1.6611 Y1.2408
    G01 X1.6562 Y1.2458
    G01 X1.6505 Y1.2499
    G01 X1.6443 Y1.2531
    G01 X1.6376 Y1.2552
    G01 X1.6307 Y1.2563
    G01 X1.5998 Y1.2563
    G01 X1.5888 Y1.2673
    G01 X1.6307 Y1.2673
    G01 X1.6376 Y1.2684
    G01 X1.6443 Y1.2706
    G01 X1.6505 Y1.2737
    G01 X1.6562 Y1.2779
    G01 X1.6611 Y1.2828
    G01 X1.6652 Y1.2885
    G01 X1.6684 Y1.2947
    G01 X1.6706 Y1.3014
    G01 X1.6717 Y1.3083
    G01 X1.6717 Y1.3153
    G01 X1.6706 Y1.3222
    G01 X1.6684 Y1.3289
    G01 X1.6652 Y1.3351
    G01 X1.6611 Y1.3408
    G01 X1.6562 Y1.3458
    G01 X1.6505 Y1.3499
    G01 X1.6443 Y1.3531
    G01 X1.6376 Y1.3552
    G01 X1.6307 Y1.3563
    G01 X1.5717 Y1.3563
    G01 X1.5648 Y1.3552
    G01 X1.5581 Y1.3531
    G01 X1.5519 Y1.3499
    G01 X1.5462 Y1.3458
    G01 X1.5412 Y1.3408
    G01 X1.5371 Y1.3351
    G01 X1.5339 Y1.3289
    G01 X1.5323 Y1.3238
    G01 X1.1729 Y1.6832
    G01 X1.1687 Y1.6875
    G01 X1.1637 Y1.6908
    G01 X1.1581 Y1.6931
    G01 X1.1522 Y1.6943
    G01 X1.0401 Y1.6943
    G01 X1.0206 Y1.7138
    G01 X1.0401 Y1.7333
    G01 X1.2366 Y1.7333
    G01 X1.5363 Y1.4335
    G01 X1.5339 Y1.4289
    G01 X1.5318 Y1.4222
    G01 X1.5307 Y1.4153
    G01 X1.5307 Y1.4083
    G01 X1.5318 Y1.4014
    G01 X1.5339 Y1.3947
    G01 X1.5371 Y1.3885
    G01 X1.5412 Y1.3828
    G01 X1.5462 Y1.3779
    G01 X1.5519 Y1.3737
    G01 X1.5581 Y1.3706
    G01 X1.5648 Y1.3684
    G01 X1.5717 Y1.3673
    G01 X1.6307 Y1.3673
    G01 X1.6376 Y1.3684
    G01 X1.6443 Y1.3706
    G01 X1.6505 Y1.3737
    G01 X1.6562 Y1.3779
    G01 X1.6611 Y1.3828
    G01 X1.6652 Y1.3885
    G01 X1.6684 Y1.3947
    G01 X1.6706 Y1.4014
    G01 X1.6717 Y1.4083
    G01 X1.6717 Y1.4153
    G01 X1.6706 Y1.4222
    G01 X1.6684 Y1.4289
    G01 X1.6652 Y1.4351
    G01 X1.6611 Y1.4408
    G01 X1.6562 Y1.4458
    G01 X1.6505 Y1.4499
    G01 X1.6443 Y1.4531
    G01 X1.6376 Y1.4552
    G01 X1.6307 Y1.4563
    G01 X1.5998 Y1.4563
    G01 X1.5888 Y1.4673
    G01 X1.6307 Y1.4673
    G01 X1.6376 Y1.4684
    G01 X1.6443 Y1.4706
    G01 X1.6505 Y1.4737
    G01 X1.6562 Y1.4779
    G01 X1.6611 Y1.4828
    G01 X1.6652 Y1.4885
    G01 X1.6684 Y1.4947
    G01 X1.6706 Y1.5014
    G01 X1.6717 Y1.5083
    G01 X1.6717 Y1.5153
    G01 X1.6706 Y1.5222
    G01 X1.6684 Y1.5289
    G01 X1.6652 Y1.5351
    G01 X1.6611 Y1.5408
    G01 X1.6562 Y1.5458
    G01 X1.6505 Y1.5499
    G01 X1.6443 Y1.5531
    G01 X1.6376 Y1.5552
    G01 X1.6307 Y1.5563
    G01 X1.5717 Y1.5563
    G01 X1.5648 Y1.5552
    G01 X1.5581 Y1.5531
    G01 X1.5519 Y1.5499
    G01 X1.5462 Y1.5458
    G01 X1.5412 Y1.5408
    G01 X1.5371 Y1.5351
    G01 X1.5339 Y1.5289
    G01 X1.5323 Y1.5238
    G01 X1.2729 Y1.7832
    G01 X1.2687 Y1.7875
    G01 X1.2637 Y1.7908
    G01 X1.2581 Y1.7931
    G01 X1.2522 Y1.7943
    G01 X1.0401 Y1.7943
    G01 X1.0206 Y1.8138
    G01 X1.0401 Y1.8333
    G01 X1.3366 Y1.8333
    G01 X1.5363 Y1.6335
    G01 X1.5339 Y1.6289
    G01 X1.5318 Y1.6222
    G01 X1.5307 Y1.6153
    G01 X1.5307 Y1.6083
    G01 X1.5318 Y1.6014
    G01 X1.5339 Y1.5947
    G01 X1.5371 Y1.5885
    G01 X1.5412 Y1.5828
    G01 X1.5462 Y1.5779
    G01 X1.5519 Y1.5737
    G01 X1.5581 Y1.5706
    G01 X1.5648 Y1.5684
    G01 X1.5717 Y1.5673
    G01 X1.6307 Y1.5673
    G01 X1.6376 Y1.5684
    G01 X1.6443 Y1.5706
    G01 X1.6505 Y1.5737
    G01 X1.6562 Y1.5779
    G01 X1.6611 Y1.5828
    G01 X1.6652 Y1.5885
    G01 X1.6684 Y1.5947
    G01 X1.6706 Y1.6014
    G01 X1.6717 Y1.6083
    G01 X1.6717 Y1.6153
    G01 X1.6706 Y1.6222
    G01 X1.6684 Y1.6289
    G01 X1.6652 Y1.6351
    G01 X1.6611 Y1.6408
    G01 X1.6562 Y1.6458
    G01 X1.6505 Y1.6499
    G01 X1.6443 Y1.6531
    G01 X1.6376 Y1.6552
    G01 X1.6307 Y1.6563
    G01 X1.5998 Y1.6563
    G01 X1.5888 Y1.6673
    G01 X1.6307 Y1.6673
    G01 X1.6376 Y1.6684
    G01 X1.6443 Y1.6706
    G01 X1.6505 Y1.6737
    G01 X1.6562 Y1.6779
    G01 X1.6611 Y1.6828
    G01 X1.6652 Y1.6885
    G01 X1.6684 Y1.6947
    G01 X1.6706 Y1.7014
    G01 X1.6717 Y1.7083
    G01 X1.6717 Y1.7153
    G01 X1.6706 Y1.7222
    G01 X1.6684 Y1.7289
    G01 X1.6652 Y1.7351
    G01 X1.6611 Y1.7408
    G01 X1.6562 Y1.7458
    G01 X1.6505 Y1.7499
    G01 X1.6443 Y1.7531
    G01 X1.6376 Y1.7552
    G01 X1.6307 Y1.7563
    G01 X1.5717 Y1.7563
    G01 X1.5648 Y1.7552
    G01 X1.5581 Y1.7531
    G01 X1.5519 Y1.7499
    G01 X1.5462 Y1.7458
    G01 X1.5412 Y1.7408
    G01 X1.5371 Y1.7351
    G01 X1.5339 Y1.7289
    G01 X1.5323 Y1.7238
    G01 X1.3729 Y1.8832
    G01 X1.3687 Y1.8875
    G01 X1.3637 Y1.8908
    G01 X1.3581 Y1.8931
    G01 X1.3522 Y1.8943
    G01 X1.0401 Y1.8943
    G01 X1.0206 Y1.9138
    G01 X1.0476 Y1.9408
    G01 X1.0476 Y1.9761
    G01 X1.0528 Y1.9813
    G01 X1.5427 Y1.9813
    G01 X1.5462 Y1.9779
    G01 X1.5519 Y1.9737
    G01 X1.5581 Y1.9706
    G01 X1.5648 Y1.9684
    G01 X1.5717 Y1.9673
    G01 X1.6307 Y1.9673
    G01 X1.6376 Y1.9684
    G01 X1.6443 Y1.9706
    G01 X1.6505 Y1.9737
    G01 X1.6562 Y1.9779
    G01 X1.6596 Y1.9813
    G01 X1.9754 Y1.9813
    G01 X1.9813 Y1.9825
    G01 X1.9869 Y1.9848
    G01 X1.9919 Y1.9881
    G01 X2.0127 Y2.0089
    G01 X2.0301 Y2.0089
    G01 X2.0348 Y2.0102
    G01 X2.0390 Y2.0126
    G01 X2.0425 Y2.0161
    G01 X2.0449 Y2.0203
    G01 X2.0462 Y2.0250
    G01 X2.0462 Y2.0695
    G01 X2.0449 Y2.0742
    G01 X2.0425 Y2.0784
    G01 X2.0396 Y2.0813
    G01 X2.0885 Y2.0813
    G01 X2.1363 Y2.0335
    G01 X2.1339 Y2.0289
    G01 X2.1318 Y2.0222
    G01 X2.1307 Y2.0153
    G01 X2.1307 Y2.0083
    G01 X2.1318 Y2.0014
    G01 X2.1338 Y1.9951
    G01 X2.0639 Y1.9951
    G01 X2.0580 Y1.9939
    G01 X2.0525 Y1.9916
    G01 X2.0475 Y1.9883
    G01 X1.9097 Y1.8505
    G01 X1.9054 Y1.8462
    G01 X1.9021 Y1.8412
    G01 X1.8998 Y1.8357
    G01 X1.8986 Y1.8298
    G01 X1.8986 Y1.4143
    G01 X1.8998 Y1.4084
    G01 X1.9021 Y1.4029
    G01 X1.9054 Y1.3979
    G01 X2.1110 Y1.1924
    G01 X2.1152 Y1.1881
    G01 X2.1202 Y1.1848
    G01 X2.1257 Y1.1825
    G01 X2.1316 Y1.1813
    G01 X2.1427 Y1.1813
    G01 X2.1462 Y1.1779
    G01 X2.1519 Y1.1737
    G01 X2.1581 Y1.1706
    G01 X2.1648 Y1.1684
    G01 X2.1717 Y1.1673
    G01 X2.2307 Y1.1673
    G01 X2.2376 Y1.1684
    G01 X2.2443 Y1.1706
    G01 X2.2505 Y1.1737
    G01 X2.2562 Y1.1779
    G01 X2.2611 Y1.1828
    G01 X2.2652 Y1.1885
    G01 X2.2684 Y1.1947
    G01 X2.2706 Y1.2014
    G01 X2.2717 Y1.2083
    G01 X2.2717 Y1.2153
    G01 X2.2706 Y1.2222
    G01 X2.2684 Y1.2289
    G01 X2.2652 Y1.2351
    G01 X2.2611 Y1.2408
    G01 X2.2562 Y1.2458
    G01 X2.2505 Y1.2499
    G01 X2.2443 Y1.2531
    G01 X2.2376 Y1.2552
    G01 X2.2307 Y1.2563
    G01 X2.1717 Y1.2563
    G01 X2.1648 Y1.2552
    G01 X2.1581 Y1.2531
    G01 X2.1519 Y1.2499
    G01 X2.1462 Y1.2458
    G01 X2.1450 Y1.2446
    G01 X1.9596 Y1.4300
    G01 X1.9596 Y1.5012
    G01 X2.0836 Y1.3772
    G01 X2.0878 Y1.3730
    G01 X2.0928 Y1.3696
    G01 X2.0984 Y1.3673
    G01 X2.1043 Y1.3661
    G01 X2.1890 Y1.3661
    G01 X2.1948 Y1.3673
    G01 X2.2307 Y1.3673
    G01 X2.2376 Y1.3684
    G01 X2.2443 Y1.3706
    G01 X2.2505 Y1.3737
    G01 X2.2562 Y1.3779
    G01 X2.2611 Y1.3828
    G01 X2.2652 Y1.3885
    G01 X2.2684 Y1.3947
    G01 X2.2701 Y1.3998
    G01 X2.3317 Y1.3382
    G01 X2.3317 Y0.9969
    G01 X2.0798 Y0.7450
    G01 X2.0765 Y0.7400
    G01 X2.0742 Y0.7345
    G01 X2.0730 Y0.7286
    G01 X2.0730 Y0.3763
    G01 X2.0535 Y0.3568
    G01 X2.0340 Y0.3763
    G01 X2.0340 Y0.7704
    G01 X2.2095 Y0.9459
    G01 X2.2270 Y0.9459
    G01 X2.2317 Y0.9472
    G01 X2.2359 Y0.9496
    G01 X2.2393 Y0.9531
    G01 X2.2418 Y0.9573
    G01 X2.2430 Y0.9620
    G01 X2.2430 Y1.0065
    G01 X2.2418 Y1.0112
    G01 X2.2393 Y1.0154
    G01 X2.2359 Y1.0189
    G01 X2.2317 Y1.0213
    G01 X2.2270 Y1.0226
    G01 X2.1825 Y1.0226
    G01 X2.1778 Y1.0213
    G01 X2.1736 Y1.0189
    G01 X2.1701 Y1.0154
    G01 X2.1677 Y1.0112
    G01 X2.1664 Y1.0065
    G01 X2.1664 Y0.9891
    G01 X1.9798 Y0.8025
    G01 X1.9765 Y0.7975
    G01 X1.9742 Y0.7920
    G01 X1.9730 Y0.7861
    G01 X1.9730 Y0.3763
    G01 X1.9535 Y0.3568
    G01 X1.9265 Y0.3839
    G01 X1.8806 Y0.3839
    G01 X1.8480 Y0.3513
    G01 X1.8480 Y0.3054
    G01 X1.8750 Y0.2783
    G01 X1.8480 Y0.2513
    G01 X1.8480 Y0.2054
    G01 X1.8730 Y0.1804
    G01 X1.8730 Y0.1801
    G01 X1.8742 Y0.1742
    G01 X1.8765 Y0.1686
    G01 X1.8798 Y0.1636
    G01 X1.9448 Y0.0987
    G01 X1.9491 Y0.0944
    G01 X1.9541 Y0.0911
    G01 X1.9596 Y0.0888
    G01 X1.9655 Y0.0876
    G01 X2.2077 Y0.0876
    G01 X2.2136 Y0.0888
    G01 X2.2192 Y0.0911
    G01 X2.2242 Y0.0944
    G01 X2.3026 Y0.1728
    G01 X2.3265 Y0.1728
    G01 X2.3590 Y0.2054
    G01 X2.3590 Y0.2513
    G01 X2.3320 Y0.2783
    G01 X2.3590 Y0.3054
    G01 X2.3590 Y0.3513
    G01 X2.3265 Y0.3839
    G01 X2.2806 Y0.3839
    G01 X2.2535 Y0.3568
    G01 X2.2265 Y0.3839
    G01 X2.1806 Y0.3839
    G01 X2.1535 Y0.3568
    G01 X2.1340 Y0.3763
    G01 X2.1340 Y0.7130
    G01 X2.3817 Y0.9606
    G01 X2.3859 Y0.9648
    G01 X2.3892 Y0.9698
    G01 X2.3915 Y0.9754
    G01 X2.3927 Y0.9812
    G01 X2.3927 Y1.3538
    G01 X2.3915 Y1.3597
    G01 X2.3892 Y1.3652
    G01 X2.3859 Y1.3702
    G01 X2.2661 Y1.4901
    G01 X2.2684 Y1.4947
    G01 X2.2706 Y1.5014
    G01 X2.2717 Y1.5083
    G01 X2.2717 Y1.5153
    G01 X2.2706 Y1.5222
    G01 X2.2684 Y1.5289
    G01 X2.2666 Y1.5325
    G01 X2.4321 Y1.5325
    G01 X2.4380 Y1.5337
    G01 X2.4436 Y1.5360
    G01 X2.4486 Y1.5393
    G01 X2.4528 Y1.5435
    G01 X2.5607 Y1.6514
    G01 X3.1689 Y1.6514
    G01 X3.1939 Y1.6264
    G01 X3.2399 Y1.6264
    G01 X3.2669 Y1.6534
    G01 X3.2939 Y1.6264
    G01 X3.3399 Y1.6264
    G01 X3.3724 Y1.6589
    G01 X3.3724 Y1.7049
    G01 X3.3454 Y1.7319
    G01 X3.3724 Y1.7589
    G01 X3.3724 Y1.8049
    G01 X3.3454 Y1.8319
    G01 X3.3724 Y1.8589
    G01 X3.3724 Y1.9049
    G01 X3.3454 Y1.9319
    G01 X3.3724 Y1.9589
    G01 X3.3724 Y2.0049
    G01 X3.3454 Y2.0319
    G01 X3.3724 Y2.0589
    G01 X3.3724 Y2.1049
    G01 X3.3425 Y2.1348
    G01 X3.4519 Y2.1348
    G01 X3.5128 Y2.0740
    G01 X3.5128 Y1.1461
    G01 X3.3325 Y0.9658
    G01 X3.3297 Y0.9658
    G01 X3.1473 Y1.1482
    G01 X3.1431 Y1.1524
    G01 X3.1381 Y1.1558
    G01 X3.1325 Y1.1581
    G01 X3.1266 Y1.1592
    G01 X3.1037 Y1.1592
    G01 X3.0897 Y1.1732
    G01 X3.0528 Y1.1732
    G01 X3.0268 Y1.1472
    G01 X3.0268 Y1.1103
    G01 X3.0528 Y1.0842
    G01 X3.0897 Y1.0842
    G01 X3.1037 Y1.0982
    G01 X3.1110 Y1.0982
    G01 X3.2662 Y0.9430
    G01 X3.2639 Y0.9383
    G01 X3.2617 Y0.9317
    G01 X3.2606 Y0.9248
    G01 X3.2606 Y0.9178
    G01 X3.2617 Y0.9108
    G01 X3.2639 Y0.9042
    G01 X3.2670 Y0.8979
    G01 X3.2712 Y0.8923
    G01 X3.2761 Y0.8873
    G01 X3.2818 Y0.8832
    G01 X3.2880 Y0.8800
    G01 X3.2947 Y0.8779
    G01 X3.3016 Y0.8768
    G01 X3.3606 Y0.8768
    G01 X3.3675 Y0.8779
    G01 X3.3742 Y0.8800
    G01 X3.3804 Y0.8832
    G01 X3.3861 Y0.8873
    G01 X3.3895 Y0.8908
    G01 X3.6011 Y0.8908
    G01 X3.7471 Y0.7448
    G01 X3.7458 Y0.7431
    G01 X3.7424 Y0.7363
    G01 X3.7400 Y0.7291
    G01 X3.7388 Y0.7215
    G01 X3.7388 Y0.7139
    G01 X3.7400 Y0.7064
    G01 X3.7424 Y0.6991
    G01 X3.7458 Y0.6923
    G01 X3.7503 Y0.6861
    G01 X3.7557 Y0.6807
    G01 X3.7619 Y0.6762
    G01 X3.7687 Y0.6728
    G01 X3.7760 Y0.6704
    G01 X3.7835 Y0.6692
    G01 X3.7868 Y0.6692
    G01 X3.7868 Y0.6662
    G01 X3.7835 Y0.6662
    G01 X3.7760 Y0.6650
    G01 X3.7687 Y0.6627
    G01 X3.7619 Y0.6592
    G01 X3.7557 Y0.6547
    G01 X3.7503 Y0.6493
    G01 X3.7458 Y0.6431
    G01 X3.7424 Y0.6363
    G01 X3.7400 Y0.6291
    G01 X3.7388 Y0.6215
    G01 X3.7388 Y0.6139
    G01 X3.7400 Y0.6064
    G01 X3.7424 Y0.5991
    G01 X3.7458 Y0.5923
    G01 X3.7503 Y0.5861
    G01 X3.7557 Y0.5807
    G01 X3.7619 Y0.5762
    G01 X3.7687 Y0.5728
    G01 X3.7760 Y0.5704
    G01 X3.7835 Y0.5692
    G01 X3.7868 Y0.5692
    G01 X3.7868 Y0.5662
    G01 X3.7835 Y0.5662
    G01 X3.7760 Y0.5650
    G01 X3.7687 Y0.5627
    G01 X3.7619 Y0.5592
    G01 X3.7557 Y0.5547
    G01 X3.7503 Y0.5493
    G01 X3.7495 Y0.5482
    G01 X3.6261 Y0.5482
    G01 X3.6202 Y0.5470
    G01 X3.6147 Y0.5447
    G01 X3.6097 Y0.5414
    G01 X3.3906 Y0.3224
    G01 X3.3905 Y0.3224
    G01 X3.3814 Y0.3239
    G01 X3.3722 Y0.3239
    G01 X3.3631 Y0.3224
    G01 X3.3543 Y0.3196
    G01 X3.3461 Y0.3154
    G01 X3.3387 Y0.3100
    G01 X3.3321 Y0.3035
    G01 X3.3267 Y0.2960
    G01 X3.3226 Y0.2878
    G01 X3.3197 Y0.2791
    G01 X3.3183 Y0.2700
    G01 X3.3183 Y0.2607
    G01 X3.3197 Y0.2517
    G01 X3.3226 Y0.2429
    G01 X3.3267 Y0.2347
    G01 X3.3321 Y0.2272
    G01 X3.3387 Y0.2207
    G01 X3.3461 Y0.2153
    G01 X3.3543 Y0.2111
    G01 X3.3631 Y0.2083
    G01 X3.3722 Y0.2068
    G01 X3.3814 Y0.2068
    G01 X3.3905 Y0.2083
    G01 X3.3992 Y0.2111
    G01 X3.4074 Y0.2153
    G01 X3.4149 Y0.2207
    G01 X3.4214 Y0.2272
    G01 X3.4268 Y0.2347
    G01 X3.4310 Y0.2429
    G01 X3.4338 Y0.2517
    G01 X3.4353 Y0.2607
    G01 X3.4353 Y0.2700
    G01 X3.4338 Y0.2791
    G01 X3.4338 Y0.2792
    G01 X3.6418 Y0.4872
    G01 X3.7495 Y0.4872
    G01 X3.7503 Y0.4861
    G01 X3.7557 Y0.4807
    G01 X3.7619 Y0.4762
    G01 X3.7687 Y0.4728
    G01 X3.7760 Y0.4704
    G01 X3.7835 Y0.4692
    G01 X3.8511 Y0.4692
    G01 X3.8587 Y0.4704
    G01 X3.8659 Y0.4728
    G01 X3.8727 Y0.4762
    G01 X3.8789 Y0.4807
    G01 X3.8843 Y0.4861
    G01 X3.8888 Y0.4923
    G01 X3.8923 Y0.4991
    G01 X3.8946 Y0.5064
    G01 X3.8958 Y0.5139
    G01 X3.8958 Y0.5215
    G01 X3.8946 Y0.5291
    G01 X3.8923 Y0.5363
    G01 X3.8888 Y0.5431
    G01 X3.8843 Y0.5493
    G01 X3.8789 Y0.5547
    G01 X3.8727 Y0.5592
    G01 X3.8659 Y0.5627
    G01 X3.8587 Y0.5650
    G01 X3.8511 Y0.5662
    G01 X3.8478 Y0.5662
    G01 X3.8478 Y0.5692
    G01 X3.8511 Y0.5692
    G01 X3.8587 Y0.5704
    G01 X3.8659 Y0.5728
    G01 X3.8727 Y0.5762
    G01 X3.8789 Y0.5807
    G01 X3.8843 Y0.5861
    G01 X3.8888 Y0.5923
    G01 X3.8923 Y0.5991
    G01 X3.8946 Y0.6064
    G01 X3.8958 Y0.6139
    G01 X3.8958 Y0.6215
    G01 X3.8946 Y0.6291
    G01 X3.8923 Y0.6363
    G01 X3.8888 Y0.6431
    G01 X3.8843 Y0.6493
    G01 X3.8789 Y0.6547
    G01 X3.8727 Y0.6592
    G01 X3.8659 Y0.6627
    G01 X3.8587 Y0.6650
    G01 X3.8511 Y0.6662
    G01 X3.8478 Y0.6662
    G01 X3.8478 Y0.6692
    G01 X3.8511 Y0.6692
    G01 X3.8587 Y0.6704
    G01 X3.8659 Y0.6728
    G01 X3.8727 Y0.6762
    G01 X3.8789 Y0.6807
    G01 X3.8843 Y0.6861
    G01 X3.8888 Y0.6923
    G01 X3.8923 Y0.6991
    G01 X3.8946 Y0.7064
    G01 X3.8958 Y0.7139
    G01 X3.8958 Y0.7215
    G01 X3.8946 Y0.7291
    G01 X3.8923 Y0.7363
    G01 X3.8888 Y0.7431
    G01 X3.8843 Y0.7493
    G01 X3.8789 Y0.7547
    G01 X3.8727 Y0.7592
    G01 X3.8659 Y0.7627
    G01 X3.8587 Y0.7650
    G01 X3.8511 Y0.7662
    G01 X3.8120 Y0.7662
    G01 X3.6375 Y0.9407
    G01 X3.6332 Y0.9450
    G01 X3.6282 Y0.9483
    G01 X3.6227 Y0.9506
    G01 X3.6168 Y0.9518
    G01 X3.4047 Y0.9518
    G01 X3.5670 Y1.1140
    G01 X3.5703 Y1.1190
    G01 X3.5726 Y1.1246
    G01 X3.5738 Y1.1305
    G01 X3.5738 Y2.0896
    G01 X3.5726 Y2.0955
    G01 X3.5703 Y2.1011
    G01 X3.5670 Y2.1061
    G01 X3.5628 Y2.1103
    G01 X3.4883 Y2.1848
    G01 X3.4840 Y2.1890
    G01 X3.4790 Y2.1924
    G01 X3.4735 Y2.1947
    G01 X3.4676 Y2.1959
    G01 X3.2974 Y2.1959
    G01 X3.2915 Y2.1947
    G01 X3.2859 Y2.1924
    G01 X3.2809 Y2.1890
    G01 X3.2767 Y2.1848
    G01 X3.2293 Y2.1374
    G01 X3.2046 Y2.1374
    G01 X2.9833 Y2.3587
    G01 X2.9833 Y2.7826
    G01 X3.0788 Y2.8782
    G01 X3.1414 Y2.8782
    G01 X3.1609 Y2.8587
    G01 X3.1339 Y2.8317
    G01 X3.1339 Y2.7857
    G01 X3.1609 Y2.7587
    G01 X3.1339 Y2.7317
    G01 X3.1339 Y2.6857
    G01 X3.1609 Y2.6587
    G01 X3.1339 Y2.6317
    G01 X3.1339 Y2.5857
    G01 X3.1609 Y2.5587
    G01 X3.1339 Y2.5317
    G01 X3.1339 Y2.4857
    G01 X3.1664 Y2.4532
    G01 X3.2124 Y2.4532
    G01 X3.2394 Y2.4802
    G01 X3.2664 Y2.4532
    G01 X3.3124 Y2.4532
    G01 X3.3449 Y2.4857
    G01 X3.3449 Y2.5317
    G01 X3.3179 Y2.5587
    G01 X3.3449 Y2.5857
    G01 X3.3449 Y2.6317
    G01 X3.3179 Y2.6587
    G01 X3.3449 Y2.6857
    G01 X3.3449 Y2.7112
    G01 X3.4840 Y2.8503
    G01 X3.4883 Y2.8546
    G01 X3.4916 Y2.8596
    G01 X3.4939 Y2.8651
    G01 X3.4951 Y2.8710
    G01 X3.4951 Y2.9951
    G01 X3.4939 Y3.0010
    G01 X3.4916 Y3.0066
    G01 X3.4883 Y3.0116
    G01 X3.4095 Y3.0903
    G01 X3.4053 Y3.0946
    G01 X3.4003 Y3.0979
    G01 X3.3947 Y3.1002
    G01 X3.3888 Y3.1014
    G01 X2.1230 Y3.1014
    G01 X2.1171 Y3.1002
    G01 X2.1115 Y3.0979
    G01 X2.1065 Y3.0946
    G01 X1.9884 Y2.9765
    G01 X1.9842 Y2.9722
    G01 X1.9808 Y2.9672
    G01 X1.9785 Y2.9617
    G01 X1.9774 Y2.9558
    G01 X1.9774 Y2.8316
    G01 X1.9785 Y2.8257
    G01 X1.9808 Y2.8202
    G01 X1.9842 Y2.8152
    G01 X2.1070 Y2.6924
    G01 X2.1113 Y2.6881
    G01 X2.1163 Y2.6848
    G01 X2.1218 Y2.6825
    G01 X2.1277 Y2.6813
    G01 X2.1427 Y2.6813
    G01 X2.1462 Y2.6779
    G01 X2.1519 Y2.6737
    G01 X2.1581 Y2.6706
    G01 X2.1648 Y2.6684
    G01 X2.1717 Y2.6673
    G01 X2.2307 Y2.6673
    G01 X2.2376 Y2.6684
    G01 X2.2443 Y2.6706
    G01 X2.2505 Y2.6737
    G01 X2.2562 Y2.6779
    G01 X2.2611 Y2.6828
    G01 X2.2652 Y2.6885
    G01 X2.2684 Y2.6947
    G01 X2.2706 Y2.7014
    G01 X2.2717 Y2.7083
    G01 X2.2717 Y2.7153
    G01 X2.2706 Y2.7222
    G01 X2.2684 Y2.7289
    G01 X2.2652 Y2.7351
    G01 X2.2611 Y2.7408
    G01 X2.2562 Y2.7458
    G01 X2.2505 Y2.7499
    G01 X2.2443 Y2.7531
    G01 X2.2376 Y2.7552
    G01 X2.2307 Y2.7563
    G00 Z0.0787
    G00 X2.2307 Y2.6563
    G01 Z-0.0039 F5.91
    G01 X2.1717 Y2.6563 F7.87
    G01 X2.1648 Y2.6552
    G01 X2.1581 Y2.6531
    G01 X2.1519 Y2.6499
    G01 X2.1462 Y2.6458
    G01 X2.1412 Y2.6408
    G01 X2.1371 Y2.6351
    G01 X2.1339 Y2.6289
    G01 X2.1318 Y2.6222
    G01 X2.1307 Y2.6153
    G01 X2.1307 Y2.6083
    G01 X2.1318 Y2.6014
    G01 X2.1339 Y2.5947
    G01 X2.1371 Y2.5885
    G01 X2.1412 Y2.5828
    G01 X2.1462 Y2.5779
    G01 X2.1519 Y2.5737
    G01 X2.1581 Y2.5706
    G01 X2.1648 Y2.5684
    G01 X2.1717 Y2.5673
    G01 X2.2307 Y2.5673
    G01 X2.2376 Y2.5684
    G01 X2.2443 Y2.5706
    G01 X2.2505 Y2.5737
    G01 X2.2562 Y2.5779
    G01 X2.2611 Y2.5828
    G01 X2.2652 Y2.5885
    G01 X2.2684 Y2.5947
    G01 X2.2706 Y2.6014
    G01 X2.2717 Y2.6083
    G01 X2.2717 Y2.6153
    G01 X2.2706 Y2.6222
    G01 X2.2684 Y2.6289
    G01 X2.2652 Y2.6351
    G01 X2.2611 Y2.6408
    G01 X2.2562 Y2.6458
    G01 X2.2505 Y2.6499
    G01 X2.2443 Y2.6531
    G01 X2.2376 Y2.6552
    G01 X2.2307 Y2.6563
    G00 Z0.0787
    G00 X2.2307 Y2.5563
    G01 Z-0.0039 F5.91
    G01 X2.1717 Y2.5563 F7.87
    G01 X2.1648 Y2.5552
    G01 X2.1581 Y2.5531
    G01 X2.1519 Y2.5499
    G01 X2.1462 Y2.5458
    G01 X2.1412 Y2.5408
    G01 X2.1371 Y2.5351
    G01 X2.1339 Y2.5289
    G01 X2.1318 Y2.5222
    G01 X2.1307 Y2.5153
    G01 X2.1307 Y2.5083
    G01 X2.1318 Y2.5014
    G01 X2.1339 Y2.4947
    G01 X2.1371 Y2.4885
    G01 X2.1412 Y2.4828
    G01 X2.1462 Y2.4779
    G01 X2.1519 Y2.4737
    G01 X2.1581 Y2.4706
    G01 X2.1648 Y2.4684
    G01 X2.1717 Y2.4673
    G01 X2.2307 Y2.4673
    G01 X2.2376 Y2.4684
    G01 X2.2443 Y2.4706
    G01 X2.2505 Y2.4737
    G01 X2.2562 Y2.4779
    G01 X2.2611 Y2.4828
    G01 X2.2652 Y2.4885
    G01 X2.2684 Y2.4947
    G01 X2.2706 Y2.5014
    G01 X2.2717 Y2.5083
    G01 X2.2717 Y2.5153
    G01 X2.2706 Y2.5222
    G01 X2.2684 Y2.5289
    G01 X2.2652 Y2.5351
    G01 X2.2611 Y2.5408
    G01 X2.2562 Y2.5458
    G01 X2.2505 Y2.5499
    G01 X2.2443 Y2.5531
    G01 X2.2376 Y2.5552
    G01 X2.2307 Y2.5563
    G00 Z0.0787
    G00 X2.2307 Y2.4563
    G01 Z-0.0039 F5.91
    G01 X2.1717 Y2.4563 F7.87
    G01 X2.1648 Y2.4552
    G01 X2.1581 Y2.4531
    G01 X2.1519 Y2.4499
    G01 X2.1462 Y2.4458
    G01 X2.1412 Y2.4408
    G01 X2.1371 Y2.4351
    G01 X2.1339 Y2.4289
    G01 X2.1318 Y2.4222
    G01 X2.1307 Y2.4153
    G01 X2.1307 Y2.4083
    G01 X2.1318 Y2.4014
    G01 X2.1339 Y2.3947
    G01 X2.1371 Y2.3885
    G01 X2.1412 Y2.3828
    G01 X2.1462 Y2.3779
    G01 X2.1519 Y2.3737
    G01 X2.1581 Y2.3706
    G01 X2.1648 Y2.3684
    G01 X2.1717 Y2.3673
    G01 X2.2307 Y2.3673
    G01 X2.2376 Y2.3684
    G01 X2.2443 Y2.3706
    G01 X2.2505 Y2.3737
    G01 X2.2562 Y2.3779
    G01 X2.2611 Y2.3828
    G01 X2.2652 Y2.3885
    G01 X2.2684 Y2.3947
    G01 X2.2706 Y2.4014
    G01 X2.2717 Y2.4083
    G01 X2.2717 Y2.4153
    G01 X2.2706 Y2.4222
    G01 X2.2684 Y2.4289
    G01 X2.2652 Y2.4351
    G01 X2.2611 Y2.4408
    G01 X2.2562 Y2.4458
    G01 X2.2505 Y2.4499
    G01 X2.2443 Y2.4531
    G01 X2.2376 Y2.4552
    G01 X2.2307 Y2.4563
    G00 Z0.0787
    G00 X2.2307 Y2.3563
    G01 Z-0.0039 F5.91
    G01 X2.1717 Y2.3563 F7.87
    G01 X2.1648 Y2.3552
    G01 X2.1581 Y2.3531
    G01 X2.1519 Y2.3499
    G01 X2.1462 Y2.3458
    G01 X2.1412 Y2.3408
    G01 X2.1371 Y2.3351
    G01 X2.1339 Y2.3289
    G01 X2.1318 Y2.3222
    G01 X2.1307 Y2.3153
    G01 X2.1307 Y2.3083
    G01 X2.1318 Y2.3014
    G01 X2.1339 Y2.2947
    G01 X2.1371 Y2.2885
    G01 X2.1412 Y2.2828
    G01 X2.1462 Y2.2779
    G01 X2.1519 Y2.2737
    G01 X2.1581 Y2.2706
    G01 X2.1648 Y2.2684
    G01 X2.1717 Y2.2673
    G01 X2.2307 Y2.2673
    G01 X2.2376 Y2.2684
    G01 X2.2443 Y2.2706
    G01 X2.2505 Y2.2737
    G01 X2.2562 Y2.2779
    G01 X2.2611 Y2.2828
    G01 X2.2652 Y2.2885
    G01 X2.2684 Y2.2947
    G01 X2.2706 Y2.3014
    G01 X2.2717 Y2.3083
    G01 X2.2717 Y2.3153
    G01 X2.2706 Y2.3222
    G01 X2.2684 Y2.3289
    G01 X2.2652 Y2.3351
    G01 X2.2611 Y2.3408
    G01 X2.2562 Y2.3458
    G01 X2.2505 Y2.3499
    G01 X2.2443 Y2.3531
    G01 X2.2376 Y2.3552
    G01 X2.2307 Y2.3563
    G00 Z0.0787
    G00 X2.2307 Y2.2563
    G01 Z-0.0039 F5.91
    G01 X2.1717 Y2.2563 F7.87
    G01 X2.1648 Y2.2552
    G01 X2.1581 Y2.2531
    G01 X2.1519 Y2.2499
    G01 X2.1462 Y2.2458
    G01 X2.1412 Y2.2408
    G01 X2.1371 Y2.2351
    G01 X2.1339 Y2.2289
    G01 X2.1318 Y2.2222
    G01 X2.1307 Y2.2153
    G01 X2.1307 Y2.2083
    G01 X2.1318 Y2.2014
    G01 X2.1339 Y2.1947
    G01 X2.1371 Y2.1885
    G01 X2.1412 Y2.1828
    G01 X2.1462 Y2.1779
    G01 X2.1519 Y2.1737
    G01 X2.1581 Y2.1706
    G01 X2.1648 Y2.1684
    G01 X2.1717 Y2.1673
    G01 X2.2307 Y2.1673
    G01 X2.2376 Y2.1684
    G01 X2.2443 Y2.1706
    G01 X2.2505 Y2.1737
    G01 X2.2562 Y2.1779
    G01 X2.2611 Y2.1828
    G01 X2.2652 Y2.1885
    G01 X2.2684 Y2.1947
    G01 X2.2706 Y2.2014
    G01 X2.2717 Y2.2083
    G01 X2.2717 Y2.2153
    G01 X2.2706 Y2.2222
    G01 X2.2684 Y2.2289
    G01 X2.2652 Y2.2351
    G01 X2.2611 Y2.2408
    G01 X2.2562 Y2.2458
    G01 X2.2505 Y2.2499
    G01 X2.2443 Y2.2531
    G01 X2.2376 Y2.2552
    G01 X2.2307 Y2.2563
    G00 Z0.0787
    G00 X2.2307 Y1.3563
    G01 Z-0.0039 F5.91
    G01 X2.1717 Y1.3563 F7.87
    G01 X2.1648 Y1.3552
    G01 X2.1581 Y1.3531
    G01 X2.1519 Y1.3499
    G01 X2.1462 Y1.3458
    G01 X2.1412 Y1.3408
    G01 X2.1371 Y1.3351
    G01 X2.1339 Y1.3289
    G01 X2.1318 Y1.3222
    G01 X2.1307 Y1.3153
    G01 X2.1307 Y1.3083
    G01 X2.1318 Y1.3014
    G01 X2.1339 Y1.2947
    G01 X2.1371 Y1.2885
    G01 X2.1412 Y1.2828
    G01 X2.1462 Y1.2779
    G01 X2.1519 Y1.2737
    G01 X2.1581 Y1.2706
    G01 X2.1648 Y1.2684
    G01 X2.1717 Y1.2673
    G01 X2.2307 Y1.2673
    G01 X2.2376 Y1.2684
    G01 X2.2443 Y1.2706
    G01 X2.2505 Y1.2737
    G01 X2.2562 Y1.2779
    G01 X2.2611 Y1.2828
    G01 X2.2652 Y1.2885
    G01 X2.2684 Y1.2947
    G01 X2.2706 Y1.3014
    G01 X2.2717 Y1.3083
    G01 X2.2717 Y1.3153
    G01 X2.2706 Y1.3222
    G01 X2.2684 Y1.3289
    G01 X2.2652 Y1.3351
    G01 X2.2611 Y1.3408
    G01 X2.2562 Y1.3458
    G01 X2.2505 Y1.3499
    G01 X2.2443 Y1.3531
    G01 X2.2376 Y1.3552
    G01 X2.2307 Y1.3563
    G00 Z0.0787
    G00 X1.6307 Y1.1563
    G01 Z-0.0039 F5.91
    G01 X1.5717 Y1.1563 F7.87
    G01 X1.5648 Y1.1552
    G01 X1.5581 Y1.1531
    G01 X1.5519 Y1.1499
    G01 X1.5462 Y1.1458
    G01 X1.5412 Y1.1408
    G01 X1.5371 Y1.1351
    G01 X1.5339 Y1.1289
    G01 X1.5318 Y1.1222
    G01 X1.5307 Y1.1153
    G01 X1.5307 Y1.1083
    G01 X1.5318 Y1.1014
    G01 X1.5339 Y1.0947
    G01 X1.5371 Y1.0885
    G01 X1.5412 Y1.0828
    G01 X1.5462 Y1.0779
    G01 X1.5519 Y1.0737
    G01 X1.5581 Y1.0706
    G01 X1.5648 Y1.0684
    G01 X1.5717 Y1.0673
    G01 X1.6307 Y1.0673
    G01 X1.6376 Y1.0684
    G01 X1.6443 Y1.0706
    G01 X1.6505 Y1.0737
    G01 X1.6562 Y1.0779
    G01 X1.6611 Y1.0828
    G01 X1.6652 Y1.0885
    G01 X1.6684 Y1.0947
    G01 X1.6706 Y1.1014
    G01 X1.6717 Y1.1083
    G01 X1.6717 Y1.1153
    G01 X1.6706 Y1.1222
    G01 X1.6684 Y1.1289
    G01 X1.6652 Y1.1351
    G01 X1.6611 Y1.1408
    G01 X1.6562 Y1.1458
    G01 X1.6505 Y1.1499
    G01 X1.6443 Y1.1531
    G01 X1.6376 Y1.1552
    G01 X1.6307 Y1.1563
    G00 Z0.0787
    G00 X1.6307 Y1.8563
    G01 Z-0.0039 F5.91
    G01 X1.5717 Y1.8563 F7.87
    G01 X1.5648 Y1.8552
    G01 X1.5581 Y1.8531
    G01 X1.5519 Y1.8499
    G01 X1.5462 Y1.8458
    G01 X1.5412 Y1.8408
    G01 X1.5371 Y1.8351
    G01 X1.5339 Y1.8289
    G01 X1.5318 Y1.8222
    G01 X1.5307 Y1.8153
    G01 X1.5307 Y1.8083
    G01 X1.5318 Y1.8014
    G01 X1.5339 Y1.7947
    G01 X1.5371 Y1.7885
    G01 X1.5412 Y1.7828
    G01 X1.5462 Y1.7779
    G01 X1.5519 Y1.7737
    G01 X1.5581 Y1.7706
    G01 X1.5648 Y1.7684
    G01 X1.5717 Y1.7673
    G01 X1.6307 Y1.7673
    G01 X1.6376 Y1.7684
    G01 X1.6443 Y1.7706
    G01 X1.6505 Y1.7737
    G01 X1.6562 Y1.7779
    G01 X1.6611 Y1.7828
    G01 X1.6652 Y1.7885
    G01 X1.6684 Y1.7947
    G01 X1.6706 Y1.8014
    G01 X1.6717 Y1.8083
    G01 X1.6717 Y1.8153
    G01 X1.6706 Y1.8222
    G01 X1.6684 Y1.8289
    G01 X1.6652 Y1.8351
    G01 X1.6611 Y1.8408
    G01 X1.6562 Y1.8458
    G01 X1.6505 Y1.8499
    G01 X1.6443 Y1.8531
    G01 X1.6376 Y1.8552
    G01 X1.6307 Y1.8563
    G00 Z0.0787
    G00 X1.6307 Y1.9563
    G01 Z-0.0039 F5.91
    G01 X1.5717 Y1.9563 F7.87
    G01 X1.5648 Y1.9552
    G01 X1.5581 Y1.9531
    G01 X1.5519 Y1.9499
    G01 X1.5462 Y1.9458
    G01 X1.5412 Y1.9408
    G01 X1.5371 Y1.9351
    G01 X1.5339 Y1.9289
    G01 X1.5318 Y1.9222
    G01 X1.5307 Y1.9153
    G01 X1.5307 Y1.9083
    G01 X1.5318 Y1.9014
    G01 X1.5339 Y1.8947
    G01 X1.5371 Y1.8885
    G01 X1.5412 Y1.8828
    G01 X1.5462 Y1.8779
    G01 X1.5519 Y1.8737
    G01 X1.5581 Y1.8706
    G01 X1.5648 Y1.8684
    G01 X1.5717 Y1.8673
    G01 X1.6307 Y1.8673
    G01 X1.6376 Y1.8684
    G01 X1.6443 Y1.8706
    G01 X1.6505 Y1.8737
    G01 X1.6562 Y1.8779
    G01 X1.6611 Y1.8828
    G01 X1.6652 Y1.8885
    G01 X1.6684 Y1.8947
    G01 X1.6706 Y1.9014
    G01 X1.6717 Y1.9083
    G01 X1.6717 Y1.9153
    G01 X1.6706 Y1.9222
    G01 X1.6684 Y1.9289
    G01 X1.6652 Y1.9351
    G01 X1.6611 Y1.9408
    G01 X1.6562 Y1.9458
    G01 X1.6505 Y1.9499
    G01 X1.6443 Y1.9531
    G01 X1.6376 Y1.9552
    G01 X1.6307 Y1.9563
    G00 Z0.0787
    G00 X1.6307 Y2.8563
    G01 Z-0.0039 F5.91
    G01 X1.5717 Y2.8563 F7.87
    G01 X1.5648 Y2.8552
    G01 X1.5581 Y2.8531
    G01 X1.5519 Y2.8499
    G01 X1.5462 Y2.8458
    G01 X1.5412 Y2.8408
    G01 X1.5371 Y2.8351
    G01 X1.5339 Y2.8289
    G01 X1.5318 Y2.8222
    G01 X1.5307 Y2.8153
    G01 X1.5307 Y2.8083
    G01 X1.5318 Y2.8014
    G01 X1.5339 Y2.7947
    G01 X1.5371 Y2.7885
    G01 X1.5412 Y2.7828
    G01 X1.5462 Y2.7779
    G01 X1.5519 Y2.7737
    G01 X1.5581 Y2.7706
    G01 X1.5648 Y2.7684
    G01 X1.5717 Y2.7673
    G01 X1.6307 Y2.7673
    G01 X1.6376 Y2.7684
    G01 X1.6443 Y2.7706
    G01 X1.6505 Y2.7737
    G01 X1.6562 Y2.7779
    G01 X1.6611 Y2.7828
    G01 X1.6652 Y2.7885
    G01 X1.6684 Y2.7947
    G01 X1.6706 Y2.8014
    G01 X1.6717 Y2.8083
    G01 X1.6717 Y2.8153
    G01 X1.6706 Y2.8222
    G01 X1.6684 Y2.8289
    G01 X1.6652 Y2.8351
    G01 X1.6611 Y2.8408
    G01 X1.6562 Y2.8458
    G01 X1.6505 Y2.8499
    G01 X1.6443 Y2.8531
    G01 X1.6376 Y2.8552
    G01 X1.6307 Y2.8563
    G00 Z0.0787
    G00 X3.7878 Y0.8444
    G01 Z-0.0039 F5.91
    G01 X3.8555 Y0.8444 F7.87
    G01 X3.8630 Y0.8456
    G01 X3.8703 Y0.8480
    G01 X3.8771 Y0.8514
    G01 X3.8833 Y0.8559
    G01 X3.8887 Y0.8613
    G01 X3.8931 Y0.8675
    G01 X3.8966 Y0.8743
    G01 X3.8990 Y0.8816
    G01 X3.9002 Y0.8891
    G01 X3.9002 Y0.8967
    G01 X3.8990 Y0.9043
    G01 X3.8966 Y0.9115
    G01 X3.8931 Y0.9183
    G01 X3.8887 Y0.9245
    G01 X3.8833 Y0.9299
    G01 X3.8771 Y0.9344
    G01 X3.8703 Y0.9379
    G01 X3.8630 Y0.9402
    G01 X3.8555 Y0.9414
    G01 X3.7878 Y0.9414
    G01 X3.7803 Y0.9402
    G01 X3.7730 Y0.9379
    G01 X3.7662 Y0.9344
    G01 X3.7601 Y0.9299
    G01 X3.7547 Y0.9245
    G01 X3.7502 Y0.9183
    G01 X3.7467 Y0.9115
    G01 X3.7443 Y0.9043
    G01 X3.7431 Y0.8967
    G01 X3.7431 Y0.8891
    G01 X3.7443 Y0.8816
    G01 X3.7467 Y0.8743
    G01 X3.7502 Y0.8675
    G01 X3.7547 Y0.8613
    G01 X3.7601 Y0.8559
    G01 X3.7662 Y0.8514
    G01 X3.7730 Y0.8480
    G01 X3.7803 Y0.8456
    G01 X3.7878 Y0.8444
    G00 Z0.0787
    G00 X3.7878 Y0.9444
    G01 Z-0.0039 F5.91
    G01 X3.8555 Y0.9444 F7.87
    G01 X3.8630 Y0.9456
    G01 X3.8703 Y0.9480
    G01 X3.8771 Y0.9514
    G01 X3.8833 Y0.9559
    G01 X3.8887 Y0.9613
    G01 X3.8931 Y0.9675
    G01 X3.8966 Y0.9743
    G01 X3.8990 Y0.9816
    G01 X3.9002 Y0.9891
    G01 X3.9002 Y0.9967
    G01 X3.8990 Y1.0043
    G01 X3.8966 Y1.0115
    G01 X3.8931 Y1.0183
    G01 X3.8887 Y1.0245
    G01 X3.8833 Y1.0299
    G01 X3.8771 Y1.0344
    G01 X3.8703 Y1.0379
    G01 X3.8630 Y1.0402
    G01 X3.8555 Y1.0414
    G01 X3.7878 Y1.0414
    G01 X3.7803 Y1.0402
    G01 X3.7730 Y1.0379
    G01 X3.7662 Y1.0344
    G01 X3.7601 Y1.0299
    G01 X3.7547 Y1.0245
    G01 X3.7502 Y1.0183
    G01 X3.7467 Y1.0115
    G01 X3.7443 Y1.0043
    G01 X3.7431 Y0.9967
    G01 X3.7431 Y0.9891
    G01 X3.7443 Y0.9816
    G01 X3.7467 Y0.9743
    G01 X3.7502 Y0.9675
    G01 X3.7547 Y0.9613
    G01 X3.7601 Y0.9559
    G01 X3.7662 Y0.9514
    G01 X3.7730 Y0.9480
    G01 X3.7803 Y0.9456
    G01 X3.7878 Y0.9444
    G00 Z0.0787
    G00 X3.7878 Y1.0444
    G01 Z-0.0039 F5.91
    G01 X3.8555 Y1.0444 F7.87
    G01 X3.8630 Y1.0456
    G01 X3.8703 Y1.0480
    G01 X3.8771 Y1.0514
    G01 X3.8833 Y1.0559
    G01 X3.8887 Y1.0613
    G01 X3.8931 Y1.0675
    G01 X3.8966 Y1.0743
    G01 X3.8990 Y1.0816
    G01 X3.9002 Y1.0891
    G01 X3.9002 Y1.0967
    G01 X3.8990 Y1.1043
    G01 X3.8966 Y1.1115
    G01 X3.8931 Y1.1183
    G01 X3.8887 Y1.1245
    G01 X3.8833 Y1.1299
    G01 X3.8771 Y1.1344
    G01 X3.8703 Y1.1379
    G01 X3.8630 Y1.1402
    G01 X3.8555 Y1.1414
    G01 X3.7878 Y1.1414
    G01 X3.7803 Y1.1402
    G01 X3.7730 Y1.1379
    G01 X3.7662 Y1.1344
    G01 X3.7601 Y1.1299
    G01 X3.7547 Y1.1245
    G01 X3.7502 Y1.1183
    G01 X3.7467 Y1.1115
    G01 X3.7443 Y1.1043
    G01 X3.7431 Y1.0967
    G01 X3.7431 Y1.0891
    G01 X3.7443 Y1.0816
    G01 X3.7467 Y1.0743
    G01 X3.7502 Y1.0675
    G01 X3.7547 Y1.0613
    G01 X3.7601 Y1.0559
    G01 X3.7662 Y1.0514
    G01 X3.7730 Y1.0480
    G01 X3.7803 Y1.0456
    G01 X3.7878 Y1.0444
    G00 Z0.0787
    G00 X1.4650 Y0.6444
    G01 Z-0.0039 F5.91
    G01 X1.5326 Y0.6444 F7.87
    G01 X1.5402 Y0.6456
    G01 X1.5474 Y0.6480
    G01 X1.5542 Y0.6514
    G01 X1.5604 Y0.6559
    G01 X1.5658 Y0.6613
    G01 X1.5703 Y0.6675
    G01 X1.5738 Y0.6743
    G01 X1.5761 Y0.6816
    G01 X1.5773 Y0.6891
    G01 X1.5773 Y0.6967
    G01 X1.5761 Y0.7043
    G01 X1.5738 Y0.7115
    G01 X1.5703 Y0.7183
    G01 X1.5658 Y0.7245
    G01 X1.5604 Y0.7299
    G01 X1.5542 Y0.7344
    G01 X1.5474 Y0.7379
    G01 X1.5402 Y0.7402
    G01 X1.5326 Y0.7414
    G01 X1.4650 Y0.7414
    G01 X1.4575 Y0.7402
    G01 X1.4502 Y0.7379
    G01 X1.4434 Y0.7344
    G01 X1.4372 Y0.7299
    G01 X1.4318 Y0.7245
    G01 X1.4273 Y0.7183
    G01 X1.4239 Y0.7115
    G01 X1.4215 Y0.7043
    G01 X1.4203 Y0.6967
    G01 X1.4203 Y0.6891
    G01 X1.4215 Y0.6816
    G01 X1.4239 Y0.6743
    G01 X1.4273 Y0.6675
    G01 X1.4318 Y0.6613
    G01 X1.4372 Y0.6559
    G01 X1.4434 Y0.6514
    G01 X1.4502 Y0.6480
    G01 X1.4575 Y0.6456
    G01 X1.4650 Y0.6444
    G00 Z0.0787
    G00 X2.2047 Y0.9843
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.0079 Y2.0472
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.8504 Y2.9646
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.3031 Y2.9646
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.8173 Y0.5177
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.8173 Y0.6177
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.8173 Y0.7177
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.5736 Y0.2654
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3768 Y0.2654
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y3.0118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y2.9118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y2.8118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y2.7118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y2.6118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y2.5118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y2.4118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y2.3118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y2.2118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y2.1118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y2.0118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y1.9118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y1.8118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y1.7118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y1.6118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y1.5118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y1.4118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y1.3118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y1.2118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.6012 Y1.1118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y1.1118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y1.2118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y1.3118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y1.4118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y1.5118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y1.6118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y1.7118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y1.8118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y1.9118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y2.0118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y2.1118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y2.2118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y2.3118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y2.4118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y2.5118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y2.6118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y2.7118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y2.8118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y2.9118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2012 Y3.0118
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.7138 Y0.6951
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.7138 Y0.6151
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.7193 Y0.2541
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.7193 Y0.3341
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.8217 Y0.8929
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.8217 Y0.9929
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.8217 Y1.0929
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.0311 Y0.9213
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.0311 Y0.8213
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.0311 Y0.7213
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.0311 Y0.6213
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3311 Y0.6213
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3311 Y0.7213
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3311 Y0.8213
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3311 Y0.9213
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.2169 Y2.0819
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3169 Y2.0819
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.2169 Y1.9819
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3169 Y1.9819
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.2169 Y1.8819
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3169 Y1.8819
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.2169 Y1.7819
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3169 Y1.7819
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.2169 Y1.6819
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3169 Y1.6819
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.8803 Y2.9087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.9803 Y2.9087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.8803 Y2.8087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.9803 Y2.8087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.8803 Y2.7087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.9803 Y2.7087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.8803 Y2.6087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.9803 Y2.6087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.8803 Y2.5087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.9803 Y2.5087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.1894 Y2.9087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.2894 Y2.9087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.1894 Y2.8087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.2894 Y2.8087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.1894 Y2.7087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.2894 Y2.7087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.1894 Y2.6087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.2894 Y2.6087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.1894 Y2.5087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.2894 Y2.5087
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.8921 Y1.9638
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.9921 Y1.9638
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.8921 Y1.8638
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.9921 Y1.8638
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.8921 Y1.7638
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.9921 Y1.7638
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.8921 Y1.6638
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.9921 Y1.6638
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.8921 Y1.5638
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.9921 Y1.5638
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.3035 Y0.3283
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.3035 Y0.2283
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2035 Y0.3283
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.2035 Y0.2283
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.1035 Y0.3283
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.1035 Y0.2283
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.0035 Y0.3283
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.0035 Y0.2283
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.9035 Y0.3283
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.9035 Y0.2283
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.2240 Y1.7091
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.2240 Y1.9059
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.2240 Y1.1303
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.2240 Y1.3272
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.6787 Y1.1689
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.6787 Y1.0689
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X2.6787 Y0.9689
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.4988 Y0.4929
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.4988 Y0.5929
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.4988 Y0.6929
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.4543 Y1.0862
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.4543 Y0.9862
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.4543 Y0.8862
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.1443 Y0.9862
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.4543 Y0.5913
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.4543 Y0.4913
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.4543 Y0.3913
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.1443 Y0.4913
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.2185 Y2.1079
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.3185 Y2.1079
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.4185 Y2.1079
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.3185 Y2.7979
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X1.3976 Y2.2181
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.9976 Y2.2181
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3461 Y1.1366
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.3461 Y1.5366
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.0713 Y1.5287
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X3.0713 Y1.1287
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.2240 Y0.5122
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 X0.2240 Y0.7091
    G01 Z-0.0039 F5.91
    G00 Z0.0787
    G00 Z0.4724
    M05
    M02
    Jun 2007
    3735
    A utility program needs to honor the various rules that can be freely used.
    I am sure it is easy to find all used parameters then create unique ones, or at least complain, and give some result.
    Not working without any feedback leads to lack of confidence.
    As for my own PCB editor, it generates parametrized items so it is very easy to tune the programs and adjust for tooling limits that may occur without the need to create new code.
    If you look closely at my routing code, it is very good at shortest path and minimal Z moves.
    Always joining closest vectors that are within a given tolerance. ... about 15% of cutter diameter is my default.
    Step through it and see how efficient it is.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Jan 2010
    2141
    Somewhat OT, but I'm wondering what tools you used to create your web site.
    Quickly scanning the page source shows that you're using Bootstrap (and I really like the Oswald font), but are you using it directly or through some kind of blogging software platform?
    Jul 2013
    13
    Your lack of confidence is understandable since it didnt work for you (at least not yet). However:
    • Had you used almost any other program, it would have worked fine and the program would have filled you with confidence
    • There are plenty of other users who are very happy and very grateful
    • I am just one guy developing this so have not got the money or the resources to put in. I have released the source code so feel free to make changes to the code
    • I could apply a quick fix as you say but to do things properly, I would like to develop a proper GCode parser which may take a while
    • I originally made this to fix my own problems with milling a PCB and subsequently released it for everyone to use. I am still certain that people can and have found it useful
    • I am currently working on some other stuff and cannot work on the program immediately however I will fix the problems
    • There are many people who are more than grateful for my fast fixing time
    • Notice the version number (0.7.7) and the price tag. FREE.
    Actually, my web design friend made a page for me. I think he did everything directly through dreamweaver or some such. However, I want to add more pages and content so im looking at various CMS tools currently.
    Jan 2010
    2141
    Quote Originally Posted by Daedelus View Post
    OK...
    If you happen to talk to your web design friend and don't mind asking, I'd be interested in finding out exactly which tool(s) he/she used.
    I am assembling a small ShapeOko router which I may use for PCB milling, and once I get it set up I will try your autoleveling software. Thanks for sharing it.
    Mar 2004
    1661
    The auto leveling feature already exists in LinuxCNC.
    LinuxCNC Documentation Wiki: ProbeKins
    Regarding the Oswald font, it's downloaded by your browser from Google Fonts. Either you declare it in your CSS or as a href in the HTML header. Daedelus page is referencing it in the HTML header:
    Code:
    href='http://fonts.googleapis.com/css?family=Oswald:700' rel='stylesheet' type='text/css'>
    I would say it's a cleaner implementation to import it in the CSS, but there is nothing wrong with it.
    Google Fonts Oswald
    Google Fonts
    Jul 2013
    13
    I did run into this page a while back but it looks very complex procedure. From the page:
    typical work flow
    • probe an area, or workpiece, repeatedly and record the probe results with (PROBEOPEN probe.txt) and (PROBECLOSE) .
    • convert this file into a triangulated correction mesh with probe2stl
    • load the correction mesh into the probekins shared memory segment with stlcorr.
    • set the enable-z-correct HAL pin to 1
    • touch off Z zero at an arbitrary point within the area covered by the probed points.
    My autoleveller:
    • load a GCode file into the GUI
    • change the probing options if you need to
    • click to generate a modified GCode file
    • open that file in LinuxCNC
    This is much easier IMHO. Plus it works on mach 3 also. I also know that one guy has successfully modified the output GCode and used it in TurboCNC
    Mar 2004
    1661
    My autoleveller:
    The guys I know who run probekins at daily basis have added a touch and go-button in the Axis GUI making all these steps with a click.
    I'm not saying one is better than the other, though.
    Jul 2013
    13
    Hi doorknob,
    My friend just replied to my earlier text message. He used the bootstrap framework as you said, then just html and CSS. So, no there was no blogging platforms involved.
    Jan 2010
    2141
    OK, thanks for the info...
    Apr 2013
    21
    Hi Daedelus,
    Just want to say I use your software, and Im very happy with it!
    Thanks for making it
    Jul 2013
    13
    No problem. Glad you find it useful
    P.S. Doorknob, I have changed the site as it was growing too big for one page and now use a CMS for content.
    www.autoleveller.co.uk
    Since a probe is so fundamental to autolevelling, I made basic probe setup guide at www.autoleveller.co.uk/cnc-probe-guide
    Jan 2010
    2141
    I'm not sure whether I captured an image of the site before you changed it.
    But no problemo...
    Feb 2013
    9
    I like the simple idea of modifying the g-code. I also really like that you wrote this in java, and that I can run it under Linux.
    When I can transition from proprietary control software to linuxcnc or mach3, I look forward to trying it.
    Thanks!
    Feb 2007
    711
    Nice program, Good idea for adapting to different programs.
    I won't get a chance to test it out, I use probekins in linuxcnc and it works great.
    Feb 2007
    1
    Hi Daedelus; Nice work,I'm very happy using it!!
  1. New Autoleveller software
    By Daedelus in forum PCB milling
    Last Post: 10-20-2013, 06:18 PM
  2. Need software advice...What software can import .JPG files?
    By pairofjacks in forum Uncategorised CAM Discussion
    Last Post: 06-01-2011, 12:18 PM
  3. MIE Solutions - Free Quoting Software Trial Software available
    By MIE Solutions in forum News Announcements
    Last Post: 01-07-2009, 05:42 PM
  4. First post in the software dept. Free cnc software?
    By runinbymdnt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-07-2007, 04:49 AM
