The larger commercial type controls (Mitsubishi, Fanuc etc) have gone with a proprietary serial interface on their encoders for some time now.
This is fine when both motor and drive is purchased and the PID loop is closed in the drive, but when trying to mix and match drives and motors, and using controllers that are capable of closing the loop external to the drive, then this is where it is useful to use the universal quadrature encoder.
Also with controllers that close the loop, non intelligent drives are capable of being used, in this case the encoder is not required by the drive itself.
Al.
Albert E.
