587,790 active members*
3,618 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori SL3 with Fanuc 3TF control (adding comments to program)
Results 1 to 7 of 7
    Apr 2010
    38
    Hello
    Is the 3tF control capable of receiving a file with comments? I have them in my program but have never been able to have them come
    over when sending the file to the machine by RS232.
    Any input would be great
    Mark
    Aug 2011
    2517
    comments are always put between brackets. e.g.
    (THIS IS A COMMENT)
    depending on what model you have exactly, the 3T doesn't have a screen and instead has a single row of 7-segment LEDS so you can't view comments in the machine, nor can you write them in a program generated at the control.
    Apr 2010
    38
    Re: Mori SL3 with Fanuc 3TF control (adding comments to program)
    Hello thanks for the reply. But I have the Fanuc 3TF with color crt do you know if it is possible? I have them in my posted file but when I download all that is in its place is a comma.
    Also are you familiar with the transmission noise that occurs when in g96 when making quick rpm changes up and down , sounds like a clacking/slapping sound. I have pulled the transmission before but nothing stands out that may be wrong. I have had the lathe four three years now and it has always been there.
    Mark Reuss
    2932
    Is your comm program possibly stripping out the comments when sending?
    Aug 2011
    2517
    just a comma? do you still see the comment brackets? i.e. (,) or just a , and no brackets?
    I have to agree it's probably something with the comm program. try using a different transfer program.
    you can get a free program here.....
    NCLink Registration | OneCNC CAD & CAM
    Apr 2010
    38
    Ok
    Thanks for your help. I will try their dnc software.
    Mark
    Mar 2013
    12
    I can upgrade 3Tf for Dnc transmit by rewriting 8 Rom on main board. If you know about Cnc and electronic I can send the all Data of 8 Rom to you. Free. My email: [email protected]. So so
  1. Adding More RAM for A Fanuc Control
    By tricky in forum Fanuc
    Last Post: 03-15-2009, 03:49 PM
  2. fanuc program comments
    By Rich 72 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-04-2007, 01:38 PM
  3. Adding comments in program for Pro NC
    By quadbob in forum PTC Pro/Manufacture
    Last Post: 04-27-2007, 09:54 AM
  4. Adding Comments to G-code Programs
    By bill south in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-20-2007, 02:51 PM
  5. Replies: 3
    Last Post: 03-19-2007, 04:27 PM
