587,791 active members*
3,086 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > I need the belt specs for 1990's Anilam Z-axis drive.
Results 1 to 3 of 3
    Apr 2013
    162
    The Z-axis cogged belt on my circa 1990 Acra knee mill, originally equipped with Anilam Crusader M control, is missing so I don't have the original to get numbers off of.
    The aluminum drive housing has the Anilam logo cast into it, so I figure any similar knee mill that has the same should use the same belt. I've already bought new belts for the X and Y axes.
    X is a 210L050 56 teeth
    Y is a 300L050 80 teeth (There is a mis-marked run of 300L050 by Gates with 84 teeth.)
    Z is shorter than the 210L050 but by how much? Tooth profile is the same as the other two.
    Mar 2011
    67
    It is a 187L050 belt. Anilam/Heidenhain P/N 67200057 if they still have it. Try ordering through MSC. They used to deal with Anilam parts.
    Mar 2011
    67
    If I remember correctly, I think it was a 187L050 belt. A 187L050 is approx 18.7 in outside circumference.
  1. Direct drive axis or belt reduction?
    By vertcnc in forum Benchtop Machines
    Last Post: 04-19-2013, 11:43 PM
  2. G0704 z axis belt drive question
    By kuyote in forum Benchtop Machines
    Last Post: 02-28-2013, 04:55 PM
  3. Drive Fundamentals : R&P vs belt for 120" router X-axis
    By tlharris in forum Linear and Rotary Motion
    Last Post: 09-11-2011, 04:43 AM
  4. Thinking about Belt Drive for X and Y axis
    By Rob37 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-30-2011, 02:45 AM
  5. Belt drive rotary axis.
    By Art Ransom in forum Linear and Rotary Motion
    Last Post: 07-27-2008, 08:42 PM
