Weakest link in performance of Anilam controller?
The fastest programmed feedrate I can achieve with my Anilam system, is 80 ipm. Machine will rapid at 200ipm. During feed moves, at the max feedrate, the machine will hesitate between moves. This does not appear to be an exact stop vs continuous issue. How can I determine if I am at the limit of the control, the servo drivers, or the servos?
The servos say 31amp, 110v. The whole servo system (minus spindle) runs off 110v 15a breaker. PC is dos based.
Thanks,
Joe
If you try to make everything idiot proof, someone will just breed a better idiot!
