587,611 active members*
3,892 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > RFQ - ti and 7075 alum cnc turned parts w/2nd mill/drill ops
Results 1 to 5 of 5
    I have some parts that I need turned, which will have secondary milling and drilling operations. The material of choice includes titanium and 7075 alum. Please be very capable and efficient, working well with these materials. Overall part sizes are around 1" OD and a few inches long. Shaft portions turned down to .197" dia. Secondary operations include tapping a few holes for m2x0.4mm.
    I'll need a few samples of each part to verify capability and quality of work prior to short run production. I've tried having these parts done with multiple shops in the past and found the shops incapable of actually doing the work. This will be an ongoing working relationship with much future work, with the right shop.
    BW
    817-805-3013
    [email protected]
    It's all about the Cool Factor!
    Billet Works Designs
    Nov 2012
    55
    I would like to quote this project for you. I have fifteen years experience working with titanium for various aerospace applications. As well as significant experience machining 7075. You can email me at [email protected]. Thanks!
    Oct 2010
    103
    email sent
    Sep 2006
    179
    If you can't find anyone let me know. I would be glad to take a look and give you a quote. I have 7axis swiss machines that, depending on the second ops, could more then likely do them in one op. Work a lot with 6AL4V with +/-.0005 tolerances.
    Feb 2011
    78
    Hello Don,
    I would like to quote on the work your needing. I am very capable of performing very close tolerance work that is correct in dimension, appearance, and surface finish.
    Please email drawings and I'll get back with you asap. [email protected]
    Thanks,
    Blake Augustine
    Augustine Machine & Design LLC
    Louisville KY
  1. RFQ two turned alum parts
    By rdoty in forum RFQ (Request for Quote)
    Last Post: 02-07-2013, 10:08 PM
  2. Using 7075 or 2024 alum in place of 1018 steel?
    By zaebis in forum MetalWork Discussion
    Last Post: 07-15-2012, 05:14 PM
  3. Where to buy parts Jet JMD 18 drill/mill?
    By jGEE in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2009, 02:28 AM
  4. Turned parts on a mill
    By cncwhiz in forum Uncategorised MetalWorking Machines
    Last Post: 08-30-2009, 04:34 AM
  5. RFQ: Alum. CNC Mill/Lathe parts Canada please.
    By hardyn in forum Employment Opportunity
    Last Post: 03-26-2007, 04:33 PM
