587,167 active members*
3,439 visitors online*
Results 1 to 3 of 3
    May 2013
    99
    Mach 3 Spindle Issue
    When running Mach 3 the spindle doesn't want to work. But the manual controls for moving different Axis works correctly. When Mach 3 isn't running I can power on the spindle manually, but when Mach 3 is working the spindle doesn't want to work.
    Apr 2003
    540
    There's a lot of questions unanswered that make it pretty hard to determine your problem. Was it working before? Or, is this a new build than you're trying to make it work? Is Mach 3 configured correctly (ports/pins)? What controller and or breakout board? Does it have a built in SSR to control the spindle? Are you using a VFD or other means to control the speed or just simple on/off?
    May 2013
    99
    The machine is a simple 3040 desktop. The spindle was working before.
  1. G540 / Mach 3 issue (PWM weirdness for spindle control)
    By benha in forum Machines running Mach Software
    Last Post: 11-05-2014, 12:01 AM
  2. Cambam issue or Mach 3 Issue??
    By tracyranson in forum CamBam
    Last Post: 07-11-2011, 04:03 PM
  3. Mach 3 homing issue.
    By evo4wrx in forum CNC Machine Related Electronics
    Last Post: 07-10-2010, 03:04 PM
  4. MACH 3 FREEZE ISSUE XP pro 02
    By carbidecraters in forum Mach Software (ArtSoft software)
    Last Post: 02-25-2010, 07:49 PM
  5. Mach issue with my mill
    By Rich05 in forum Mach Software (ArtSoft software)
    Last Post: 12-01-2008, 12:00 AM
