587,923 active members*
3,393 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazak FH6800 Fusion640 not start after reinstall a new battery.
Results 1 to 7 of 7
    Jun 2013
    3
    Dear Viewers, friends,
    I have a mazak FH6800 last time it is stand for Cmos battery which is died completely, Then we was changed it but Fusion 640 program is not responding at the end of loading. I am also reinstall this software but nothing going on,
    Please help me out of this problum .
    Best Regards
    Jhon Ford
    Feb 2009
    6028
    CMOS battery or memory battery? If it was the lithium battery AA size, then you need to re initialize the control and re load all the parameters stored on the hdd.
    Jun 2013
    3
    Hi Underthetire,
    Yes there was AA size lithium battery which i was changed,You tell me that I need to initialize the control and reload all the parameters but how can i, please define the proceture i can highly appriciate it.and what about Cmos setup data its allready in default condition. Thanks for repllying.
    best regards
    Jhon Ford
    Sep 2010
    27
    sram clear, restore the data. here you'll find all you need http://victoriacaruk.com/Mazak%20Maz...740MT0201E.pdf
    Sep 2010
    27
    Guys! I cant find tool magazine battery. can someone give me a screen where it is or detail explanation?
    Sep 2008
    93
    chatjoker
    the barery is in the MRJ2 drive.
    this drive is in electric box in the magazine.
    Sep 2010
    27
    found it a while ago. to be correct. its under tool magazine door, hiden under panel.
  1. MAZAK FH6800's Parameters for Tool Lenght measurement system
    By sonu in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-28-2022, 11:11 AM
  2. mazak fusion640 iso lap cycle
    By mononofu in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-16-2011, 12:56 PM
  3. Error in table position for z axis, Mazak FH6800
    Last Post: 12-21-2010, 07:08 AM
  4. mazak fh6800 atc driver alarm
    By waseem sajjad in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-07-2010, 01:46 PM
  5. Mazak FH6800
    By spartus333 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-31-2010, 07:07 PM
