587,608 active members*
4,064 visitors online*
Results 1 to 3 of 3
    Jun 2003
    2103
    Got Mach 3 running smooth except for
    there is always that except isn't there? I was finally forced to move to Mach3 and am now using an Ethernet SmoothStepper. This has been a saga of failure upon failure and I won't go into them except the one.
    I have my 4th axis set up as angular and motor tuned with correct units per to get a correct 360 rotation with mdi !!! My problem is I cannot get Mach to recognize my reference switch set as a home only, or even if I set it as a limit. I have tried the switch as hi and lo, the switch as nc and no. The bob led blinks as the switch is activated when the shaft moves by it, but that is all. Is does not stop to reference nor does it stop if I set the switch as a limit switch.
    I am homing/reffing in the negative and have to move a touch in the negative to get off the switch. I have not thought to home in the positive. Would that help me with this?
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Jun 2003
    2103
    hmmmm over 50 views and not a peep! This must be a difficult one.
    Mike
    35538
    My guess would be a Smoothstepper issue. But I've never used one, so have no further help.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. NOT smooth running TNC155B
    By Tommie in forum Uncategorised CAM Discussion
    Last Post: 05-01-2012, 09:25 PM
  2. Smooth Stepper G540 and Mach
    By dfmiller in forum Gecko Drives
    Last Post: 06-13-2011, 05:32 PM
  3. Mach 3 setup for G540 & Smooth Stepper
    By jefftomerlin in forum Mach Software (ArtSoft software)
    Last Post: 07-31-2010, 06:56 PM
  4. Joe's 2006 running smooth and accurate.
    By robertmonroe in forum Joes CNC Model 2006
    Last Post: 05-12-2009, 05:55 AM
  5. Losing steps, smooth jogging, choppy running.
    By Ranscon in forum Automation Technology Products
    Last Post: 10-26-2008, 10:19 PM
