587,322 active members*
3,283 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Full Enclosure and Coolant System Upgrade
Page 3 of 3 123
Results 41 to 46 of 46
  1. #41
    Jan 2012
    789
    I love the rubber ducky. :-)
  2. #42
    Dec 2004
    57
    Quote Originally Posted by tbaker2500 View Post
    Hah! My three year old was in the garage with me and requested that she get it back for the second time. I couldn't convince her that I needed to keep it, so I managed to swing a trade for a rubber frog. I guess future videos will show that one... *sigh*
    Christopher Anglin
    www.mc2racing.com
  3. #43
    Sep 2012
    1543
    I have the ring, but only use half of it, and shoot from the side. Works great for what I do.
  4. #44
    Dec 2004
    57
    Quote Originally Posted by BAMCNC.COM View Post
    That's a pretty good idea. In fact, since I have three ports to connect coolant hoses to, I could disassemble the ring and do something like putting three nozzles on each hose. Might minimize or eliminate coolant nozzle adjustments. Perhaps I'll test that next.
    Christopher Anglin
    www.mc2racing.com
  5. #45
    Jun 2006
    3063
    Nice job on the coolant modifications and thanks for posting the process in so much detail. I'm sure the effort is appreciated by many others here.
    I noticed your comment about standoff on the drain fittings inside the tray and it reminded me of a bulkhead fitting that Banjo makes:
    3/4" X 1" Threaded Flange EPDM PP Bolted Tank Flange
    The interesting feature is that it is designed so that the inside volume of the tank it is attached to (or tray in this case) can be completely drained. The smallest size they make is 3/4-in and I needed a 1/2-in size for a project at work so I designed my own. I can supply PDF drawings for that if anyone is interested. The tray probably needs at least a 1-in size and my drawings could be easily adapted for something larger than 1/2-in. The drawings supplied by Banjo at the above link may provide enough info for shop-built design as well.
    Mike
  6. #46
    Dec 2004
    57
    Re: Full Enclosure and Coolant System Upgrade
    I've improved the cover over the control cabinet. Here's the video:
    http://youtu.be/HTcYZxkuDRk
    Christopher Anglin
    www.mc2racing.com
Page 3 of 3 123
  1. RF45 Clone with full enclosure, coolant, and tool changer
    By mikemaat in forum Vertical Mill, Lathe Project Log
    Last Post: 06-07-2015, 08:50 PM
  2. new linear way mini millw/full atc, coolant, enclosure etc.
    By fixridermtl in forum Vertical Mill, Lathe Project Log
    Last Post: 06-18-2013, 05:48 PM
  3. Torus Pro Coolant System And Enclosure Upgrades
    By SCzEngrgGroup in forum Novakon
    Last Post: 04-15-2013, 08:15 PM
  4. Flood Coolant System Upgrade
    By saabaero in forum Tormach Personal CNC Mill
    Last Post: 03-19-2011, 01:10 PM
  5. Taig Drainage/Coolant System-Enclosure Build~ Pictures~Video~!
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 01-16-2008, 12:58 AM
