587,777 active members*
2,603 visitors online*
Results 1 to 7 of 7
    May 2005
    1662
    ceramic tile ??
    It's bathroom remodel time. Is it possible to use a cnc router to cut the ceramic floor tiles or would it be wiser to rent a wet cutter ? Rotozip offers a dry cutter that claims to do the job.
    link........
    Bits
    Anyone who says "It only goes together one way" has no imagination.
    Feb 2008
    13
    i'm not the best user to give an opinion since i don't have a cnc yet and don't know what type of machine you have, BUT based on the experiences on ceramic cutting, i really don't think that using cnc is a good idea. Ceramic is very hard to cut, but the worst is the dust it makes, very thin and abrasive... may ruin some moving parts of your cnc... Wet cutting is always better.
    Just my opinion.
    Cheers
    May 2005
    1662
    yeah, that dust looks nasty. My router can't tolerate liquid and my mill can't spin fast enough for diamond tools. On to plan B or possibly C.
    A round shower stall..... starting to regret that purchase
    Apr 2004
    5752
    Rent a wet-cut tile saw
    It will rip through a ceramic tile in seconds. Even if you had a Bavelloni CNC router equipped for wet cutting of stone and ceramic, I'd still recommend the tile saw; it's the right tool for the job. And forget about the roto-zip - it's okay for the occasional fancy curved cut, but it will fill your house with dust very quickly, and works very slowly, at least on stoneware tiles. Use your CNC router to make some fancy woodwork details; it's great for that sort of thing.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Jan 2012
    Why not vacuum up the dust by holding the nozzle close to the bit?
    May 2012
    231
    Quote Originally Posted by cyclestart View Post
    Most diamond incrusted blade only need about 3600 rpm to be used. After looking at Rotozip seems they use 15000-30000 rpm on their tools.
    Oct 2008
    2100
    I know. I know. Two years too late, but I saw this thread, and then found this video. It is possible with heavy flood coolant to cut granite with a rotary cutter on a CNC. I couldn't imagine trying to do it dry though. Skip to about the 6 minute mark where they have it on the second machine.
    CNC Fabrication of Granite Countertops - Granite Shorts Ep.9 - www.marble.com - YouTube
    Bob La Londe
    http://www.YumaBassMan.com
  1. Cutting Ceramic Tile ô¿ô
    By lockeyone in forum Hobby Discussion
    Last Post: 04-26-2016, 12:18 PM
  2. Wood +Glass+Tile Cnc
    By crosswinds in forum Engraving Machines
    Last Post: 01-26-2008, 06:18 PM
  3. Anyone cutting carpeting or tile?
    By Matt B in forum Material Machining Solutions
    Last Post: 12-27-2005, 06:27 PM
  4. Printing on hard surface tile?
    By jeffterm in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-01-2004, 11:32 PM
  5. Anyone Cutting Carpet of Vinyl Tile?
    By Matt B in forum DIY CNC Router Table Machines
    Last Post: 09-29-2003, 04:37 PM
