587,436 active members*
3,479 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Create Thickness
Results 1 to 2 of 2
    Jun 2013
    1
    Exclamation Create Thickness
    Hi
    I imported a IGS file but the part is composed with just surfaces and i wanted to know how i create thickness because when i create the toolpaths all the walls desappears.
    Tks
    Apr 2003
    3578
    You can not make them thicker as they are surfaces now if you turn them into Sheet solids then you can thicken them. but I do not think this is the problem I would look at your programming method's.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. how to add a wall thickness
    By yllis in forum Rhino 3D
    Last Post: 02-14-2012, 08:53 AM
  2. Pines Numbers 3&4 Benders Frame Thickness and Nose Thickness
    By morribi in forum Bending, Forging, Extrusion...
    Last Post: 02-04-2010, 04:59 AM
  3. Zero thickness in cut loft
    By Michael El in forum Solidworks
    Last Post: 06-18-2008, 10:58 PM
  4. What is the greatest thickness
    By mbkowns in forum Vacuum forming, Thermoforming etc
    Last Post: 10-30-2006, 04:33 PM
