587,482 active members*
3,386 visitors online*
Results 1 to 3 of 3
    Oct 2011
    5
    Adding Probe to 1998 VF3
    hi guys
    new to Haas machines......the machine i baught doesnt have the probe option and doesnt have macros.. it does have VQC..... is it still possible to add a probe to this thing
    Mar 2010
    1852
    I'm pretty sure you can add the probe, but it will be expensive. As far as I know you will need the whole probe system of course and you will need scaling and macros which is not cheap either.
    Believe me, you can get by without the probe and get other accessories like a good 4th axis and more tooling.
    Mike
    Feb 2010
    1184
    Quote Originally Posted by rayje View Post
    hi guys
    You can add a probe to any machine but if you are looking to use the Visual Quick Code Probing(VQCP) cycles that are on machines newer than yours, then the answer is no.
    VQCP requirements are for machines built after January 2000.
    If you really want probes though, it will require seperate interface boxes for the spindle probe and one for the table tool setter. Then they will need to be tied into the machine using m-code relays and skip signal inputs. I have done this many times on machines prior to the VQCP systems. You can check with your local HFO to see if they can help you with this, but most likely you may need someone from Renishaw or a local Renishaw rep to help you figure out what you will need and help with the install.
    It is doable, but like Machinit mentioned though, you will need additional machine options turned on not to mention the cost for hardware and labor to install. All of this can add up quickly and the whole package may be cost prohibitive.
    Good luck!
  1. Adding a tool setter and probe
    By Captdave in forum HURCO
    Last Post: 04-29-2014, 08:22 PM
  2. Adding probe to LMS KX3 BOB
    By diyengineer in forum X3/SX3/G0619/G0463
    Last Post: 04-23-2013, 09:09 AM
  3. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
  4. Adding Mcodes or "poor man's part probe"
    By Wade C in forum Fadal
    Last Post: 06-03-2011, 08:23 PM
  5. Adding a probe to my NM-135
    By tas99 in forum Novakon
    Last Post: 01-29-2010, 02:46 AM
