If you open the G540 case, (carefully pry up the corners) you can physically swap the drives by removing 2 screws. Easy Peasy. You could even leave out the damaged drive and send it to Gecko for repair.
CR.
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
I did not realize how easy it was to take apart.
I swaped the A & Z axis.
Left the bad drive out, will try to return for repair when i get
everything up and running. I might screw up something else.
Thank You
Bob
