587,818 active members*
3,069 visitors online*
Thread: smart path
Results 1 to 2 of 2
    May 2009
    281
    smart path
    is it possible to have smartpath process a nc file add the code to optimize the motion according to the parameters and save it to disk for review / editing / use?
    could it be saved to a file outside of the diagnostic screen to avoid the added commentary from the diagnostic process?
    Apr 2003
    332
    SmartPath does these calculations on-the-fly based on the conditions "at the moment". While we could make it save the code it modifies, SmartPath by design creates extra these moves, feedrates changes, look ahead on cutting forces, spindle RPM, Decel, Accel changes inter-actively based on a group of monitored conditions. This is a Patented process. Yes, we could save the optimized code if we wanted. This would be something we would have to customize here. However, if you did run the saved program again later the live-conditions would change so you would lose the benefits SmartPath is designed to give you.
    Tech Support
    CamSoft Corp.
    [email protected]
    PH 951-674-8100
    Fax 951-674-3110
    PC Based CNC Control For The Machine Tool CNC Retrofit And CNC Controller OEM Market
  1. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
  2. Help on Smart Machine
    By jhbalaji in forum Mechanical Calculations/Engineering Design
    Last Post: 04-13-2011, 05:21 AM
  3. Buy Smart Bar Puller,Get Bonus Smart Bar Stopper
    By ARIK in forum News Announcements
    Last Post: 03-01-2011, 04:10 AM
  4. HELP! I need someone smart that knows Fanuc 3T
    By Tim Thacker in forum Fanuc
    Last Post: 06-13-2008, 02:34 AM
  5. Smart cam ????????
    By shelburnebri in forum Uncategorised CAM Discussion
    Last Post: 12-07-2006, 08:27 AM
