587,927 active members*
4,092 visitors online*
Results 1 to 11 of 11
    Nov 2012
    162
    Decent G-Code Editor
    Hi gurus. Looking for a bit of info. I have a Mitsubishi High Speed cutter that has a max cut of .020 on a part that is 2" thick. That's 100 cuts around the part to get to depth. I can reduce cut time by eliminating the lift and repositioning moves each time it goes around the part. I have been hand editing code but it takes hours for each part.
    Does anyone know of a program (cheap) that can edit code by looking at specific loops or repetitions? I have BOBCAM to produce code and DNC4U to edit and send/receive.
    Thanks.
    Aug 2011
    2517
    there's nothing. Mastercam can produce optimized cutting paths but you won't find any program that can take 100 long-hand g-code cuts and make it less. That would be like finding the pot of gold at the end of the rainbow. You might be able to machine it a different way or with a different cutter or multiple different types of cutters to make it take less cuts but that'll require some knowledge and innovation.
    Nov 2012
    96
    Notepad and a six-pack.
    Jan 2004
    3154
    I believe you can still download NCPlot V1 for free.
    Extremely basic but has graphics and a find-and-replace command.
    IDK your control but I would reprogram using a sub routine, will be very simple because you only need to cut and paste the "roundabout" code once. The main body of the program will only be a few lines. One stating to repeat the sub 100 times and a couple of lines to change to incremental, Z move of -.02, and change back to absolute (assuming that you program in absolute mode).
    www.integratedmechanical.ca
    Apr 2013
    18
    What you could do is optimize your cutting data. Try G-Wizard
    GWizard: A CNC Machinist's Calculator for Feeds and Speeds
    2932
    Please post an example before/after.
    Feb 2006
    338
    Lightbulb
    Not a solution, but some tools and ideas.
    If all the Z passes are the same, start with making it a loop or sub program.
    A good test editor with color syntax highlighting makes a big difference if your editing g-code (or just reading it for verification)
    Predator editor CNC code specific editor with tools just for g-code, but expensive if not part of you CAM package.
    UltraEdit A great customizable editor meant for computer programers, but a little customization to the syntax definitions and it is great for g-code. < $100
    Notepad++ Another editor meant for computer programers but free. Same deal, edit the syntax definitions.
    A back plotter and/or virtual CNC
    Predator software offers both.
    NCPlot
    LinuxCNC virtual machine running the "simulation hardware" works as a free backplotter.
    Aug 2011
    2517
    another CNC text editor with CNC-specific color highlighting is NCLink and it's free......
    CAD CAM CNC software solutions by OneCNC CAD/CAM
    Feb 2013
    39
    NC Corrector is free and runs well on more recent machines:
    NC Corrector, free G-Code editor.
    Listed here: Previewing G-Code - ShapeOko
    Mar 2010
    3
    I was in the same situation. I did some reading about Macro programming. I also asked a friend who is an Application Engineer for help.
    What you want to do is loop your program. The book that helped me was Parametric Programming For CNC Machining & Turning Centers. You can purchase it from CNC Concepts. The book is written by Mike Lynch. There web-site is: CNC Concepts, Inc.
    I used Ncplot to check my code.
    I hope this helps.
    Jan 2013
    119
    Maybe you need cam software, that fits your needs.
  1. G-code editor?
    By gearsoup in forum G-Code Programing
    Last Post: 11-28-2011, 03:06 PM
  2. G code editor for MAC
    By DIFF OVER in forum Uncategorised CAM Discussion
    Last Post: 10-28-2010, 01:21 AM
  3. G Code Editor
    By Ryan P in forum News Announcements
    Last Post: 07-24-2009, 09:58 PM
  4. NC code editor
    By grimy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-07-2009, 04:57 AM
  5. Looking for g-code editor
    By avengine in forum Community Club House
    Last Post: 04-28-2006, 07:01 PM
