587,496 active members*
3,285 visitors online*
Results 1 to 4 of 4
    Jul 2012
    REGULATOR SHORT CIRCUIT
    Hello!
    I have a problem on a Deckel MAHO FP4 machine....
    When machine starts up (powers up a BOSCH driver) suddenly main fuses jumps down and machine gets a power cutoff.
    I'm sure that regulator is problem because i wired fuses before regulator (which doesn't exist there normally) and when power cutoff (short circuit) comes up two of three fuses get activated.
    Now, it would be easy problem if regulators were problem indeed...
    I realized that short circuit comes up only if spindle drive is connected via bus bars...otherwise not even if all of the other axes with 4th axis also remains connected. So i connected other spindle drive (with other power supply also) from working machine and the same problem comes up. I thought that PLC sends wrong voltage to drivers input, but that's not the case as i disconnected all cables that are connected to spindle drive (except power supply) and problem remains.
    Just one thing that i can think off which couls cause this problem is that power switches got bad contacts and can't deliver high current to the driver.
    Anyone has other idea?
    Hello Arjuna
    You can have problem with GRAETZ and capacitor on main power for servo motors, or transistors on some servo unit.
    first check for short connections at diodes and capacitor, after that, you can disconnect PCB-s for servo motors ( two boards for axe, from left to right for x,y,z,4 )
    if you like I can send to you schematic for machine
    regards, good luck
    Jul 2012
    Ej bok, vidim da si iz okolice pa možemo i ovako komunicirati.
    Hvala na odgovoru za početak!
    Problem je u tome što osigurači padnu samo kad spojim jedinicu vretena na DC sabirnicu, ali čak ni tada osigurači ne padnu ako stroj nije upaljen tj. regulatori svih osi preuzmu kontrolu nad motorima.
    Dakle, ako ne palim cijeli stroj nego spojim kompletan regulator na trofazni napon preko žica sve je ok i osigurači ne padaju, a to znači da graetz i filter kondenzatori dobiju pun napon (mjerio sam).
    Isto tako ako palim stroj normalno a sa DC sabirnice izostavim samo regulator vretena stroj će se kratkotrajno upaliti i onda ugasiti zato jer mu dozvole prolaze i kroz jedinicu vretena, ali se ne gasi tako da izbiju svi glavni osigurači nego samo kaže na monitoru da nema dozvole za gibanje i tako mogu paliti koliko hoću puta.
    Možda i je problem u kondenzatorima tek onda kad se povuče snaga iz njih, trebao bi probati sve spojiti bez njih pa ću onda vidjeti!
    Bok stari,
    Hi, it's better if you write in English here, out of respect for other visitors Forum.
    I would be glad to contact me on PM djordje at datatehnik dot com
    regards
  1. Fanuc 10m short circuit limit switch
    By Swemill in forum Fanuc
    Last Post: 04-21-2022, 12:07 AM
  2. Short circuit protection
    By Beaker in forum CNC Machine Related Electronics
    Last Post: 10-07-2009, 12:16 PM
  3. Stepper Motor Short circuit??
    By dak70 in forum Stepper Motors / Drives
    Last Post: 06-23-2008, 03:07 AM
  4. Short circuit question
    By Tomax in forum CNC Machine Related Electronics
    Last Post: 04-30-2008, 03:46 AM
  5. need high current regulator circuit
    By tekno in forum CNC Machine Related Electronics
    Last Post: 05-23-2006, 02:00 AM
