587,564 active members*
3,402 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Feb 2012
    125
    Spost vs Mpost
    I only use mpost, but sometimes the program gets wrong.
    I'm 3D rough machining, if I use helix ramping instead of plunge ramping, the machine moves without changing tool.
    I talk to support and they said that only happens using MPOST.
    In this moment I have a HAAS VCE 500 and a FANUC 18iMB, does anyone have a SPOST file to those machines.
    PLUNGE
    :1
    (OK.NCC 27-02-2013)
    T1 M6
    G0 G54 G90 X202.61 Y-4.279 S6000 M3
    Z5. H0 M8
    G0 Z0.51
    G1 Z-0.74 F1000.0
    X202.581 Y-4.282 Z-1.009
    X202.502 Y-4.316 Z-1.266
    X202.427 Y-4.43 Z-1.498
    X202.475 Y-4.603 Z-1.694
    X202.66 Y-4.798 Z-1.868
    X202.87 Y-5.02 Z-1.968
    X202.971 Y-5.072 Z-1.985
    X203.084 Y-5.048 Z-1.99
    G3 X203.166 Y-4.901 I-0.089 J0.147 F2000.0
    G1 Y-4.579
    G3 X202.866 Y-4.279 I-0.3 J0
    G1 X202.614
    G3 X202.475 Y-4.603 I0 J-0.192
    G1 X202.87 Y-5.02
    G3 X203.084 Y-5.048 I0.125 J0.118
    G1 X203.144 Y-4.986 Z-1.987 F1000.0
    HELIX
    :1
    (NOK.NCC 27-02-2013)
    G1 X112.403 Y-44.408 Z5.009 F1000.0 S6000
    Z3.759
    X112.494 Z3.291
    X112.755 Z2.891
    X113.146 Z2.617
    X113.611 Z2.51
    X180.873 Z0.234
    X207.068 Z-0.652
    X207.187 Y-44.363 Z-0.656
    X207.385 Y-44.187 Z-0.665
    X207.446 Y-44.053 Z-0.67
    Y-5.048 Z-1.99
    G3 X205.988 Y-4.8 I-0.75 J0
    G1 X205.276 Y-6.829
    G2 X202.915 Y-7.496 I-1.415 J0.497
    X203.084 Y-5.048 I0.946 J1.164
    G1 Y-4.579
    G1 X202.614
    G1 X202.87 Y-5.02
    X203.166 Y-4.901 Z-1.978
    Y-4.579 Z-1.886
    X203.117 Y-4.414 Z-1.793
    X202.999 Y-4.31 Z-1.672
    X202.866 Y-4.279 Z-1.528
    X202.709 Z-1.28
    X202.614 Z-1.002
    X202.586 Y-4.281 Z-0.74
    X202.586 Z0.51
    X202.529 Y-4.341 Z1.18
    X202.361 Y-4.517 Z1.81
    X202.091 Y-4.799 Z2.361
    X201.737 Y-5.168 Z2.801
    X201.319 Y-5.605 Z3.102
    X200.863 Y-6.081 Z3.248
    X200.858 Y-6.087 Z3.249
    T1 M6
    G0 G54 G90 X167.878 Y-40.534 S6000 M3
    Z7.748 H0 M8
    G0 X167.527 Y-40.901 Z7.749
    May 2012
    100
    I dont understand, you have H0 on both examples.
    You might have something wrong in your postprocessor,
    it should correspond to the T-number.
    If Mpost outpost your Toolchange like in your second example,
    it is very strange. Can you post your Postform here?
    It is located in X:\Surfcam\Postlib
    Feb 2012
    125
    Quote Originally Posted by Anders6612 View Post
    The post used is the same in both examples, what changes is the entry PLUNGE our HELIX.
    name HAAS (Metric)
    % 00
    / 00
    : >4
    N >4
    G >2
    g >2 G
    X ->4.>3
    Y ->4.>3
    Z ->4.>3
    I ->4.>3
    J ->4.>3
    K ->4.>3
    Q ->4.>3
    R ->4.>3
    P >40
    F >3.1
    H >2
    D >2
    T >2
    S >4
    M >2
    ModalLetters X Y Z F
    ModalGs 0 1 2 3 73 74 76 80 81 82 83 84 85
    Sequence#s N 0 1 1
    First#? N
    Last#? N
    HCode X
    VCode Y
    Dcode Z
    FeedCode F
    Comment ( )
    Spindle 3 4 5
    Coolant 8 9 7
    DComp 41 42 40
    LComp 43 49
    Feed G<1>
    Rapid G<0>
    Cw G<2>
    Ccw G<3>
    Inc/Abs G 91 90
    CtrCode I J
    Spaces? Y
    Incremental? N
    CtrIncremental? Y
    ByQuadrants? N
    UppercaseComments? Y
    StartCode
    %<0>
    :<Program#>
    End
    1stToolChange
    T<Tool> M<6>
    G<0> G<Work> G<90> X<H> Y<V> S<Speed> M<Direct>
    Z<D> H<Lcomp> M<Cool>
    End
    Infeed
    G<Side> X<H> Y<V> D<DComp> F<FRate>
    end
    Outfeed
    G<1> G<40> X<H> Y<V>
    Z<D>
    end
    ToolChange
    G<0> G<49> Z<0> M<9>
    T<Tool> M<6>
    G<0> G<90> G<Work> X<H> Y<V> S<Speed> M<Direct>
    G<43> Z<D> H<Lcomp> M<Cool>
    End
    EndCode
    G<0> g<91> G<28> Z<0>
    M<5>
    %<0>
    End
    Drill
    G<81> X<H> Y<V> Z<D> R<Vclear> F<FRate>
    end cancel
    Peck
    G<83> X<H> Y<V> Z<D> Q<VBite> R<Vclear> F<FRate>
    end cancel
    Tap
    G<84> X<H> Y<V> Z<D> R<Vclear> F<Frate> Q<VBite>
    end cancel
    LTap
    G<74> X<H> Y<V> Z<D> R<Vclear> F<FRate>
    end cancel
    Ream
    G<85> X<H> Y<V> Z<D> R<Vclear> F<FRate>
    end cancel
    Bore
    G<86> X<H> Y<V> Z<D> R<Vclear> F<FRate>
    end cancel
    Back
    G<87> X<H> Y<V> Z<D> R<Vclear> F<FRate>
    end cancel
    Cancel
    G<80>
    end
    May 2012
    100
    Thats very strange. But you can build your own spost using
    Spost configuration, in Start Surfcam menu.
    I guess your post is very easy to configure.
    Feb 2012
    125
    I also try but, the result isn't the same.
    May 2012
    100
    Try this: Haas
    I added a X Y home position at the end, i can remove it if you dont want it.
    Quote Originally Posted by forjaco View Post
    I'm 3D rough machining, if I use helix ramping instead of plunge ramping, the machine moves without changing tool.HELIX
    Hi, forjaco, it shouldn't matter if you plunge, ramp or helix down.
    I've tried your post and seems to be working Ok, (of course whit a simulated file). I'm attaching an m3 post that I've used for more than 10 years without problems. Should you come into another trouble, please post your scprt file to be analized and perhaps give you a rigth solution.
    Regards, Mario
    Attached Files Attached Files
    May 2012
    100
    I agree, it should not have anything to do with the Mpost.
    Something is bugging. If still a problem, is it possible for
    you to post the file?
    Here is an Mpost with Linecode and Rapidcode. Maybe that will help.
    Haas.txt
    Feb 2012
    125
    Thanks for help I will try your post's.
    @Anders6612
    Can you upload your file Uncx01.p15 in another service, because I cannot download.
    Feb 2012
    125
    I try your post and the result is the same.
    Anders6612 post
    Code:
    O1
    G28 G91 Z0
    G28 G91 X0 Y0
    G80 G49 G40
    (04-03-2013 08.25.06)
    Z3.759
    X112.494 Z3.291
    X112.755 Z2.891
    X113.146 Z2.617
    X113.611 Z2.51
    X180.873 Z0.234
    X207.068 Z-0.652
    Y-5.048 Z-1.99
    G1 X205.276 Y-6.829
    G1 Y-4.579
    G1 X202.614
    G1 X202.87 Y-5.02
    Y-4.579 Z-1.886
    X202.709 Z-1.28
    X202.614 Z-1.002
    X202.586 Z0.51
    T1 M6
    (T.DIAM. = 8. MM.)
    (T.RADIO = 0 MM.)
    G40 G90 G17 G54 X167.878 Y-40.534
    G43 Z7.748 H0
    M3 S6000
    M8
    G1 X167.07 Y-41.379 Z7.605 F1000.0
    mariojl post
    Code:
    :0001
    G1 X112.403 Y-44.408 Z5.009 F1000 M8
    Z3.759
    X112.494 Z3.291
    X112.755 Z2.891
    X113.146 Z2.617
    X113.611 Z2.51
    X180.873 Z0.234
    X207.068 Z-0.652
    Y-5.048 Z-1.99
    G1 X205.276 Y-6.829
    G1 Y-4.579
    G1 X202.614
    G1 X202.87 Y-5.02
    Y-4.579 Z-1.886
    X202.709 Z-1.28
    X202.614 Z-1.002
    X202.586 Z0.51
    G40 G21 G17
    M6 T1
    N10 M1 (T1 ENDMILL DIA 8)
    Z7.748 H0
    G0 Z7.749
    X167.527 Y-40.901
    G1 X167.07 Y-41.379 Z7.605 F1000 M8
    Like I said before the problem isn't the post processor file. Is the way like Surfcam process it. The support said that if I use a SPOST instead of MPOST I will reduce this kind of problems.
    Hi forjaco:
    For sure you're not using the post I gave you, it's not posting the way it should.
    The heading of it should look like this :
    O1
    G28 G91 Z0
    G28 G91 X0 Y0
    G80 G49 G40
    (4/3/2013 9.24.41)
    (DISHAAF.NCC 4/3/2013)
    T139 M6
    (T.DIAM. = 12. MM.)
    (T.RADIO = 0 MM.)
    G40 G90 G17 G54 X1.747 Y13.552
    G43 Z95. H139
    M3 S796
    M8
    G0 Z72.356
    I've been working and supporting Surfcam for more than 20 years, using almost exclusive Mpost, and never had a trouble like this.
    Please post your scprt file so I can debug it and probably can give a solution.
    Mario
    May 2012
    100
    It is a zip file. Just unzip it.
    Uncx01.zip
    Feb 2012
    125
    Quote Originally Posted by mariojl View Post
    Hi forjaco:
    O1
    G28 G91 Z0
    G28 G91 X0 Y0
    G80 G49 G40
    (4/3/2013 9.24.41)
    T139 M6
    (T.DIAM. = 12. MM.)
    (T.RADIO = 0 MM.)
    G43 Z95. H139
    M3 S796
    M8
    G0 Z72.356
    Mario
    Here is the file
    Uncx01.zip
    Thank I will try.
    Feb 2012
    125
    Uncx01.zip
    Using this SPOST the result is OK
    :3
    T1 M6
    G1 G54 G43 X112.403 Y-44.408 H0 F1000. S6000 M3
    Z5.009 M8
    Z3.759
    X112.494 Z3.291
    X112.755 Z2.89
    X113.146 Z2.617
    X113.611 Z2.51
    X180.872 Z.234
    X207.068 Z-.652
    X207.187 Y-44.363 Z-.656
    X207.385 Y-44.187 Z-.665
    X207.446 Y-44.053 Z-.67
    Y-5.048 Z-1.99
    G3 X205.988 Y-4.8 I-.75 J0.
    G1 X205.276 Y-6.829
    G2 X202.915 Y-7.496 I-1.416 J.497
    Hi forjaco:
    Here I'm again, the scprt file is Ok, posted with the haas post i sent you is Ok, here is what it looks like:
    O25
    G28 G91 Z0
    G28 G91 X0 Y0
    G80 G49 G40
    (4/3/2013 10.34.15)
    (EX-699AAA.NCC 4/3/2013)
    (SURFWARE DIRECT)
    T1 M6
    (T.DIAM. = 8. MM.)
    (T.RADIO = 0 MM.)
    G40 G90 G17 G56 X112.505 Y-44.408
    G43 Z113. H0
    M3 S6000
    M8
    G0 Z4.504
    G1 Z3.254 F1000.0
    X112.596 Z2.786
    X112.856 Z2.386
    X113.247 Z2.112
    X113.712 Z2.005
    X207.068 Z-1.155
    X207.187 Y-44.363 Z-1.159
    X207.385 Y-44.187 Z-1.168
    X207.446 Y-44.053 Z-1.173
    Just in case I'm posting the full nc file.
    You're using Surfcam 6, and the structure of the Pc directory is quite different from previous versions, the postform is located ( by default instalation) in C./users/public/surfcam/surfcam6/config/postlib/...( it may difers a little, as I have a spanish windows 7)
    Please check and make sure you copied the post there.
    Regards, Mario
    And again; just looked at your file and wonder, you'll have a trouble when you'll try to finish this at the bottom section of R 1.5, marked in this picture with a red circle.
    Must take care when create a drive curve surface, that your drive profile have a radius larger than the cross section R.
    Mario
    Doubt?
    Hi, forjaco:
    Did your problems have been solved?
    It'll be nice to hear from you.
    Feb 2012
    125
    Now is OK. but this version 6 has a lot of problems.
    Now I found another:
    I do a 2d Pocket with a sketch imported from solidworks and this was a result (889).
    For bypass this a had to create a spline for create a correct toolpath (889_OK).
    Jul 2010
    14
    Dear mariojl,
    It seems you had good information about MPOST. I had a SIEMENS 840de for VMC I need a Mpost for the controller. Can you help me in this? I use surfcam 4
    if yes, Please conact me to [email protected]
    thanks
    Hi forjaco:
    If by creating a spline your problem went away, it's not a SURFCAM problem, it could be your SW sketch.
    Some times imported geom doesn't fit to well.
    You may post here the SW sketch and let me take a look at. if so, I can submit it as a bug.
    Regards
    Mario
Page 1 of 2 12
  1. edit spost
    By Steve Manthey in forum Surfcam
    Last Post: 02-19-2009, 07:28 AM
  2. SPOST setup
    By cadmanj in forum Surfcam
    Last Post: 09-07-2008, 05:58 PM
  3. 4th axis spost
    By doridori4ag in forum Fadal
    Last Post: 03-13-2008, 06:22 AM
  4. Mpost/Spost Tips and Tricks
    By tnik in forum Surfcam
    Last Post: 12-20-2006, 07:32 PM
  5. Surfcam 5 axis spost
    By babanh in forum Surfcam
    Last Post: 11-20-2006, 03:55 AM
