If I may offer this, here's my the way I select cutting parameters for my PCNC1100.
I use a freeware calculator called ME Consultant 2.0. It's on a few download sites when I Google it. It has a DOS feel to it, so I don't think viruses are an issue.
So for me, there are a few constants I like to use. I'll use the published chip load for the cutter and material I'm using. I may adjust it down a little if it seems too heavy. Typically in aluminum with carbide, .004" for a 1/2" EM, .002" for a 3/8, .001" for a 1/4".
When I'm roughing aluminum as fast as possible, I usually use a 1/2" end mill at 3200 RPM. This seems to be the RPM were motor torque really starts to fall. I think it is more important to be at near peak spindle torque than trying to meet published SFM. When I'm using a 3/8 end mill, 3800 RPM works well.
When rough contouring I'll use 30% of the tool diameter for the WoC. And for slotting, well WoC is hard to adjust.
So if I have a new end mill that I want to setup a feed and speed for, here's how I do it.
Using ME Consultant, I'll enter the stock material, select carbide end mill, enter the end mill diameter and the number of flutes.
Next I'll enter the RPM Limit for the cutter I'm using, example 3200 for a 1/2" EM. This way I will not get a calculation above this RPM.
For WoC I'll either enter 30 or 100% of the tools diameter.
Then lastly I'll adjust the DoC to a calculated .9 horsepower. This gets me pretty close for a starting point.
Then I'll do some test cuts on some rem material. Better to break an end mill than scrap a parts and break an end mill. I'll look for the spindle bogging down, tool pull out and chatter. If the spindle bogs or the tool pulls out, I'll decrease the depth of cut. If there excessive chatter after adjusting the DoC, I'll adjust the feed and RPM down to maintain the same chip load.
A variable to this is a very deep slot or pocket. The stock coolant system on the PCNC1100 is not so good at flushing out chips. Sometimes I'll back off the DoC to control the amount of chips being produced.
So I know there are many techniques for feeds and speeds. I worked with a guy that in aluminum it was 3000 RPM, 30 IPM for every end mill...he liked it simple. This is just away that is working well for me.
Barry
Tormach PCNC1100, Mach 3 R3.043.037, MastercamX5 level 3.
