587,395 active members*
3,556 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > matra mill alarms fanuc om control alarm code 1004
Results 1 to 2 of 2
    Feb 2013
    6
    I had a air pressure alarm code 1002 . i fixed the air issue but when it alarmed out its in between tool changes and now im getting a 1004 code as well as a 1012 code how do i reset the limit switch (LS) parameter to reset switch...or where can i download a fanuc om parameter and diagnostic manual.
    Dec 2008
    239
    Sir the 1XXX alarms are user alarms , This is designed or written by MTB ( Machine Tool builder ) and it varies machine to machine . For manual send me your e mail id i will send you the manual . you can check the reference limit switches . For your Existing problems.or you can try with Although parameter No. 1012#0 (IDGx) was set to 1 to inhibit
    the reference position from being set again for a return to the
    reference position without a dog, an attempt was made to
    perform a manual return to the reference position.
    regards
    Prabhat Mishra
    [email protected]
  1. Matra TM-20C,Fanuc O-T parameters
    By Grzesiek in forum Fanuc
    Last Post: 02-21-2013, 12:48 AM
  2. Matra fanuc wire edm machine
    By adt2005 in forum EDM Discussion General Topics
    Last Post: 06-25-2012, 04:54 PM
  3. Kitamura MyCenter 2xiH ATC 1004 alarm
    By vanlarry in forum Kitamura
    Last Post: 12-16-2011, 12:33 AM
  4. Problem on WIre machine (Fanuc, Matra)
    By dzcatic in forum EDM Discussion General Topics
    Last Post: 04-04-2011, 08:55 PM
